Retrofitting Lane assist camera without changing windshield?
AWD4416
Texas
Just found out that AliExpress is a rip off, local printer will print full colour for around 20euros
I went with a local FedEx location to print it. I also printed it in two sheets $8 (regular paper) and taped it together cause they wanted like $80 (poster type paper) for the print on a single sheet.
As for the previous post about the errors, once you calibrate the camera, a lot of errors will go away but you still need to get the proper coding on the camera. I'm not sure if I posted my coding here but there are plenty of stock coding examples on the Ros Tech website. You also code other modules (example, 13, 17, 44, 4B) to acknowledged there is a camera installed.
Sn00ky
Amsterdam
MK7 variant DSG
Mini update:
As stated on MQB.PL acc and front assist don’t have to work with eachother so I Disabled front camera on module A5 and 13, that cleared all communication errors.
Did anyone got it working with standard factory ACC fitted?
@AWD4416 will check module 4b all the others where adjusted.
can you please enlighten me about coding the camera? Thought it was just calibrating....
Found the following thread which may have the solution when coded via app OBDELEVEN?:
https://www.drive2.com/b/467374356494811937/#comments
After correct coding (BYTE 16 BIT 7), the error U11230 was removed successfully, continue furthe
<-does the above adjustment seem correct?
AWD4416
Texas
Mini update:
Check out my post a few pages back
https://golfmk7.com/forums/index.ph...thout-changing-windshield.358776/post-7509688
This is a decent enough starting point as the first few bytes along with the last few bytes kept giving me errors. If you use long coding on OBDeleven (module A5), you can narrow down your configuration using the binary button on the top right as there are a few descriptions that only show up there. Originaly my 2019 GTI had brake assist and was upgraded by Doctor to ACC. Once I installed and coded/calibrated the camera, I was able to get lane assist going. Traffic Jam Assist is also possible but you will need access to VCP or some one like Doctor that can configure it properly.
Sn00ky
Amsterdam
MK7 variant DSG
I think i did a good job coding the A5 module, its indeed easy peasy with OBD11 thanks for pointing out my options, really appreciated!
just calibration though, waiting for the calibration board and fixed the camera mirror cover
Reaper1
Finally got the balls too add the 12v ignited plus on the control module of lane assist
first try: 5 errors regarding the camera malfunctioning -> FFC was placed wrong 😑
second try: 3 errors see below:
Are these the ones that should remain when no calibration and adjustments of a5 module has been done?
From top to down:
1:?
2: camera needs calibration
3: could be that the module is still configured with old setting will update list of setting that has to be changed:
-lance change assist is enabled (don’t have)
-offcourse the cameraheather which is not there?
-the manufacturer selected is audi (dont have)
-light high beam selected is only light (need to select high beam and dynamic light assist
-headlights type selected is led ( i have xenon)
-trailer module selected is not installed (is installed)
These errors are fine, first one Is just cause you didnt code the rest of the modules or the current module, once all modules coding is correct you should only have basic setting error.
Sn00ky
Amsterdam
MK7 variant DSG
After two weeks, the calibration board arrived this week... I think i got it calibrated as it doesn’t give me an error for basic calibration anymore, can imagine the car got tired after so many retries 😂😭🤣
but the thing that got it working is to switch the mode to eol and keep pressings and measuring until completed
just the dynamic calibration, cause at the moment the car leans/hugs the left side of the lane
Rapier
Uk
A3 8v polo
Thanks for the replies re the calibration board . Is there anyone on here who could help me calibrate as i only have vcds. Pm me a price please . Ps midlands areas uk
IWMTom
VW Retrofit recently got a fancy ADAS setup - worth getting in touch with him given you're in the midlands; he's in Redditch.
Sn00ky
Amsterdam
MK7 variant DSG
FML 🤦 0.006 difference
Max offset=2.5
do i need to re-run static? As I didn’t backup and can’t clear error...
Sn00ky
Amsterdam
MK7 variant DSG
Did you get a fault code? if not then the camera can compensate for that offset. Keep driving until the dynamic calibration is finished or you get a fault code.
yes, I did get a fault code, lane assist is disabled at the moment (acc is still running). I can recall @Reaper1, that yours failed too, did you need to rerun static?
onoff
Greece
Tiguan
Guys, you did the printing of the VAS6430 Card directly from the file that was posted or had to create the file (Coreldraw) in the scale for printing!View attachment 171398
Hello
did anyone manage to print this in a regular A4 printer with the pdf file that is in this tread?
My printer just printed 1 page and all of it:D
what settings must we do to printer a couple of A4 page so it also have the right size?
thank you
