Good night Friends, I'm almost giving up on the project, I've done almost everything of tests for operation (camera calibration), and I was not successful! just now I replaced the flat cable with a brand new one, but without success. I tested with two cameras (5Q0980653G), a new and a used one and I always have the same information on the ODIS screen, see attachment:
But I will keep trying! kkk
Guys ask me a question, which should be done first, Calibrate the camera with ODIS or use the VCDS to make the modifications ??
I would like a favor from you: if you could pass the tutorial for coding the VCDS that you used and it worked, because I'm suspecting that it may be an adjustment I'm making, I'm using it to adjust an XAGICO tutorial with VCDS and I'm not sure that is the correct one. I thank you and I hope this group's help. thank you !
Again, you cant start anything without loading parameters to your camera.
Of course it wont work.
