Retrofitting Heated Steering Wheel
xabhax
15 GTI
Had a little hiccup. Was getting touch sensor errors when turning on heat on the steering wheel. There is a drive2 article about this being a problem with 3q0 gateway software 3Q0907530AC (5388), 3Q0907530AN (5389) or 3Q0907530AG (5423). They suggest update to 3Q0907530AR (5502). Archive contains 3q0 firmware, some 2q0 BCM firmware, and a whole bunch of parameters. No need to load any parameters, or atleast i didnt have to coming from 3Q0907530AC (5388)
Here is the post
Cuzoe
Nice find... I have AG in the gateway. But still haven't installed the 2Q0 camera to enable travel assist. If you didn't have to reload anything when coming from AC then I should update. To be clear, you updated firmware and didn't have to do anything else? I don't have the ability to clear CP/reenable anything.
Unrelated but kind of related... I think my driving profile data said is doing something that's preventing me from being able to set ambient lighting to Manual/Automatic.
I've got to put together a "quick" test data set and experiment. I'm thinking the first thing I'm going to do is remove the ambient lighting selection from the Individual driving profile. In digging through some factory driving profile data sets ambient lighting is never a selectable choice in individual, even when assigned in the other profiles.
Projects building up again, but the baby doesn't care, lol. And he's so much more fun than messing around with the car ?.
xabhax
15 GTI
Correct. I didn't have to upload any parameters, or clear cp.
I've read the articles on drive2 about parameter editing and messing with driving profile pictures and info. I gotta steer clear of that, I would be changing stuff left and right. Probably to the point of bricking something. I am getting more and more intrigued by the ambient lights.
Kids are fun, cars are cheaper though. Ya I gotta stop trying to do multiple retrofits at once. Always leads to the same thing, my interior being torn apart for weeks at a time. And inevitably after putting it back together, I take it apart again. It's a cycle I'm trying to break.
Cuzoe
Good thing about the driving profile data set is that you can't break anything. The flash is only that section of the firmware. So when/if you screw up, your driving profiles are just screwed up. When I was initially figuring things out I would flash something and find that a setting had disappeared or that changing driving modes was no longer changing something like it should. Drove around with steering stuck in Comfort when I added that setting to Normal and Sport.
I probably flashed 30 data sets as I figured out what all needed to be changed to get the options that I wanted. I knew exactly what I wanted, I just kept finding more places in the data set where things had to be changed to make it happen. There are a lot of dependencies in the data set.
Now for me to change something is a ~10 minute process for the editing, and then the actual flash takes about 30 seconds. The longest part is waiting on The VM to start on my old Surface laptop.
mannymoda
Canada
2019 Alltrack Execli
General rule of thumb from what I've gathered: Do a scan of the car, and if the Module 16 - Steering Wheel returns a *569 part number, stick with *569 (B or C). If your scan returns *549, stick with *549 ("D" seems to be the appropriate appendage).
What if there is no Module 16 - Steering Wheel in the scan results? Has it migrated to Module 09 - Cent. Elect. - Steering Column Switch?
Nuje
Island near Vancouver
2015 Sportwagen TDI
Could be (?).
Look in the dropdown list of sub-modules there and see if there's something with the appropriate part number - if so, that's where it is.
Auto-scan will also give you a list of all of the modules and part numbers - sub-modules included.
mannymoda
Canada
I finally got my parts and attacked this project.
I have some serious issues though. Post install, I got every error possible. Here is the VCDS Scan:
Friday,28,October,2022,19:20:35:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.9.0.0 HEX-V2 CB: 0.4622.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
VIN: 3VWH17AU9KM521113 License Plate: 4
Mileage: 44279km-27513mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F 69 A5 CA D6 D7
VIN: 3VWH17AU9KM521113 Mileage: 44279km-27513miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: Malfunction 0010
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13--- CVN: C87BA4D6
Coding: 311D00322476002F1000
Shop #: WSC 00066 790 00424
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS020_VW37.rod
VCID: 46D55605582413EB9DF-8012
VINID: 0E69D804746525B7450810410C70F68BA1
1 Fault Found:
19854 - Steering Column Control Module
U0212 00 [039] - No Communications
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 78 °C
Intake air temperature: 31 °C
Ambient air pressure: 1020 mbar
Voltage terminal 30: 12.050 V
Unlearning counter according OBD: 40
Engine: operating status: ES
ECU_STATE: ENG_STOP
Engine oil temperature: 57.0 °C
Time since engine start: 0.0 s
T_ES: 8 min
Cruise control switch actuation-Main switch: Not operated
Cruise control switch actuation-Set: Not operated
Cruise control switch actuation-Resume: Not operated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: Not operated
Cruise control switch actuation-DELAY: Not operated
Cruise control switch actuation-Cancel: Not operated
Cruise control switch actuation-Main switch hardware: Not operated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: Not operated
Cruise control switch actuation-Main switch CAN: Not operated
Cruise control switch actuation-Large increment: Not operated
Cruise control switch actuation-Control component verified: No
T_AST_SAE: 0 s
Readiness: 1110 1101
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 018 HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01907241007 CVN: 0000F57F
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 59EF8D79F99A8C13C0D-800C
1 Fault Found:
21222 - Steering Column Control Module
U0212 00 [011] - No Communications
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DT HW: 5Q0 614 517 BP
Component: ESC H35 0108
Revision: 00000000 Serial number: 52499000000175
Coding: 43FA6AA13022096D80780301A0C629C2560C9001C005943436435050F0A94B0B0040010312121212B435351919323200
Shop #: WSC 00066 790 00160
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
VCID: 0655960518A4D3EBDDF-8052
No fault code found.
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0524995000
Coding: 132C0C0723
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D75109652218F3945-8010
1 Fault Found:
12718340 - Databus
U1121 00 [137] - Missing Message
[Tip-TNF 241771]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:16
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Park selector lever position: Timeout
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition not met
No active error mode: Condition met
Key signature validity: Condition met
Control Module Voltage: 12.110 V
Driver information key position copy workshop: not active
Driver information: roll warning: not active
Driver information: emergency shutdown: not active
Internal_key_position: no_message
Driver information comfort switching: not active
Vehicle speed: 0.0 km/h
Engine RPM: 0.0 /min
Status of vehicle locking: Vehicle unlocked
Approach to the inside: not active
Actuation to the inside: not active
Approach to the outside: not active
Actuation to the outside: not active
Pulling actuation: outside door handle: not active
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID-sensor 1 authentication: status: No response
ID-sensor 2 authentication: status: No response
ID-sensor 3 authentication: status: No response
ID-sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 02020024200118000104004C12151008
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
VCID: 48C9583D5230059B6F3-801C
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
1 Fault Found:
459027 - Databus
U1121 00 [009] - Missing Message
[Tip-TNF 220120]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:16
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 036 0265
Revision: -------- Serial number: C86408101907IF
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00066 790 00395
ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7BA3F7F153669E03B21-802E
Wiper motor control module:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 190702 043 0551
Serial number: 97022066190718200736
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: SAY19M07D29H07M13S38
Coding: 0008DD
Humidity sensor: interior:
1 Fault Found:
795140 - Steering Column Control Module
U0212 00 [009] - No Communications
[Tip-TNF 234601]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:16
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 12.0 V
Outside temperature: 13.0 °C
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000137089R19220
Coding: 0271167911
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000.rod
VCID: 51FF7559A16AC45338D-8004
2 Faults Found:
12718594 - Databus
[Tip-TNF 226601]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:22
13688835 - Databus
U1123 00 [009] - Received Error Message
[Tip-TNF 226614]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:22
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V2.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 350000C941FFC728949C810520400600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
ROD: EV_ACCBOSCHVW416_002_VW37.rod
VCID: 44D14C0D6E1821FB83B-8010
4 Faults Found:
2177 - Databus
[Tip-TNF 206703]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
Control Module temperature: 31 °C
Voltage terminal 15: 12.0 V
Velocity_vehicle_reference: 0.00 m/s
Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
Status_ACC_System: ACC_irreversible error
1076 - Databus
[Tip-TNF 203274]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
1116 - Databus
U1122 00 [009] - Implausible Message
[Tip-TNF 201194]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
2068 - Databus
[Tip-TNF 208229]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR0CJKCZ
Coding: 8CCCFC00000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 47CB5B015F2E0AE3669-8012
Seat occupied recognition passenger side:
Subsystem 1 - Part No SW: 4M0 959 339 B HW: 4M0 959 339 B
Component: BF-Gewichtss. H14 0022
Serial number: IBH00000000000C78S6L
Coding: 303136
Crash sensor for side airbag: driver side:
Subsystem 2 - Part No SW: ----------- HW: 480 002 108 19
Component: SideSensor_Df 001 0887
Serial number: 35700000000BE524CE3.
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: ----------- HW: 480 002 008 19
Component: SideSensor_Pf 001 0887
Serial number: 358000000005A18DBE3
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 4 - Part No SW: ----------- HW: 480 403 107 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B4F08AF87D64P
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 5 - Part No SW: ----------- HW: 480 400 108 19
Component: SideSensor_Pr 004 6149
Serial number: 35200012A2C061F354D+
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 6 - Part No SW: ----------- HW: 480 400 909 19
Component: FrontSensor_D 004 6149
Serial number: 3550001202CA45F192F5
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 7 - Part No SW: ----------- HW: 480 400 909 19
Component: FrontSensor_P 005 6149
Serial number: 3560001BEF08AF82D92-
Coding: 2D2D2D
1 Fault Found:
9437202 - Igniter for Driver's Airbag
B1000 12 [137] - Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:19
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 740 D HW: 5G1 920 740 D
Component: KOMBI 251 2700
Coding: 0BA5101DED88880902887A0B5001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 270BFB81FF6EEAE3869-8072
1 Fault Found:
16776975 - Databus
[Tip-TNF 236227]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:16
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 16091900840961
Coding: 0901000830085900FB00221A1E0F00000001070000000000000000000000
GVL: 01C63C0000000600C0CC80000000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013025
ROD: EV_GatewNF_VW37.rod
VCID: 6E85CEA51014FBAB05F-803A
Generator:
Component: 0-00-0d-00-04
Multifunction steering wheel control module:
Inverter for electrical outlet:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: U13DCAC H27 0810
Serial number: 8005883
2 Faults Found:
66568 - Local data bus 2
U1076 00 [009] - Electrical malfunction
[Tip-TNF 217072]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:18
Terminal 30 power supply: 12.0 V
Terminal 15: On
197169 - Controls in Steering Wheel
U108E 00 [008] - No Communications
[Tip-TNF 241822]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 41
Mileage: 44279 km
Date: 2022.10.28
Time: 18:06:02
Terminal 30 power supply: 13.5 V
Terminal 15: OFF
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H55 7084
Serial number: HA1-00005.06.19
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4CC1642D4648E9BB4BB-8018
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
ASAM Dataset: EV_LCMLeftHELLAAU736 001012
ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000220598015
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: 313F15D9C1AAA45358D-8064
1 Fault Found:
12666373 - Databus
[Tip-TNF 232986]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:19
Result lock conditions: invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: Not operated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 Status: valid
Remote Start: not active
Driver door: to
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: OFF
Highside unlock: No
Motor break: not active
Activation lowside unlock: OFF
Activation lowside lock: OFF
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd true
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Learn mode: Adapted
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 0.00 km/h
UBat internal: 11.3 V
UMotorBridge: 6.2 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition met
Lock condition E2E vehicle speed: Condition met
Lock condition timeout vehicle speed: Condition met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition not met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition met
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0081
Serial number: 0524726554
Coding: 02012103
ASAM Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: 3D2739E90DF25033CC5-8068
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0081
Serial number: 0527161485
Coding: 020121
1 Fault Found:
119301 - Databus
[Tip-TNF 235204]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 M HW: 5Q4 959 593 F
Component: TSG FS 006 0247
Serial number: 42038927600805
Coding: 003A13200400040000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
VCID: 4FFB7321B75ED2A32E9-801A
Rear Driver Side Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 811 F HW: 5Q4 959 811 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 010 0004
Serial number: 00000000000004280958
Coding: 011000
1 Fault Found:
196660 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:21
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5QM 909 144 B HW: 5QM 909 144 B
Component: EPS_MQB_ZFLS 172 1081
Coding: 930A0000
ASAM Dataset: EV_SteerAssisMQB 015157
ROD: EV_SteerAssisMQB_015.rod
VCID: 50F9705DAA60CD5B373-8004
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1KMD05WEVL
Coding: 2200000000AAAAAA000000000000
ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 2E050EA5D094BBAB45F-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 05091900842308
Coding: 000000050900211200110F01030000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 353721C935C28873045-8060
1 Fault Found:
13705483 - Databus
[Tip-TNF 235206]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:16
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 M HW: 5Q4 959 592 F
Component: TSG BFS 006 0247
Serial number: 46039925400235
ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
VCID: 4EC56E25B054DBAB25F-801A
Rear Passenger Door Control Module:
Subsystem 1 - Part No SW: 5Q4 959 812 F HW: 5Q4 959 812 F Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 010 0004
Serial number: 00000000000004277407
Coding: 091000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 853 0890
Serial number:
Coding: 027312020000000041220002001828009F0508F401200505C6
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 33331FD13BB696432A1-8066
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav 254 8130
Serial number: VWZ6ZMW2835791
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 E HW: -----------
Component: NAR 2018/19 --- 0810
Serial number: --------------------
1 Fault Found:
1637 - Interface for External Media
U11B8 00 [009] - No Communications
[Tip-TNF 233784]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:17
Voltage terminal 30: 12.1 V
Interface for external media: status-Status: Open circuit
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0447495495
Coding: 0210000200000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 42DD4A15740C2FCBB17-8016
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 15071915K23323
Coding: 000307020002020100221355C150490084000E20012000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40D9401D7A003DDBA73-8014
1 Fault Found:
1123369 - Databus
[Tip-TNF 222806]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 1
Mileage: 44279 km
Date: 2022.10.28
Time: 16:59:22
Control Module temperature: 30 °C
Outside temperature: 10.0 °C
System run time: 392.7 s
Voltage terminal 15: 11.9 V
mid: 02 91
Status of camera: operational
Engine_Running_Info: 0
Software_Info_4: 0
Software_Info_3: 1
Software_Info_2: 6
Software_Info_1: 0
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Coding: 00804073720C
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW37.rod
VCID: 75B7E1C97542C873C45-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392F2DF919DA6C13E0D-806C
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:37, VBatt start/end: 12.5V/12.5V)-----------
I used an adaptor cable I got from AliExpress. Verified the pinouts and they matched what @Nuje provided in his initial post.
The vehicles existing 16 pin connector only has 7 conductors though.
If I compare the functions listed in the original post with the empty slots on my connector, it looks like I am missing the CAN H/L or they are on pins 12/13.
I am not sure how this can be possible considering my original clockspring/steering wheel functioned prior to the swap.
Notice Pins 12 and 13 are populated on my vehicle connector which are empty on the adapter harness.
I believe the wiring on my car does not correspond with the provided list and therefore is not compatible with the adapter.
If anyone would have the pinout or wiring diagram of Clockspring 5Q1 953 569 (Original Unit), it would help me trace the inconsistency.
2019 Alltrack
Thanks for any help.
Cuzoe
Clear all faults then post an Auto-scan of what's left... And maybe post a link to that adapter if they have the schematic for it on the listing.
Cuzoe
Module 19 - Gateway is showing an electrical fault. The gateway is how everything talks, so whatever is causing that fault is probably causing all your other faults.
What is that picture of? It looks like the clock spring but also looks strange. Although later cars have a steering column lock module. I don't think my car or Nuje's has that?
What were your original/new part numbers?
mannymoda
Canada
Original Part Number 5Q1 953 569 (Photo provided above)
New Part Number 5Q1 953 569B (Currently Installed)
mannymoda
Canada
The adapter wiring is not correct for my car.....hence the errors.
I tried to locate a wiring diagram or pinout of the clockspring online without success.
mannymoda
Canada
Photo of the new clockspring. Apart from the addition of the two power pins, it looks identical.
Starting to think it is a direct hookup...pin for pin.
mannymoda
Canada
For the most part, this has been solved.
I rewired the adapter as follows and all the errors magically disappeared.
Now, my only problem is I have lost my rear wiper. I guess the clockspring came from a vehicle that didn't have a rear wiper.
Just have to find the coding or adaptation to activate it.
If you have a good idea as to where I should be looking, that would be great :)
