They don’t like giving them out ��
The TCU is inside the gearbox on DSG
The ECU will need to be coded to accept the DSG, but otherwise should support it, yes.Are you sure that the TCU is compatible with the ECU that was installed for a manual shift car?
You can pay for 24 hour access to full offical factory diagrams/manuals/repair guides here:I’m retrofitting DSG gearbox to golf r mk7, i done all the mechanical work and fitted the full engine bay wiring loom for the dsg plug but they no plug in car for shift lever so I need to wire it in, as someone got wiring diagram thanks.
I done wiring for shifter lever and put battery back on car, I coded DSG on can gateway but having trouble code in the other modules do you need security access codes for coding, need to put rest of interior back together
I got 12.12 vcds.
