Retrofit of facelift BCM into pre-facelift Mk7 (in progress, please help ?)
xabhax
15 GTI
Golf 8 mirror bottoms with area view are on AliExpress. From the pics I’ve seen they look like they might work.
CarloP
Italy
@Cuzoe : Hi.
I'm probably misreading your post - but there are a bunch of adaptation channels related to the windshield washer pump in the BCM ; they are mixed-in with other channels under the parent name "Front_wiper" (some channels use the German word Frontwischer):
So, to add to your excellent suggestion related to checking the physical wiring/connections, I wonder whether there might be a coding problem here - I'm guessing of course?
There are 2 x versions of front washer pumps used in these cars and they are defined in the channel:
  • ENG141682-ENG141966-Front_wiper-Frontwischertyp
The permissible values for this channel are "direct" and "LIN". OP's admap confirms that the value in his/her new BCM is the latter.
However, if I'm reading your wiring diagram correctly, the simple circuit arrangement suggests that the pump is directly wired into the BCM socket - I think! Because it's an easy try and if the physical wiring checks are OK - maybe flip the channel setting?
The other way to check my hypothesis is to look at the value of Byte 13, Bit 0 on the old BCM - if this Bit was set, then the appropriate value of the adaptation channel above in the new BCM is "Direct"
Don
First of all thanks for your time!
Before installing the new BCM I took pictures and complete saves of everything. Below I attach the photo of the bit you mentioned.
As you can see in my last scan (carried out for the RGB leds) the pump is set to the same value.?
Is it possible that a short circuit occurred on the circuit in the bcm? I bought it used, maybe the old car had an accident...
CarloP
Italy
I suspect it should just be the one adaptation... as mentioned by DV52. If it works with the old BCM we should assume the wiring is good, which would suggest a BCM problem.
On a different note... any progress on the areaview cameras in the mirrors? :LOL:
I'm still evaluating the different options.. maybe I've found a solution. Further updates coming soon;)
xabhax
15 GTI
DV52
Australia
@CarloP : Of course, in the wild-vast world of diagnostics (particularly, remote-diagnostics via a forum like this) ANYTHING is possible - but it's unlikely IMO because I suspect that the BCM circuits are designed to be self protecting against short-circuit/overload.
Here's what the motherboard from a BCM looks like:
Don
CarloP
Italy
Don
I really can't understand what's causing it. Damn pump.
Could it be a "weak" negative?
DV52
Australia
@CarloP: Again, anything is possible and I repeat, a forum like this is a very poor medium over which to conduct remote diagnostics!! However, whenever I am puzzled by strange problems on a car (like this), I always go back to basics!
According to the VCDS screen-shot on your previous post, the fault descriptor is "Windshield washer pump - Electrical Failure".
To use a Strine (look it up) term from down-under, these words kind-of suggest (to me. at least) that the pump itself is "cactus" (cactus-f#cktus!!) - maybe?
Don
Toluxo
Mexico
Golf MK7
Hello, I need help, I have a 2016 golf sportwagen, I want to put ambient color on the cluster (VC) screen and on the infotainment screen, I want to put headlight washers too, I did the BCM SWAP, but the remote control does not close the doors (my car have Kessy), open the doors , open the trunk and panic sounds, what should I do?
Cuzoe
@Toluxo What are the part numbers of your original and new BCMs?
And what is the part number of your gateway?
As for the keys, did you go through the key pairing process?
Toluxo
Mexico
Golf MK7
thank you : the original part is 5Q0 937 087 AA, i have installed 5Q0937085CF, the key fob pairing process was done, i swapped the GW to 3Q0907530AG
Cuzoe
Gotcha, both your BCM and Gateway should be capable of ambient colors on infotainment and dash. Can you post an adaptation map of your BCM
Code:
Preferably in Code tags like this, keeps the thread easy to scroll.
Toluxo
Mexico
Golf MK7
Maybe this has more errors, but the most important thing is that the fob (open and close) works, the heated seats, the rear defroster, the errors in the lights may be a little easier to fix, I want to believe it.
Thank you very much, i have an adhex from 2017 Sportwagen too, but it have the same problem with fob
;SW:5Q0-937-085-CF HW:5Q0-937-085-CF --- Cent. Elect. --- SA: 31347
;Component:BCM MQBAB MNA H42 0411Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB
21001​
EV_BCMBOSCH_021_VW27.rod
;Thursday
9​
February
2023​
19:28:25:25289
;VCDS Version: Release 22.10.0 (x64) Data version: 20221026 DS344.0
;VCID: 7F5B0154377B5063928-802A
IDE00001-ENG99061-Production mode-Access controlnot active
3​
IDE00001-ENG115730-Production mode-Exterior lightingnot active
3​
IDE00001-ENG112304-Production mode-Heckwischernot active
3​
IDE00001-ENG98647-Production mode-Interior lightsnot active
3​
IDE00001-ENG115729-Production mode-Scheinwerferreinigungnot active
3​
IDE00001-ENG115731-Production mode-Virtuel_pedalnot active
3​
IDE00002-Transport modeactive
1​
IDE00820-Activating and deactivating all development messagesnot active
1​
IDE01550-Service position170.494336 °
2​
IDE02152-Characteristics in production mode2000 ms
4​
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during lockingDELAY
10​
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegelnnot active
10​
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung globalactive
10​
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhornactive
10​
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegelnactive
10​
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhornshort
10​
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldungactive
10​
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchtenot active
10​
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessenactive
10​
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehlactive
10​
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit250 ms
10​
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit250 ms
10​
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit250 ms
10​
IDE02332-Deactivate production mode
0​
3​
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischennot active
8​
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischennot active
8​
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 18 s
8​
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 216 s
8​
IDE02711-ENG112304-Rear wiper-Heckwischerlogikgesteuert
8​
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlaufnot active
8​
IDE02711-ENG114946-Rear wiper-Komfortwischen Heckactive
8​
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 15 s
8​
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 23 s
8​
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik7 s
8​
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall7 s
8​
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HWactive
8​
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_WischerKeine_Spannungsanforderung
8​
IDE02711-ENG116691-Rear wiper-Traenenwischen Heckactive
8​
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck0 ms
8​
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset0.3 °
16​
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit50.0 %/s
16​
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrtboth sides
16​
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold0.0 km/h
16​
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur100.0 °C
16​
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur95.0 °C
16​
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel120 °
16​
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur80.0 °C
16​
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel80 °
16​
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold40.0 km/h
16​
IDE03638-ENG116674-Stationary cornering lamp-VorschriftECE R119
16​
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht15 min
16​
IDE03787-Activate left/right hand drive switch-overnot active
1​
IDE04927-IDE01446-Window heater-Running time of heated front window600 s
11​
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung35.0 °C
11​
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung35.0 °C
11​
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer0 s
11​
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direktnot installed
11​
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmusnot installed
11​
IDE04927-ENG126845-Window heater-FSH Automatiknot active
11​
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert320 s
11​
IDE04927-ENG141955-Window heater-heizbare Heckscheibeinstalled
11​
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibenot installed
11​
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablagenot installed
11​
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSHactive
11​
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSHactive
11​
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv4.0 °C
11​
IDE04927-ENG141962-Window heater-Waschduesenheizunginstalled
11​
IDE04927-ENG154810-Window heater-window heating front activation time pause320 s
11​
IDE04928-MAS01577-Anti-theft protection-Parking heaternot installed
8​
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhornactive
8​
IDE04928-ENG115864-Anti-theft protection-Alarmsignalfrequency modulated
8​
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm systemactive
8​
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklickactiv
8​
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMInot_active
8​
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerungnot active
8​
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modusnot active
8​
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Soundernot installed
8​
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensornot installed
8​
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtetNo
8​
IDE04928-ENG142249-Anti-theft protection-OBD Alarmnot_active
8​
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarmactiv
8​
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)No
8​
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_InnenraumueberwachungNo
8​
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl10 Alarme
8​
IDE04928-ENG142008-Anti-theft protection-tilt_sensorNo
8​
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebelnot active
8​
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarmkeine verzoegerung
8​
IDE05143-MAS02985-Writing parameter-Value
130​
5​
IDE05143-MAS04381-Writing parameter-Parameter addressFE 00 00
5​
IDE05144-Read parameter addressFE 00 00
3​
IDE05145-Light configuration0C 34 00 14 02 00 64 08 00 32 00 00 00 03 03 80 0C 3E 00 15 04 00 64 08 00 32 00 00 00 05 00 80 04 48 00 4A 14 03 64 00 00 99 08 09 23 02 00 80 04 4C 00 4C 14 05 64 00 00 99 08 09 23 04 00 80 01 3A 00 49 14 03 20 00 00 1A 08 09 7F 02 00 80 01 44 00 4B 14 05 20 00 00 80 08 0A 7F 04 00 80 03 36 00 1A 0B 0F 7F 1E 00 80 00 00 00 00 00 00 03 40 00 1B 0C 0F 7F 1E 00 80 00 00 00 00 00 00 24 35 00 26 08 09 7F 14 00 7F 00 00 00 00 00 00 24 3F 00 27 08 0A 7F 14 00 7F 00 00 00 00 00 00 02 37 00 1E 0D 0F 7F 00 00 00 00 00 00 00 00 00 02 41 00 1F 0E 0F 7F 00 00 00 00 00 00 00 00 00 0A 38 00 11 12 16 64 0F 1E 64 00 00 00 00 00 00 0A 41 00 23 13 17 64 0F 1E 64 00 00 00 00 00 00
224​
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler
0​
30​
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CANHeizmatten am LIN-Modul (Sitzlueftung)
30​
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss1 s
30​
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss0.00 °C
30​
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle18.50 °C
30​
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle18.00 °C
30​
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle18.50 °C
30​
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle18.00 °C
30​
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle26.00 °C
30​
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle25.50 °C
30​
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle26.00 °C
30​
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle25.50 °C
30​
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle43.00 °C
30​
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle42.50 °C
30​
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle43.00 °C
30​
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle42.50 °C
30​
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HISollspannungsanforderung 14.7
30​
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LOKeine_Spannungsanforderung
30​
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabenot installed
30​
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_7515.7 V
30​
IDE06425-Dynamometer mode: functionalnot active
1​
IDE06507-MAS13125-Button in center console-Function of button 1Start-stop
8​
IDE06507-MAS13129-Button in center console-Function of button 2not coded/not installed
8​
IDE06507-MAS13132-Button in center console-Function of button 3not coded/not installed
8​
IDE06507-MAS13135-Button in center console-Function of button 4not coded/not installed
8​
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LEDLED not installed
8​
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglichactive
8​
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RStnot active
8​
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeigeactive
8​
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustikactive
8​
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RStactive
8​
IDE07007-ENG249923-Air conditioning/heating function via remote control-pa_RSt_MOD_verbautinstalled
8​
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Startinstalled
8​
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbautnot installed
8​
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierungactive
8​
IDE07356-Position during interval mode31.494474 °
2​
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufsabschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit
6​
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit30 min
6​
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Einactive
6​
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regenactive
9​
IDE08786-ENG141956-Assistance light functions-Humidity sensorinstalled
9​
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeitnormal
9​
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabenot active
9​
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktionnot active
9​
IDE08786-ENG141985-Assistance light functions-Regen_LichtsensorLIN_REGEN_LICHT_SENSOR
9​
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensorinstalled
9​
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual
7​
19​
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual
11​
19​
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformationactive
19​
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplungnot active
19​
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_defaultnot active
19​
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit0.10 s
19​
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1
2​
19​
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2
3​
19​
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3
1​
19​
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbignot active
19​
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbignot active
19​
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach
80%​
19​
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe
2​
19​
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum
50%​
19​
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole
80%​
19​
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer
50%​
19​
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn
50%​
19​
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnenactive
19​
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnenactive
19​
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnennot active
19​
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschaltenactive
19​
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbigactive
19​
IDE09731-ENG98648-Int. light: 2nd generation-Interior lightingKeine_Spannungsanforderung
19​
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWMnot active
19​
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbignot active
19​
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlichtnot installed
19​
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbignot active
19​
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivierennot active
19​
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbigactive
19​
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafelnot installed
19​
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafelnot installed
19​
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbignot active
19​
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30Ginstalled
19​
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechselnot active
19​
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default
0​
5​
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMIactive
5​
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafelnot installed
5​
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafelnot installed
5​
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprechernot installed
5​
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonenactive
5​
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem ausactive
5​
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtungnot installed
5​
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtungnot installed
5​
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofilnot installed
5​
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMInot installed
5​
IDE09732-ENG114629-Interior light: light configuration-Footwell lightingnot installed
5​
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMIactive
5​
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbarnot active
5​
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtungnot installed
5​
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtungnot installed
5​
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne
30%​
17​
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz
30%​
17​
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne
30%​
17​
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz
30%​
17​
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne
50%​
17​
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz
50%​
17​
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne
50%​
17​
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz
50%​
17​
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne
75%​
17​
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz
75%​
17​
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne
80%​
17​
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz
80%​
17​
IDE09761-ENG142025-Seat fan charac. curve-Seat pneumaticsnot installed
17​
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftungnot installed
17​
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbarinstalled
17​
IDE10298-Alternating park position 17.494498 °
2​
IDE10299-Alternating park position 229.494476 °
2​
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit
1​
256​
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach
1​
256​
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum
0.4​
256​
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel
0​
256​
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher
1​
256​
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko
1​
256​
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd
1​
256​
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer
0​
256​
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI
0​
256​
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2
0​
256​
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3
0​
256​
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4
0​
256​
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI
0​
256​
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2
0​
256​
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3
0​
256​
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4
0​
256​
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab
1​
256​
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf
1​
256​
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI
0​
256​
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay
0​
256​
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum
70%​
256​
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel
0%​
256​
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum
70%​
256​
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel
0%​
256​
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum
70%​
256​
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel
0%​
256​
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum
70%​
256​
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel
0%​
256​
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit
100%​
256​
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach
100%​
256​
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum
70%​
256​
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht
100%​
256​
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel
0%​
256​
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher
100%​
256​
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko
100%​
256​
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd
100%​
256​
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren
0%​
256​
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit
100%​
256​
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach
100%​
256​
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum
0%​
256​
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht
100%​
256​
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel
0%​
256​
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher
100%​
256​
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko
100%​
256​
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd
100%​
256​
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren
0%​
256​
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit
100%​
256​
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach
100%​
256​
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum
70%​
256​
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht
100%​
256​
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel
0%​
256​
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher
100%​
256​
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko
100%​
256​
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd
100%​
256​
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren
0%​
256​
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach
100%​
256​
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum
127%​
256​
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel
0%​
256​
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko
100%​
256​
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd
100%​
256​
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit
126%​
256​
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach
126%​
256​
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum
126%​
256​
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht
0%​
256​
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel
0%​
256​
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher
126%​
256​
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko
126%​
256​
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd
126%​
256​
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum
127%​
256​
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel
0%​
256​
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit
100%​
256​
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach
100%​
256​
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum
126%​
256​
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht
100%​
256​
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel
0%​
256​
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher
100%​
256​
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko
100%​
256​
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd
100%​
256​
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren
0%​
256​
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit
100%​
256​
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach
100%​
256​
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum
70%​
256​
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht
100%​
256​
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel
0%​
256​
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher
100%​
256​
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko
100%​
256​
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd
100%​
256​
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren
0%​
256​
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach
100%​
256​
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum
70%​
256​
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel
0%​
256​
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko
100%​
256​
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd
100%​
256​
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit
100%​
256​
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach
100%​
256​
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum
70%​
256​
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht
100%​
256​
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel
0%​
256​
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher
100%​
256​
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko
100%​
256​
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd
100%​
256​
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren
0%​
256​
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit
100%​
256​
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach
100%​
256​
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum
70%​
256​
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht
100%​
256​
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel
0%​
256​
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher
100%​
256​
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko
100%​
256​
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd
100%​
256​
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren
0%​
256​
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte200 ms
256​
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit0.0 s
256​
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach0.0 s
256​
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum0.0 s
256​
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht0.0 s
256​
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko0.0 s
256​
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren0.0 s
256​
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit0.0 s
256​
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach0.0 s
256​
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum2.0 s
256​
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht0.0 s
256​
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko0.0 s
256​
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren0.0 s
256​
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit0.0 s
256​
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach0.0 s
256​
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum0.0 s
256​
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht0.0 s
256​
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko0.0 s
256​
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren0.0 s
256​
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit0.0 s
256​
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach0.0 s
256​
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum0.0 s
256​
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht0.0 s
256​
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko0.0 s
256​
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren0.0 s
256​
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit0.0 s
256​
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach0.0 s
256​
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum0.0 s
256​
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht0.0 s
256​
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko0.0 s
256​
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren0.0 s
256​
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit0.0 s
256​
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach0.0 s
256​
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum0.0 s
256​
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht0.0 s
256​
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko0.0 s
256​
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren0.0 s
256​
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit0.0 s
256​
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach0.0 s
256​
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum0.0 s
256​
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht0.0 s
256​
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko0.0 s
256​
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren0.0 s
256​
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen
0​
256​
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1
43​
30​
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10
20​
30​
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2
0​
30​
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3
0​
30​
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4
0​
30​
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5
0​
30​
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6
0​
30​
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7
0​
30​
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8
11​
30​
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9
0​
30​
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1
50​
30​
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10
255​
30​
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2
77​
30​
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3
116​
30​
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4
154​
30​
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5
193​
30​
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6
255​
30​
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7
230​
30​
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8
238​
30​
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9
255​
30​
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1
255​
30​
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10
170​
30​
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2
255​
30​
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3
255​
30​
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4
255​
30​
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5
255​
30​
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6
255​
30​
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7
230​
30​
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8
210​
30​
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9
210​
30​
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelungnot installed
3​
IDE11944-ENG141948-Keyless access and start authorization-Kessyinstalled
3​
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeberactive
3​
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnennot active
3​
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessenactive
3​
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzungactive
3​
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExitactive
3​
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExitactive
3​
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelungactive
3​
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control moduleNot available
6​
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition SensorNot available
6​
IDE12302-SFT271875-Identification of sub-bus participant-Light switchNot available
6​
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control moduleNot available
6​
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control headNot available
6​
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensorNot available
6​
IDE12302-SFT271896-Identification of sub-bus participant-Alarm hornNot available
6​
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control moduleNot available
6​
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control moduleNot available
6​
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control moduleNot available
6​
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interiorNot available
6​
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heaterNot available
6​
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heaterNot available
6​
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrestNot available
6​
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushionNot available
6​
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrestNot available
6​
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushionNot available
6​
IDE12302-ENG246961-Identification of sub-bus participant-Remote_ControlNot available
6​
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switchNot available
6​
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin
0​
30​
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin
0​
30​
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin
0​
30​
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin
0​
30​
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin
0​
30​
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin
0​
30​
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin
0​
30​
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin
0​
30​
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin
0​
30​
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin
0​
30​
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin
0​
30​
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin
0​
30​
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin
0​
30​
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin
0​
30​
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin
0​
30​
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin
0​
30​
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin
0​
30​
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin
0​
30​
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin
0​
30​
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin
0​
30​
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin
0​
30​
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin
0​
30​
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin
0​
30​
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin
0​
30​
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin
0​
30​
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin
0​
30​
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin
0​
30​
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin
0​
30​
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin
0​
30​
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin
0​
30​
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltungactive
5​
MAS01490-ENG116830-Energy management-Energy_Management_AdaptationEnergy management active
5​
MAS01490-ENG142256-Energy management-Hochvoltfahrzeugnot installed
5​
MAS01490-ENG141950-Energy management-Hybrid vehicleNo
5​
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagementnot active
5​
MAS01490-ENG141978-Energy management-Recuperationactive
5​
MAS01490-ENG142037-Energy management-Zweitbatterienot installed
5​
MAS05055-lower turn position31.494474 °
2​
MAS05056-upper turn position170.494336 °
2​
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze1200 lx
24​
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze2200 lx
24​
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle0 lx
24​
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO600 lx
24​
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten1200 lx
24​
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten2200 lx
24​
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red00 00
24​
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell4000 lx
24​
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highwaynot active
24​
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rainnot active
24​
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivityfrueh
24​
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFFnot active
24​
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabenot active
24​
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung0 mV
24​
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke0 lx
24​
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung0 mV
24​
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke0 lx
24​
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung
2​
24​
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_statusnot active
9​
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC00 00 00
9​
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTCFirst_dtc
9​
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahrenactive
4​
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FTactive
4​
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoilernot installed
4​
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11
30​
60​
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12
30​
60​
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13
110​
60​
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14
140​
60​
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15
160​
60​
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16
200​
60​
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17
255​
60​
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18
255​
60​
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19
255​
60​
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20
255​
60​
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21
255​
60​
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22
255​
60​
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23
255​
60​
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24
255​
60​
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25
255​
60​
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26
255​
60​
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27
115​
60​
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28
90​
60​
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29
70​
60​
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30
100​
60​
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11
255​
60​
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12
235​
60​
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13
235​
60​
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14
255​
60​
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15
225​
60​
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16
225​
60​
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17
200​
60​
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18
160​
60​
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19
120​
60​
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20
90​
60​
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21
40​
60​
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22
30​
60​
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23
30​
60​
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24
30​
60​
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25
0​
60​
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26
0​
60​
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27
0​
60​
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28
40​
60​
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29
90​
60​
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30
110​
60​
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11
60​
60​
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12
0​
60​
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13
0​
60​
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14
50​
60​
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15
0​
60​
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16
0​
60​
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17
0​
60​
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18
0​
60​
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19
0​
60​
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20
10​
60​
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21
30​
60​
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22
65​
60​
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23
120​
60​
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24
195​
60​
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25
220​
60​
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26
255​
60​
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27
255​
60​
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28
255​
60​
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29
255​
60​
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30
240​
60​
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin
0​
60​
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin
0​
60​
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin
0​
60​
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin
0​
60​
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin
0​
60​
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin
0​
60​
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin
0​
60​
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin
0​
60​
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin
0​
60​
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin
0​
60​
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin
0​
60​
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin
0​
60​
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin
0​
60​
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin
0​
60​
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin
0​
60​
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin
0​
60​
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin
0​
60​
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin
0​
60​
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin
0​
60​
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin
0​
60​
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin
0​
60​
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin
0​
60​
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin
0​
60​
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin
0​
60​
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin
0​
60​
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin
0​
60​
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin
0​
60​
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin
0​
60​
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin
0​
60​
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin
0​
60​
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin
0​
60​
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin
0​
60​
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin
0​
60​
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin
0​
60​
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin
0​
60​
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin
0​
60​
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin
0​
60​
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin
0​
60​
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin
0​
60​
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin
0​
60​
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin
0​
60​
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin
0​
60​
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin
0​
60​
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin
0​
60​
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin
0​
60​
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin
0​
60​
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin
0​
60​
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin
0​
60​
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin
0​
60​
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin
0​
60​
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin
0​
60​
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin
0​
60​
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin
0​
60​
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin
0​
60​
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin
0​
60​
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin
0​
60​
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin
0​
60​
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin
0​
60​
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin
0​
60​
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin
0​
60​
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1
1​
30​
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10
1​
30​
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11
1​
30​
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12
1​
30​
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13
1​
30​
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14
1​
30​
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15
1​
30​
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2
1​
30​
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3
1​
30​
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4
1​
30​
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5
1​
30​
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6
1​
30​
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7
1​
30​
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8
1​
30​
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9
1​
30​
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1door
30​
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10door
30​
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11door
30​
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12door
30​
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13door
30​
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14door
30​
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15door
30​
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2door
30​
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3door
30​
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4door
30​
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5door
30​
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6door
30​
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7door
30​
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8door
30​
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9door
30​
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1single-color
30​
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10not installed
30​
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11not installed
30​
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12not installed
30​
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13not installed
30​
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14not installed
30​
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15not installed
30​
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2single-color
30​
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3single-color
30​
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4single-color
30​
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5not installed
30​
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6not installed
30​
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7not installed
30​
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8not installed
30​
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9not installed
30​
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12
0​
60​
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1
0​
60​
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10
0​
60​
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11
0​
60​
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13
0​
60​
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14
0​
60​
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15
0​
60​
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16
0​
60​
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17
0​
60​
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18
0​
60​
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19
0​
60​
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2
0​
60​
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20
0​
60​
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3
0​
60​
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4
0​
60​
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5
0​
60​
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6
0​
60​
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7
0​
60​
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8
0​
60​
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9
0​
60​
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1
0​
60​
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10
0​
60​
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11
0​
60​
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12
0​
60​
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13
0​
60​
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14
0​
60​
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15
0​
60​
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16
0​
60​
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17
0​
60​
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18
0​
60​
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19
0​
60​
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2
0​
60​
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20
0​
60​
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3
0​
60​
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4
0​
60​
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5
0​
60​
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6
0​
60​
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7
0​
60​
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9
0​
60​
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8
0​
60​
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1not installed
60​
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10not installed
60​
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11not installed
60​
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12not installed
60​
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13not installed
60​
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14not installed
60​
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15not installed
60​
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16not installed
60​
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17not installed
60​
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18not installed
60​
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19not installed
60​
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2not installed
60​
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20not installed
60​
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3not installed
60​
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4not installed
60​
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5not installed
60​
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6not installed
60​
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7not installed
60​
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9not installed
60​
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8not installed
60​
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-AmbienteKeine_Spannungsanforderung
23​
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0
1​
23​
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1
1​
23​
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10
1​
23​
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11
1​
23​
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12
1​
23​
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13
1​
23​
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14
1​
23​
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15
1​
23​
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2
1​
23​
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3
1​
23​
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4
1​
23​
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5
1​
23​
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6
1​
23​
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7
1​
23​
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8
1​
23​
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9
1​
23​
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinkennot active
10​
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinkenactive
10​
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaengerseparte
10​
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashingnot active
10​
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinkennot active
10​
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittungnot active
10​
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay50 ms
10​
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinkennot active
10​
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_BlinkenfunktionenWarnblinke_zulaessig
10​
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinkenactive
10​
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen
3​
10​
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinkennot active
10​
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2not active
10​
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashingnot active
10​
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECASPreCrash_passiv
10​
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_linksnot active
10​
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechtsnot active
10​
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinkennot active
10​
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinkennot active
10​
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashingnot active
10​
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinkennot active
10​
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinkennot active
10​
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinkennot active
10​
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenznot active
10​
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max120 min
10​
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUSnot active
10​
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EINnot active
10​
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_aufnot active
10​
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zunot active
10​
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_LeuchtentypH7
9​
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperrennot active
9​
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze350 km/h
9​
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze350 km/h
9​
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei TagDaytime running lamps
9​
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL5 km/h
9​
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglichnot active
9​
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlichtnot active
9​
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrumentnot active
9​
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbautnot installed
9​
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlichtactive
9​
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglichnot active
9​
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschaltenactive
9​
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTOnot active
9​
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlichtnot active
9​
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchtenot active
9​
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeitnot active
9​
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolgeactive
9​
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitierenin Betrieb lassen
9​
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_BlinklichtNo
5​
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit0 km/h
5​
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBAnot active
5​
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktionnot active
5​
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappenot installed
5​
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6No
18​
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lightinstalled
18​
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzungabschaltbar über Energiemanagement
18​
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzungabschaltbar über Energiemanagement
18​
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes StandlichtAktive Begrenzung
18​
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf0 ms
18​
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home LeuchtenLow beam
18​
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatusautomatic
18​
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home EinschaltereignisDriver door
18​
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfachactive
18​
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_KonfigHinweis_in_LDS-Stellung_Null_und_SL
18​
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer VerfuegbarkeitstimerFaktor fuer x5 Minuten
18​
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LHKeine_Spannungsanforderung
18​
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lampKeine_Spannungsanforderung
18​
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung696 lx
18​
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung800 lx
18​
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_LadezustandsanzeigeNo
18​
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslichtintegriert in Suchbeleuchtung
18​
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinkertrue
18​
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFLYes
18​
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_SchlusslichtYes
18​
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_NebellichtYes
18​
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_StandlichtstellungYes
18​
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home VerbausstatusEnabled
18​
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6not active
18​
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)discrete
18​
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhaltenklemmenabhaengig
18​
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Modulenot installed
18​
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beamKeine_Spannungsanforderung
18​
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHOMenuesteuerung Zeit aktivieren
18​
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome10 seconds
18​
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP10 seconds
18​
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellungactive
18​
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAPactive
18​
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviertnot active
18​
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht ausactive
18​
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklichtnot active
18​
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit24 s
18​
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6No
18​
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lampKeine_Spannungsanforderung
18​
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchtenot active
18​
ENG126647-ENG98399-debug_light_function-Activation
0​
11​
ENG126647-ENG101417-debug_light_function-Adresse
0​
11​
ENG126647-ENG126820-debug_light_function-Bitmask
0​
11​
ENG126647-ENG126821-debug_light_function-Divisor
0​
11​
ENG126647-ENG98827-debug_light_function-Offset
0​
11​
ENG126647-ENG126822-debug_light_function-Polaritaet
0​
11​
ENG246955-ENG246967-digital_key-central_locking_digital_key_generalnot installed
3​
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btleactive
3​
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktionactive
3​
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertueractive
3​
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btleactive
3​
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktionactive
3​
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertueractive
3​
ENG246955-ENG246991-digital_key-pa_Two_Keysnot active
3​
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0
0.00%​
6​
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1
50.00%​
6​
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2
100.00%​
6​
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0
0.00%​
6​
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1
50.00%​
6​
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2
100.00%​
6​
ENG122934-erase_error_table55 00 00
3​
ENG122933-error_mask0 bit
2​
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAPpresent
6​
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_FernlichtsteuerungAFS: FLA: BCM-Fernlicht
6​
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Resetnot active
6​
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistentnot installed
6​
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellungpresent
6​
ENG141685-Front_wash_function
10​
2​
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRAnot active
6​
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung800 ms
6​
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogrammactive
6​
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlaufnot active
6​
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfigKeine_Spannungsanforderung
6​
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtaupositionactive
6​
ENG141682-ENG141966-Front_wiper-FrontwischertypLIN
6​
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltungactive
6​
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischernot active
6​
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer0 ms
6​
ENG141682-ENG115771-Front_wiper-Regensensor aktivierenDeactivating
6​
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay300 ms
6​
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenzactive
6​
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Statusnot active
6​
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierungactive
6​
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variantnot active
6​
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaubenot active
6​
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 ausnot active
6​
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaubeactive
6​
ENG99457-ENG117394-Head area heater-blower_speed
1​
2​
ENG99457-ENG98971-Head area heater-Temperature
-2​
2​
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluidinstalled
8​
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluidnot installed
8​
ENG141645-MAS00213-HW_Verbau-Insufficient coolantinstalled
8​
ENG141645-MAS00214-HW_Verbau-Brake pad wearnot installed
8​
ENG141645-ENG142026-HW_Verbau-Druckklappenot installed
8​
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktivnot active
8​
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckungnot installed
8​
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensorinstalled
8​
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaubenot installed
8​
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelungnot installed
8​
ENG141645-ENG142036-HW_Verbau-PTC Zuheizernot installed
8​
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15active
8​
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelungnot active
8​
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0
-100.00%​
30​
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1
-100.00%​
30​
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2
-100.00%​
30​
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3
-100.00%​
30​
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4
-100.00%​
30​
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5
-100.00%​
30​
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6
-100.00%​
30​
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7
-100​
30​
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8
-100.00%​
30​
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9
-100.00%​
30​
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0
100.00%​
30​
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1
90.00%​
30​
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2
80.00%​
30​
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3
70.00%​
30​
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4
60.00%​
30​
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5
50.00%​
30​
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6
40.00%​
30​
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7
30.00%​
30​
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8
15.00%​
30​
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9
0.00%​
30​
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0maximize
16​
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0maximize
16​
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0minimize
16​
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0
100​
16​
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0
50​
16​
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0
0​
16​
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0
0​
16​
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0
14​
16​
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0
34​
16​
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 012 - Blinkleuchten
16​
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0Always
16​
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0Blinken links Hellphase
16​
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0not active
16​
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0not active
16​
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0not active
16​
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0not active
16​
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0Blinken links Dunkelphase
16​
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0Blinken links Dunkelphase
16​
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15maximize
16​
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15maximize
16​
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15maximize
16​
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15
100​
16​
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15
0​
16​
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15
0​
16​
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15
0​
16​
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15
63​
16​
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15
0​
16​
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 1541 - LED Kleinleistung
16​
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15Always
16​
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15Warnblinktaster_Suchbeleuchtung
16​
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15not active
16​
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15not active
16​
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15not active
16​
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15not active
16​
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15not active
16​
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15not active
16​
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15not active
16​
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10maximize
16​
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10maximize
16​
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10maximize
16​
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10
127​
16​
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10
0​
16​
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10
0​
16​
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10
0​
16​
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 101E
16​
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10
37​
16​
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 102 - Shutter: Diagnosesensierung für 'LED low'
16​
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10Always
16​
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10Left high beam
16​
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10Lichthupe generell
16​
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10not active
16​
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10not active
16​
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10not active
16​
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10not active
16​
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10not active
16​
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10not active
16​
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11maximize
16​
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11maximize
16​
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11maximize
16​
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11
127​
16​
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11
0​
16​
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11
0​
16​
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11
0​
16​
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 111F
16​
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11
41​
16​
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 112 - Shutter: Diagnosesensierung für 'LED low'
16​
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11Always
16​
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11Right high beam
16​
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11Lichthupe generell
16​
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11not active
16​
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11not active
16​
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11not active
16​
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11not active
16​
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11not active
16​
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11not active
16​
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12maximize
16​
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12maximize
16​
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12maximize
16​
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12
100​
16​
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12
100​
16​
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12
0​
16​
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12
0​
16​
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12
11​
16​
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12
38​
16​
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 1210 - allgemeine Scheinwerfer
16​
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12Always
16​
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12Nebellicht links
16​
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12Abbiegelicht links
16​
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12Lichthupe generell
16​
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12Coming Home oder Leaving Home aktiv
16​
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12not active
16​
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12not active
16​
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12not active
16​
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12not active
16​
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13maximize
16​
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13maximize
16​
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13maximize
16​
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13
100​
16​
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13
100​
16​
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13
0​
16​
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13
0​
16​
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13
23​
16​
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13
41​
16​
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 1310 - allgemeine Scheinwerfer
16​
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13Always
16​
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13Nebellicht rechts
16​
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13Abbiegelicht rechts
16​
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13Lichthupe generell
16​
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13Coming Home oder Leaving Home aktiv
16​
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13not active
16​
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13not active
16​
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13not active
16​
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13not active
16​
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16maximize
16​
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16maximize
16​
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16maximize
16​
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
100​
16​
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16
0​
16​
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16
0​
16​
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16
0​
16​
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16
0​
16​
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16
0​
16​
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 1643 - allgemeine LED
16​
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16Always
16​
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16not active
16​
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16not active
16​
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16not active
16​
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16not active
16​
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16not active
16​
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16not active
16​
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16not active
16​
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17maximize
16​
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17maximize
16​
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17maximize
16​
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17
100​
16​
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17
0​
16​
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17
0​
16​
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17
0​
16​
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17
0​
16​
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17
0​
16​
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17not active
16​
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17Always
16​
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17not active
16​
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17not active
16​
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17not active
16​
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17not active
16​
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17not active
16​
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17not active
16​
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17not active
16​
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18maximize
16​
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18minimize
16​
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18maximize
16​
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18
100​
16​
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18
100​
16​
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18
0​
16​
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18
0​
16​
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18
0​
16​
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18
0​
16​
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 1836 - LED Kleinleistung
16​
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18Always
16​
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18Blinken links Hellphase
16​
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18Luggage compartment light
16​
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18not active
16​
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18Blinken links Dunkelphase
16​
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18not active
16​
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18not active
16​
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18not active
16​
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19maximize
16​
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19minimize
16​
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19maximize
16​
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19
127​
16​
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19
100​
16​
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19
0​
16​
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19
0​
16​
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19
18​
16​
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19
18​
16​
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 1936 - LED Kleinleistung
16​
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19Always
16​
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19Blinken rechts Hellphase
16​
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19Luggage compartment light
16​
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19not active
16​
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19not active
16​
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19Blinken rechts Dunkelphase
16​
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19not active
16​
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19not active
16​
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1maximize
16​
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1maximize
16​
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1minimize
16​
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1
100​
16​
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1
50​
16​
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1
0​
16​
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1
0​
16​
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1
15​
16​
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 13E
16​
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 112 - Blinkleuchten
16​
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1Always
16​
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1Blinken rechts Hellphase
16​
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1not active
16​
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1not active
16​
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1not active
16​
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1not active
16​
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1Blinken rechts Dunkelphase
16​
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1not active
16​
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20maximize
16​
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20minimize
16​
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20maximize
16​
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20
127​
16​
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20
100​
16​
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20
0​
16​
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20
127​
16​
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20
0​
16​
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20
0​
16​
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 2035 - kombinierte LED Blink-Bremsleuchten
16​
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20Always
16​
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20Brake lamp
16​
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20Blinken links Hellphase
16​
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20Luggage compartment light
16​
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20not active
16​
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20Blinken links Dunkelphase
16​
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20not active
16​
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20not active
16​
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21maximize
16​
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21minimize
16​
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21maximize
16​
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21
127​
16​
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21
100​
16​
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21
0​
16​
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21
127​
16​
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21
0​
16​
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21
0​
16​
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 2135 - kombinierte LED Blink-Bremsleuchten
16​
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21Always
16​
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21Brake lamp
16​
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21Blinken rechts Hellphase
16​
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21Luggage compartment light
16​
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21Parking light right
16​
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21Blinken rechts Dunkelphase
16​
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21not active
16​
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21not active
16​
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21Parking light right
16​
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22maximize
16​
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22maximize
16​
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22maximize
16​
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22
100​
16​
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22
0​
16​
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22
0​
16​
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22
0​
16​
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 222C
16​
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22
29​
16​
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 2242 - LED dritte Bremsleuchte
16​
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22Always
16​
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22Brake lamp
16​
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22not active
16​
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22not active
16​
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22not active
16​
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22not active
16​
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22not active
16​
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22not active
16​
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22not active
16​
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23maximize
16​
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23maximize
16​
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23maximize
16​
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23
127​
16​
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23
127​
16​
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23
0​
16​
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23
0​
16​
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23
0​
16​
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23
0​
16​
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 2343 - allgemeine LED
16​
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23Always
16​
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23not active
16​
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23not active
16​
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23not active
16​
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23not active
16​
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23not active
16​
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23not active
16​
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24maximize
16​
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24maximize
16​
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24maximize
16​
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24
127​
16​
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24
0​
16​
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24
0​
16​
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24
0​
16​
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24
0​
16​
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24
0​
16​
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 2443 - allgemeine LED
16​
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24Always
16​
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24Parking light right
16​
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24not active
16​
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24not active
16​
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24not active
16​
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24not active
16​
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24not active
16​
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24not active
16​
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25maximize
16​
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25maximize
16​
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25maximize
16​
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25
127​
16​
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25
0​
16​
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25
0​
16​
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25
0​
16​
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25
30​
16​
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25
28​
16​
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 2543 - allgemeine LED
16​
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25Always
16​
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25not active
16​
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25not active
16​
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25not active
16​
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25not active
16​
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25not active
16​
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25not active
16​
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25not active
16​
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26maximize
16​
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26maximize
16​
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26maximize
16​
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26
100​
16​
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26
100​
16​
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26
0​
16​
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26
0​
16​
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 262E
16​
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 260C
16​
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 269 - allgemeine Glühlampe 27W: auch H15
16​
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26only_if_closed
16​
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26Nebelschlusslicht wenn kein Anhaenger gesteckt
16​
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26not active
16​
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26not active
16​
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26not active
16​
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26not active
16​
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26not active
16​
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26not active
16​
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26not active
16​
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27maximize
16​
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27maximize
16​
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27maximize
16​
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27
127​
16​
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27
0​
16​
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27
0​
16​
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27
0​
16​
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27
53​
16​
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27
0​
16​
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 2743 - allgemeine LED
16​
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27Always
16​
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27not active
16​
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27not active
16​
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27not active
16​
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27not active
16​
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27not active
16​
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27not active
16​
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27not active
16​
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28maximize
16​
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28maximize
16​
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28maximize
16​
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28
127​
16​
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28
0​
16​
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28
0​
16​
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28
0​
16​
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28
31​
16​
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 280B
16​
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 2832 - allgemeine LED bis 12W
16​
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28Always
16​
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28Rueckfahrlicht
16​
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28Coming Home oder Leaving Home aktiv
16​
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28not active
16​
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28not active
16​
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28not active
16​
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28not active
16​
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28not active
16​
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28not active
16​
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29maximize
16​
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29maximize
16​
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29maximize
16​
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29
127​
16​
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29
0​
16​
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29
0​
16​
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29
0​
16​
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29
32​
16​
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 291B
16​
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 2932 - allgemeine LED bis 12W
16​
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29Always
16​
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29Rueckfahrlicht
16​
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29Coming Home oder Leaving Home aktiv
16​
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29not active
16​
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29not active
16​
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29not active
16​
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29not active
16​
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29not active
16​
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29not active
16​
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2minimize
16​
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2maximize
16​
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2minimize
16​
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2
100​
16​
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2
25​
16​
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2
35​
16​
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2
0​
16​
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 24A
16​
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2
48​
16​
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 24 - LED Tagfahrlichtmodul Signal
16​
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2Always
16​
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2Daytime running lamps
16​
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2Blinken links Dunkelphase
16​
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2not active
16​
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2not active
16​
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2Blinken links Hellphase
16​
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2not active
16​
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30maximize
16​
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30maximize
16​
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30maximize
16​
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30
100​
16​
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30
0​
16​
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30
0​
16​
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30
0​
16​
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30
2​
16​
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30
0​
16​
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 3036 - LED Kleinleistung
16​
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30Always
16​
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30Footwell lamp
16​
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30not active
16​
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30not active
16​
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30not active
16​
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30not active
16​
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30not active
16​
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30not active
16​
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30not active
16​
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31maximize
16​
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31maximize
16​
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31maximize
16​
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31
0​
16​
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31
0​
16​
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31
0​
16​
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31
0​
16​
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31
0​
16​
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31
0​
16​
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31not active
16​
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31Always
16​
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31not active
16​
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31not active
16​
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31not active
16​
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31not active
16​
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31not active
16​
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31not active
16​
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31not active
16​
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31not active
16​
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32maximize
16​
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32maximize
16​
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32maximize
16​
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32
0​
16​
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32
0​
16​
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32
0​
16​
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32
0​
16​
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32
0​
16​
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32
0​
16​
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32not active
16​
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32Always
16​
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32not active
16​
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32not active
16​
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32not active
16​
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32not active
16​
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32not active
16​
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32not active
16​
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32not active
16​
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32not active
16​
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33maximize
16​
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33maximize
16​
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33maximize
16​
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33
0​
16​
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33
0​
16​
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33
0​
16​
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33
0​
16​
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33
0​
16​
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33
0​
16​
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33not active
16​
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33Always
16​
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33not active
16​
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33not active
16​
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33not active
16​
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33not active
16​
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33not active
16​
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33not active
16​
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33not active
16​
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33not active
16​
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34maximize
16​
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34maximize
16​
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34maximize
16​
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34
0​
16​
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34
0​
16​
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34
0​
16​
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34
0​
16​
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34
0​
16​
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34
0​
16​
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34not active
16​
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34Always
16​
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34not active
16​
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34not active
16​
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34not active
16​
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34not active
16​
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34not active
16​
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34not active
16​
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34not active
16​
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34not active
16​
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3minimize
16​
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3maximize
16​
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3minimize
16​
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3
100​
16​
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3
25​
16​
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3
35​
16​
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3
0​
16​
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 34C
16​
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 34C
16​
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 34 - LED Tagfahrlichtmodul Signal
16​
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3Always
16​
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3Daytime running lamps
16​
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3Blinken rechts Dunkelphase
16​
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3not active
16​
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3not active
16​
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3Blinken rechts Hellphase
16​
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3not active
16​
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4maximize
16​
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4maximize
16​
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4minimize
16​
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4
32​
16​
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4
26​
16​
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4
127​
16​
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4
0​
16​
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4
49​
16​
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 43A
16​
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 41 - LED Tagfahrlichtmodul Versorgung
16​
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4Always
16​
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4Daytime running lamps
16​
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4Blinken links Dunkelphase
16​
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4not active
16​
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4not active
16​
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4Blinken links Hellphase
16​
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4not active
16​
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5minimize
16​
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5maximize
16​
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5minimize
16​
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5
32​
16​
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5
0​
16​
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5
127​
16​
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5
0​
16​
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 54B
16​
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5
44​
16​
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 51 - LED Tagfahrlichtmodul Versorgung
16​
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5Always
16​
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5Daytime running lamps
16​
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5Blinken rechts Dunkelphase
16​
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5not active
16​
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5not active
16​
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5Parking light right
16​
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5Blinken rechts Hellphase
16​
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5not active
16​
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6minimize
16​
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6maximize
16​
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6maximize
16​
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6
127​
16​
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6
0​
16​
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6
0​
16​
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6
0​
16​
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 61A
16​
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6
36​
16​
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 63 - Xenon Abblendlicht
16​
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6Always
16​
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6Abblendlicht links
16​
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6Lichthupe generell
16​
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6Coming Home oder Leaving Home aktiv
16​
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6not active
16​
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6not active
16​
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6not active
16​
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6not active
16​
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6not active
16​
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7minimize
16​
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7maximize
16​
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7maximize
16​
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7
127​
16​
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7
0​
16​
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7
0​
16​
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7
0​
16​
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 71B
16​
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7
40​
16​
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 73 - Xenon Abblendlicht
16​
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7Always
16​
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7Abblendlicht rechts
16​
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7Lichthupe generell
16​
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7Coming Home oder Leaving Home aktiv
16​
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7not active
16​
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7not active
16​
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7not active
16​
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7not active
16​
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7not active
16​
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8maximize
16​
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8maximize
16​
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8maximize
16​
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8
127​
16​
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8
127​
16​
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8
0​
16​
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8
0​
16​
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8
26​
16​
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8
35​
16​
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 836 - LED Kleinleistung
16​
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8Always
16​
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8Parklicht links (beidseitiges Parklicht aktiviert li & re)
16​
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8Daytime running lamps
16​
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8not active
16​
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8not active
16​
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8not active
16​
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8not active
16​
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8not active
16​
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9maximize
16​
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9maximize
16​
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9maximize
16​
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9
127​
16​
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9
127​
16​
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9
0​
16​
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9
0​
16​
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9
27​
16​
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 93F
16​
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 936 - LED Kleinleistung
16​
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9Always
16​
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
16​
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9Parking light right
16​
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9Daytime running lamps
16​
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9not active
16​
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9not active
16​
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9not active
16​
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9not active
16​
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9not active
16​
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck24 00 00 00 02 08 64 2A 00 64 03 00 80 00 00 00 24 18 00 18 04 08 7F 2A 00 64 00 05 80 00 00 00 23 00 00 00 18 02 7F 2A 00 64 03 00 80 00 09 7F 23 00 00 00 18 04 7F 2A 0A 64 05 00 80 00 0A 7F 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 00 00 00 08 09 7F 00 00 7F 00 00 00 00 00 00 2B 00 00 00 08 0A 7F 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 09 0C 00 2E 1A 00 E4 00 00 64 00 00 00 00 00 00 2B 00 00 53 08 00 7F 00 00 00 00 00 00 00 00 00 20 0B 00 31 19 1E 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 1E 7F 00 00 00 00 00 00 00 00 00
192​
ENG141662-Leuchtenkonfiguration_Sonstiges2B 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 64 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00
128​
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR2-Sensor LWR
62​
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges0 mm
62​
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampenot active
62​
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze
90.00%​
62​
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze
10.00%​
62​
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung-127.0 ms
62​
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz
15%​
62​
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe10.0 s
62​
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1-8.00 mm/%
62​
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2-8.00 mm/%
62​
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3-8.00 mm/%
62​
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1-8.00 mm/%
62​
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2-8.00 mm/%
62​
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3-8.00 mm/%
62​
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_VarianteVariante_1
62​
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR
0.00%​
62​
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf0.00 Hz
62​
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildungnormal
62​
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_SignalNegative
62​
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_10 mm
62​
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_20 mm
62​
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_30 mm
62​
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_40 mm
62​
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand0 mm
62​
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe0 mm
62​
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle
95.00%​
62​
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle
5.00%​
62​
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr0 km/h
62​
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr100 Hz
62​
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung0.00 Hz
62​
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_HoehenwerteBCM
62​
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installednot installed
62​
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlichtactive
62​
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese
20.00%​
62​
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstartnot active
62​
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad0.0 %/s
62​
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht
-100.00%​
62​
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbautHIM
62​
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR0.00 s
62​
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp12.0 s
7​
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang10 s
7​
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktionactive
7​
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logikactive
7​
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FASNicht_verbaut
7​
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Piloparknot active
7​
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze100 m
7​
ENG246957-ENG246981-Lichttaster-Lichttastermodullds
7​
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config
1​
7​
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle30 km/h
7​
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängignot active
7​
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameteractive
7​
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängigactive
7​
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängignot active
7​
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameteractive
7​
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängigactive
7​
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängignot active
7​
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1active
1​
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2active
1​
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3active
1​
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4active
1​
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5active
1​
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6active
1​
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typnot active
1​
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0
0.00%​
12​
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1
5.00%​
12​
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2
50.00%​
12​
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3
75.00%​
12​
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4
110​
12​
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5
126.5​
12​
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0
0.00%​
12​
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1
6.00%​
12​
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2
16.00%​
12​
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3
30.00%​
12​
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4
60.00%​
12​
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5
100.00%​
12​
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0
-5.00%​
20​
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1
-5.00%​
20​
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2
-5.00%​
20​
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3
-5.00%​
20​
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4
-5.00%​
20​
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0
-5​
20​
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1
-5​
20​
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2
-5​
20​
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3
-5​
20​
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4
-5​
20​
ENG122979-ENG141954-Networking-A/C electronicsinstalled
8​
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraetinstalled
8​
ENG122979-ENG141974-Networking-Bremsen_Steuergeraetinstalled
8​
ENG122979-ENG141953-Networking-Getriebesteuergeraetinstalled
8​
ENG122979-ENG99457-Networking-Head area heaternot installed
8​
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SGnot installed
8​
ENG124714-ENG142044-OCU-DWA_pushactive
8​
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfareactive
8​
ENG124714-ENG246970-OCU-IAA -Nutzer_managementinstalled
8​
ENG124714-OCU-installed
8​
ENG124714-ENG142261-OCU-Remote HuF Abbruch20 km/h
8​
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz3 Hz
8​
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s180 s
8​
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s32000 ms
8​
ENG124714-ENG125657-OCU-Remote_Unlock_LockVia ZV-Absicherung Light
8​
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbaractive
16​
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten
7​
16​
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnungnot active
16​
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbaractive
16​
ENG98831-ENG126848-Personalization-Personalisierung_aktivnot active
16​
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkionprofiles_inactive
16​
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbaractive
16​
ENG98831-ENG142030-Personalization-Profil_VarianteSchluessel
16​
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1active
16​
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2not active
16​
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3not active
16​
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4not active
16​
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbautNo
4​
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbautNo
4​
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegelnNo
4​
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbautNo
4​
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegelnNo
4​
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbautNo
4​
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegeltNo
4​
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbautNo
4​
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbautNo
4​
ENG141646-MAS01065-Querschnitts_funktionen-BrandVW
5​
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokollactive
5​
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigungactive
5​
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherungnot active
5​
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21active
5​
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_DrucktankklappenstatusPin A31
5​
ENG141646-ENG154685-Querschnitts_funktionen-HupeSollspannungsanforderung 13.5
5​
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgebenactive
5​
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahmenot_installed
5​
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystemnot active
5​
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignmentLeft
5​
ENG141646-ENG141965-Querschnitts_funktionen-Traffic sideRight
5​
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis5 km/h
8​
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max50 km/h
8​
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM1.5 s
8​
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMInot active
8​
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Washnot installed
8​
ENG122927-RLS_close_glazing2.0 s
1​
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off120 s
3​
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on10 s
3​
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off65 km/h
3​
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on140 km/h
3​
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle6000 lx
2​
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high
12​
2​
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low
6​
2​
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht30 s
2​
ENG122929-RLS_LIN_Communication4 s
1​
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn200 lx
1​
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day500 lx
1​
ENG122930-RLS_tunel_gateway_recognize5 s
1​
ENG122935-RLS_Washer_Front15 s
1​
ENG122926-RLS_wiper_position_parking15 s
1​
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung
10​
10​
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer systemnot installed
10​
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung
0​
10​
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangelactive
10​
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit2000 ms
10​
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit800 ms
10​
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit0 ms
10​
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit0 ms
10​
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit800 ms
10​
ENG115729-ENG154424-Scheinwerferreinigung-WaschenKeine_Spannungsanforderung
10​
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SGnot installed
4​
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer BlinkerMFG
4​
ENG116588-Sonderfunktionen-not enabled
4​
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1not installed
4​
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappenactive
5​
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modusby convenience operation via remote control key
5​
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappenactive
5​
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkungactive
5​
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellungnot active
5​
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegelactive
5​
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappungactive
5​
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrtactive
5​
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelungnot active
5​
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchronnot active
5​
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt
250​
10​
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel10 km/h
10​
ENG153700-ENG154803-Steering Column Switch-Verbauort_LenkstockschalterCAN
10​
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel1000 ms
10​
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen40 ms
10​
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x00.0 lx
10​
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X18.0 lx
10​
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X250.0 lx
10​
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X380.0 lx
10​
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4100.0 lx
10​
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0
6​
10​
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1
6​
10​
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2
20​
10​
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3
50​
10​
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4
100​
10​
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x00.0 lx
10​
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X18.0 lx
10​
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X250.0 lx
10​
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X380.0 lx
10​
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4100.0 lx
10​
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0
6​
10​
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1
6​
10​
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2
20​
10​
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3
50​
10​
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4
100​
10​
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x00 ms
22​
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1200 ms
22​
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x102000 ms
22​
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2400 ms
22​
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3600 ms
22​
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4800 ms
22​
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X51000 ms
22​
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X61200 ms
22​
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x71400 ms
22​
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x81600 ms
22​
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x91800 ms
22​
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0
100.00%​
22​
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1
100.00%​
22​
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10
0.00%​
22​
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2
95.00%​
22​
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3
80.00%​
22​
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4
40.00%​
22​
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5
20.00%​
22​
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6
10.00%​
22​
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7
5.00%​
22​
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8
3.00%​
22​
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9
1.00%​
22​
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM0.00 s
21​
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM0.00 s
21​
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM0.00 s
21​
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM0.00 s
21​
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM0.00 s
21​
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_SuchbeleuchtungHMI
21​
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen1.1 s
21​
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen0.0 s
21​
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampenot active
21​
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschaltenactive
21​
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtungactive
21​
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS
11​
21​
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM0.00 s
21​
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert
100%​
21​
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahlFotosensor_Kombi
21​
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung AktivierungAlways active
21​
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor
0.1​
21​
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert
6.00%​
21​
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0
0​
22​
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1
50​
22​
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10
0​
22​
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2
100​
22​
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3
200​
22​
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4
253​
22​
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5
0​
22​
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6
0​
22​
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7
0​
22​
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8
0​
22​
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9
0​
22​
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y00 lx
22​
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y150 lx
22​
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y100 lx
22​
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2100 lx
22​
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3
200​
22​
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4
500​
22​
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5
0​
22​
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y60 lx
22​
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y70 lx
22​
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y80 lx
22​
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y90 lx
22​
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x00 ms
22​
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1200 ms
22​
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x102000 ms
22​
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2400 ms
22​
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3600 ms
22​
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4800 ms
22​
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X51000 ms
22​
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X61200 ms
22​
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x71400 ms
22​
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x81600 ms
22​
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x91800 ms
22​
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0
0.00%​
22​
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1
1.00%​
22​
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10
100.00%​
22​
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2
3.00%​
22​
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3
5.00%​
22​
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4
11.00%​
22​
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5
22.00%​
22​
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6
40.00%​
22​
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7
80.00%​
22​
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8
95.00%​
22​
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9
100.00%​
22​
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x00 lx
8​
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X18 lx
8​
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X250 lx
8​
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3500 lx
8​
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0
100​
8​
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1
100​
8​
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2
100​
8​
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3
100​
8​
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x00 lx
8​
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X18 lx
8​
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X250 lx
8​
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3500 lx
8​
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0
6​
8​
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1
6​
8​
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2
100​
8​
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3
100​
8​
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0
0.00%​
12​
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1
6.00%​
12​
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2
16.00%​
12​
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3
30.00%​
12​
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4
60.00%​
12​
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5
100.00%​
12​
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0
10​
12​
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1
10​
12​
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2
100​
12​
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3
150​
12​
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4
220​
12​
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5
253​
12​
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x00 lx
10​
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X18 lx
10​
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2200 lx
10​
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3300 lx
10​
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4500 lx
10​
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0
16​
10​
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1
16​
10​
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2
100​
10​
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3
100​
10​
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4
100​
10​
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x00 lx
10​
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X18 lx
10​
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2220 lx
10​
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3300 lx
10​
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4500 lx
10​
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0
6​
10​
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1
6​
10​
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2
100​
10​
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3
100​
10​
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4
100​
10​
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0
0​
12​
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1
10​
12​
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2
50​
12​
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3
100​
12​
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4
220​
12​
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5
253​
12​
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0
2.00%​
12​
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1
2.00%​
12​
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2
6.00%​
12​
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3
10.00%​
12​
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4
80.00%​
12​
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5
100.00%​
12​
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x00 lx
8​
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X18 lx
8​
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X250 lx
8​
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3500 lx
8​
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0
6​
8​
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1
6​
8​
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2
100​
8​
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3
100​
8​
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x00 lx
8​
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X18 lx
8​
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X250 lx
8​
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3500 lx
8​
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0
100​
8​
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1
100​
8​
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2
100​
8​
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3
100​
8​
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0
0.00%​
6​
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1
50.00%​
6​
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2
100.00%​
6​
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0
0.00%​
6​
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1
50.00%​
6​
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2
100.00%​
6​
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x00 lx
12​
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1200 lx
12​
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2400 lx
12​
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3600 lx
12​
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4800 lx
12​
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X51020 lx
12​
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0
0​
12​
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1
84​
12​
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2
166​
12​
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3
250​
12​
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4
370​
12​
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5
500​
12​
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x00 ms
10​
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x12000 ms
10​
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x23000 ms
10​
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x34000 ms
10​
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x45100 ms
10​
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0
1.00%​
10​
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1
5​
10​
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2
15​
10​
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3
40​
10​
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4
100​
10​
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnenactive
4​
ENG141632-ENG116646-Sunroof-SAD Komfort schliessenactive
4​
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnentilting
4​
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1installed
4​
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3not installed
4​
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rolloinstalled
4​
ENG141632-ENG142022-Sunroof-Verortung SchiebedachmoduleLIN
4​
ENG141969-ENG249827-UGDO-Anlernblinkennot active
3​
ENG141969-ENG249832-UGDO-Bedienfeldnot installed
3​
ENG141969-ENG172987-UGDO-ugdo_transmitternot installed
3​
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurablenot active
3​
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdecknot_installed
9​
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeckactive
9​
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktivnot active
9​
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetriebnot active
9​
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_closenot installed
9​
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck globalactive
9​
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnenactive
9​
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließenactive
9​
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklaufactive
9​
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessenactive
9​
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerungnur wenn mind. 1 Raste zu
9​
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung sendenAlways
9​
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unitnot installed
9​
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedachnot active
9​
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienungactive
9​
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessyactive
9​
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinderactive
9​
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienungactive
9​
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessyactive
9​
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinderactive
9​
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedalactive
9​
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbarnot active
9​
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbaunot installed
9​
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_VersionVersion_1_2
9​
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 100 00
20​
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 200 00
20​
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 300 00
20​
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 400 00
20​
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 100 00
20​
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 200 00
20​
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 300 00
20​
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 400 00
20​
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 500 00
20​
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 600 00
20​
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation
5​
8​
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold30 s
8​
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation180 s
8​
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute
40​
3​
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute
60​
3​
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute
30​
3​
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFBnot active
7​
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_externactive
7​
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstasteractive
7​
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Einactive
7​
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 einnot active
7​
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direktnot installed
7​
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Tasternot installed
7​
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktionnot active
7​
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelungactive
7​
ENG141651-ENG115755-ZV allgemein-Notschließfunktionactive
7​
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessungnot active
7​
ENG141651-ENG141957-ZV allgemein-Radio freq.315MHz
7​
ENG141651-ENG141958-ZV allgemein-TankschlossBidirectional
7​
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_LaderaumFreigabe_Softtouch
7​
ENG141651-ENG116623-ZV allgemein-ZV TuerentriegelungEinzeltuerentriegelung
7​
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktioninstalled
7​
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heckactive
3​
ENG141654-ENG116621-ZV Autolock-automatisches Entriegelnactive
3​
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeitactive
3​
ENG141654-ENG116706-ZV Autolock-Autounlock NARactive
3​
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelungnot active
3​
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlocknot active
3​
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperrennot active
4​
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessennot active
4​
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrashnot active
4​
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckelsactive
7​
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgangnot active
7​
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktasternot active
7​
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentastervia_CAN
7​
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerungactive
7​
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungenactive
7​
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_VorrasteYes
7​
ENG141653-ENG141995-ZV Heck-Heckschloss_SteuerungContact control
7​
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster0.0 s
7​
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegeltnot active
7​
ENG141653-ENG141982-ZV Heck-Tausch_Tank_HecktreiberausgangYes
7​
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckelactive
7​
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfennot active
7​
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp1 or 2 notch rear actuator
7​
ENG141681-IDE02021-ZV Komfort-Comfort closingactive
8​
ENG141681-IDE02022-ZV Komfort-Comfort openingactive
8​
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hintenYes
8​
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnenactive
8​
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessenactive
8​
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit600 s
8​
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 ausactive
8​
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechenactive
8​
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnenactive
8​
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessenactive
8​
ENG141681-ENG115670-ZV Komfort-Komfortbedienung globalactive
8​
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuernot active
8​
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbaradjustable
8​
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessennot active
8​
ENG141681-ENG125656-ZV Komfort-Regenschliessen_artonce
8​
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_ausnot active
8​
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnennot active
8​
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessennot active
8​
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss2-Motorenschloesser
5​
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignalnicht invertiert
5​
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseitenot installed
5​
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseitenot installed
5​
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_linksNo
5​
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechtsNo
5​
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafternot installed
5​
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCMDriver side
5​
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappenot active
5​
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NARYes
5​
ENG141652-ENG141959-ZV Türkonfiguration-ViertuererYes
5​
Elapsed Time: 02:30
Toluxo
Mexico
Golf MK7
Gotcha, both your BCM and Gateway should be capable of ambient colors on infotainment and dash. Can you post an adaptation map of your BCM
Code:
Preferably in Code tags like this, keeps the thread easy to scroll.
  • adpmap-09-5Q0-937-085-CF_3VWFA7AU3G-20230209-1928.zip
Cuzoe
@Toluxo First try this... 19 - Gateway > Long Coding Helper (select "Yes" to use experimental) > FPA_Funktion_AMB needs to be checked... Byte 11 Bit 7
Everything looks okay in your BCM ad-map I think. The only thing I saw that was different from mine is
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI... You have "active" where I have "not active"
... the translation of this doesn't make much sense to me but I would change it, if only because my AID/Dash colors change and yours don't.
*** I would only worry about this BCM adaptation if changing the gateway long coding does not work ***
