Retrofit of facelift BCM into pre-facelift Mk7 (in progress, please help 😬)
DV52
Australia
....................... the turn signals doesn't works
hmm........ which turn signals (front, or rear)?
According to my BCM compare spreadsheet - it looks like someone has attempted to code US style turn-signals into the new BCM. Unfortunately - I can't understand the coding changes (they look wrong)!!
In any event, it appears that this car has incandescent turn-signal lamps in the headlight fittings (because Dimmwert AB = 100). I would caution against enabling US style turn-signals on a car that has incandescent turn-signal lamps. The turn-signal lamp bases in these cars are rated for operation of what engineers call "50% duty cycle". This is because the turn-signal only illuminates 50% of the time.
When you enable US style turn-signals, the lamp illuminates 100% of the time (in this car, when the low-beams are switched-ON). The rating equation for electrical devices says that power is proportional to the square of electrical current. So, doubling current from 50% duty cycle to 100% results in a four-fold increase in power flow!!
So, the "US style turn-signal tweak" will force 400% more power to flow through a lamp holder that was designed for 50% Duty Cycle operation - not good!!
Bottom line= while US style turn-signal is OK for LED lamps (because of the low current needs of these devices), incandescent lamp holders on the turn-signal fitting will overheat and will eventually fail
My suggestion is that you revert the channel settings with the ID numbers in my spreadsheet below back to Old Setting values. This will disable US style turn-signal - but it should resolve your turn-signal problem ( I think)
Code:
ID
729
720
733
734
718
919
910
923
908
Don
Toluxo
Mexico
Golf MK7
Code:
ID
729
720
733
734
718
919
910
923
908
Don
THANK YOU VERY MUCH, my car is made for North America Market (NAR), equipped with Xenon headlamps and led taillamps, now the car open and close, have the turn signals working, close the car with the hand in the handle door, but not be opened with the hand in the door, the trunk can't be opened with the kessy in the pocket, is necessary to press the trunk open button, the fob works (lock and unlock) from a distance near to 45 ft.
The Current admap is attached here.
the 09 have this intermittent dtc's
Code:
Thursday,16,February,2023,23:07:48:25289
VCDS Version: Release 22.10.0 (x64) Running on Windows 10 x64
www.Ross-Tech.com
                Address 09: Cent. Elect.       Labels: 5Q0-937-08X-V2.clb
Control Module Part Number: 5Q0 937 085 CF    HW: 5Q0 937 085 CF
  Component and/or Version: BCM MQBAB MNA H42 0411
           Software Coding: 000000000000000000000000000000000000000000000000000000000000
            Work Shop Code: WSC 03743 444 00001
              ASAM Dataset: EV_BCMMQB 021001 (VW37)
                       ROD: EV_BCMBOSCH_021_VW27.rod
                      VCID: 7F5B0154377B5063928-802A
2 Faults Found:
202506 - Motor for Central Locking of Rear Trunk/Hatch
          B12DD 15 [009] - Open or Short to Plus
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 9
                    Date: 2000.00.00
                    Time: 00:00:00
                    Terminal 15 status: OFF
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: no cause for fault protection
                    Voltage: 12.2 V
                    Outside temperature: 20.5 °C
233497 - Remote key 2
          B147A F1 [008] - Suppressed Opening Procedure
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 49
                    Mileage: 20039 km
                    Date: 2023.02.16
                    Time: 23:03:46
                    CAN-Bus_aktiv: On
                    OFF: operated
                    Voltage: 12.3 V
  • adpmap-09-5Q0-937-085-CF_3VWFA7AU3-20230216-2308.zip
DV52
Australia
@Toluxo : I have no idea what you are saying!!! I was responding to your "turn signals doesn't work" statement and you are telling me that this (NAR) car has "Xenon headlamps and led taillamps".
It really doesn't matter what type of Main/high beam lights are installed in this car - or what type of tail-light fittings it has! None of this information has ANY impact on the type of lamps in the front turn-signal lights!!
Your latest admap confirms that the BCM still believes that 2 x front turn-signal lights are incandescent lamps. I note that the US style turn-signal function on your new admap has Dimmwert CD=50. This will ameliorate the lamp base over-heatng problem in my previous post (it restores the 50% Duty cycle design criteria).
But the repeated Blinken links Dunkelphase command on Leuchte 0 BLK VL B36-Lichtfunktion H 0 is just plain wrong!!
Don
DV52
Australia
@wamba16 : When you say "I change BCM VW golf 7 2014 5Q0937084AA to 5Q0937084DD" - how did you set-up the coding values in the new module?
I assume that the original BCM in a MY14 Golf had an active long-code string, But I suspect that the "DD" dataset version has the newer adaptation channel database without a long-code facility.
So - how did you transfer the factory-set software switch positions in long-code from the old BCM (in particular, Byte 7) into the adaptation channel values on the new BCM (in particular, the Außenlicht_uebergreifend-LDS group of channels)?
And, is the setting for Außenlicht_uebergreifend-Lichtdrehschalter (LDS) = LIN on the new module?
Don
DV52
Australia
yes normally all coding in adaptation is correct
and Außenlicht_uebergreifend-Lichtdrehschalter (LDS) = discreet same long coding in byte 7
hmm...... I don't believe that your conviction above is "correct"!! Let's try doing this another way - by going back to basics!!
The software switches that tell the BCM what type of rain-light sensor is installed ain't "long coding in byte 7" - it's actually on Byte 06, specifically on Bit 0-1.
From your admap - the long-code string on your old BCM = 00151A46C04122FB0BA44080B10C0720180A00000000
So, the highlighted Byte 06 = Hex22 = Binary 00100010.
Remembering that Binary values are read from right-to-left, Byte 06, Bit 0-1 (see highlighted digits) = hex02. This is the normal set-up for a factory installed rain-light (humidity?) sensor on MQB platform cars like a Golf mk7/mk7.5.
As shown on my table below - hex02 means LIN_REGEN_Light_SENSOR
ByteBitFunctionValue
060-1Rain Light SensorNot Installed =hex00
Discrete=hex01
LIN_Rain_Sensor=hex02
Again, I repeat (tautology intentional) - try my earlier suggestion
"Außenlicht_uebergreifend-Lichtdrehschalter (LDS) = LIN on the new module?"
Don
PS: the additional matter (which we haven't discussed) for a correctly operating rain-light (humidity?) sensor is the long-code value on the device, itself. As you might be aware (and as I hope you will now agree) the sensor on this car is a LIN device meaning that it uses a single wire communication protocol. The LIN master for these messages is the BCM - so the sensor is a "slave" (in VCDS speak - it's a "subsystem" in OBD11 language) to the hex09 module. If you have further problems after implementing my proposal above - I suggest that you post-up the sensor long-code string
Cuzoe
I have to admit I'm confused by this suggestion, keeping in mind that I speak no German...
Google alleges that Außenlicht_uebergreifend-Lichtdrehschalter (LDS) translates to "Outside light General rotary light switch"
Our rotary switch uses discretes so shouldn't this value be discrete? The rain light sensor is a different matter of course, but it's not clear to me that this adaptation has anything to do with that. Wjen able to get to my computer I can look through my current ad-map to see what channels dealt with RLS.
For what it's worth I have auto headlights and this channel is set to discrete. Everything works.
DV52
Australia
@Cuzoe and @wamba16 - I think that I owe both of you an apology!! My bad! You are both correct and I have erred!! .
The channel Außenlicht_uebergreifend-Lichtdrehschalter (LDS) does indeed refer to the communication method for the actual rotary light switch.
On some MQB platform cars, like a Golf mk7, this is a dumb device with a loom containing multiple wires that terminate on the BCM and on other cars, (like an Audi A3, 8V) this is a LIN device with a single wire. I incorrectly used an A3 admap when responding!
So yes, you are both correct. The first part of my previous response about the long-code string for the old BCM was correct . These software switches from the old BCM translate to the following channel on the new BCM:
  • IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor>LIN_REGEN_LICHT_SENSOR
The admap for the new BCM shows that the channel above is correctly coded
Again, my apology to you both - I had a brain-fart!!:cry:
Don
PS: I will amend my wrong advice so as not to confuse others reading this post!
Cuzoe
@DV52.. no worries over here. Can I retrofit that LIN connected switch? Pointless no doubt... but I'm looking for low hanging fruit that can be done without putting the car "down" for maintenance 😁.
Although I suppose if I'm being honest I'm more interested in the Mk8 Golf light switch (touch buttons). It's not like I ever touch the light switch anyway. And either will require some dash modification. And the Mk8 switch has the defrost options on it, hmm?
DV52
Australia
hmm........ I agree with your thinking - why would you want to change the comms method for the LDS (seems like a lot of work for very little return!)?
The same series BCM is used on a range of MQB platform cars - but I would think that whether the module supports LIN based LDS would be dependent on the dataset version (I was using 5Q0-937-084-CG for my wrong advice - so this module does support LIN based LDS)
I assume (guess really) that VAG chooses to use the LIN based device to save on the cost of copper in their Audis
As for the Mk8 version LDS - that's an entirely different matter!! Retrofitting MQB-evo platform equipment onto a MQB platform car isn't impossible - but it would have to be problematic, IMO!
Don
DV52
Australia
@wamba: Hi.
I assume that this car is fitted with a low-line RVC. Here is the wiring diagram for a low-line RVC:
Notice the connection of the RVC to the BCM (which is "J519" in my picture). Pin #64, socket A (circled) is the pin that triggers the logo-gate to open and the RVC to operate when reverse gear is selected. And it is also the pin that powers the right-side reverse light on the tails.
However, because you say that both reverse lights don't illuminate (as well as the RVC), my hunch is that this could be a case of the BCM not seeing the change in status of the reverse-switch, I guess.
In respect of this being a coding matter, AFAIK there isn't a specific software switch that tells the BCM to recognize the changed status of the reverse switch. I suspect that this absence is because ALL BCMs on these cars have a reverse-switch. I suggest that you check if the Leuchte-sets for the left/right reverse lights are active- these are:
  • Leuchte28RFL LC11 (left-side)
  • Leuchte29RFL RA64 (right-side)
I'm not sure what type lamps are fitted to the reverse lights on this car (LED, or incandescent) - so I can't give you specific values for the Leuctche channels. If you suspect a problem with the Leuchte-sets, post-up details of the existing channel values for one car-side - please
But, this might not be a coding problem - If indeed this is a physical problem, then there probably wouldn't be an error message on the BCM (I think). This is likely to be so because the BCM probably doesn't receive any CAN messages about reverse gear - its total understanding about whether reverse gear is selected comes from the physical transmission switch. Therefore - if the physical switch, or the wire termination on the BCM pin is faulty - the BCM will just assume that the car isn't in reverse gear and it won't operate the reverse lights, or the RVC (which is EXACTLY what has happened to this car) - and there will be NO error messages!!
So- the reverse-switch on these cars is a simple, normally-open, single-pole, single-throw switch. It is connected via a fuse to battery volts on one of the switch contacts and it switches +volts onto pin #11, socket B on the BCM when reverse gear is selected.
Maybe grab a multi-meter and check that the BCM pin is receiving battery volts when the car is in reverse gear (hand-brake applied, of course if this car is fitted with auto-transmission)?
Don
david.Golf
Sweden
Golf 7 GTE Hybrid
Hello and thanks for your post. I have a Golf 7 GTE 2015 and i have done the facelift oem headlight upgrade and i installed all the wires and module 4B . But when i came to the adaptation part then theres is missing parts or channels related to enabling the LCM ( 4b) module to control the lights and other channels also missing. Do i have to upgrade to 7.5 BCM or as i understood that i will found them in coding section ??
My current bcm is 5Q0937084AJ
MQBAB H
And the one ism planning to install is 5Q0937084DG
is there any thing to consider before doing the upgrade ?
since i have upgraded the headlights do i HAVE TO upgrade the bcm as well ?
Thanks.
david.Golf
Sweden
Golf 7 GTE Hybrid
MQBAB H
Thanks.
malison
Hungary
Golf MK7
Hello Guys,
I'm fighting with the adaptation of the facelifted BCM since a year, please help me!
My car has a factory adaptive xenon with only one "U" daytime running light +a lighting dot / side (so these are not Golf R lamps, they doesn't have dynamic indicator).
I retrofitted original facelifted "high" lamps to the rear. With the original BCM everything is working fine, but with the facelifted I have a "526615 U101400 Control module coded incorrectly" error in the BCM, and "Fault: vehicle lighting" on the dash.
Every lighting working fine, but I have this error. In case of the old BCM I used a tutorial for coding of the rear light.
One of my friend has same rear lights in his facelifted Golf, I tried his adaptations as well, but the situation is same with that adaptation. So I think that I have to modify the front light's adaptation.
Do you have any idea what's wrong?
Thank you in advance,
Code:
SW:5Q0-937-084-BR   HW:5Q0-937-084-AE ---  Cent. Elect.
Component:BCM MQBAB H   H16 0138, Coding:00010E46C24122FB4BE44000B11C07281C00000000000000000000000000
EV_BCMCONTI,013000,EV_BCMBOSCH_013.rod
IDE00001-ENG99061-Production mode-Access control,not active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not active ,3
IDE00001-ENG98647-Production mode-Interior lighting,not active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,3
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,3
IDE00002-Transport mode,active ,1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active ,12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,5 ,12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active ,12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active ,12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,active ,12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating ,12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active ,12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms,12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,320 ms,12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms,12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms,12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,320 ms,12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active ,12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active ,12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,not active ,12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0 ,12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,not active ,12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active ,12
IDE01550-Service position,170.49 °,2
IDE02152-Characteristics in production mode,2000 ms,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,4
IDE02332-Deactivate production mode,0 ,3
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active ,8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,50 %,8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,100 %,8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,50 %,8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,Enabled ,8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed ,8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,-63.75 °,14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.00 %/s,14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,double sided ,14
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.00 km/h,14
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.00 °C,14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.00 °C,14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.00 °C,14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,180 °,14
IDE03638-ENG116676-static AFS light-Upper speed threshold,40.00 km/h,14
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte ,8
IDE04923-ENG115774-Turn signal control-Komfortblinken,active ,8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3 ,8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,MFG ,8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled ,8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active ,8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10 ,8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,10.00 %,8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,350 km/h,14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,350 km/h,14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,not active ,14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig ,14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h,14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided ,14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,active ,14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active ,14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active ,14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active ,14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min,14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam ,8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,manual ,8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door ,8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx,8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx,8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled ,8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 seconds ,8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active ,8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP,active ,8
IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C,8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C,8
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,4
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln,active ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,not active ,8
IDE05142-ENG116706-Access control-Autounlock NAR,not active ,8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active ,8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active ,8
IDE05142-ENG115722-Access control-Electrical rear lid,not active ,8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active ,8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active ,8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,8
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung,not active ,8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active ,8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable ,8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,8
IDE05142-ENG115755-Access control-Notschließfunktion,active ,8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always ,8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always ,8
IDE05142-ENG115758-Access control-Valet Parking,not active ,8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active ,8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active ,8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active ,8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active ,8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active ,8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung ,8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active ,8
IDE05144-Read parameter address,00 00 00 ,3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0,34 ,560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1,3E ,560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10,00 ,560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11,00 ,560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12,38 ,560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13,42 ,560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14,00 ,560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15,00 ,560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16,08 ,560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17,18 ,560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18,00 ,560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19,00 ,560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2,48 ,560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20,10 ,560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21,20 ,560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22,29 ,560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23,0A ,560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24,1A ,560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25,28 ,560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26,1C ,560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27,00 ,560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28,0B ,560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29,1B ,560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3,4C ,560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30,00 ,560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31,00 ,560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32,00 ,560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33,00 ,560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34,00 ,560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4,3A ,560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5,44 ,560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6,36 ,560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7,40 ,560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8,35 ,560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9,3F ,560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize ,560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize ,560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize ,560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize ,560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize ,560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize ,560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize ,560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize ,560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize ,560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize ,560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize ,560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize ,560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize ,560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize ,560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize ,560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize ,560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize ,560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize ,560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize ,560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize ,560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize ,560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize ,560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize ,560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize ,560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize ,560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize ,560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize ,560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize ,560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize ,560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize ,560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize ,560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize ,560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize ,560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize ,560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize ,560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize ,560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize ,560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize ,560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize ,560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize ,560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize ,560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize ,560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize ,560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize ,560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize ,560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize ,560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize ,560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize ,560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize ,560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize ,560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize ,560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize ,560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize ,560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize ,560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize ,560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize ,560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize ,560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize ,560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize ,560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize ,560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize ,560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize ,560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize ,560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize ,560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize ,560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize ,560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize ,560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize ,560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize ,560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize ,560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize ,560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize ,560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize ,560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize ,560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize ,560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize ,560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize ,560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize ,560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize ,560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize ,560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize ,560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize ,560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize ,560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize ,560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize ,560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize ,560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize ,560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize ,560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize ,560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize ,560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize ,560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize ,560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize ,560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize ,560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize ,560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize ,560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize ,560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize ,560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize ,560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize ,560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize ,560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize ,560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize ,560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize ,560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize ,560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100 ,560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100 ,560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,0 ,560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,0 ,560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100 ,560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100 ,560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0 ,560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0 ,560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,127 ,560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,127 ,560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,127 ,560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,127 ,560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,100 ,560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,127 ,560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,127 ,560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100 ,560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,127 ,560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,127 ,560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,127 ,560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,127 ,560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,127 ,560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,127 ,560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,127 ,560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,100 ,560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,89 ,560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,0 ,560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,0 ,560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,0 ,560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,0 ,560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127 ,560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127 ,560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127 ,560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127 ,560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,127 ,560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,127 ,560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0 ,560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0 ,560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0 ,560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0 ,560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0 ,560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0 ,560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0 ,560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0 ,560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0 ,560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0 ,560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0 ,560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0 ,560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,26 ,560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0 ,560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0 ,560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0 ,560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,127 ,560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,127 ,560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0 ,560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0 ,560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0 ,560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0 ,560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0 ,560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,26 ,560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0 ,560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0 ,560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0 ,560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0 ,560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0 ,560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127 ,560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127 ,560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,0 ,560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,0 ,560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0 ,560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0 ,560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0 ,560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0 ,560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0 ,560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0 ,560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0 ,560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0 ,560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0 ,560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0 ,560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0 ,560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0 ,560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0 ,560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0 ,560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,0 ,560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0 ,560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0 ,560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0 ,560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0 ,560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0 ,560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0 ,560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0 ,560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0 ,560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0 ,560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0 ,560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,0 ,560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0 ,560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0 ,560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0 ,560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0 ,560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0 ,560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,0 ,560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,0 ,560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0 ,560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0 ,560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0 ,560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0 ,560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0 ,560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0 ,560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0 ,560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0 ,560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0 ,560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0 ,560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0 ,560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0 ,560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0 ,560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0 ,560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0 ,560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0 ,560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0 ,560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0 ,560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0 ,560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0 ,560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0 ,560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0 ,560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0 ,560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0 ,560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0 ,560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0 ,560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0 ,560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0 ,560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0 ,560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0 ,560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0 ,560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0 ,560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0 ,560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0 ,560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0 ,560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0 ,560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0 ,560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0 ,560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0 ,560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0,14 ,560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1,15 ,560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10,00 ,560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11,00 ,560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12,22 ,560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13,23 ,560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14,00 ,560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15,00 ,560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16,16 ,560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17,18 ,560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18,41 ,560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19,42 ,560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2,4A ,560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20,39 ,560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21,3A ,560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C ,560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23,29 ,560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24,2A ,560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25,30 ,560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26,2F ,560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27,47 ,560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28,31 ,560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29,32 ,560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3,4C ,560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30,02 ,560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31,00 ,560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32,00 ,560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33,00 ,560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34,00 ,560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4,49 ,560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5,4B ,560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6,1A ,560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7,1B ,560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8,26 ,560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9,27 ,560
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten ,560
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten ,560
IDE05145-ENG116062-Light configuration-Lasttyp 10,not active ,560
IDE05145-ENG116081-Light configuration-Lasttyp 11,not active ,560
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer ,560
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active ,560
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active ,560
IDE05145-ENG116176-Light configuration-Lasttyp 16,38 - LED Blinkleuchten ,560
IDE05145-ENG116195-Light configuration-Lasttyp 17,38 - LED Blinkleuchten ,560
IDE05145-ENG116214-Light configuration-Lasttyp 18,38 - LED Blinkleuchten ,560
IDE05145-ENG116233-Light configuration-Lasttyp 19,38 - LED Blinkleuchten ,560
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116252-Light configuration-Lasttyp 20,43 - allgemeine LED ,560
IDE05145-ENG116271-Light configuration-Lasttyp 21,43 - allgemeine LED ,560
IDE05145-ENG116290-Light configuration-Lasttyp 22,42 - LED dritte Bremsleuchte ,560
IDE05145-ENG116309-Light configuration-Lasttyp 23,43 - allgemeine LED ,560
IDE05145-ENG116328-Light configuration-Lasttyp 24,43 - allgemeine LED ,560
IDE05145-ENG116347-Light configuration-Lasttyp 25,43 - allgemeine LED ,560
IDE05145-ENG116366-Light configuration-Lasttyp 26,43 - allgemeine LED ,560
IDE05145-ENG116385-Light configuration-Lasttyp 27,36 - LED Kleinleistung ,560
IDE05145-ENG116404-Light configuration-Lasttyp 28,43 - allgemeine LED ,560
IDE05145-ENG116423-Light configuration-Lasttyp 29,43 - allgemeine LED ,560
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,560
IDE05145-ENG116442-Light configuration-Lasttyp 30,36 - LED Kleinleistung ,560
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active ,560
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active ,560
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active ,560
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active ,560
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,560
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht ,560
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht ,560
IDE05145-ENG116024-Light configuration-Lasttyp 8,36 - LED Kleinleistung ,560
IDE05145-ENG116043-Light configuration-Lasttyp 9,36 - LED Kleinleistung ,560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always ,560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always ,560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always ,560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always ,560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always ,560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always ,560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always ,560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always ,560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,only_if_closed ,560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,only_if_closed ,560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always ,560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always ,560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always ,560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always ,560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always ,560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always ,560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always ,560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always ,560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always ,560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,only_if_closed ,560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always ,560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,only_if_closed ,560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,only_if_closed ,560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always ,560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always ,560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always ,560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always ,560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always ,560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always ,560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always ,560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always ,560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always ,560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always ,560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always ,560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always ,560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17,0 ,560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13,0 ,560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2 ,560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4 ,560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,0 ,560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,0 ,560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18 ,560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19 ,560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0 ,560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0 ,560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,2 ,560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,4 ,560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2 ,560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4 ,560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,20 ,560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24 ,560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24 ,560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24 ,560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8 ,560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8 ,560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8 ,560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,27 ,560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,37 ,560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25 ,560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25 ,560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,20 ,560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43 ,560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,0 ,560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,0 ,560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,0 ,560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,0 ,560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,20 ,560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,20 ,560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11 ,560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12 ,560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,8 ,560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,8 ,560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0 ,560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0 ,560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,0 ,560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,0 ,560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,22 ,560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,23 ,560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0 ,560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0 ,560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,0 ,560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0 ,560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0 ,560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,0 ,560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0 ,560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0 ,560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0 ,560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,33 ,560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,33 ,560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,0 ,560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0 ,560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0 ,560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0 ,560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0 ,560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,0 ,560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0 ,560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0 ,560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0 ,560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0 ,560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0 ,560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,0 ,560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,0 ,560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15 ,560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15 ,560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,9 ,560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,10 ,560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0 ,560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0 ,560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0 ,560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0 ,560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0 ,560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0 ,560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0 ,560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0 ,560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0 ,560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0 ,560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0 ,560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,8 ,560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0 ,560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0 ,560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0 ,560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,20 ,560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,20 ,560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0 ,560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0 ,560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0 ,560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0 ,560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0 ,560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,8 ,560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0 ,560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0 ,560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0 ,560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0 ,560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0 ,560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,8 ,560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,8 ,560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,0 ,560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,0 ,560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0 ,560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0 ,560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0 ,560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0 ,560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0 ,560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0 ,560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0 ,560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0 ,560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0 ,560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0 ,560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0 ,560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0 ,560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0 ,560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0 ,560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,9 ,560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0 ,560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0 ,560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0 ,560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,9 ,560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,10 ,560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0 ,560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0 ,560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0 ,560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0 ,560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0 ,560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,10 ,560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0 ,560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0 ,560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0 ,560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0 ,560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0 ,560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,9 ,560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,10 ,560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0 ,560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0 ,560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0 ,560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0 ,560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0 ,560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0 ,560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0 ,560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0 ,560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0 ,560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0 ,560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0 ,560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0 ,560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0 ,560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0 ,560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0 ,560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0 ,560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,0 ,560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,0 ,560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,0 ,560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0 ,560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0 ,560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0 ,560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0 ,560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0 ,560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0 ,560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0 ,560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0 ,560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,0 ,560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0 ,560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0 ,560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0 ,560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0 ,560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0 ,560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,0 ,560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,0 ,560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0 ,560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0 ,560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0 ,560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0 ,560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0 ,560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0 ,560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0 ,560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0 ,560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0 ,560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0 ,560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0 ,560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0 ,560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0 ,560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0 ,560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0 ,560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0 ,560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0 ,560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0 ,560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0 ,560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0 ,560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0 ,560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0 ,560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0 ,560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0 ,560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0 ,560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0 ,560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0 ,560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0 ,560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0 ,560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0 ,560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0 ,560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0 ,560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0 ,560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0 ,560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0 ,560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0 ,560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0 ,560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0 ,560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0 ,560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0 ,560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0 ,560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0 ,560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0 ,560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0 ,560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0 ,560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0 ,560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0 ,560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0 ,560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0 ,560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0 ,560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0 ,560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0 ,560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0 ,560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0 ,560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0 ,560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0 ,560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0 ,560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0 ,560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0 ,560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0 ,560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0 ,560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0 ,560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0 ,560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0 ,560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0 ,560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0 ,560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0 ,560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0 ,560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0 ,560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0 ,560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0 ,560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0 ,560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0 ,560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0 ,560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0 ,560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0 ,560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0 ,560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0 ,560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0 ,560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0 ,560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0 ,560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0 ,560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0 ,560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0 ,560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0 ,560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0 ,560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0 ,560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0 ,560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0 ,560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0 ,560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0 ,560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0 ,560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0 ,560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0 ,560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0 ,560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0 ,560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0 ,560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0 ,560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0 ,560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0 ,560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0 ,560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0 ,560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0 ,560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0 ,560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0 ,560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0 ,560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0 ,560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0 ,560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0 ,560
IDE05145-ENG154438-Light configuration-Reserved 0,0 ,560
IDE05145-ENG99841-Light configuration-Reserved 1,0 ,560
IDE05145-ENG154357-Light configuration-Reserved 10,0 ,560
IDE05145-ENG154352-Light configuration-Reserved 11,0 ,560
IDE05145-ENG154182-Light configuration-Reserved 12,0 ,560
IDE05145-ENG154265-Light configuration-Reserved 13,0 ,560
IDE05145-ENG154334-Light configuration-Reserved 14,0 ,560
IDE05145-ENG154340-Light configuration-Reserved 15,0 ,560
IDE05145-ENG154204-Light configuration-Reserved 16,0 ,560
IDE05145-ENG154344-Light configuration-Reserved 17,0 ,560
IDE05145-ENG154195-Light configuration-Reserved 18,0 ,560
IDE05145-ENG154190-Light configuration-Reserved 19,0 ,560
IDE05145-ENG99862-Light configuration-Reserved 2,0 ,560
IDE05145-ENG154300-Light configuration-Reserved 20,0 ,560
IDE05145-ENG154439-Light configuration-Reserved 21,0 ,560
IDE05145-ENG154440-Light configuration-Reserved 22,0 ,560
IDE05145-ENG154441-Light configuration-Reserved 23,0 ,560
IDE05145-ENG154442-Light configuration-Reserved 24,0 ,560
IDE05145-ENG154443-Light configuration-Reserved 25,0 ,560
IDE05145-ENG154444-Light configuration-Reserved 26,0 ,560
IDE05145-ENG154445-Light configuration-Reserved 27,0 ,560
IDE05145-ENG154446-Light configuration-Reserved 28,0 ,560
IDE05145-ENG154447-Light configuration-Reserved 29,0 ,560
IDE05145-ENG101107-Light configuration-Reserved 3,00 ,560
IDE05145-ENG154448-Light configuration-Reserved 30,0 ,560
IDE05145-ENG154449-Light configuration-Reserved 31,0 ,560
IDE05145-ENG154450-Light configuration-Reserved 32,0 ,560
IDE05145-ENG154451-Light configuration-Reserved 33,0 ,560
IDE05145-ENG154452-Light configuration-Reserved 34,0 ,560
IDE05145-ENG154267-Light configuration-Reserved 4,0 ,560
IDE05145-ENG154291-Light configuration-Reserved 5,0 ,560
IDE05145-ENG154239-Light configuration-Reserved 6,0 ,560
IDE05145-ENG154308-Light configuration-Reserved 7,0 ,560
IDE05145-ENG154184-Light configuration-Reserved 8,0 ,560
IDE05145-ENG154255-Light configuration-Reserved 9,0 ,560
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 42 29 85 ,172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,22.50 °C,24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,21.50 °C,24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.00 °C,24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.50 °C,24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active ,8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM,not active ,8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,active ,8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active ,8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active ,8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,100 %,8
IDE06425-Roller test bench mode: functional,not active ,1
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights ,4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active ,4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active ,4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active ,4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,4
IDE07356-Position during interval mode,31.49 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit ,12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,12
IDE08542-IDE02021-Access control 2-Comfort closing,active ,8
IDE08542-IDE02022-Access control 2-Comfort opening,not active ,8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active ,8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active ,8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s,8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active ,8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active ,8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active ,8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key ,8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active ,8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active ,8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active ,8
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active ,8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,active ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,active ,8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active ,8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active ,8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,active ,8
IDE08542-ENG125656-Access control 2-Regenschliessen_art,Permanent ,8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,active ,8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not active ,8
IDE08542-ENG154261-Access control 2-Reserved_4,not active ,8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active ,8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active ,8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active ,8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting ,8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,not active ,8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,not active ,8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active ,8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,active ,8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active ,8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active ,8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active ,8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms,8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active ,8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active ,8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms,8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active ,8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,present ,8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active ,8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active ,8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active ,2
IDE08787-ENG101416-Auxiliary functions-Reserved_1,not active ,2
IDE08787-ENG99458-Auxiliary functions-Reserved_2,not active ,2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active ,2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active ,2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active ,2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active ,4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,active ,4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active ,4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active ,4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active ,4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active ,4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,active ,4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,active ,4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active ,4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active ,4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active ,4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active ,4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active ,4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active ,4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active ,4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active ,4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active ,4
IDE09595-ENG115658-Characteristic curve-x0,0 lx,18
IDE09595-ENG101574-Characteristic curve-X1,2000 lx,18
IDE09595-ENG99557-Characteristic curve-X2,4000 lx,18
IDE09595-ENG102140-Characteristic curve-X3,6000 lx,18
IDE09595-ENG102936-Characteristic curve-X4,8000 lx,18
IDE09595-ENG103548-Characteristic curve-X5,10200 lx,18
IDE09595-ENG148955-Characteristic curve-y1_0,0 ,18
IDE09595-ENG148956-Characteristic curve-y1_1,40 ,18
IDE09595-ENG148957-Characteristic curve-y1_2,90 ,18
IDE09595-ENG148958-Characteristic curve-y1_3,140 ,18
IDE09595-ENG148959-Characteristic curve-y1_4,190 ,18
IDE09595-ENG148960-Characteristic curve-y1_5,245 ,18
IDE09595-ENG148961-Characteristic curve-y2_0,0 ,18
IDE09595-ENG148962-Characteristic curve-y2_1,60 ,18
IDE09595-ENG148963-Characteristic curve-y2_2,110 ,18
IDE09595-ENG148964-Characteristic curve-y2_3,160 ,18
IDE09595-ENG148965-Characteristic curve-y2_4,210 ,18
IDE09595-ENG148966-Characteristic curve-y2_5,255 ,18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225 ,20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225 ,20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225 ,20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225 ,20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225 ,20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225 ,20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active ,20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,active ,20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225 ,20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225 ,20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225 ,20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,active ,20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,installed ,2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,installed ,2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,installed ,2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed ,2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung,3000 ms,10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit,1000 ms,10
IDE09733-ENG147405-LED bar setting values-Lockout time,0 s,10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige,0 s,10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz,25 ,10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor,0 ,10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS,393210 lx,10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS,393210 lx,10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,12
IDE10298-Alternating park position 1,7.49 °,2
IDE10299-Alternating park position 2,29.49 °,2
MAS05055-lower turn position,31.49 °,2
MAS05056-upper turn position,170.49 °,2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,not active ,8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active ,8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active ,8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,not active ,8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,not active ,8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,not active ,8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active ,8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,not active ,8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,not active ,8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,not active ,8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,not active ,8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,not active ,8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,not active ,8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active ,8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed ,30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed ,30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed ,30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed ,30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed ,30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed ,30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed ,30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed ,30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed ,30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed ,30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed ,30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed ,30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed ,30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0 ,60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0 ,60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0 ,60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0 ,60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0 ,60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0 ,60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0 ,60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0 ,60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0 ,60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0 ,60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0 ,60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0 ,60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,0 ,60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0 ,60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0 ,60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0 ,60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0 ,60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0 ,60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0 ,60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0 ,60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0 ,60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0 ,60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0 ,60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0 ,60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0 ,60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed ,60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed ,60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed ,60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed ,60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed ,60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed ,60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed ,60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed ,60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed ,60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed ,60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed ,60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed ,60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed ,60
ENG126647-ENG98399-debug_light_function-Activation,0 ,11
ENG126647-ENG101417-debug_light_function-Adresse,0 ,11
ENG126647-ENG126820-debug_light_function-Bitmask,0 ,11
ENG126647-ENG126821-debug_light_function-Divisor,0 ,11
ENG126647-ENG98827-debug_light_function-Offset,0 ,11
ENG126647-ENG126822-debug_light_function-Polaritaet,0 ,11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0 ,11
ENG99457-ENG117394-Head area heater-blower_speed,1 ,2
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms,22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms,22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms,22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms,22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms,22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms,22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms,22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms,22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms,22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms,22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms,22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %,22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %,22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %,22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %,22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %,22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %,22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %,22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %,22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %,22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %,22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %,22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0 ,22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50 ,22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0 ,22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100 ,22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200 ,22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253 ,22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0 ,22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0 ,22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0 ,22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0 ,22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0 ,22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx,22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx,22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx,22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx,22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200 ,22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500 ,22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0 ,22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx,22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx,22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx,22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx,22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms,22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms,22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms,22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms,22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms,22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms,22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms,22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms,22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms,22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms,22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms,22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %,22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %,22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %,22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %,22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %,22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %,22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %,22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %,22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %,22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %,22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %,22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %,12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %,12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %,12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %,12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %,12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %,12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10 ,12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10 ,12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100 ,12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150 ,12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220 ,12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253 ,12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx,10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx,10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx,10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx,10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx,10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00 ,10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00 ,10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00 ,10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00 ,10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00 ,10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx,10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx,10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx,10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx,10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx,10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00 ,10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00 ,10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00 ,10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00 ,10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00 ,10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0,0 ,12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1,10 ,12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2,50 ,12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3,100 ,12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4,220 ,12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5,253 ,12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0,2.00 %,12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1,2.00 %,12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2,6.00 %,12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3,10.00 %,12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4,80.00 %,12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5,100.00 %,12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx,8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx,8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx,8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx,8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00 ,8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00 ,8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00 ,8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00 ,8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx,8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx,8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx,8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,500 lx,8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00 ,8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00 ,8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00 ,8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00 ,8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0,0.00 %,6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1,50.00 %,6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2,100.00 %,6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0,0.00 %,6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1,50.00 %,6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2,100.00 %,6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx,8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx,8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx,8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx,8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00 ,8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00 ,8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00 ,8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00 ,8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx,8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx,8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx,8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx,8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00 ,8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00 ,8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00 ,8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00 ,8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0,0.00 %,6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1,50.00 %,6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2,100.00 %,6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0,0.00 %,6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1,50.00 %,6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2,100.00 %,6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,100 ms,10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,160 ms,10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,200 ms,10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,260 ms,10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %,10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00 ,10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00 ,10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,10.00 ,10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00 ,10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0 ,16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0 ,16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active ,16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active ,16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active ,16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active ,16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active ,16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0 ,16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0 ,16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active ,16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active ,16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active ,16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active ,16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active ,16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active ,16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active ,16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0 ,16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0 ,16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0 ,16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active ,16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active ,16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active ,16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active ,16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active ,16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active ,16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active ,16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active ,16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0 ,16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0 ,16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,Abbiegelicht links ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active ,16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active ,16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active ,16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active ,16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active ,16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active ,16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0 ,16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0 ,16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,Abbiegelicht rechts ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active ,16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active ,16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active ,16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active ,16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active ,16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active ,16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize ,16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize ,16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize ,16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0 ,16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0 ,16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0 ,16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0 ,16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15,00 ,16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00 ,16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active ,16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always ,16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active ,16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active ,16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active ,16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active ,16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active ,16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active ,16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active ,16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0 ,16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0 ,16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,16 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,08 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active ,16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active ,16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active ,16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active ,16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active ,16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0 ,16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0 ,16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,18 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,18 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active ,16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active ,16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active ,16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active ,16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0 ,16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,41 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,00 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0 ,16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,42 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,00 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0 ,16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0 ,16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase ,16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active ,16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,39 ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,10 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,43 - allgemeine LED ,16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,3A ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,20 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,43 - allgemeine LED ,16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0 ,16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0 ,16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0 ,16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active ,16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,127 ,16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Rear lid open ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Daytime running lights ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,127 ,16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0 ,16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Rear lid open ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Daytime running lights ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0 ,16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0 ,16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0 ,16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28 ,16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED ,16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0 ,16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0 ,16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2F ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,1C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize ,16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0 ,16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,47 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,36 - LED Kleinleistung ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Klemme 30G ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active ,16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active ,16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize ,16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0 ,16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0 ,16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0 ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht ,16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active ,16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active ,16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active ,16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active ,16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active ,16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active ,16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0 ,16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0 ,16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0 ,16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32 ,16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active ,16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active ,16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active ,16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active ,16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active ,16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active ,16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active ,16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active ,16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0 ,16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0 ,16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light ,16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active ,16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active ,16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active ,16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active ,16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active ,16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active ,16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active ,16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0 ,16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0 ,16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00 ,16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active ,16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active ,16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active ,16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active ,16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active ,16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active ,16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active ,16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active ,16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0 ,16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0 ,16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00 ,16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active ,16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active ,16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active ,16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active ,16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active ,16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active ,16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active ,16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active ,16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0 ,16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0 ,16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00 ,16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active ,16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active ,16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active ,16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active ,16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active ,16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active ,16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active ,16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active ,16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0 ,16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0 ,16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00 ,16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active ,16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active ,16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active ,16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active ,16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active ,16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active ,16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active ,16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active ,16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active ,16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active ,16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active ,16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0 ,16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0 ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active ,16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active ,16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active ,16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active ,16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active ,16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0 ,16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0 ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active ,16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active ,16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active ,16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active ,16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0 ,16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung ,16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active ,16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active ,16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active ,16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active ,16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0 ,16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active ,16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active ,16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active ,16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active ,16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize ,16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize ,16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize ,16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0 ,16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0 ,16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0 ,16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0 ,16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14,00 ,16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00 ,16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active ,16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always ,16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active ,16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active ,16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active ,16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active ,16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active ,16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active ,16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active ,16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active ,16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske,63 ,1
ENG126648-ENG148864-LIN-Mirrormode-Stage,0 ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %,12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
ENG122976-ENG148891-Remote_Start_Adaption-Anzahl zulaessiger Remotestarts,2 ,8
ENG122976-ENG148876-Remote_Start_Adaption-RemoteStart Betrieb Dauer,10 min,8
Code:
SW:5Q0-937-084-DG   HW:5Q0-937-084-CF ---  Cent. Elect.
Component:BCM MQBAB M+  H38 0312, Coding:000000000000000000000000000000000000000000000000000000000000
EV_BCMMQB,020001,EV_BCMBOSCH_020.rod
IDE00001-ENG99061-Production mode-Access control,not active ,3
IDE00001-ENG115730-Production mode-Exterior lighting,not active ,3
IDE00001-ENG112304-Production mode-Heckwischer,not active ,3
IDE00001-ENG98647-Production mode-Interior lighting,not active ,3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active ,3
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active ,3
IDE00002-Transport mode,active ,1
IDE00820-Activating and deactivating all development messages,not active ,1
IDE01550-Service position,170.494336 °,2
IDE02152-Characteristics in production mode,2000 ms,4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate ,10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,active ,10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,active ,10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,active ,10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,normal ,10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,active ,10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active ,10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,300 ms,10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,300 ms,10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,300 ms,10
IDE02332-Deactivate production mode,0 ,3
IDE02488-DWA Interior monitoring,100 %,1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,not active ,8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active ,8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,8 s,8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,16 s,8
IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active ,8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active ,8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,3 s,8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,1 s,8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,5 s,8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,5 s,8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,1000 ms,8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,3.3 °,16
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
IDE03638-ENG116675-static AFS light-Lower speed threshold,0.0 km/h,16
IDE03638-ENG116682-static AFS light-Maximaltemperatur,100.0 °C,16
IDE03638-ENG116679-static AFS light-obere Grenztemperatur,95.0 °C,16
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
IDE03638-ENG116680-static AFS light-untere Grenztemperatur,80.0 °C,16
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
IDE03638-ENG116676-static AFS light-Upper speed threshold,50.0 km/h,16
IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
IDE03638-ENG115830-static AFS light-Zeitwert Einschaltzeit Abbiegelicht,15 min,16
IDE03787-Activate left/right hand drive switch-over,not active ,1
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s,11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.0 °C,11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.0 °C,11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer,0 s,11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt,not installed ,11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus,not installed ,11
IDE04927-ENG126845-Window heater-FSH Automatik,not active ,11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s,11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe,installed ,11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe,not installed ,11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-50.0 °C,11
IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
IDE04927-ENG154810-Window heater-window heating front activation time pause,240 s,11
IDE04928-MAS01577-Anti-theft device-Parking heater,not installed ,8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,active ,8
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated ,8
IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,activ ,8
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active ,8
IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
IDE04928-ENG141961-Anti-theft device-Heckscheibenbruchsensor,not installed ,8
IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,not_active ,8
IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active ,8
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
IDE05143-MAS02985-Writing parameter-Value,132 ,5
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
IDE05144-Read parameter address,FE 00 00 ,3
IDE05145-Light configuration,0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 02 00 64 00 00 00 00 00 00 00 00 00 04 48 00 4A 14 00 64 08 09 1A 00 00 00 00 00 00 04 4C 00 4C 14 00 64 08 0A 1A 00 00 00 00 00 00 01 3A 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 01 44 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 03 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 03 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 24 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 24 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 29 45 00 63 46 00 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
IDE05822-DWA Vehicle inclination sensor,100 %,1
IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 42 29 85 ,172
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,24.00 °C,30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,22.00 °C,30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,24.00 °C,30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,22.00 °C,30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,34.00 °C,30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,34.00 °C,30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,32.00 °C,30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,55.00 °C,30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,53.00 °C,30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,55.00 °C,30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,53.00 °C,30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe,not installed ,30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
IDE06425-Roller test bench mode: functional,not active ,1
IDE06507-MAS13125-Button in center console-Function of button 1,Start-stop ,8
IDE06507-MAS13129-Button in center console-Function of button 2,not coded/not installed ,8
IDE06507-MAS13132-Button in center console-Function of button 3,Driving program ,8
IDE06507-MAS13135-Button in center console-Function of button 4,not coded/not installed ,8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
IDE07007-ENG142252-A/C heater function via remote control-Abbruch_Hupen_RSt,not active ,8
IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,not installed ,8
IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
IDE07356-Position during interval mode,31.494474 °,2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active ,9
IDE08786-ENG141956-Assistance light functions-Humidity sensor,installed ,9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal ,9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion,not active ,9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,0 ,19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s,19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,80 %,19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %,19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,80 %,19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,80 %,19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active ,19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active ,19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht,not installed ,19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,active ,19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active ,19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel,not installed ,19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel,not installed ,19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed ,5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active ,5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed ,5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed ,5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed ,5
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active ,5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar,not active ,5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,installed ,5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed ,5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %,17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %,17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %,17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %,17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %,17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %,17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %,17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %,17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %,17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik,not installed ,17
IDE10298-Alternating park position 1,7.494498 °,2
IDE10299-Alternating park position 2,29.494476 °,2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,1.00 ,256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,1.00 ,256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,0 ,256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,1 ,256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,1 ,256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,0 ,256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %,256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100 %,256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %,256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %,256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100 %,256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %,256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %,256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %,256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %,256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,100 %,256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %,256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %,256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100 %,256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %,256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %,256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,100 %,256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %,256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %,256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %,256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0.0 s,256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0.0 s,256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0.0 s,256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0.0 s,256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0.0 s,256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0.0 s,256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0.0 s,256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0.0 s,256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0.0 s,256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0.0 s,256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0.0 s,256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0.0 s,256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0.0 s,256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0.0 s,256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0.0 s,256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0.0 s,256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0.0 s,256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0.0 s,256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0.0 s,256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0.0 s,256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0.0 s,256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0.0 s,256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0.0 s,256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0.0 s,256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0.0 s,256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0.0 s,256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0.0 s,256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0.0 s,256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0.0 s,256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0.0 s,256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0.0 s,256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0.0 s,256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0.0 s,256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0.0 s,256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0.0 s,256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0.0 s,256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0.0 s,256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0.0 s,256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0.0 s,256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0.0 s,256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,0 ,256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,255 ,30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,253 ,30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,255 ,30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,255 ,30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,255 ,30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,255 ,30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,255 ,30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,255 ,30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,255 ,30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,46 ,30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,32 ,30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,105 ,30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,129 ,30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,145 ,30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,170 ,30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,193 ,30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,219 ,30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,155 ,30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,116 ,30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,14 ,30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,installed ,3
IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen,not active ,3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,255 ,30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,60 ,30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,255 ,30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,255 ,30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,255 ,30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,224 ,30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,183 ,30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,137 ,30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,108 ,30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,83 ,30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,109 ,30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,255 ,30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,88 ,30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,50 ,30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,210 ,30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,255 ,30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,255 ,30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,255 ,30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,255 ,30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,160 ,30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,18 ,30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,85 ,30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,35 ,30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,35 ,30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,31 ,30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,25 ,30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,23 ,30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,20 ,30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung,active ,5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active ,5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug,not installed ,5
MAS01490-ENG141950-Energy management-Hybrid vehicle,No ,5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement,not active ,5
MAS01490-ENG141978-Energy management-Recuperation,active ,5
MAS01490-ENG142037-Energy management-Zweitbatterie,not installed ,5
MAS05055-lower turn position,31.494474 °,2
MAS05056-upper turn position,170.494336 °,2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,1200 lx,24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,2200 lx,24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO,600 lx,24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten,1200 lx,24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten,2200 lx,24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,4000 lx,24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway,not active ,24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain,not active ,24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity,frueh ,24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF,not active ,24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe,not active ,24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke,0 lx,24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung,02 ,24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler,not installed ,4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,225 ,60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,201 ,60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,144 ,60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,15 ,60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,18 ,60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,82 ,60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,238 ,60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,255 ,60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,255 ,60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,255 ,60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,255 ,60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,255 ,60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,255 ,60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,255 ,60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,255 ,60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,255 ,60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,249 ,60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,233 ,60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,209 ,60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,184 ,60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,161 ,60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,142 ,60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,116 ,60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,90 ,60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,19 ,60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,255 ,60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,255 ,60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,93 ,60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,170 ,60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,216 ,60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,252 ,60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,255 ,60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,255 ,60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,255 ,60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,255 ,60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,255 ,60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,255 ,60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,255 ,60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,255 ,60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,255 ,60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,255 ,60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,253 ,60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,255 ,60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,47 ,60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,37 ,60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,19 ,60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,1 ,60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,1 ,60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,1 ,60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,2 ,60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,3 ,60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,3 ,60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,3 ,60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,14 ,60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,28 ,60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,75 ,60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,255 ,60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,255 ,60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,255 ,60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,255 ,60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,255 ,60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,255 ,60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,255 ,60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,255 ,60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,255 ,60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,255 ,60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,255 ,60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,236 ,60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,191 ,60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,156 ,60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,115 ,60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,80 ,60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,35 ,60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,241 ,60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,255 ,60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,17 ,60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,15 ,60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,12 ,60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,11 ,60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,72 ,60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,104 ,60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,136 ,60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,165 ,60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,174 ,60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,192 ,60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,225 ,60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,255 ,60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,255 ,60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,255 ,60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,255 ,60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,255 ,60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,255 ,60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,255 ,60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,255 ,60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,188 ,60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed ,30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed ,30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed ,30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed ,30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed ,30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed ,30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed ,30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed ,30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed ,30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed ,30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed ,30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed ,30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed ,30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed ,30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0 ,60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0 ,60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0 ,60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0 ,60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0 ,60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0 ,60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0 ,60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0 ,60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0 ,60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0 ,60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0 ,60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0 ,60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0 ,60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0 ,60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0 ,60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0 ,60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0 ,60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0 ,60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0 ,60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0 ,60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0 ,60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0 ,60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0 ,60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0 ,60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0 ,60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0 ,60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0 ,60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0 ,60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0 ,60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0 ,60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed ,60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed ,60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed ,60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed ,60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed ,60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed ,60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed ,60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed ,60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed ,60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed ,60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed ,60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed ,60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed ,60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Sollspannungsanforderung 13.5 ,23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken,active ,10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger,separte ,10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing,not active ,10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay,50 ms,10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken,not active ,10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Wechselblinken_Warnblinken ,10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken,active ,10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen,3 ,10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken,not active ,10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2,active ,10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,active ,10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,active ,10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag,Daytime running lights ,9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,4 km/h,9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte,not active ,9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit,not active ,9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge,active ,9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,not active ,5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe,not installed ,5
ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht,Aktive Begrenzung ,18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis,Driver door ,18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige,No ,18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL,Yes ,18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung,Yes ,18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus,Enabled ,18
ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten,klemmenabhaengig ,18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,not installed ,18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,20 seconds ,18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,60 seconds ,18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung,active ,18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP,active ,18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus,active ,18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte,not active ,18
ENG126647-ENG98399-debug_light_function-Activation,0 ,11
ENG126647-ENG101417-debug_light_function-Adresse,0 ,11
ENG126647-ENG126820-debug_light_function-Bitmask,0 ,11
ENG126647-ENG126821-debug_light_function-Divisor,0 ,11
ENG126647-ENG98827-debug_light_function-Offset,0 ,11
ENG126647-ENG126822-debug_light_function-Polaritaet,0 ,11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
ENG246955-ENG246991-digital_key-pa_Two_Keys,not active ,3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0,0.0 %,6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1,50.0 %,6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2,100.0 %,6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0,0.0 %,6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1,50.0 %,6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2,100.0 %,6
ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
ENG122934-erase_error_table,55 00 00 ,3
ENG122933-error_mask,0 bit,2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP,present ,6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
ENG141685-Front_wash_function,10 ,2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,active ,6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm,active ,6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition,not active ,6
ENG141682-ENG141966-Front_wiper-Frontwischertyp,LIN ,6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active ,6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer,not active ,6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz,active ,6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant,not active ,6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube,not active ,6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
ENG99457-ENG117394-Head area heater-blower_speed,1 ,2
ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid,installed ,8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant,installed ,8
ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv,not active ,8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung,not installed ,8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor,installed ,8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube,installed ,8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer,not installed ,8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,-0.00 %,30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,-0.10 %,30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,-0.60 %,30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,-1.10 %,30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,-1.60 %,30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,-2.10 %,30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,-2.60 %,30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,-3.10 ,30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,-3.60 %,30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-4.10 %,30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,95.0 %,30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,85.0 %,30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,78.0 %,30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,71.0 %,30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,65.0 %,30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,57.0 %,30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,51.0 %,30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,46.0 %,30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,39.0 %,30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,32.0 %,30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize ,16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize ,16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize ,16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100 ,16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0 ,16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0 ,16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0 ,16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,14 ,16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34 ,16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten ,16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always ,16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase ,16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active ,16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active ,16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active ,16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active ,16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active ,16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active ,16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active ,16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15,maximize ,16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15,maximize ,16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15,maximize ,16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15,100 ,16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15,0 ,16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15,0 ,16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15,0 ,16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15,00 ,16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15,Always ,16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15,not active ,16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15,not active ,16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15,not active ,16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15,not active ,16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15,not active ,16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15,not active ,16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15,not active ,16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize ,16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize ,16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize ,16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127 ,16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0 ,16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0 ,16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0 ,16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,63 ,16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,45 ,16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,41 - LED Kleinleistung ,16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always ,16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Versorgungsbedarf der LCM Module ,16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,not active ,16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active ,16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active ,16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active ,16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active ,16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active ,16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active ,16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize ,16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize ,16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize ,16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,0 ,16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0 ,16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0 ,16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0 ,16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11,00 ,16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,00 ,16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,not active ,16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always ,16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,not active ,16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,not active ,16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active ,16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active ,16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active ,16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active ,16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active ,16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active ,16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize ,16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize ,16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize ,16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0 ,16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0 ,16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0 ,16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always ,16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active ,16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active ,16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active ,16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active ,16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active ,16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active ,16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize ,16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize ,16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize ,16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0 ,16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0 ,16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0 ,16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always ,16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active ,16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active ,16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active ,16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active ,16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active ,16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active ,16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize ,16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize ,16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize ,16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0 ,16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0 ,16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0 ,16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,41 ,16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,00 ,16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,38 - LED Blinkleuchten ,16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Blinken links Hellphase ,16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,not active ,16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active ,16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active ,16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active ,16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active ,16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active ,16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize ,16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize ,16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize ,16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0 ,16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0 ,16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0 ,16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,42 ,16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,00 ,16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,38 - LED Blinkleuchten ,16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Blinken rechts Hellphase ,16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,not active ,16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active ,16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active ,16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active ,16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active ,16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active ,16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize ,16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize ,16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize ,16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0 ,16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0 ,16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0 ,16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18,16 ,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08 ,16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always ,16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase ,16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active ,16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active ,16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active ,16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active ,16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active ,16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active ,16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize ,16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize ,16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize ,16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0 ,16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0 ,16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0 ,16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19,18 ,16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18 ,16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always ,16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase ,16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active ,16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active ,16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active ,16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active ,16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active ,16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active ,16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize ,16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize ,16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize ,16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100 ,16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0 ,16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0 ,16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0 ,16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,15 ,16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E ,16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten ,16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always ,16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken links Hellphase ,16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active ,16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active ,16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active ,16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active ,16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active ,16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active ,16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active ,16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize ,16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize ,16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize ,16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0 ,16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0 ,16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always ,16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light ,16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active ,16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active ,16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active ,16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active ,16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active ,16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize ,16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize ,16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize ,16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0 ,16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0 ,16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always ,16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light ,16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active ,16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active ,16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active ,16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active ,16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active ,16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize ,16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize ,16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize ,16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0 ,16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0 ,16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0 ,16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22,2C ,16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29 ,16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always ,16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light ,16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active ,16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active ,16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active ,16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active ,16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active ,16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active ,16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active ,16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize ,16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize ,16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize ,16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0 ,16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0 ,16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,29 ,16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A ,16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always ,16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active ,16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active ,16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active ,16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active ,16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize ,16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize ,16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize ,16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0 ,16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0 ,16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,2A ,16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A ,16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always ,16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,Parking light right ,16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active ,16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active ,16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active ,16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active ,16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize ,16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize ,16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize ,16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0 ,16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0 ,16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0 ,16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25,30 ,16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28 ,16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,43 - allgemeine LED ,16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always ,16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active ,16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active ,16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active ,16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active ,16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active ,16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active ,16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize ,16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize ,16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize ,16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0 ,16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0 ,16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0 ,16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active ,16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active ,16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active ,16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active ,16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active ,16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active ,16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active ,16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize ,16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize ,16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize ,16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0 ,16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0 ,16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0 ,16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,00 ,16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,00 ,16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,36 - LED Kleinleistung ,16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always ,16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken ,16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active ,16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active ,16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active ,16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active ,16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active ,16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active ,16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active ,16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize ,16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize ,16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize ,16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0 ,16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0 ,16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0 ,16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28,31 ,16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B ,16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht ,16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active ,16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active ,16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active ,16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active ,16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active ,16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active ,16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize ,16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize ,16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize ,16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0 ,16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0 ,16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0 ,16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29,32 ,16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B ,16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht ,16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active ,16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active ,16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active ,16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active ,16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active ,16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active ,16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active ,16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize ,16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize ,16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,100 ,16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,26 ,16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0 ,16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,4A ,16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48 ,16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal ,16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always ,16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Daytime running lights ,16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,not active ,16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active ,16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active ,16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize ,16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize ,16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize ,16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0 ,16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0 ,16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0 ,16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,02 ,16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00 ,16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always ,16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light ,16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active ,16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active ,16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active ,16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active ,16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active ,16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active ,16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active ,16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize ,16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize ,16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize ,16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0 ,16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0 ,16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0 ,16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00 ,16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active ,16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always ,16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active ,16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active ,16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active ,16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active ,16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active ,16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active ,16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active ,16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize ,16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize ,16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize ,16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0 ,16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0 ,16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0 ,16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00 ,16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active ,16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always ,16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active ,16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active ,16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active ,16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active ,16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active ,16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active ,16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active ,16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize ,16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize ,16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize ,16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0 ,16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0 ,16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0 ,16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00 ,16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active ,16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always ,16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active ,16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active ,16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active ,16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active ,16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active ,16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active ,16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active ,16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize ,16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize ,16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize ,16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0 ,16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0 ,16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0 ,16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00 ,16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active ,16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always ,16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active ,16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active ,16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active ,16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active ,16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active ,16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active ,16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active ,16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize ,16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize ,16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,100 ,16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,26 ,16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0 ,16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,4C ,16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C ,16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal ,16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always ,16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Daytime running lights ,16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,not active ,16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,Parking light right ,16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active ,16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active ,16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize ,16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize ,16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127 ,16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127 ,16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0 ,16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,49 ,16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A ,16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always ,16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Daytime running lights ,16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,not active ,16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active ,16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active ,16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize ,16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize ,16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127 ,16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127 ,16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0 ,16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,4B ,16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44 ,16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung ,16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always ,16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Daytime running lights ,16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,not active ,16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,Parking light right ,16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active ,16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active ,16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize ,16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize ,16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize ,16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0 ,16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0 ,16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6,1A ,16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36 ,16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht ,16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always ,16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links ,16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active ,16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active ,16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active ,16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active ,16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active ,16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize ,16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize ,16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize ,16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0 ,16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0 ,16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7,1B ,16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40 ,16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht ,16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always ,16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts ,16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active ,16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active ,16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active ,16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active ,16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active ,16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize ,16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize ,16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize ,16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0 ,16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0 ,16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0 ,16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,26 ,16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,35 ,16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,36 - LED Kleinleistung ,16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always ,16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active ,16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active ,16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active ,16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active ,16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active ,16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active ,16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize ,16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize ,16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize ,16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0 ,16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0 ,16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0 ,16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,27 ,16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3F ,16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,36 - LED Kleinleistung ,16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always ,16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,Parking light right ,16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active ,16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active ,16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active ,16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active ,16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active ,16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active ,16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 0A 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 24 00 00 00 3F 00 7F 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 1B 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
ENG141662-Leuchtenkonfiguration_Sonstiges,26 00 00 41 02 00 7F 00 00 00 00 00 00 00 00 00 26 00 00 42 04 00 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR,1-Sensor_LWR ,62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz,15 %,62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe,10.0 s,62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle,95.0 %,62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,255 km/h,62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr,100 Hz,62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,CAN_Daempferregelung ,62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,not installed ,62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,not active ,7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1,not active ,1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2,not active ,1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3,not active ,1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4,not active ,1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5,not active ,1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6,not active ,1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ,not active ,1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.0 %,12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.0 %,12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.0 %,12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.0 %,12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.0 %,12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.0 %,12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.0 %,12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-0.00 %,20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-0.60 %,20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-1.35 %,20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-2.60 %,20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-3.00 %,20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-0.00 ,20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,0.40 ,20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,0.60 ,20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,0.50 ,20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-0.10 ,20
ENG122979-ENG141954-Networking-A/C electronics,installed ,8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
ENG122979-ENG99457-Networking-Head area heater,not installed ,8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
ENG124714-ENG142044-OCU-DWA_push,active ,8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
ENG124714-OCU-,not installed ,8
ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,0 ,16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung,not active ,16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active ,16
ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,not active ,16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,not active ,16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4,not active ,16
ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll,active ,5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung,not active ,5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben,active ,5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem,not active ,5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
ENG122927-RLS_close_glazing,2.0 s,1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
ENG122929-RLS_LIN_Communication,4 s,1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
ENG122930-RLS_tunel_gateway_recognize,5 s,1
ENG122935-RLS_Washer_Front,15 s,1
ENG122926-RLS_wiper_position_parking,15 s,1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,installed ,10
ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,400 ms,10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,400 ms,10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
ENG116588-Sonderfunktionen-,not enabled ,4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1,not installed ,4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,not active ,5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung,active ,5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,CAN ,10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,2000 ms,10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0,0.0 lx,10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1,8.0 lx,10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2,50.0 lx,10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3,80.0 lx,10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4,100.0 lx,10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0,6.0 ,10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1,6.0 ,10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2,20.0 ,10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3,50.0 ,10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4,100.0 ,10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0,0.0 lx,10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1,8.0 lx,10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2,50.0 lx,10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3,80.0 lx,10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4,100.0 lx,10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0,6.0 ,10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1,6.0 ,10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2,20.0 ,10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3,50.0 ,10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4,100.0 ,10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0,0 ms,22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0,100.0 %,22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10,0.0 %,22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM,0.00 s,21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,5.0 s,21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,12.0 s,21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe,not active ,21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,active ,21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung,active ,21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,5 ,21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,50 %,21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl,Fotosensor_RLS ,21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung,Always active ,21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.248 ,21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,1.0 %,21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0,0 ,22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1,50 ,22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10,0 ,22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2,100 ,22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3,200 ,22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4,253 ,22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5,0 ,22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6,0 ,22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7,0 ,22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8,0 ,22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9,0 ,22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0,0 lx,22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10,0 lx,22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4,500 ,22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5,0 ,22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6,0 lx,22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7,0 lx,22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8,0 lx,22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9,0 lx,22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0,0 ms,22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0,0.0 %,22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10,100.0 %,22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0,0 lx,8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1,8 lx,8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2,50 lx,8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3,500 lx,8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0,100.0 ,8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1,100.0 ,8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2,100.0 ,8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3,100.0 ,8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0,0 lx,8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1,8 lx,8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2,50 lx,8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,500 lx,8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0,6.0 ,8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1,6.0 ,8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2,100.0 ,8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3,100.0 ,8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0,0.0 %,12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1,6.0 %,12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2,16.0 %,12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3,30.0 %,12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4,60.0 %,12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5,100.0 %,12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0,10 ,12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1,10 ,12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2,100 ,12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3,150 ,12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4,220 ,12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5,253 ,12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0,0 lx,10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1,8 lx,10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2,200 lx,10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3,300 lx,10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4,500 lx,10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0,16.0 ,10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1,16.0 ,10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2,100.0 ,10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3,100.0 ,10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4,100.0 ,10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0,0 lx,10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1,8 lx,10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2,220 lx,10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3,300 lx,10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4,500 lx,10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0,6.0 ,10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1,6.0 ,10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2,100.0 ,10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3,100.0 ,10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4,100.0 ,10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0,0 ,12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1,10 ,12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,100 ,12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,150 ,12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4,220 ,12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5,253 ,12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,6.0 %,12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,6.0 %,12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,16.0 %,12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,30.0 %,12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,60.0 %,12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5,100.0 %,12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0,0 lx,8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1,8 lx,8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2,50 lx,8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3,500 lx,8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0,6.0 ,8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1,6.0 ,8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2,100.0 ,8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3,100.0 ,8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0,0 lx,8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1,8 lx,8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2,50 lx,8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3,500 lx,8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0,100.0 ,8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1,100.0 ,8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2,100.0 ,8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3,100.0 ,8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0,0.0 %,6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1,50.0 %,6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2,100.0 %,6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0,0.0 %,6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1,50.0 %,6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2,100.0 %,6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0,0 lx,12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4,900 lx,12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5,1020 lx,12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0,0 ,12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,42 ,12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,84 ,12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,126 ,12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,220 ,12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5,500 ,12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0,0 ms,10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1,2000 ms,10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2,3000 ms,10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3,4000 ms,10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4,5100 ms,10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0,1.0 %,10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1,5.0 ,10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2,15.0 ,10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3,40.0 ,10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4,100.0 ,10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3,not installed ,4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,CAN ,4
ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck,not_installed ,9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,not active ,9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv,not active ,9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,not active ,9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,Always ,9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,not installed ,9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach,not active ,9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,not active ,9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,not active ,9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,not active ,9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,not active ,9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,not active ,9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,not active ,9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,not active ,9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,not installed ,9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1,00 00 ,20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2,00 00 ,20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3,00 00 ,20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4,00 00 ,20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1,00 00 ,20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2,00 00 ,20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3,00 00 ,20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4,00 00 ,20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5,00 00 ,20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6,00 00 ,20
ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB,not active ,7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern,not active ,7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,not active ,7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,not active ,7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion,not active ,7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung,active ,7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung,not active ,7
ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,Freigabe_Softtouch ,7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,installed ,7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck,active ,3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln,active ,3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active ,4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active ,7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster,not active ,7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Contact control ,7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang,No ,7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel,active ,7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen,not active ,7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp,1 or 2 notch rear actuator ,7
ENG141681-IDE02021-ZV Komfort-Comfort closing,active ,8
ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten,Yes ,8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit,600 s,8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus,active ,8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen,active ,8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global,active ,8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer,not active ,8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar,adjustable ,8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen,active ,8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art,Permanent ,8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus,active ,8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal,nicht invertiert ,5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite,not installed ,5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite,not installed ,5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links,No ,5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts,No ,5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter,not installed ,5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM,Driver side ,5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active ,5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,Yes ,5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer,Yes ,5
