Retrofit of facelift BCM into pre-facelift Mk7 (in progress, please help 😬)
Cuzoe
Edit: Not sure if this should be the very first line here, but if you decide to do this make sure you get a 315Mhz BCM, if you're in North America. It was suggested to me that that didn't matter because there is an adaptation channel to choose the frequency. I went with a ROW spec BCM. Found that the key fob didn't work and thought it was a pairing issue. Turns out it only worked when held a couple inches away from the BCM, discovered by @xabhax. NAR spec BCM solved the issue.
So it is generally known that facelift Mk7's (and other facelift MQB cars) have a BCM with no long coding. While there is plenty of reason to upgrade to a BCM High (support for heated seats, fog lights, etc.) there isn't much reason for retrofitting a facelift BCM that I can think of, beyond wanting RGB ambient lights. The common belief is (was) that pre-facelift cars do not support RGB ambient lights. That is not entirely true, as discovered in my thread here. My pre-facelift BCM does support RGB ambient lighting, but in a very limited way compared to facelift cars. I updated the first post over there, but will add more detail of the limitations at some point.
Now moving back toward the target here... but a quick run down of concerns (this list might grow):
  • Many of the adaptation channels have the same IDExxxx-ENGxxxxxx numbers and descriptions... easy easy
  • Some of them have the same IDExxxx-ENGxxxxxx numbers with similar descriptions... also pretty easy
  • Some have completely different IDExxxx-ENGxxxxxx numbers, moving them to a different place in the channel map but still with the same/similar descriptions... not too bad
  • Each has channels that look to be about the same thing but are in different groups... okay, Google translate helps here, helps always really
  • Lighting control, which was once in Leuchte channels has been moved to a couple long byte strings... see here for details.
    • So I will be converting my Leuchte channels sets to corresponding byte strings
  • Facelift headlights moved lots of control to lighting control modules (LCM), this is beyond my "work scope" as I have halogens (now Osrams, but same thing to the BCM)
  • All the long coding is now in adaptations, so Google translate and then some experimentation
  • Lots of channels that exist in pre-facelift but do not (in an obvious way) exist in facelift, and vice versa... Google translate will again be your friend
I will, in the first few posts, probably experiment with some different formatting to show pre-facelift vs facelift adaptations. Where the adaptations have the same IDExxxx-ENGxxxxxx numbers with same/similar descriptions I may not always include translations (because laziness). Where the difference is only IDExxxx-ENGxxxxxx numbers I will somehow indicate that but probably won't translate much. I will have to figure a way to clearly indicate when a channel exists in one map but not the other. And finally I intend to add translations and descriptions (as best I can figure out, but with community help as well) for those channel groups that replace functions previously configured via long coding.
Finally, this will be a slow process. I've got a newborn at the house and I've got the facelift BCM on my computer desk so getting this done is not an urgent matter. I'm not going to go through the trouble of reserving a bunch of posts as this project will not be quick. If anyone has any format suggestions please post an example. Ultimately I want this to be easy to decipher. Even after I start making posts with formatting, I will go back and edit if/when a more clear format is suggested. It may turn out that a Google spreadsheet makes the most sense for this, but we shall see.
Edit: As I thought more about this it occurred to me that I should reserve a few posts for the following reasons:
  1. This will not be a definitive DIY (a-la a @golfdave thread) because I will, for the most part only be focused on what it takes to retrofit a facelift BCM into my car. That isn't to say a lot, or even most, of it won't apply to anyone doing it but I feel it would be wrong to suggest otherwise.
  2. I think it best to have a couple posts up top that show (with pictures, to be added) the current long coding options in my BCM and the sub-modules of the BCM (in my car these are wiper control module, rain/light sensor, anti-theft alarm sensor, and alarm horn)
  3. My car has several retrofits, mods and other coding tweaks (found here and elsewhere) that I hope to maintain through this retrofit. I will try to list these in a post, as I remember them. It's very unlikely I will link where I found each tweak/coding change/etc... but I know that I'm taking zero credit for discovering any of these. I'm just listing them to be thorough in this thread.
  4. There should be something up top with a starting adaptation map of my BCM and one of the BCM I'm retrofitting.
  5. Probably reserve one more post, just in case 🤷‍♂️.
Cuzoe
So about my car... 2015 Golf TDI S, currently with BCM high (as called out in ETKA for my car).
List of current retrofits, at the time this scan was taken (all do not have implications for the BCM):
pACC, DCC, AID, Audi Chirp Alarm, Interior Motion Sense Alarm, Rain/Light Sensor (for auto headlights and wipers), Auto-dimming Rear View Mirror, MIB 2.5, Parking Aid, Parking Assist, Driving Modes, ESC button (shifter area), Blind Spot Monitoring, Lane Assist, High Beam Assist, Fog Lights, Mk7.5 Euro Tails, Soundaktor (internal), Rear View Camera (lowline), Power Folding Mirrors, Heated Seats
List of imminent retrofits, which may have BCM implications by the time I finish this:
Soundaktor (external), Heated Mk8 Steering Wheel, Overhead Ambient Lighting, OEM RGB Lighting
Current BCM; 09 - Central Electronics - SW:5Q0-937-087-S HW:5Q0-937-087-S
Code:
;SW:5Q0-937-087-S   HW:5Q0-937-087-S ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0145     Coding:00000B46404182E96DE44080B10003A01002000000000000000000000000
;EV_BodyContrModul1UDSBosc    14004    EV_BCMBOSCH_014.rod
;Sunday    27    March
;VCDS Version: Release 22.3.0 (x64)  Data version: 20220225 DS336.1
;VCID: 4BC36833734A7FB36A0-801E
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA    not active     12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm    active     12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf    active     12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer    not active     12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren    Deactivating     12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel    not active     12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit    0 ms    12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit    0 ms    12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit    0 ms    12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit    0 ms    12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit    0 ms    12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz    active     12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status    not active     12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung    not active     12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant    0    12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus    not active     12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube    not active     12
IDE01550-Service position    170.49 °    2
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    active     4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    active     4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    active     4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    short     4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    active     4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     4
IDE02332-Deactivate production mode    0    3
IDE02488-Anti-theft system interior monitoring    100%    1
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum    100%    8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer    80%    8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn    80%    8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung    Enabled     8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel    installed     8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel    installed     8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    -63.75 °    14
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.00 %/s    14
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    double sided     14
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.00 km/h    14
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.00 °C    14
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.00 °C    14
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 °    14
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.00 °C    14
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    180 °    14
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.00 km/h    14
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     14
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger    separte     8
IDE04923-ENG115774-Turn signal control-Komfortblinken    active     8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen    3    8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker    MFG     8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen    not enabled     8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung    not active     8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung    Always active     8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor    0.1    8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert    10.00%    8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze    350 km/h    14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze    350 km/h    14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich    active     14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten    klemmenabhaengig     14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit    0 km/h    14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert    not active     14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion    not active     14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus    active     14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht    not active     14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht    not active     14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren    limitieren     14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht    15 min    14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten    Fog lamp     8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus    automatic     8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis    Driver door     8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung    46400 lx    8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung    12 lx    8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus    Enabled     8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome    20 seconds     8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP    20 seconds     8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung    active     8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP    active     8
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.00 °C    8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.00 °C    8
IDE04927-ENG126845-Window heater-FSH Automatik    active     8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     4
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     4
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     4
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     4
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    1 Alarm     4
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     4
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    keine verzoegerung     4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck    active     8
IDE05142-ENG116621-Access control-automatisches Entriegeln    active     8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit    active     8
IDE05142-ENG116706-Access control-Autounlock NAR    active     8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB    not active     8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung    not active     8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels    active     8
IDE05142-ENG115722-Access control-Electrical rear lid    not active     8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein    not active     8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein    not active     8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung    active     8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock    adjustable     8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     8
IDE05142-ENG115755-Access control-Notschließfunktion    active     8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung    not active     8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung    Always     8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden    Always     8
IDE05142-ENG115758-Access control-Valet Parking    not active     8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe    not active     8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT    not active     8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer    not active     8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel    active     8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen    not active     8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung    Einzeltuerentriegelung     8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash    not active     8
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0    34    560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1    3E     560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10    0    560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11    0    560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12    38    560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13    42    560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14    0    560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15    0    560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16    0    560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17    0    560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18    0    560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19    0    560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2    0    560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20    13    560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21    23    560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22    29    560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23    0A     560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24    1A     560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25    28    560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26    0    560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27    0    560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28    0    560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29    1B     560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3    0    560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30    0    560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31    0    560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32    0    560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33    0    560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34    0    560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4    48    560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5    4C     560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6    36    560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7    40    560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8    37    560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9    41    560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0    maximize     560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1    maximize     560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10    maximize     560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11    maximize     560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12    maximize     560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13    maximize     560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14    maximize     560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15    maximize     560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16    maximize     560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17    maximize     560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18    maximize     560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19    maximize     560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2    maximize     560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20    minimize     560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21    minimize     560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22    maximize     560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23    maximize     560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24    maximize     560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25    maximize     560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26    maximize     560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27    maximize     560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28    maximize     560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29    maximize     560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3    maximize     560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30    maximize     560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31    maximize     560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32    maximize     560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33    maximize     560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34    maximize     560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4    minimize     560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5    minimize     560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6    maximize     560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7    maximize     560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8    maximize     560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9    maximize     560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0    maximize     560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1    maximize     560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10    maximize     560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11    maximize     560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12    maximize     560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13    maximize     560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14    maximize     560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15    maximize     560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16    maximize     560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17    maximize     560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18    maximize     560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19    maximize     560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2    maximize     560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20    maximize     560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21    maximize     560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22    maximize     560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23    maximize     560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24    maximize     560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25    maximize     560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26    maximize     560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27    maximize     560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28    maximize     560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29    maximize     560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3    maximize     560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30    maximize     560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31    maximize     560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32    maximize     560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33    maximize     560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34    maximize     560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4    maximize     560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5    maximize     560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6    maximize     560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7    maximize     560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8    maximize     560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9    maximize     560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0    maximize     560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1    maximize     560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10    maximize     560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11    maximize     560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12    maximize     560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13    maximize     560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14    maximize     560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15    maximize     560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16    maximize     560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17    maximize     560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18    maximize     560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19    maximize     560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2    maximize     560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20    maximize     560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21    maximize     560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22    maximize     560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23    maximize     560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24    maximize     560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25    maximize     560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26    maximize     560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27    maximize     560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28    maximize     560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29    maximize     560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3    maximize     560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30    maximize     560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31    maximize     560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32    maximize     560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33    maximize     560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34    maximize     560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4    maximize     560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5    maximize     560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6    maximize     560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7    maximize     560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8    maximize     560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9    maximize     560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0    100    560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1    100    560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10    0    560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11    0    560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12    100    560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13    100    560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14    0    560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15    0    560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16    0    560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17    0    560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18    0    560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19    0    560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2    100    560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20    100    560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21    100    560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22    100    560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23    28    560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24    28    560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25    100    560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26    0    560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27    28    560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28    100    560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29    100    560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3    100    560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30    127    560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31    0    560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32    0    560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33    0    560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34    0    560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4    100    560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5    100    560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6    100    560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7    100    560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8    100    560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9    100    560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0    0    560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1    0    560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10    0    560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11    0    560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12    0    560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13    0    560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14    0    560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15    0    560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16    0    560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17    0    560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18    0    560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19    0    560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2    0    560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20    0    560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21    0    560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22    0    560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23    100    560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24    100    560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25    0    560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26    0    560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27    0    560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28    0    560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29    0    560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3    0    560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30    100    560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31    0    560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32    0    560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33    0    560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34    0    560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4    0    560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5    0    560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6    0    560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7    0    560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8    0    560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9    0    560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0    0    560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1    0    560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10    0    560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11    0    560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12    0    560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13    0    560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14    0    560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15    0    560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16    0    560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17    0    560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18    0    560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19    0    560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2    0    560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20    28    560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21    28    560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22    0    560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23    0    560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24    0    560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25    0    560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26    0    560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27    0    560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28    0    560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29    0    560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3    0    560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30    0    560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31    0    560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32    0    560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33    0    560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34    0    560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4    31    560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5    31    560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6    0    560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7    0    560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8    0    560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9    0    560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0    0    560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1    0    560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10    0    560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11    0    560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12    0    560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13    0    560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14    0    560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15    0    560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16    0    560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17    0    560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18    0    560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19    0    560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2    0    560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20    0    560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21    0    560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22    0    560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23    0    560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24    0    560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25    0    560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26    0    560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27    0    560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28    0    560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29    0    560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3    0    560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30    0    560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31    0    560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32    0    560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33    0    560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34    0    560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4    0    560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5    0    560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6    0    560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7    0    560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8    0    560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9    0    560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0    14    560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1    15    560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10    0    560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11    0    560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12    22    560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13    23    560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14    0    560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15    0    560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16    0    560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17    0    560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18    0    560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19    0    560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2    45    560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20    3D     560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21    3E     560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22    2C     560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23    29    560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24    2A     560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25    30    560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26    0    560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27    47    560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28    31    560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29    32    560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3    46    560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30    0    560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31    0    560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32    0    560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33    0    560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34    0    560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4    43    560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5    44    560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6    1A     560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7    1B     560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8    1C     560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9    1D     560
IDE05145-ENG115873-Light configuration-Lasttyp 0    12 - Blinkleuchten     560
IDE05145-ENG115892-Light configuration-Lasttyp 1    12 - Blinkleuchten     560
IDE05145-ENG116062-Light configuration-Lasttyp 10    not active     560
IDE05145-ENG116081-Light configuration-Lasttyp 11    not active     560
IDE05145-ENG116100-Light configuration-Lasttyp 12    10 - allgemeine Scheinwerfer     560
IDE05145-ENG116119-Light configuration-Lasttyp 13    10 - allgemeine Scheinwerfer     560
IDE05145-ENG116138-Light configuration-Lasttyp 14    not active     560
IDE05145-ENG116157-Light configuration-Lasttyp 15    not active     560
IDE05145-ENG116176-Light configuration-Lasttyp 16    not active     560
IDE05145-ENG116195-Light configuration-Lasttyp 17    not active     560
IDE05145-ENG116214-Light configuration-Lasttyp 18    not active     560
IDE05145-ENG116233-Light configuration-Lasttyp 19    not active     560
IDE05145-ENG115910-Light configuration-Lasttyp 2    not active     560
IDE05145-ENG116252-Light configuration-Lasttyp 20    34 - LED Bremsleuchten     560
IDE05145-ENG116271-Light configuration-Lasttyp 21    34 - LED Bremsleuchten     560
IDE05145-ENG116290-Light configuration-Lasttyp 22    42 - LED dritte Bremsleuchte     560
IDE05145-ENG116309-Light configuration-Lasttyp 23    38 - LED Blinkleuchten     560
IDE05145-ENG116328-Light configuration-Lasttyp 24    38 - LED Blinkleuchten     560
IDE05145-ENG116347-Light configuration-Lasttyp 25    18 - 2* 5W     560
IDE05145-ENG116366-Light configuration-Lasttyp 26    not active     560
IDE05145-ENG116385-Light configuration-Lasttyp 27    32 - allgemeine LED bis 12W     560
IDE05145-ENG116404-Light configuration-Lasttyp 28    32 - allgemeine LED bis 12W     560
IDE05145-ENG116423-Light configuration-Lasttyp 29    9 - allgemeine Glühlampe 27W: auch H15     560
IDE05145-ENG115929-Light configuration-Lasttyp 3    not active     560
IDE05145-ENG116442-Light configuration-Lasttyp 30    18 - 2* 5W     560
IDE05145-ENG116461-Light configuration-Lasttyp 31    not active     560
IDE05145-ENG116480-Light configuration-Lasttyp 32    not active     560
IDE05145-ENG116499-Light configuration-Lasttyp 33    not active     560
IDE05145-ENG116518-Light configuration-Lasttyp 34    not active     560
IDE05145-ENG115948-Light configuration-Lasttyp 4    9 - allgemeine Glühlampe 27W: auch H15     560
IDE05145-ENG115967-Light configuration-Lasttyp 5    9 - allgemeine Glühlampe 27W: auch H15     560
IDE05145-ENG115986-Light configuration-Lasttyp 6    11 - Abblendlicht     560
IDE05145-ENG116005-Light configuration-Lasttyp 7    11 - Abblendlicht     560
IDE05145-ENG116024-Light configuration-Lasttyp 8    10 - allgemeine Scheinwerfer     560
IDE05145-ENG116043-Light configuration-Lasttyp 9    10 - allgemeine Scheinwerfer     560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0    Always     560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1    Always     560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10    Always     560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11    Always     560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12    Always     560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13    Always     560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14    Always     560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15    Always     560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16    Always     560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17    Always     560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18    Always     560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19    Always     560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2    Always     560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20    Always     560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21    Always     560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22    Always     560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23    Always     560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24    Always     560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25    Always     560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26    Always     560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27    Always     560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28    only_if_closed     560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29    Always     560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3    Always     560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30    Always     560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31    Always     560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32    Always     560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33    Always     560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34    Always     560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4    Always     560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5    Always     560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6    Always     560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7    Always     560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8    Always     560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9    Always     560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17    0    560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13    0    560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0    2    560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1    4    560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10    0    560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11    0    560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12    18    560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13    19    560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14    0    560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15    0    560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16    0    560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17    0    560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18    0    560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19    0    560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2    8    560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20    24    560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21    24    560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22    24    560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23    0    560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24    0    560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25    8    560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26    0    560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27    8    560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28    63    560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29    25    560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3    8    560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30    43    560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31    0    560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32    0    560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33    0    560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34    0    560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4    20    560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5    20    560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6    11    560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7    12    560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8    13    560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9    14    560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0    0    560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1    0    560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10    0    560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11    0    560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12    22    560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13    23    560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14    0    560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15    0    560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16    0    560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18    0    560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19    0    560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2    0    560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20    0    560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21    0    560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22    0    560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23    0    560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24    0    560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25    0    560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26    0    560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27    0    560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28    0    560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29    0    560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3    0    560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30    38    560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31    0    560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32    0    560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33    0    560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34    0    560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4    0    560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5    0    560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6    0    560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7    0    560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8    15    560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9    15    560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0    0    560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1    0    560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10    0    560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11    0    560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12    0    560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14    0    560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15    0    560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16    0    560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17    0    560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18    0    560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19    0    560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2    0    560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20    0    560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21    0    560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22    0    560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23    2    560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24    4    560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25    0    560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26    0    560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27    0    560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28    0    560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29    0    560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3    0    560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30    41    560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31    0    560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32    0    560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33    0    560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34    0    560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4    6    560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5    7    560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6    0    560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7    0    560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8    0    560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9    0    560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0    0    560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1    0    560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10    0    560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11    0    560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12    0    560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13    0    560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14    0    560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15    0    560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16    0    560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17    0    560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18    0    560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19    0    560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2    0    560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20    0    560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21    0    560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22    0    560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23    0    560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24    0    560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25    0    560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26    0    560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27    0    560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28    0    560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29    0    560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3    0    560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30    0    560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31    0    560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32    0    560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33    0    560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34    0    560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4    0    560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5    0    560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6    0    560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7    0    560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8    0    560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9    0    560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0    0    560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1    0    560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10    0    560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11    0    560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12    0    560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13    0    560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14    0    560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15    0    560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16    0    560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17    0    560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18    0    560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19    0    560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2    0    560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20    0    560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21    0    560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22    0    560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23    0    560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24    0    560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25    0    560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26    0    560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27    0    560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28    0    560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29    0    560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3    0    560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30    0    560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31    0    560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32    0    560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33    0    560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34    0    560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4    8    560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5    8    560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6    0    560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7    0    560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8    0    560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9    0    560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0    0    560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1    0    560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10    0    560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11    0    560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12    0    560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13    0    560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14    0    560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15    0    560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16    0    560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17    0    560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18    0    560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19    0    560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2    0    560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20    0    560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21    0    560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22    0    560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23    0    560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24    0    560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25    0    560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26    0    560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27    0    560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28    0    560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29    0    560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30    0    560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31    0    560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32    0    560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33    0    560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34    0    560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4    0    560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6    0    560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7    0    560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8    0    560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9    0    560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3    0    560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5    0    560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0    0    560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1    0    560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10    0    560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11    0    560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12    0    560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13    0    560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14    0    560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15    0    560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16    0    560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17    0    560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18    0    560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19    0    560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2    0    560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20    0    560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21    0    560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22    0    560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23    0    560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24    0    560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25    0    560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26    0    560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27    0    560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28    0    560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29    0    560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3    0    560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30    0    560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31    0    560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32    0    560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33    0    560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34    0    560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4    0    560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5    0    560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6    0    560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7    0    560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8    0    560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9    0    560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0    0    560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1    0    560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10    0    560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11    0    560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12    0    560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13    0    560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14    0    560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15    0    560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16    0    560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17    0    560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18    0    560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19    0    560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2    0    560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20    0    560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21    0    560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22    0    560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23    0    560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24    0    560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25    0    560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26    0    560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27    0    560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28    0    560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29    0    560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3    0    560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30    0    560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31    0    560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32    0    560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33    0    560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34    0    560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4    0    560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5    0    560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6    0    560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7    0    560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8    0    560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9    0    560
IDE05145-ENG154438-Light configuration-Reserved 0    0    560
IDE05145-ENG99841-Light configuration-Reserved 1    0    560
IDE05145-ENG154357-Light configuration-Reserved 10    0    560
IDE05145-ENG154352-Light configuration-Reserved 11    0    560
IDE05145-ENG154182-Light configuration-Reserved 12    0    560
IDE05145-ENG154265-Light configuration-Reserved 13    0    560
IDE05145-ENG154334-Light configuration-Reserved 14    0    560
IDE05145-ENG154340-Light configuration-Reserved 15    0    560
IDE05145-ENG154204-Light configuration-Reserved 16    0    560
IDE05145-ENG154344-Light configuration-Reserved 17    0    560
IDE05145-ENG154195-Light configuration-Reserved 18    0    560
IDE05145-ENG154190-Light configuration-Reserved 19    0    560
IDE05145-ENG99862-Light configuration-Reserved 2    0    560
IDE05145-ENG154300-Light configuration-Reserved 20    0    560
IDE05145-ENG154439-Light configuration-Reserved 21    0    560
IDE05145-ENG154440-Light configuration-Reserved 22    0    560
IDE05145-ENG154441-Light configuration-Reserved 23    0    560
IDE05145-ENG154442-Light configuration-Reserved 24    0    560
IDE05145-ENG154443-Light configuration-Reserved 25    0    560
IDE05145-ENG154444-Light configuration-Reserved 26    0    560
IDE05145-ENG154445-Light configuration-Reserved 27    0    560
IDE05145-ENG154446-Light configuration-Reserved 28    0    560
IDE05145-ENG154447-Light configuration-Reserved 29    0    560
IDE05145-ENG101107-Light configuration-Reserved 3    0    560
IDE05145-ENG154448-Light configuration-Reserved 30    0    560
IDE05145-ENG154449-Light configuration-Reserved 31    0    560
IDE05145-ENG154450-Light configuration-Reserved 32    0    560
IDE05145-ENG154451-Light configuration-Reserved 33    0    560
IDE05145-ENG154452-Light configuration-Reserved 34    0    560
IDE05145-ENG154267-Light configuration-Reserved 4    0    560
IDE05145-ENG154291-Light configuration-Reserved 5    0    560
IDE05145-ENG154239-Light configuration-Reserved 6    0    560
IDE05145-ENG154308-Light configuration-Reserved 7    0    560
IDE05145-ENG154184-Light configuration-Reserved 8    0    560
IDE05145-ENG154255-Light configuration-Reserved 9    0    560
IDE05822-Anti-theft alarm system vehicle inclination sensor    100%    1
IDE05823-DWA Interior monitoring parameter set    01 0A 08 00 43 63 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD 46 06 1C 0F 1E 00 85 0F 39 F7 64 23 55 42 57 9B 25 44 3F 3A 29 27 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 9B 05 34 3F 3A 69 58 03 0D 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 9B 05 24 3F 3A 69 47 03 0D 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 94 05 24 3F 3A 69 58 02 04 09 A3 05 34 26 19 15 0C 12 18 86 09 26 33 67 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 40 71 28 F1     172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s    24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C    24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    22.50 °C    24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    21.50 °C    24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    22.50 °C    24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    21.50 °C    24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    36.00 °C    24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    35.00 °C    24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    36.00 °C    24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    35.00 °C    24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    53.50 °C    24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    52.50 °C    24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    53.50 °C    24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    52.50 °C    24
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten    active     8
IDE06096-ENG116597-Interior lights-KL30G ohne PWM    not active     8
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe    not active     8
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten    not active     8
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung    active     8
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert    100%    8
IDE06425-Dynamometer mode: functional    not active     1
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag    Daytime running lamps     4
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     4
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     4
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    active     4
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    active     4
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO    not active     4
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     4
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte    not active     4
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     4
IDE07356-Position during interval mode    31.49 °    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit     12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    12
IDE08542-IDE02021-Access control 2-Comfort closing    active     8
IDE08542-IDE02022-Access control 2-Comfort opening    active     8
IDE08542-ENG128459-Access control 2-easycloselight_aktiv    not active     8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen    active     8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen    not active     8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit    600 s    8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus    active     8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen    active     8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen    active     8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen    active     8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus    by look command via remote control key     8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen    not active     8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen    active     8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung    not active     8
IDE08542-ENG115670-Access control 2-Komfortbedienung global    active     8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer    not active     8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen    active     8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen    active     8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung    active     8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung    not active     8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf    not active     8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel    active     8
IDE08542-ENG125656-Access control 2-Regenschliessen_art    Permanent     8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus    active     8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock    Via ZV-Absicherung Light     8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen    not active     8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen    not active     8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen    not active     8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen    tilting     8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen    not active     8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen    not active     8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung    active     8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt    active     8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron    not active     8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal    not active     8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar    not active     8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung    0 ms    8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach    not active     8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig    kein_Hinweis     8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset    not active     8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert    0 ms    8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    sensitive     8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    not active     8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent    present     8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung    present     8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA    not active     8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte    not active     8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben    active     2
IDE08787-ENG101416-Auxiliary functions-Reserved_1    not active     2
IDE08787-ENG99458-Auxiliary functions-Reserved_2    not active     2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15    active     2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    not active     2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    not active     2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken    not active     4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing    not active     4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken    not active     4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung    not active     4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken    not active     4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken    not active     4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2    not active     4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing    not active     4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links    active     4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts    active     4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken    not active     4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing    not active     4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active     4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken    not active     4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS    active     4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN    active     4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf    active     4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu    active     4
IDE09595-ENG115658-Characteristic curve-x0    0 lx    18
IDE09595-ENG101574-Characteristic curve-X1    2000 lx    18
IDE09595-ENG99557-Characteristic curve-X2    4000 lx    18
IDE09595-ENG102140-Characteristic curve-X3    6000 lx    18
IDE09595-ENG102936-Characteristic curve-X4    8000 lx    18
IDE09595-ENG103548-Characteristic curve-X5    10200 lx    18
IDE09595-ENG148955-Characteristic curve-y1_0    0    18
IDE09595-ENG148956-Characteristic curve-y1_1    40    18
IDE09595-ENG148957-Characteristic curve-y1_2    90    18
IDE09595-ENG148958-Characteristic curve-y1_3    140    18
IDE09595-ENG148959-Characteristic curve-y1_4    190    18
IDE09595-ENG148960-Characteristic curve-y1_5    245    18
IDE09595-ENG148961-Characteristic curve-y2_0    0    18
IDE09595-ENG148962-Characteristic curve-y2_1    60    18
IDE09595-ENG148963-Characteristic curve-y2_2    110    18
IDE09595-ENG148964-Characteristic curve-y2_3    160    18
IDE09595-ENG148965-Characteristic curve-y2_4    210    18
IDE09595-ENG148966-Characteristic curve-y2_5    255    18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.50 s    20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    1    20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    2    20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    3    20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1    255    20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2    255    20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3    0    20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    active     20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    active     20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    not active     20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1    0    20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2    255    20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3    0    20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active     20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen    not active     20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    active     20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1    0    20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2    255    20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3    255    20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    active     20
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    installed     2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    installed     2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    active     2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    active     2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    installed     2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    installed     2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    installed     2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed     2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    installed     2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung    3000 ms    10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit    1000 ms    10
IDE09733-ENG147405-LED bar setting values-Lockout time    0 s    10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige    0 s    10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz    25    10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor    0    10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS    393210 lx    10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS    393210 lx    10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    12
IDE10298-Alternating park position 1    7.49 °    2
IDE10299-Alternating park position 2    29.49 °    2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    1    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    1    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    1    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    5    256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    84    256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0    256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    255    256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    255    256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    255    256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0    256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    127    256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    100%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    100%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    100%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    100%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    0%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    100%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    100%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    100%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    100%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    100%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    100%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    100%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    100%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    100%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    100%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    100%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    100%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    0%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    100%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    100%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    100%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    0%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    100%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    100%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    100%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    127%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    126%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    126%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    125%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    126%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    126%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    126%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    126%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    127%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    127%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    0%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    126%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    100%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    100%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    100%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    100%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    100%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    100%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    100%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    100%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    0%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    0%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    100%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    100%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    0%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    100%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    100%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    100%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    0%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    0%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    0%    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    0.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
MAS01490-Energy management    active     1
MAS05055-lower turn position    31.49 °    2
MAS05056-upper turn position    170.49 °    2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck    active     8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb    not active     8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG    not active     8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global    active     8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen    active     8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen    active     8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen    not active     8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach    not active     8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung    active     8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy    active     8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder    active     8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung    active     8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy    active     8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder    active     8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein    not active     8
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1.2    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1.2    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    Footwell     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    Footwell     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    Cockpit     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    I-panel     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    single-color     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    multicolor     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    multicolor     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    multicolor     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    multicolor     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    1    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    2    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    3    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    4    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe    0    11
ENG99457-ENG117394-Head area heater-blower_speed    1    2
ENG99457-ENG98971-Head area heater-Temperature    -2    2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0    0 ms    22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1    200 ms    22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10    2000 ms    22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2    400 ms    22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3    600 ms    22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4    800 ms    22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5    1000 ms    22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6    1200 ms    22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7    1400 ms    22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8    1600 ms    22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9    1800 ms    22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0    100.00%    22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1    72.00%    22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10    0.00%    22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2    48.00%    22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3    33.00%    22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4    18.00%    22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5    12.00%    22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6    8.00%    22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7    6.00%    22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8    4.00%    22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9    2.00%    22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0    0    22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1    50    22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10    0    22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2    100    22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3    200    22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4    253    22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5    0    22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6    0    22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7    0    22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8    0    22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9    0    22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0    0 lx    22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1    50 lx    22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10    0 lx    22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2    100 lx    22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3    200    22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4    500    22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5    0    22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6    0 lx    22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7    0 lx    22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8    0 lx    22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9    0 lx    22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0    0 ms    22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1    200 ms    22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10    2000 ms    22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2    400 ms    22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3    600 ms    22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4    800 ms    22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5    1000 ms    22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6    1200 ms    22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7    1400 ms    22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8    1600 ms    22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9    1800 ms    22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0    0.00%    22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1    1.00%    22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10    100.00%    22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2    3.00%    22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3    5.00%    22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4    11.00%    22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5    22.00%    22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6    40.00%    22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7    80.00%    22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8    95.00%    22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9    100.00%    22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0    0.00%    12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1    6.00%    12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2    16.00%    12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3    30.00%    12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4    60.00%    12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5    100.00%    12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0    10    12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1    10    12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2    100    12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3    150    12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4    220    12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5    253    12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0    0 lx    10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1    8 lx    10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2    200 lx    10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3    300 lx    10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4    500 lx    10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0    16    10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1    16    10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2    100    10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3    100    10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4    100    10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0    0 lx    10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1    8 lx    10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2    220 lx    10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3    300 lx    10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4    500 lx    10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0    6    10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1    6    10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2    100    10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3    100    10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4    100    10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0    0    12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1    10    12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2    50    12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3    100    12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4    220    12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5    253    12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0    2.00%    12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1    2.00%    12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2    6.00%    12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3    10.00%    12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4    80.00%    12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5    100.00%    12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0    0 lx    8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1    8 lx    8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2    50 lx    8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3    500 lx    8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0    100    8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1    100    8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2    100    8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3    100    8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0    0 lx    8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1    8 lx    8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2    50 lx    8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3    500 lx    8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0    6    8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1    6    8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2    100    8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3    100    8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0    0.00%    6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1    50.00%    6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2    100.00%    6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0    0.00%    6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1    50.00%    6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2    100.00%    6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0    0 lx    8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1    8 lx    8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2    50 lx    8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3    500 lx    8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0    100    8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1    100    8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2    100    8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3    100    8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0    0 lx    8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1    8 lx    8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2    50 lx    8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3    500 lx    8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0    6    8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1    6    8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2    100    8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3    100    8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0    0.00%    6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1    50.00%    6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2    100.00%    6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0    0.00%    6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1    50.00%    6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2    100.00%    6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1    100 ms    10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2    160 ms    10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3    200 ms    10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4    260 ms    10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1    5    10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2    15    10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3    10    10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4    100    10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    100    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    12 - Blinkleuchten     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    0    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    0    16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    0    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    not active     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    not active     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    not active     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    0    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    0    16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    0    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    not active     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    not active     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    not active     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    100    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    10 - allgemeine Scheinwerfer     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    Abbiegelicht links     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    100    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    10 - allgemeine Scheinwerfer     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Nebellicht rechts     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    Abbiegelicht rechts     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15    maximize     16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15    maximize     16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15    maximize     16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15    0    16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15    0    16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15    0    16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15    0    16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15    0    16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15    0    16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15    not active     16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15    Always     16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15    not active     16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15    not active     16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15    not active     16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15    not active     16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15    not active     16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15    not active     16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15    not active     16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    0    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    0    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    0    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    0    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    not active     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    not active     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    0    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    0    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    0    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    not active     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    not active     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    100    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    12 - Blinkleuchten     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    minimize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    28    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    34 - LED Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    minimize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    28    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    34 - LED Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    28    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    100    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    38 - LED Blinkleuchten     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    not active     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Blinken links Hellphase     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    28    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    100    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    38 - LED Blinkleuchten     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    not active     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    not active     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Blinken rechts Hellphase     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    100    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    18 - 2* 5W     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    0    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    0    16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0    16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    not active     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    Always     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    not active     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    28    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    47    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    32 - allgemeine LED bis 12W     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    100    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0    16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    32 - allgemeine LED bis 12W     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    only_if_closed     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    100    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    45    16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    0    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    not active     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    127    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    100    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    0    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    18 - 2* 5W     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    Dimmer terminal 58xs     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    Interior lighting     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    100    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    46    16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    0    16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    not active     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    minimize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    100    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    31    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    43    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    48    16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Blinken links aktiv (beide Phasen)     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    minimize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    100    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    31    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    44    16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    4C     16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Blinken rechts aktiv (beide Phasen)     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    100    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    11 - Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    not active     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    100    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    11 - Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    not active     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    100    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    1C     16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    37    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    10 - allgemeine Scheinwerfer     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Left high beam     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Lichthupe generell     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    100    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    1D     16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    41    16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    10 - allgemeine Scheinwerfer     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Right high beam     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Lichthupe generell     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14    maximize     16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14    maximize     16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14    maximize     16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14    0    16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14    0    16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14    0    16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14    0    16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14    0    16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14    0    16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14    not active     16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14    Always     16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14    not active     16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14    not active     16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14    not active     16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14    not active     16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14    not active     16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14    not active     16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14    not active     16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14    not active     16
ENG126648-ENG149012-LIN-Mirrormode-Bitmaske    63    1
ENG126648-ENG148864-LIN-Mirrormode-Stage    0    1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    not active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    not active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    not active     16
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active     8
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung    active     8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
Elapsed Time: 01:59
Retrofit BCM; 09 - Central Electronics - SW:5Q0-937-084-DD HW:5Q0-937-084-CG
Removed from a 2019 Seat Leon FR, so said the eBay listing.
Code:
;SW:5Q0-937-084-DD   HW:5Q0-937-084-CG ---  Cent. Elect.
;Component:BCM MQBAB H   H38 0273     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB    19001    EV_BCMBOSCH_019.rod
;Thursday    24    March
;VCDS Version: Release 22.3.0 (x64)  Data version: 20220225 DS336.1
;VCID: 7DA7F6EB7D7E0103A44-8028
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active     10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    not active     10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    not active     10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    normal     10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    not active     10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    active     10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl    not active     10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active     10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    200 ms    10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    200 ms    10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    200 ms    10
IDE02332-Deactivate production mode    0    3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    logikgesteuert     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms    8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    -0.3 °    16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    127.5 %/s    16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides     16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h    16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 °C    16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 °C    16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    90 °    16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 °C    16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    30 °    16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.0 km/h    16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht    15 min    16
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C    11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C    11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s    11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed     11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed     11
IDE04927-ENG126845-Window heater-FSH Automatik    not active     11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed     11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed     11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage    not installed     11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    active     11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv    -50.0 °C    11
IDE04927-ENG141962-Window heater-Waschduesenheizung    installed     11
IDE04927-ENG154810-Window heater-window heating front activation time pause    240 s    11
IDE04928-MAS01577-Anti-theft protection-Parking heater    not installed     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    not active     8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick    not_active     8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI    not_active     8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    not installed     8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed     8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    No     8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    not_active     8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm    not_active     8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    Yes     8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    No     8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    10 Alarme     8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    No     8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    keine verzoegerung     8
IDE05143-MAS02985-Writing parameter-Value    132    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-Light configuration    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 49 00 00 0B 1E 7F 1E 00 7F 00 00 00 00 00 00 05 4D 00 00 0C 1E 7F 1E 00 7F 00 00 00 00 00 00 06 52 00 5D 46 08 7F 09 3A 7F 00 00 00 00 00 00 06 53 00 5E 46 08 7F 0A 3A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 06 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 06 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00     224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler    0    30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    Heizmatten am BCM     30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    10 s    30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    1.10 °C    30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    0.00 °C    30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    0.00 °C    30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    22.50 °C    30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    21.50 °C    30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    0.00 °C    30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    0.00 °C    30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    36.00 °C    30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    35.00 °C    30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    0.00 °C    30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    0.00 °C    30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    53.00 °C    30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    52.50 °C    30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI    Keine_Spannungsanforderung     30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO    Keine_Spannungsanforderung     30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed     30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75    15.0 V    30
IDE06425-Dynamometer mode: functional    not active     1
IDE06507-MAS13125-Button in center console-Function of button 1    Start-stop     8
IDE06507-MAS13129-Button in center console-Function of button 2    not coded/not installed     8
IDE06507-MAS13132-Button in center console-Function of button 3    Driving program     8
IDE06507-MAS13135-Button in center console-Function of button 4    not coded/not installed     8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED installed     8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    active     8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active     8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    active     8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    active     8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    active     8
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit     6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    active     6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     9
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    active     9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    not active     9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR     9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    installed     9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual    0    19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation    active     19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung    not active     19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default    active     19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.10 s    19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    1    19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    5    19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    20%    19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    100%    19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    100%    19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    not active     19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    not active     19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active     19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active     19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting    Sollspannungsanforderung 13.5     19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active     19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed     19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed     19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    not installed     19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default    0    5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    active     5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    installed     5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    active     5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    active     5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed     5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed     5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active     5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed     17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    not installed     17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik    not installed     17
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    0    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    0    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    1    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    0    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    0    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    0    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    0    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    1    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    1    256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    10000    256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0    256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    0    256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    100    256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    0    256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0    256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0    256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    100%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    100%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    100%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    100%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    100%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    100%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    0%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    0%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    100%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    0%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    0%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    0%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    0%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    100%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    0%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    0%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    0%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    0%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    0%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    0%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    100%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    0%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    0%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    100%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    0%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    0%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    0%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    0%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    100%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    0%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    0%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    127%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    0%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    0%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    0%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    127%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    0%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    0%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    126%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    0%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    0%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    0%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    126%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    127%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    127%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    126%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    126%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    0%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    0%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    100%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    0%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    0%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    0%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    0%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    100%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    100%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    0%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    0%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    100%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    0%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    0%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    0%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    100%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    0%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    0%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    100%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    0%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    0%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    0%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    0%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    100%    256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    3200 ms    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    0.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    0    30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    0    30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    246    30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    213    30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    251    30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    255    30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    207    30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    0    30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    34    30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    0    30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    0    30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    0    30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    56    30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    237    30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    218    30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    255    30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    230    30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    255    30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    114    30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    0    30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    255    30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    0    30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    36    30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    44    30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    193    30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    255    30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    245    30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    255    30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    246    30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    0    30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    installed     3
IDE11944-ENG141948-Keyless access and start authorization-Kessy    installed     3
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber    not active     3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    not active     3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active     3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    not active     3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit    not active     3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit    not active     3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    not active     3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module    Not available     6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor    Not available     6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch    Not available     6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module    Not available     6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head    Not available     6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor    Not available     6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn    Not available     6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module    Not available     6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module    Not available     6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module    Not available     6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior    Not available     6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater    Not available     6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater    Not available     6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest    Not available     6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion    Not available     6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest    Not available     6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion    Not available     6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control    Not available     6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch    Not available     6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    0    30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    0    30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    254    30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    83    30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    103    30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    48    30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    27    30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    0    30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    0    30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    0    30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    0    30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    0    30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    115    30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    255    30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    254    30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    254    30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    220    30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    201    30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    53    30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    0    30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    254    30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    0    30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    12    30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    0    30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    139    30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    169    30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    254    30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    252    30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    254    30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    0    30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active     5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active     5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed     5
MAS01490-ENG141950-Energy management-Hybrid vehicle    No     5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active     5
MAS01490-ENG141978-Energy management-Recuperation    active     5
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed     5
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    1000 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 50     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    4000 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    not active     24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    not active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    frueh     24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active     24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    4500 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    6000 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    2000 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2    24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    First_dtc     9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    active     4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    active     4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed     4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11    0    60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12    0    60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13    0    60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14    0    60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15    0    60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16    0    60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17    0    60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18    0    60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19    0    60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20    0    60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21    0    60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22    0    60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23    0    60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24    0    60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25    0    60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26    0    60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27    0    60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28    0    60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29    0    60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30    0    60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11    0    60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12    0    60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13    0    60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14    0    60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15    0    60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16    0    60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17    0    60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18    0    60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19    0    60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20    0    60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21    0    60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22    0    60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23    0    60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24    0    60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25    0    60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26    0    60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27    0    60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28    0    60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29    0    60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30    0    60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11    0    60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12    0    60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13    0    60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14    0    60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15    0    60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16    0    60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17    0    60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18    0    60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19    0    60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20    0    60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21    0    60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22    0    60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23    0    60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24    0    60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25    0    60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26    0    60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27    0    60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28    0    60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29    0    60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30    0    60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin    0    60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin    0    60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin    0    60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin    0    60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin    0    60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin    0    60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin    0    60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin    0    60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin    0    60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin    0    60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin    0    60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin    0    60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin    0    60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin    0    60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin    0    60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin    0    60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin    0    60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin    0    60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin    0    60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin    0    60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin    0    60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin    0    60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin    0    60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin    0    60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin    0    60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin    0    60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin    0    60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin    0    60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin    0    60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin    0    60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin    0    60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin    0    60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin    0    60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin    0    60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin    0    60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin    0    60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin    0    60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin    0    60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin    0    60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin    0    60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin    0    60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin    0    60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin    0    60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin    0    60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin    0    60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin    0    60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin    0    60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin    0    60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin    0    60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin    0    60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin    0    60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin    0    60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin    0    60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin    0    60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin    0    60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin    0    60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin    0    60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin    0    60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin    0    60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin    0    60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    multicolor     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    1    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    2    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    3    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    4    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    4    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    5    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    8    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    9    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente    Keine_Spannungsanforderung     23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0    1    23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1    1    23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10    1    23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11    1    23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12    1    23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13    1    23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14    1    23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15    1    23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2    1    23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3    1    23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4    1    23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5    1    23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6    1    23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7    1    23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8    1    23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9    1    23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken    not active     10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken    active     10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte     10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing    not active     10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    not active     10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    not active     10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10    not active     10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms    10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active     10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen    Warnblinke_zulaessig     10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken    active     10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3    10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    not active     10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active     10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing    not active     10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS    PreCrash_passiv     10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    not active     10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    not active     10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    not active     10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    not active     10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active     10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    not active     10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    not active     10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max    55 min    10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    not active     10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    not active     10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    not active     10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    not active     10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp    H7     9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren    not active     9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h    9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h    9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lamps     9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h    9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    not active     9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut    not installed     9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    not active     9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active     9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    not active     9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active     9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active     9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen     9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No     5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h    5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    active     5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    not active     5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed     5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light    not installed     18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung     18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf    0 ms    18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beam     18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    automatic     18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door     18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    active     18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH    Keine_Spannungsanforderung     18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp    Keine_Spannungsanforderung     18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    46400 lx    18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    18 lx    18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No     18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker    false     18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL    Yes     18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes     18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht    Yes     18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes     18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled     18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete     18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig     18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module    installed     18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam    Keine_Spannungsanforderung     18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    30 seconds     18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    30 seconds     18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active     18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active     18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    One-sided     18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active     18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active     18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    24 s    18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp    Sollspannungsanforderung 13.5     18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active     18
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general    not installed     3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle    not active     3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle    not active     3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer    not active     3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%    6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%    6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%    6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%    6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%    6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%    6
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present     6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    AFS: FLA: Fernlicht ueber AFS     6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    not active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    not installed     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    present     6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    not active     6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig    Keine_Spannungsanforderung     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active     6
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active     6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms    6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    0 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    active     6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    not active     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    active     6
ENG99457-ENG117394-Head area heater-blower_speed    1    2
ENG99457-ENG98971-Head area heater-Temperature    -2    2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    not installed     8
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed     8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active     8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    not installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active     8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    -100.00%    30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    -100.00%    30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    -100.00%    30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    -100.00%    30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    -100.00%    30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    -100.00%    30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    -100.00%    30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    -100    30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    -100.00%    30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    -100.00%    30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    0.00%    30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    0.00%    30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    0.00%    30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    0.00%    30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    0.00%    30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    0.00%    30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    0.00%    30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    0.00%    30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    0.00%    30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    0.00%    30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    0    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    0    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    0    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    not active     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    not active     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize     16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize     16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize     16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100    16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0    16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0    16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0    16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    6    16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0    16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    41 - LED Kleinleistung     16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always     16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Warnblinktaster_Suchbeleuchtung     16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active     16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active     16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active     16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active     16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active     16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active     16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    0    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    0    16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    0    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    not active     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    not active     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    not active     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    0    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    0    16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    0    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    not active     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    not active     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    not active     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    100    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    6 - LED Lichtmodul     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    Abbiegelicht links     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    100    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    6 - LED Lichtmodul     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Nebellicht rechts     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    Abbiegelicht rechts     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    minimize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    127    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    41    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    8    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    48 - LED BLK Open Load U ab 65     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    only_if_closed     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    Blinken links Hellphase     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    Blinken links Dunkelphase     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    minimize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    127    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    42    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    18    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    48 - LED BLK Open Load U ab 65     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    only_if_closed     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    Blinken rechts Hellphase     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    Blinken rechts Dunkelphase     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    minimize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    127    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    48 - LED BLK Open Load U ab 65     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    Blinken links Dunkelphase     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    minimize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    127    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    48 - LED BLK Open Load U ab 65     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    Blinken rechts Dunkelphase     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    0    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    0    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    0    16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    not active     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    not active     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    127    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    2B     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    9    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    49 - LED BL Open Load U ab 65     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    127    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    2D     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    19    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    49 - LED BL Open Load U ab 65     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    0    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    49 - LED BL Open Load U ab 65     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    Quittierungsfunktion 1     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    127    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    127    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    10    16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    47 - LED 12 W Open Load U ab 65     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Coming Home oder Leaving Home aktiv     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    Daytime running lamps     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    127    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    127    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    20    16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    47 - LED 12 W Open Load U ab 65     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    Parking light right     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Coming Home oder Leaving Home aktiv     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    Daytime running lamps     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    Coming Home oder Leaving Home aktiv     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    127    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    127    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    35    16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0A     16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    47 - LED 12 W Open Load U ab 65     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    Always     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    Coming Home oder Leaving Home aktiv     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    Daytime running lamps     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    127    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    127    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    36    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    1A     16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    47 - LED 12 W Open Load U ab 65     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    Parking light right     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    Coming Home oder Leaving Home aktiv     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    Daytime running lamps     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    127    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    33    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0C     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    47 - LED 12 W Open Load U ab 65     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    only_if_closed     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Nebelschlusslicht wenn kein Anhaenger gesteckt     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    34    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    only_if_closed     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    0    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    0    16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    0    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    not active     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    not active     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    100    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    2    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    46 - LED Kleinleistung     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    0    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    0    16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    0    16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    not active     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    not active     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    0    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    0    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    0    16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    not active     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    not active     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    not active     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    not active     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    0    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    0    16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    0    16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    not active     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    not active     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    not active     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    not active     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    127    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    0    16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    49    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    5 - LED Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    Coming Home oder Leaving Home aktiv     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    Coming Home oder Leaving Home aktiv     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    127    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    0    16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    4D     16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    5 - LED Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    Coming Home oder Leaving Home aktiv     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    Coming Home oder Leaving Home aktiv     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    127    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    127    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    5D     16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    52    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    6 - LED Lichtmodul     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Versorgungsbedarf der LCM Module     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    beidseitiges Dauerparklicht     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    127    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    127    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    5E     16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    53    16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    6 - LED Lichtmodul     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Versorgungsbedarf der LCM Module     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    Parking light right     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    beidseitiges Dauerparklicht     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    30 08 00 16 02 00 7F 03 00 80 00 00 00 00 00 00 30 18 00 18 04 00 7F 05 00 80 00 00 00 00 00 00 31 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 31 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 31 00 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 2F 10 00 29 08 09 7F 1E 14 7F 00 00 00 00 00 00 2F 20 00 2A 08 0A 7F 1E 14 7F 00 00 00 00 00 00 2B 28 00 30 08 1E 7F 00 00 00 00 00 00 00 00 00 2F 0A 00 35 08 09 7F 1E 14 7F 00 00 00 00 00 00 2F 1A 00 36 08 0A 7F 1E 14 7F 00 00 00 00 00 00 2F 0C 00 33 1A 00 FF 00 00 00 00 00 00 00 00 00 09 1B 00 34 19 00 E4 00 00 00 00 00 00 00 00 00     192
ENG141662-Leuchtenkonfiguration_Sonstiges    30 08 00 41 02 00 FF 03 00 80 00 00 00 00 00 00 30 18 00 42 04 00 FF 05 00 80 00 00 00 00 00 00 2E 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 06 4C 00 64 00 00 00 00 00 00 00 00 00     128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    1-Sensor_LWR     62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    2650 mm    62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    active     62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    84.00%    62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    20.00%    62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung    -127.0 ms    62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%    62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s    62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    4.10 mm/%    62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    4.70 mm/%    62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3    4.50 mm/%    62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    3.30 mm/%    62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    3.30 mm/%    62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3    3.30 mm/%    62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Variante_1     62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    70.00%    62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    10.00 Hz    62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    Inverted     62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Positive     62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    10 mm    62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    10 mm    62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    10 mm    62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    10 mm    62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    550 mm    62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    680 mm    62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%    62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    5.00%    62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    5 km/h    62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz    62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    10.00 Hz    62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM     62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    Rear     62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    not active     62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    15.00%    62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    active     62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    5.0 %/s    62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    14.00%    62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    not installed     62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s    62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1    2.0 s    7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang    10 s    7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion    active     7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik    active     7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS    Nicht_verbaut     7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark    not active     7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze    100 m    7
ENG246957-ENG246981-Lichttaster-Lichttastermodul    lds     7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config    1    7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle    30 km/h    7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig    active     7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig    active     7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig    not active     7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active     1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active     1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active     1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active     1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active     1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active     1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    20.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    30.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    40.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    50    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    100    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    10.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    20.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    40.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -3.71%    20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -2.96%    20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -2.04%    20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -1.48%    20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -0.37%    20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -0.2    20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -0.1    20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -0.05    20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -0.01    20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    0    20
ENG122979-ENG141954-Networking-A/C electronics    installed     8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    not installed     8
ENG122979-ENG99457-Networking-Head area heater    not installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG122979-ENG141969-Networking-UGDO    not installed     8
ENG124714-ENG142044-OCU-DWA_push    not active     8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    not active     8
ENG124714-ENG246970-OCU-IAA -Nutzer_management    not installed     8
ENG124714-OCU-    not installed     8
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    not_active     8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    not active     16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    1    16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    not active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    not active     16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_inactive     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    not active     16
ENG98831-ENG142030-Personalization-Profil_Variante    Schluessel     16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    not active     16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    not active     16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    not active     16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active     16
ENG141646-MAS01065-Querschnitts_funktionen-Brand    Seat     5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active     5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    active     5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active     5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    not active     5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin A31     5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe    Keine_Spannungsanforderung     5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active     5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    not_installed     5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active     5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment    Left     5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Right     5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    5    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    installed     10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    not active     10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    2000 ms    10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    500 ms    10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms    10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms    10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    500 ms    10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen    Keine_Spannungsanforderung     10
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG    not installed     4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    SMLS     4
ENG116588-Sonderfunktionen-    not enabled     4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed     4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    not active     5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key     5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    active     5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    active     5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    active     5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    not active     5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active     5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    active     5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    active     5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    active     5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt    250    10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel    10 km/h    10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter    LIN     10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel    1000 ms    10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen    40 ms    10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx    10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx    10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx    10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx    10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx    10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6    10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6    10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20    10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50    10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100    10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx    10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx    10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx    10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx    10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx    10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6    10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6    10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20    10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50    10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100    10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms    22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms    22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms    22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms    22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms    22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms    22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms    22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms    22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms    22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms    22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms    22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%    22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    100.00%    22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%    22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    95.00%    22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    80.00%    22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    40.00%    22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    20.00%    22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    10.00%    22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    5.00%    22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    3.00%    22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    1.00%    22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s    21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM    0.00 s    21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM    0.00 s    21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI     21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    1.1 s    21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    0.0 s    21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    not active     21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active     21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active     21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    11    21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM    0.00 s    21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%    21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi     21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active     21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.2    21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    0.00%    21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0    22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50    22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0    22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100    22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200    22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253    22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0    22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0    22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0    22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0    22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0    22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx    22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    80 lx    22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx    22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    150 lx    22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    300    22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500    22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0    22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx    22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx    22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx    22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx    22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms    22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms    22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms    22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms    22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms    22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms    22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms    22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms    22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms    22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms    22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms    22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%    22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%    22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%    22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%    22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%    22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%    22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%    22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%    22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%    22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%    22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%    22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx    8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx    8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx    8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx    8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100    8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100    8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100    8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100    8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx    8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx    8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx    8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    500 lx    8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6    8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6    8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100    8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100    8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%    12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%    12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%    12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%    12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%    12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%    12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10    12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10    12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100    12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150    12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220    12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253    12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx    10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx    10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx    10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx    10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx    10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16    10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16    10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100    10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100    10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100    10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx    10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx    10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx    10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx    10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx    10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6    10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6    10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100    10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100    10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100    10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0    12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10    12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    100    12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    150    12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220    12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253    12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    5.00%    12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    5.00%    12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    15.00%    12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    40.00%    12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    82.00%    12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%    12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx    8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx    8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx    8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx    8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6    8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6    8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100    8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100    8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx    8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx    8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx    8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx    8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100    8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100    8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100    8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100    8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%    6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%    6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%    6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%    6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%    6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%    6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx    12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    200 lx    12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    400 lx    12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    600 lx    12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx    12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx    12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0    12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    84    12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    166    12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    250    12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    370    12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500    12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms    10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms    10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms    10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms    10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5    10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15    10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40    10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100    10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    not active     4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    not active     4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    Open     4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    not installed     4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    not installed     4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    not installed     4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    LIN     4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed     9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active     9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active     9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active     9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed     9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active     9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active     9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active     9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active     9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    not active     9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always     9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always     9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed     9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active     9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active     9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active     9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active     9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    active     9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active     9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active     9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active     9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar    not active     9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed     9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version    Version_1_2     9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active     7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active     7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    active     7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active     7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    not installed     7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    not installed     7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active     7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active     7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion    active     7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active     7
ENG141651-ENG141957-ZV allgemein-Radio freq.    434.42MHz     7
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional     7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch     7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Globale Entriegelung     7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    installed     7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active     3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active     3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    active     3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    not active     3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    active     3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable     3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    not active     4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    not active     4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active     7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    not installed     7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active     7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active     7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    No     7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Pulse control     7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s    7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No     7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active     7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active     7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator     7
ENG141681-IDE02021-ZV Komfort-Comfort closing    active     8
ENG141681-IDE02022-ZV Komfort-Comfort opening    active     8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    Yes     8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active     8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    active     8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s    8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active     8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    active     8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    active     8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active     8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active     8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active     8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys    not active     8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    once     8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    not active     8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    active     8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    active     8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss    2-Motorenschloesser     5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert     5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed     5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed     5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links    No     5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts    No     5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter    not installed     5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side     5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR    Yes     5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer    Yes     5
Elapsed Time: 02:15
Cuzoe
This post will contain is the VCDS screen captures of the long coding configuration of my current BCM. All of these functions have been moved into adaptations on facelift BCM's. Expect that a good portion of the adaptations channels that exist in the facelift BCM but not in the pre-facelift BCM are related to these. Also has long coding for a couple BCM connected "modules."
  • You should ignore the coding in Byte 17 for ambient lights. These bits are for ambient lighting connected directly to the BCM, which I don't know that any Golfs have. In some other MQB cars there are dual color LED (typically white in every Driving Mode, and Red in Sport/Sport equivalent) ambient lights and they get direct BCM connection.
    • I think I enabled that when I first started my RGB ambient light experimentation and never went back to change it after finding out the info previously mentioned.
  • Byte 15 Bit 7 is (I believe) is how you stop the Mode button from lighting up orange when you're in driving modes other than Normal.
    • I don't know the exact white/orange logic but I recall reading some GTI/R folks wanting to change it.
So here is all the long coding for the BCM. Bytes 18-29 are all zeroes...
Here is the long coding for the Windshield Wiper Motor (or Module, or Servo?)...
And here is the long coding for the Rain/Light/Humidity Sensor...
Cuzoe
Evolving (as I remember them) list of BCM related tweaks/mods currently implemented in my car:
  • Coming home/leaving home lights (coded to use the fog lights)
  • Fog lights as turning lights (factory function, I think, for cars that came with fogs)
  • Audi chirp alarm instead of horn for door lock/unlock
  • Hold key-fob lock/unlock for windows up/down
  • Close windows if it rains (followed a guide somewhere, can't say whether it works, I don't leave windows open)
  • OEM Mk7.5 LED Tail lights, with @JBale harness, using his coding instructions
    • I'll find the sheet and post it here at some point
    • Turn signals coded to be sequential at all times (including engine off), except when the hatch is open
  • Coded out the front "cornering" lamp, as my Osrams do not have it
    • This just prevents a soft-error in the BCM, that only showed up in a scan
  • Comfort blinker to 4 blinks
  • ESC and Driving mode buttons coded as not having orange LED, so they don't change color when out of "Normal"
  • Rear windshield wiper long coded as "not installed," deleted the rear wiper long ago
Cuzoe
So here's the VCDS long coding of my existing BCM with experimental labels enabled. A few things...
  • As before ignore the ambient light coding in Byte 17, see post 3 for the reasoning.
  • Lots of stuff here that you will have to translate if you're so inclined.
  • I will probably go through and translate anything that's present in experimental and checked
    • If there's something in experimental and not checked I will probably ignore it, for now
  • Byte 19 is an interesting one, as it may relate to the energy consumption fault sometimes seen with facelift BCM's in pre-facelift cars.
  • Bytes 20 -29 are all zeroes.
Cuzoe
First part of this post will be channels that I think are important that are not present on my prefacelift BCM
  • ENG141682-ENG141966-Front_wiper-Frontwischertyp... assumed to be comm between BCM and Wiper Module, Lin or Direct
    • Left at LIN (bus) because the wiring diagram only shows one wire from BCM to Wiper Module, I'm assuming it's LIN
Second part of this post will include channels that I find interesting and want to remember for possible future tweaks and/or retrofits:
  • ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer... Front Wiper Menu Control, not active in my car
  • IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte... Third brake light feedback on lock/unlock
  • IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn... length of horn on lock/unlock (assumed to not apply with Audi chirp)
  • IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold... max speed for cornering lights, 40kmh (about 25mph) default
  • IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel... Monitoring inside unlocking lever (car locked, windows open, alarm if someone uses inside door handle?)
xabhax
15 GTI
I gotta step my retrofit game up. Your pulling ahead :(,
Good luck with the BCM though, all those adaptation channels make my head hurt. It look me a couple days to get my xenons working as they are supposed to.
Cuzoe
My head is pre-emptively hurting as well. And I wouldn't count this as a retrofit of anything until it's done 🤣.
From what I've been told by Downtime (from some other forums) I may need to downgrade the software of the facelift BCM (from DD to CG) if I have issues with the rear defroster. I don't remember ever using but I don't want there to be a problem if I need to.
I want that Webasto... and 360 view, so hurry up with that will ya?
Cuzoe
The adaptations will not kill me, though I may kill someone, haha. I'm working my way through them, tedious though they are. I've been updating the first posts in this thread, and will continue to do so.
But I wanted to take a moment to thank @DV52 for putting together a really slick BCM compare Excel sheet using the ad-maps from my old and new BCM's. I've been using the compare plugin in Notepad++ (after messing up some setting in WinMerge) to see the two ad-maps side by side. This does work but lots of Alt-Tabbing is required. The document put together by @DV52 puts all the channels that are present in both BCM's and with not matching settings right up top. It makes it dead simple to go through and match those up. As a big relief to me this includes the all the lighting (Leuchte) channels.
As mentioned before the facelift BCM has a "Lighting Configuration" channel with a really long string that configures all of the exterior lighting. What I hadn't realized is that you can still configure a facelift BCM using the "old style" Leuchte channels and it will automatically populate the Lighting Configuration channel as appropriate (the opposite is also true, changing values in the Lighting Configuration channel changes the corresponding Leuchte channels). I should mention this is discussed in the MQB Lighting Case Study thread over Ross-Tech which I've read tens of times and didn't fully grasp until now.
In any case, on a facelift BCM equipped car this allows the 600+ Leuchte channels to be configured using just the single Lighting Configuration channel. This is nerd territory but I might love the facelift BCM.
Guto
Australia
Golf Wagon MK7
Hi there,
I followed the link in my thread in RT and registering here to following up.
I’ve been there upgrading the BCM from a MK7,5 (mine being a MK7) and had all the weird issues, I still have some ones related to the rear doors but no errors in my scan due the new BCM coming from a 2 doors GTI.
More than happy to help you out if you need and hoping this thread also help me to get those few errors sorted.;)
Thanks!
Cuzoe
@Guto if you happen to have an auto-scan and adaptation map of your pre-facelift BCM (hopefully from soon before the switch) and a current scan and adaptation map of your facelift BCM that would be great.
It would help me (and anybody else) out in my progress. And if I (or we) can help with errors I will.
Can you post a link to your RT thread as well? I'd love to read it.
Edit: I 100% read your post thinking you meant an RU (as in Drive2.ru) thread. If you meant "RT" I'd still love to read it, even though I don't know what RT is, yet, maybe 😂.
ZERO815
Köln Germany
2017 GTI SE DSG
Again very interesting work! GL
Just one quick question: "Retrofit BCM; 09 - Central Electronics - SW:5Q0-937-084-DD HW:5Q0-937-084-CG Removed from a 2019 Seat Leon FR, so said the eBay listing." - Does the Leon have the 434MHz BCM or a 315MHz BCM as the NAR MK7s have to my knowledge?
Cuzoe
That was certainly a question I had when I started this... but the facelift BCM says don't worry about it :LOL:.
Cuzoe
So here's a current ad-map of my facelift BCM. I've transferred everything applicable from my pre-facelift BCM. And to the best of my knowledge I've also set all of the pre-facelift long coding "settings" properly in their respective facelift adaptation channels. The only thing I haven't finished entirely is the interior lighting adaptations. Some of them are done (to get the on-screen options, 30 colors, AID/Infotainment colors, colors by driving profile) but some are not. Specifically there are timing adaptations (these do exist in pre-facelift BCM's by the way) so that you can have the ambient lighting come in sequence. Think something neat like footwells, door pockets, door handles, door/dash strips... but fading on with a 2 second gap between each once a door is opened. It will look like the car is "powering up" and the same sequence can be done in reverse.
I am working on a spreadsheet/list that makes sense of this. Progress will continue to be slow. All the adaptation setting I've done (on the MQB bench setup, at my computer desk) has been in the 10-15 minute windows allowed by the new baby. He is completely uninterested watching me sit here, although he's quite content to watch me walk around and do other things, haha. The document I have now won't make sense and is not consistent as I kept finding better ways to keep track of things.
Anyway... here's the 95% adapted ad-map from my new BCM, 5Q0 937 084 DD.
Code:
;SW:5Q0-937-084-DD   HW:5Q0-937-084-CG ---  Cent. Elect.
;Component:BCM MQBAB H   H38 0273     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB    19001    EV_BCMBOSCH_019_VW37.rod
;Sunday    15    May
;VCDS Version: Release 22.3.1 (x64)  Data version: 20220407 DS337.0
;VCID: 7DA7F6EB7D7E0103A49-8028
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE02152-Characteristics in production mode    2000 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    active     10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    active     10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    active     10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    short     10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    active     10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    active     10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl    not active     10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active     10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    200 ms    10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    200 ms    10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    200 ms    10
IDE02332-Deactivate production mode    0    3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    not installed     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms    8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    -63.8 °    16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.0 %/s    16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides     16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h    16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 °C    16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 °C    16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 °    16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 °C    16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    180 °    16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.0 km/h    16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht    5 min    16
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 °C    11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 °C    11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s    11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed     11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed     11
IDE04927-ENG126845-Window heater-FSH Automatik    active     11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed     11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed     11
IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage    not installed     11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active     11
IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv    -50.0 °C    11
IDE04927-ENG141962-Window heater-Waschduesenheizung    not installed     11
IDE04927-ENG154810-Window heater-window heating front activation time pause    240 s    11
IDE04928-MAS01577-Anti-theft protection-Parking heater    not installed     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    active     8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick    activ     8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI    activ     8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    Sounder_verbaut     8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed     8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    Yes     8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    not_active     8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm    activ     8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    Yes     8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    Yes     8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    10 Alarme     8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    Yes     8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    active     8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    2 sekunden verzoegerung     8
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-Light configuration    0C 34 00 14 02 00 64 00 00 00 00 00 00 00 00 00 0C 3E 00 15 04 00 64 00 00 00 00 00 00 00 00 00 00 00 00 45 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 46 08 00 64 00 00 00 00 00 00 00 00 00 09 48 00 43 14 00 64 06 00 80 08 00 1F 00 00 00 09 4C 00 44 14 00 64 07 00 80 08 00 1F 00 00 00 0B 36 00 1A 0B 00 64 00 00 00 00 00 00 00 00 00 0B 40 00 1B 0C 00 64 00 00 00 00 00 00 00 00 00 0A 37 00 1C 0D 0F 64 00 00 00 00 00 00 00 00 00 0A 41 00 1D 0E 0F 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 16 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 17 64 00 00 00 00 00 00 00 00 00     224
IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler    0    30
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    Heizmatten am BCM     30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    1 s    30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 °C    30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    22.50 °C    30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    21.50 °C    30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    22.50 °C    30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    21.50 °C    30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    0.00 °C    30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    0.00 °C    30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    42.00 °C    30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    40.00 °C    30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    53.50 °C    30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    52.50 °C    30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    53.50 °C    30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    52.50 °C    30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI    Keine_Spannungsanforderung     30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO    Keine_Spannungsanforderung     30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed     30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75    15.0 V    30
IDE06425-Dynamometer mode: functional    not active     1
IDE06507-MAS13125-Button in center console-Function of button 1    not coded/not installed     8
IDE06507-MAS13129-Button in center console-Function of button 2    not coded/not installed     8
IDE06507-MAS13132-Button in center console-Function of button 3    Driving program     8
IDE06507-MAS13135-Button in center console-Function of button 4    not coded/not installed     8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED not installed     8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    not_active     8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active     8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    not_active     8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    not_active     8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    not active     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG246992-Air conditioning/heating function via remote control-Remotestart_externe_FFB_verbaut    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    not active     8
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit     6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    10 min    6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    active     6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    not active     9
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    normal     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    active     9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    not active     9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR     9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    not installed     9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual    7    19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation    active     19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung    active     19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default    coupled     19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.50 s    19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    1    19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    5    19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    active     19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    50%    19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    100%    19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    100%    19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    active     19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active     19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    active     19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting    Keine_Spannungsanforderung     19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active     19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    installed     19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    active     19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    installed     19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    not installed     19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    active     19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default    12    5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    active     5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    installed     5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    active     5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    active     5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    installed     5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed     5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active     5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    installed     5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed     17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    not installed     17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik    not installed     17
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    1    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    1    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    1    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    111    256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    1010100    256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0    256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    11100    256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    100    256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    100000    256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0    256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0    256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    100%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    100%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    100%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    100%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    100%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    100%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    0%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    0%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    100%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    0%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    0%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    0%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    0%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    100%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    0%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    0%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    0%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    0%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    0%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    0%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    100%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    0%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    0%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    100%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    0%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    0%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    0%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    0%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    100%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    0%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    0%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    127%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    0%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    0%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    0%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    127%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    0%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    0%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    126%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    0%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    0%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    0%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    126%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    127%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    127%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    0%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    0%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    126%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    0%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    0%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    0%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    0%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    126%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    0%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    0%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    100%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    0%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    0%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    0%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    0%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    100%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    0%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    0%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    100%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    0%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    0%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    0%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    100%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    0%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    0%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    100%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    0%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    0%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    0%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    0%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    100%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    0%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    0%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    100%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    0%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    0%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    0%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    0%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    100%    256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    3200 ms    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    0.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.0 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    57    30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    255    30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    5    30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    0    30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    30    30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    70    30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    130    30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    195    30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    255    30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    255    30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    245    30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    120    30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    255    30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    255    30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    235    30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    255    30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    255    30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    240    30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    200    30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    160    30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    182    30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    0    30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    130    30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    70    30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    0    30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    0    30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    0    30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    0    30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    0    30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    0    30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    not installed     3
IDE11944-ENG141948-Keyless access and start authorization-Kessy    not installed     3
IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber    not active     3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    not active     3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active     3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    not active     3
IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit    not active     3
IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit    not active     3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    not active     3
IDE12302-SFT271873-Identification of sub-bus participant-Wiper motor control module    available.     6
IDE12302-SFT271874-Identification of sub-bus participant-Rain/Light Recognition Sensor    available.     6
IDE12302-SFT271875-Identification of sub-bus participant-Light switch    Not available     6
IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module    Not available     6
IDE12302-SFT271877-Identification of sub-bus participant-Garage door opener control head    Not available     6
IDE12302-SFT271894-Identification of sub-bus participant-Anti-theft alarm system sensor    Not available     6
IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn    available.     6
IDE12302-SFT271904-Identification of sub-bus participant-Sunroof control module    Not available     6
IDE12302-SFT271910-Identification of sub-bus participant-Roof electronics control module    Not available     6
IDE12302-SFT271928-Identification of sub-bus participant-Roof shade control module    Not available     6
IDE12302-SFT271947-Identification of sub-bus participant-Humidity sensor: interior    Not available     6
IDE12302-SFT271966-Identification of sub-bus participant-Left head area heater    Not available     6
IDE12302-SFT271967-Identification of sub-bus participant-Right head area heater    Not available     6
IDE12302-SFT272065-Identification of sub-bus participant-Blower 1 for left front backrest    Not available     6
IDE12302-SFT272067-Identification of sub-bus participant-Blower 1 for left front seat cushion    Not available     6
IDE12302-SFT272069-Identification of sub-bus participant-Blower 1 for right front backrest    Not available     6
IDE12302-SFT272071-Identification of sub-bus participant-Blower 1 for right front seat cushion    Not available     6
IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control    Not available     6
IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch    Not available     6
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    3    30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    255    30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    3    30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    3    30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    2    30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    15    30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    27    30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    43    30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    125    30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    200    30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    255    30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    146    30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    255    30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    255    30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    255    30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    255    30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    255    30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    255    30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    255    30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    255    30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    114    30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    20    30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    78    30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    59    30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    6    30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    15    30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    24    30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    3    30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    1    30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    32    30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active     5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active     5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed     5
MAS01490-ENG141950-Energy management-Hybrid vehicle    No     5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active     5
MAS01490-ENG141978-Energy management-Recuperation    active     5
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed     5
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    0 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 00     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    2000 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    active     24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    Medium     24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    active     24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    4500 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    6000 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    2000 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2    24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    First_dtc     9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    not active     4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    not active     4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed     4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11    255    60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12    255    60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13    255    60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14    255    60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15    255    60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16    255    60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17    255    60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18    240    60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19    255    60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20    235    60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21    170    60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22    130    60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23    60    60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24    0    60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25    5    60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26    0    60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27    0    60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28    0    60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29    5    60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30    0    60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11    90    60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12    40    60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13    0    60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14    0    60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15    0    60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16    0    60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17    0    60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18    116    60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19    190    60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20    121    60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21    250    60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22    255    60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23    255    60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24    255    60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25    172    60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26    125    60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27    65    60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28    0    60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29    0    60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30    0    60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11    10    60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12    30    60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13    65    60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14    130    60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15    190    60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16    220    60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17    255    60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18    252    60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19    255    60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20    217    60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21    250    60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22    255    60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23    255    60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24    255    60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25    255    60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26    255    60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27    255    60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28    250    60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29    195    60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30    130    60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin    255    60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin    255    60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin    255    60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin    247    60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin    255    60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin    255    60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin    244    60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin    250    60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin    255    60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin    100    60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin    24    60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin    18    60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin    11    60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin    4    60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin    0    60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin    5    60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin    4    60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin    1    60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin    0    60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin    0    60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin    65    60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin    20    60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin    3    60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin    38    60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin    60    60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin    30    60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin    32    60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin    134    60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin    198    60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin    255    60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin    226    60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin    235    60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin    245    60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin    255    60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin    200    60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin    178    60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin    88    60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin    3    60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin    0    60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin    0    60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin    9    60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin    1    60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin    28    60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin    63    60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin    142    60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin    188    60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin    255    60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin    255    60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin    255    60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin    130    60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin    138    60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin    152    60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin    166    60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin    182    60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin    255    60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin    255    60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin    255    60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin    255    60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin    205    60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin    155    60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    multicolor     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    1    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    2    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    3    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    4    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    4    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    5    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    8    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    9    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente    Sollspannungsanforderung 13.5     23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0    28    23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1    15    23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10    1    23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11    1    23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12    1    23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13    1    23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14    1    23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15    1    23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2    12    23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3    28    23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4    1    23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5    3    23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6    1    23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7    24    23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8    1    23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9    1    23
ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken    not active     10
ENG141649-ENG133379-Außenlicht_Blinker-Abbruch Komfortblinken    active     10
ENG141649-ENG116590-Außenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    separte     10
ENG141649-ENG121966-Außenlicht_Blinker-Crash flashing    active     10
ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken    active     10
ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung    not active     10
ENG141649-ENG142194-Außenlicht_Blinker-dynamisch_blinken_10    not active     10
ENG141649-ENG142195-Außenlicht_Blinker-Dynamische_Blink_Delay    50 ms    10
ENG141649-ENG126819-Außenlicht_Blinker-Emergency_alert_blinken    not active     10
ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen    Warnblinke_zulaessig     10
ENG141649-ENG115774-Außenlicht_Blinker-Komfortblinken    active     10
ENG141649-ENG116587-Außenlicht_Blinker-Komfortblinken Blinkzyklen    3    10
ENG141649-ENG122208-Außenlicht_Blinker-Multi_kollisions_Blinken    active     10
ENG141649-ENG122209-Außenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active     10
ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing    active     10
ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS    PreCrash_passiv     10
ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links    active     10
ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts    active     10
ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken    not active     10
ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing    not active     10
ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active     10
ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken    not active     10
ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    not active     10
ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max    55 min    10
ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS    active     10
ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN    active     10
ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf    active     10
ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu    active     10
ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp    H7     9
ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren    not active     9
ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h    9
ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h    9
ENG141647-ENG115833-Außenlicht_Front-Fahrlicht bei Tag    Daytime running lamps     9
ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h    9
ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich    active     9
ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     9
ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     9
ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut    not installed     9
ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     9
ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    active     9
ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    active     9
ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    not active     9
ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     9
ENG141647-ENG115733-Außenlicht_Front-Tagfahrlichtkontrollleuchte    not active     9
ENG141647-ENG142192-Außenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active     9
ENG141647-ENG116591-Außenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     9
ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    limitieren     9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No     5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h    5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    not active     5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    not active     5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed     5
ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather light    not installed     18
ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar über Energiemanagement     18
ENG141656-ENG142188-Außenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung     18
ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf    0 ms    18
ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten    Low beam     18
ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus    automatic     18
ENG141656-ENG116604-Außenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door     18
ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    active     18
ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     18
ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     18
ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH    Keine_Spannungsanforderung     18
ENG141656-ENG154177-Außenlicht_uebergreifend-Fog lamp    Keine_Spannungsanforderung     18
ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    46400 lx    18
ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    12 lx    18
ENG141656-ENG142189-Außenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No     18
ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     18
ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker    false     18
ENG141656-ENG141992-Außenlicht_uebergreifend-LDS_mit_AFL    Yes     18
ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes     18
ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht    Yes     18
ENG141656-ENG141993-Außenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes     18
ENG141656-ENG115657-Außenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled     18
ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete     18
ENG141656-ENG115862-Außenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig     18
ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module    not installed     18
ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam    Keine_Spannungsanforderung     18
ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     18
ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome    20 seconds     18
ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    20 seconds     18
ENG141656-ENG116602-Außenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active     18
ENG141656-ENG116606-Außenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active     18
ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert    One-sided     18
ENG141656-ENG126816-Außenlicht_uebergreifend-Standlicht aus    active     18
ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active     18
ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit    24 s    18
ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal lamp    Sollspannungsanforderung 13.5     18
ENG141656-ENG126817-Außenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active     18
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG246955-ENG246967-digital_key-central_locking_digital_key_general    not installed     3
ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle    not active     3
ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer    not active     3
ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle    not active     3
ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion    not active     3
ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer    not active     3
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%    6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%    6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%    6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%    6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%    6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%    6
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present     6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    Basis: FLA     6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    not active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    present     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    present     6
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active     6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig    Keine_Spannungsanforderung     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active     6
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active     6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms    6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    0 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active     6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    not active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    not active     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    not active     6
ENG99457-ENG117394-Head area heater-blower_speed    1    2
ENG99457-ENG98971-Head area heater-Temperature    -2    2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    not installed     8
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed     8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active     8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    not installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active     8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    -100.00%    30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    -100.00%    30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    -100.00%    30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    -100.00%    30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    -100.00%    30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    -100.00%    30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    -100.00%    30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    -100    30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    -100.00%    30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    -100.00%    30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    0.00%    30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    0.00%    30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    0.00%    30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    0.00%    30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    0.00%    30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    0.00%    30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    0.00%    30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    0.00%    30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    0.00%    30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    0.00%    30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    100    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    12 - Blinkleuchten     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize     16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize     16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize     16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100    16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0    16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0    16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0    16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    6    16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0    16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    41 - LED Kleinleistung     16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always     16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Warnblinktaster_Suchbeleuchtung     16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active     16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active     16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active     16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active     16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active     16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active     16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    0    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    0    16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    0    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    not active     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    not active     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    not active     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    0    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    0    16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    0    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    not active     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    not active     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    not active     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    100    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    22    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    38    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    10 - allgemeine Scheinwerfer     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    Nebellicht links     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    Abbiegelicht links     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    100    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    23    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    42    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    10 - allgemeine Scheinwerfer     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    Nebellicht rechts     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    Abbiegelicht rechts     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    41    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    18    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    0    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    0    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    0    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    not active     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    not active     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    0    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    0    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    0    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    not active     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    not active     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    100    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    12 - Blinkleuchten     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    minimize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    0    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    28    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    3D     16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    13    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    34 - LED Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    not active     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    not active     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    minimize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    0    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    28    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3E     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    23    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    34 - LED Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    not active     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    not active     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    28    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    100    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    38 - LED Blinkleuchten     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    Always     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    not active     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Blinken links Hellphase     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    28    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    100    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    38 - LED Blinkleuchten     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    Always     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    not active     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    aktiv 100%     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Blinken rechts Hellphase     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    100    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    18 - 2* 5W     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    0    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    0    16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    0    16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    not active     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    Always     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    not active     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    28    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    47    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    32 - allgemeine LED bis 12W     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    100    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0    16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    32 - allgemeine LED bis 12W     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    only_if_closed     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    Always     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    100    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    45    16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    0    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    not active     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    100    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    0    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    not active     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    not active     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    100    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    46    16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    0    16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    not active     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    minimize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    100    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    31    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    43    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    48    16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Blinken links aktiv (beide Phasen)     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    minimize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    100    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    31    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    44    16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    4C     16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    9 - allgemeine Glühlampe 27W: auch H15     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Blinken rechts aktiv (beide Phasen)     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    100    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    11 - Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    not active     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    100    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    11 - Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    not active     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    100    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    1C     16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    37    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    10 - allgemeine Scheinwerfer     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Left high beam     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Lichthupe generell     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    100    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    1D     16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    41    16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    10 - allgemeine Scheinwerfer     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Right high beam     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Lichthupe generell     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 22 13 00 3D 18 00 64 00 00 80 00 00 1C 00 00 00 22 23 00 3E 18 00 64 00 00 80 00 00 1C 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 26 0A 00 29 00 00 1C 02 00 64 00 00 00 00 00 00 26 1A 00 2A 00 01 1C 04 00 64 00 00 00 00 00 00 12 28 00 30 08 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 47 08 00 1C 00 00 00 00 00 00 00 00 00 20 00 00 31 3F 00 E4 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 64 00 00 00 00 00 00 00 00 00     192
ENG141662-Leuchtenkonfiguration_Sonstiges    00 00 00 41 00 00 00 00 00 00 00 00 00 00 00 00 00 18 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 06 4C 00 64 00 00 00 00 00 00 00 00 00     128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    1-Sensor_LWR     62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    2650 mm    62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    not active     62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    84.00%    62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    20.00%    62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung    -127.0 ms    62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%    62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s    62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    4.10 mm/%    62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    4.70 mm/%    62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3    4.50 mm/%    62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    3.30 mm/%    62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    3.30 mm/%    62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3    3.30 mm/%    62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Variante_1     62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    70.00%    62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    10.00 Hz    62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    Inverted     62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Positive     62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    10 mm    62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    10 mm    62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    10 mm    62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    10 mm    62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    550 mm    62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    680 mm    62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%    62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    5.00%    62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    5 km/h    62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz    62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    10.00 Hz    62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM     62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    not installed     62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    not active     62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    15.00%    62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    not active     62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    5.0 %/s    62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    14.00%    62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    not installed     62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s    62
ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1    2.0 s    7
ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang    10 s    7
ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion    active     7
ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik    active     7
ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS    Nicht_verbaut     7
ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark    not active     7
ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze    100 m    7
ENG246957-ENG246981-Lichttaster-Lichttastermodul    lds     7
ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config    1    7
ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle    30 km/h    7
ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig    active     7
ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig    not active     7
ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter    active     7
ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig    active     7
ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig    not active     7
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active     1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active     1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active     1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active     1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active     1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active     1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    20.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    30.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    40.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    50    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    100    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    10.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    20.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    40.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -3.71%    20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -2.96%    20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -2.04%    20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -1.48%    20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -0.37%    20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -0.2    20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -0.1    20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -0.05    20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -0.01    20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    0    20
ENG122979-ENG141954-Networking-A/C electronics    installed     8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    not installed     8
ENG122979-ENG99457-Networking-Head area heater    not installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG122979-ENG141969-Networking-UGDO    not installed     8
ENG124714-ENG142044-OCU-DWA_push    not active     8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    not active     8
ENG124714-ENG246970-OCU-IAA -Nutzer_management    not installed     8
ENG124714-OCU-    not installed     8
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    not_active     8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    active     16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    4    16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    active     16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG142030-Personalization-Profil_Variante    Konto (v. 1.x)     16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    active     16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    active     16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    active     16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active     16
ENG141646-MAS01065-Querschnitts_funktionen-Brand    VW     5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active     5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    active     5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active     5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    not active     5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin A31     5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe    Keine_Spannungsanforderung     5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active     5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    not_installed     5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active     5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment    Left     5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Right     5
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    not installed     10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    not active     10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    0 ms    10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    0 ms    10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms    10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms    10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    0 ms    10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen    Keine_Spannungsanforderung     10
ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG    not installed     4
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    SMLS     4
ENG116588-Sonderfunktionen-    not enabled     4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed     4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    active     5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key     5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    active     5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    active     5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    not active     5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    active     5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active     5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    active     5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    not active     5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    active     5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt    250    10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel    10 km/h    10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter    LIN     10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel    1000 ms    10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen    40 ms    10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx    10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx    10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx    10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx    10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx    10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6    10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6    10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20    10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50    10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100    10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx    10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx    10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx    10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx    10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx    10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6    10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6    10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20    10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50    10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100    10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms    22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms    22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms    22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms    22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms    22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms    22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms    22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms    22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms    22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms    22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms    22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%    22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    100.00%    22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%    22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    95.00%    22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    80.00%    22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    40.00%    22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    20.00%    22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    10.00%    22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    5.00%    22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    3.00%    22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    1.00%    22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s    21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM    0.00 s    21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM    0.00 s    21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI     21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    1.1 s    21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    0.0 s    21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    active     21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active     21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active     21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    11    21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM    0.00 s    21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%    21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi     21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active     21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.1    21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    10.00%    21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0    22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50    22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0    22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100    22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200    22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253    22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0    22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0    22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0    22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0    22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0    22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx    22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    80 lx    22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx    22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    150 lx    22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    300    22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500    22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0    22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx    22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx    22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx    22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx    22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms    22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms    22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms    22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms    22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms    22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms    22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms    22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms    22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms    22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms    22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms    22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%    22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%    22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%    22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%    22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%    22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%    22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%    22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%    22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%    22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%    22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%    22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx    8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx    8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx    8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx    8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100    8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100    8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100    8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100    8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx    8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx    8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx    8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    500 lx    8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6    8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6    8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100    8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100    8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%    12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%    12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%    12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%    12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%    12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%    12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10    12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10    12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100    12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150    12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220    12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253    12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx    10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx    10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx    10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx    10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx    10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16    10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16    10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100    10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100    10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100    10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx    10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx    10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx    10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx    10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx    10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6    10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6    10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100    10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100    10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100    10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0    12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10    12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    100    12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    150    12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220    12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253    12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    5.00%    12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    5.00%    12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    15.00%    12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    40.00%    12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    82.00%    12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%    12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx    8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx    8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx    8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx    8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6    8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6    8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100    8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100    8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx    8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx    8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx    8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx    8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100    8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100    8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100    8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100    8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%    6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%    6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%    6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%    6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%    6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%    6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx    12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    200 lx    12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    400 lx    12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    600 lx    12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx    12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx    12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0    12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    84    12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    166    12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    250    12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    370    12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500    12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms    10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms    10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms    10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms    10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5    10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15    10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40    10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100    10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    not active     4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    not active     4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting     4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    not installed     4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    not installed     4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    not installed     4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    LIN     4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed     9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active     9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active     9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active     9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed     9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active     9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active     9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen    active     9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active     9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    not active     9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always     9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always     9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed     9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active     9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active     9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active     9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active     9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung    active     9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy    active     9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder    active     9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active     9
ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar    not active     9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed     9
ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version    Version_1_2     9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active     7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active     7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    not active     7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active     7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    not installed     7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    not installed     7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active     7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active     7
ENG141651-ENG115755-ZV allgemein-Notschließfunktion    active     7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active     7
ENG141651-ENG141957-ZV allgemein-Radio freq.    315MHz     7
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional     7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch     7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Globale Entriegelung     7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    installed     7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active     3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active     3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    active     3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    active     3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable     3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    not active     4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    not active     4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active     7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    not installed     7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active     7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active     7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    No     7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Pulse control     7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s    7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No     7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active     7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active     7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator     7
ENG141681-IDE02021-ZV Komfort-Comfort closing    active     8
ENG141681-IDE02022-ZV Komfort-Comfort opening    active     8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    Yes     8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active     8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    active     8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s    8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active     8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    active     8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    active     8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active     8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active     8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    active     8
ENG141681-ENG246991-ZV Komfort-pa_Two_Keys    not active     8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    Permanent     8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    active     8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    not active     8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    not active     8
ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss    2-Motorenschloesser     5
ENG141652-ENG142043-ZV Türkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert     5
ENG141652-ENG142039-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed     5
ENG141652-ENG142038-ZV Türkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed     5
ENG141652-ENG142001-ZV Türkonfiguration-Schiebetuer_links    No     5
ENG141652-ENG142002-ZV Türkonfiguration-Schiebetuer_rechts    No     5
ENG141652-ENG142041-ZV Türkonfiguration-Schiebetueren_Crafter    not installed     5
ENG141652-ENG142244-ZV Türkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side     5
ENG141652-ENG116631-ZV Türkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     5
ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR    Yes     5
ENG141652-ENG141959-ZV Türkonfiguration-Viertuerer    Yes     5
Elapsed Time: 02:31
Guto
Australia
Golf Wagon MK7
@Guto if you happen to have an auto-scan and adaptation map of your pre-facelift BCM (hopefully from soon before the switch) and a current scan and adaptation map of your facelift BCM that would be great.
It would help me (and anybody else) out in my progress. And if I (or we) can help with errors I will.
Can you post a link to your RT thread as well? I'd love to read it.
Edit: I 100% read your post thinking you meant an RU (as in Drive2.ru) thread. If you meant "RT" I'd still love to read it, even though I don't know what RT is, yet, maybe 😂.
Hi @Cuzoe,
Here's the thread that I have in RT (Ross-Tech) regarding my AFS retrofit.
I do have the Ad-maps and scans from before and after the new BMC.
The ad-map of the old BCM:
Code:
;SW:5Q0-937-086-M   HW:5Q0-937-086-M ---  Cent. Elect. --- SA: 31347
;Component:BCM PQ37BOSCH 026 0095     Coding:03001842C24100534BE44000000403081000000000000000000000000000
;EV_BodyContrModul1UDSBosc    12003    EV_BCMBOSCH_012.rod
;Thursday    30    December    2021    13:56:13:21326
;VCDS Version: Release 21.9.0 (x64)  Data version: 20210903 DS330.0
;VCID: 44D145EA8E1EEBCBC39-8010
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA    not active     9
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    0    9
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm    active     9
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf    active     9
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     9
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer    not active     9
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren    Deactivating     9
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel    not active     9
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit    0 ms    9
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit    0 ms    9
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit    0 ms    9
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit    0 ms    9
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit    0 ms    9
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz    active     9
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status    not active     9
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung    not active     9
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     9
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus    not active     9
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube    not active     9
IDE01550-Service position    170.494336 ∞    2
IDE02152-Characteristics in production mode    0 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     2
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    Yes     2
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    not active     2
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    not active     2
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    No     2
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    normal     2
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    not active     2
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     2
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     2
IDE02332-Deactivate production mode    0    3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     3
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     3
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken    not active     3
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     3
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    3
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    3
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    3
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    3
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     3
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     3
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel    not enabled     4
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum    50%    4
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer    50%    4
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn    50%    4
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung    not enabled     4
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel    not installed     4
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     4
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    -63.75 ∞    13
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.0 %/s    13
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides     13
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h    13
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 ∞C    13
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 ∞C    13
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 ∞    13
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 ∞C    13
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    180 ∞    13
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.0 km/h    13
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     13
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger    separate     3
IDE04923-ENG115774-Turn signal control-Komfortblinken    active     3
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen    3    3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker    SMLS     3
IDE04923-ENG116588-Turn signal control-Sonderfunktionen    not enabled     3
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung    not active     3
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung    Always active     3
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor    0.10%    3
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert    10.00%    3
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze    350 km/h    14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze    350 km/h    14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich    active     14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten    klemmenabhaengig     14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit    0 km/h    14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert    One-sided     14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion    not active     14
IDE04924-ENG148888-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus    active     14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht    active     14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht    not active     14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren    not active     14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht    15 min    14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten    Low beam     5
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus    manual     5
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis    Driver door     5
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung    0    5
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung    0    5
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus    not enabled     5
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome    30 seconds     5
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP    not active     5
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung    not active     5
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP    not active     5
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    8
IDE04927-ENG116709-Window heater-Abschalttemperatur f¸r Frontscheibenheizung    35.0 ∞C    8
IDE04927-ENG116708-Window heater-Abschalttemperatur f¸r Heckscheibenheizung    35.0 ∞C    8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    time value     8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     1
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     1
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     1
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     1
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    1 Alarm     1
IDE04928-ENG148904-Anti-theft protection-‹berwachung Innenentriegelungshebel    not active     1
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    keine verzoegerung     1
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck    active     4
IDE05142-ENG116621-Access control-automatisches Entriegeln    active     4
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit    not active     4
IDE05142-ENG116706-Access control-Autounlock NAR    not active     4
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB    not active     4
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung    not active     4
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    not active     4
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels    active     4
IDE05142-ENG115722-Access control-Electrical rear lid    not active     4
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     4
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein    not active     4
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     4
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung    not active     4
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung    active     4
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock    adjustable     4
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     4
IDE05142-ENG115755-Access control-Notschlieflfunktion    active     4
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung    not active     4
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     4
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung    Always     4
IDE05142-ENG148954-Access control-Softtouch-Bet‰tigung senden    Always     4
IDE05142-ENG115758-Access control-Valet Parking    not active     4
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT    not active     4
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer    not active     4
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel    active     4
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen    not active     4
IDE05142-ENG116623-Access control-ZV Tuerentriegelung    Globale Entriegelung     4
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash    not active     4
IDE05143-MAS02985-Writing parameter-Value    130    5
IDE05143-MAS04381-Writing parameter-Parameter address    FE 00 00     5
IDE05144-Read parameter address    FE 00 00     3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0    34    560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1    3E     560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10    0    560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11    0    560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12    0    560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13    0    560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14    0    560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15    0    560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16    0    560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17    0    560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18    8    560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19    18    560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2    0    560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20    10    560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21    20    560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22    29    560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23    0A     560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24    1A     560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25    28    560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26    1C     560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27    0    560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28    0B     560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29    1B     560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3    0    560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30    0    560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31    0    560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32    0    560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33    0    560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34    0    560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4    48    560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5    4C     560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6    36    560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7    40    560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8    37    560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9    41    560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0    maximize     560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1    maximize     560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10    maximize     560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11    maximize     560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12    maximize     560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13    maximize     560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14    maximize     560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15    maximize     560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16    maximize     560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17    maximize     560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18    maximize     560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19    maximize     560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2    maximize     560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20    maximize     560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21    maximize     560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22    maximize     560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23    maximize     560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24    maximize     560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25    maximize     560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26    maximize     560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27    maximize     560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28    maximize     560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29    maximize     560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3    maximize     560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30    maximize     560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31    maximize     560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32    maximize     560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33    maximize     560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34    maximize     560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4    minimize     560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5    minimize     560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6    maximize     560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7    maximize     560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8    maximize     560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9    maximize     560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0    maximize     560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1    maximize     560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10    maximize     560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11    maximize     560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12    maximize     560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13    maximize     560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14    maximize     560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15    maximize     560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16    maximize     560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17    maximize     560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18    maximize     560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19    maximize     560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2    maximize     560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20    maximize     560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21    maximize     560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22    maximize     560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23    maximize     560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24    maximize     560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25    maximize     560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26    maximize     560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27    maximize     560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28    maximize     560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29    maximize     560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3    maximize     560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30    maximize     560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31    maximize     560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32    maximize     560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33    maximize     560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34    maximize     560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4    maximize     560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5    maximize     560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6    maximize     560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7    maximize     560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8    maximize     560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9    maximize     560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0    maximize     560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1    maximize     560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10    maximize     560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11    maximize     560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12    maximize     560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13    maximize     560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14    maximize     560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15    maximize     560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16    maximize     560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17    maximize     560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18    maximize     560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19    maximize     560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2    maximize     560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20    maximize     560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21    maximize     560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22    maximize     560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23    maximize     560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24    maximize     560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25    maximize     560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26    maximize     560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27    maximize     560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28    maximize     560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29    maximize     560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3    maximize     560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30    maximize     560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31    maximize     560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32    maximize     560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33    maximize     560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34    maximize     560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4    maximize     560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5    maximize     560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6    maximize     560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7    maximize     560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8    maximize     560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9    maximize     560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0    100    560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1    100    560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10    0    560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11    0    560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12    0    560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13    0    560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14    0    560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15    0    560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16    0    560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17    0    560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18    100    560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19    100    560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2    0    560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20    100    560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21    100    560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22    100    560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23    35    560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24    35    560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25    127    560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26    100    560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27    0    560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28    100    560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29    100    560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3    0    560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30    0    560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31    0    560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32    0    560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33    0    560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34    0    560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4    100    560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5    100    560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6    100    560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7    100    560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8    100    560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9    100    560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0    0    560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1    0    560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10    0    560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11    0    560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12    0    560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13    0    560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14    0    560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15    0    560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16    0    560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17    0    560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18    0    560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19    0    560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2    0    560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20    35    560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21    35    560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22    0    560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23    100    560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24    100    560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25    0    560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26    0    560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27    0    560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28    0    560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29    0    560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3    0    560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30    0    560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31    0    560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32    0    560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33    0    560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34    0    560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4    0    560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5    0    560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6    0    560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7    0    560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8    0    560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9    0    560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0    0    560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1    0    560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10    0    560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11    0    560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12    0    560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13    0    560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14    0    560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15    0    560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16    0    560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17    0    560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18    0    560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19    0    560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2    0    560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20    0    560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21    0    560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22    0    560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23    0    560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24    0    560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25    0    560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26    0    560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27    0    560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28    0    560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29    0    560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3    0    560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30    0    560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31    0    560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32    0    560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33    0    560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34    0    560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4    31    560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5    31    560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6    0    560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7    0    560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8    0    560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9    0    560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0    0    560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1    0    560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10    0    560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11    0    560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12    0    560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13    0    560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14    0    560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15    0    560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16    0    560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17    0    560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18    0    560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19    0    560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2    0    560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20    0    560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21    0    560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22    0    560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23    0    560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24    0    560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25    0    560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26    0    560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27    0    560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28    0    560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29    0    560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3    0    560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30    0    560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31    0    560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32    0    560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33    0    560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34    0    560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4    0    560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5    0    560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6    0    560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7    0    560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8    0    560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9    0    560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0    14    560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1    15    560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10    0    560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11    0    560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12    0    560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13    0    560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14    0    560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15    0    560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16    0    560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17    0    560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18    16    560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19    18    560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2    0    560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20    39    560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21    3A     560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22    2C     560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23    29    560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24    2A     560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25    30    560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26    2F     560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27    0    560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28    31    560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29    32    560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3    0    560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30    0    560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31    0    560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32    0    560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33    0    560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34    0    560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4    43    560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5    44    560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6    1A     560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7    1B     560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8    1C     560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9    1D     560
IDE05145-ENG115873-Light configuration-Lasttyp 0    12 - Blinkleuchten     560
IDE05145-ENG115892-Light configuration-Lasttyp 1    12 - Blinkleuchten     560
IDE05145-ENG116062-Light configuration-Lasttyp 10    not active     560
IDE05145-ENG116081-Light configuration-Lasttyp 11    not active     560
IDE05145-ENG116100-Light configuration-Lasttyp 12    not active     560
IDE05145-ENG116119-Light configuration-Lasttyp 13    not active     560
IDE05145-ENG116138-Light configuration-Lasttyp 14    not active     560
IDE05145-ENG116157-Light configuration-Lasttyp 15    not active     560
IDE05145-ENG116176-Light configuration-Lasttyp 16    not active     560
IDE05145-ENG116195-Light configuration-Lasttyp 17    not active     560
IDE05145-ENG116214-Light configuration-Lasttyp 18    12 - Blinkleuchten     560
IDE05145-ENG116233-Light configuration-Lasttyp 19    12 - Blinkleuchten     560
IDE05145-ENG115910-Light configuration-Lasttyp 2    not active     560
IDE05145-ENG116252-Light configuration-Lasttyp 20    13 - Bremsleuchten     560
IDE05145-ENG116271-Light configuration-Lasttyp 21    13 - Bremsleuchten     560
IDE05145-ENG116290-Light configuration-Lasttyp 22    42 - LED dritte Bremsleuchte     560
IDE05145-ENG116309-Light configuration-Lasttyp 23    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG116328-Light configuration-Lasttyp 24    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG116347-Light configuration-Lasttyp 25    43 - allgemeine LED     560
IDE05145-ENG116366-Light configuration-Lasttyp 26    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG116385-Light configuration-Lasttyp 27    not active     560
IDE05145-ENG116404-Light configuration-Lasttyp 28    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG116423-Light configuration-Lasttyp 29    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG115929-Light configuration-Lasttyp 3    not active     560
IDE05145-ENG116442-Light configuration-Lasttyp 30    not active     560
IDE05145-ENG116461-Light configuration-Lasttyp 31    not active     560
IDE05145-ENG116480-Light configuration-Lasttyp 32    not active     560
IDE05145-ENG116499-Light configuration-Lasttyp 33    not active     560
IDE05145-ENG116518-Light configuration-Lasttyp 34    not active     560
IDE05145-ENG115948-Light configuration-Lasttyp 4    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG115967-Light configuration-Lasttyp 5    9 - allgemeine Gl¸hlampe 27W: auch H15     560
IDE05145-ENG115986-Light configuration-Lasttyp 6    11 - Abblendlicht     560
IDE05145-ENG116005-Light configuration-Lasttyp 7    11 - Abblendlicht     560
IDE05145-ENG116024-Light configuration-Lasttyp 8    10 - allgemeine Scheinwerfer     560
IDE05145-ENG116043-Light configuration-Lasttyp 9    10 - allgemeine Scheinwerfer     560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0    Always     560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1    Always     560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10    Always     560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11    Always     560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12    Always     560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13    Always     560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14    Always     560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15    Always     560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16    Always     560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17    Always     560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18    Always     560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19    Always     560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2    Always     560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20    Always     560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21    Always     560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22    Always     560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23    only_if_closed     560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24    only_if_closed     560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25    Always     560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26    only_if_closed     560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27    Always     560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28    only_if_closed     560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29    only_if_closed     560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3    Always     560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30    Always     560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31    Always     560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32    Always     560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33    Always     560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34    Always     560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4    Always     560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5    Always     560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6    Always     560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7    Always     560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8    Always     560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9    Always     560
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17    0    560
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13    0    560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0    2    560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1    4    560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10    0    560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11    0    560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12    0    560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13    0    560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14    0    560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15    0    560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16    0    560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17    0    560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18    2    560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19    4    560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2    0    560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20    24    560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21    24    560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22    24    560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23    8    560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24    8    560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25    8    560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26    28    560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27    0    560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28    25    560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29    25    560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3    0    560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30    0    560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31    0    560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32    0    560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33    0    560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34    0    560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4    20    560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5    20    560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6    11    560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7    12    560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8    13    560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9    14    560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0    0    560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1    0    560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10    0    560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11    0    560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12    0    560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13    0    560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14    0    560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15    0    560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16    0    560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18    0    560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19    0    560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2    0    560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20    0    560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21    0    560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22    0    560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23    0    560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24    0    560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25    0    560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26    0    560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27    0    560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28    0    560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29    0    560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3    0    560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30    0    560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31    0    560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32    0    560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33    0    560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34    0    560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4    0    560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5    0    560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6    0    560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7    0    560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8    15    560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9    15    560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0    0    560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1    0    560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10    0    560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11    0    560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12    0    560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14    0    560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15    0    560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16    0    560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17    0    560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18    0    560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19    0    560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2    0    560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20    8    560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21    8    560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22    0    560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23    24    560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24    24    560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25    0    560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26    0    560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27    0    560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28    0    560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29    0    560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3    0    560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30    0    560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31    0    560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32    0    560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33    0    560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34    0    560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4    6    560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5    7    560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6    0    560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7    0    560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8    0    560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9    0    560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0    0    560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1    0    560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10    0    560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11    0    560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12    0    560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13    0    560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14    0    560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15    0    560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16    0    560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17    0    560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18    0    560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19    0    560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2    0    560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20    9    560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21    10    560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22    0    560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23    0    560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24    0    560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25    0    560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26    0    560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27    0    560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28    0    560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29    0    560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3    0    560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30    0    560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31    0    560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32    0    560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33    0    560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34    0    560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4    0    560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5    0    560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6    0    560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7    0    560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8    0    560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9    0    560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0    0    560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1    0    560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10    0    560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11    0    560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12    0    560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13    0    560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14    0    560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15    0    560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16    0    560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17    0    560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18    0    560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19    0    560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2    0    560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20    0    560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21    0    560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22    0    560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23    0    560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24    0    560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25    0    560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26    0    560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27    0    560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28    0    560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29    0    560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3    0    560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30    0    560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31    0    560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32    0    560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33    0    560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34    0    560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4    31    560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5    31    560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6    0    560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7    0    560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8    0    560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9    0    560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0    0    560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1    0    560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10    0    560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11    0    560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12    0    560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13    0    560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14    0    560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15    0    560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16    0    560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17    0    560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18    0    560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19    0    560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2    0    560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20    0    560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21    0    560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22    0    560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23    0    560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24    0    560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25    0    560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26    0    560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27    0    560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28    0    560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29    0    560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30    0    560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31    0    560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32    0    560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33    0    560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34    0    560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4    9    560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6    0    560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7    0    560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8    0    560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9    0    560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3    0    560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5    10    560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0    0    560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1    0    560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10    0    560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11    0    560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12    0    560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13    0    560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14    0    560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15    0    560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16    0    560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17    0    560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18    0    560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19    0    560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2    0    560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20    0    560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21    0    560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22    0    560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23    0    560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24    0    560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25    0    560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26    0    560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27    0    560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28    0    560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29    0    560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3    0    560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30    0    560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31    0    560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32    0    560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33    0    560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34    0    560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4    0    560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5    0    560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6    0    560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7    0    560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8    0    560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9    0    560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0    0    560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1    0    560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10    0    560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11    0    560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12    0    560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13    0    560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14    0    560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15    0    560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16    0    560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17    0    560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18    0    560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19    0    560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2    0    560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20    0    560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21    0    560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22    0    560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23    0    560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24    0    560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25    0    560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26    0    560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27    0    560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28    0    560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29    0    560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3    0    560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30    0    560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31    0    560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32    0    560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33    0    560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34    0    560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4    0    560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5    0    560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6    0    560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7    0    560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8    0    560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9    0    560
IDE05145-ENG154438-Light configuration-Reserved 0    0    560
IDE05145-ENG99841-Light configuration-Reserved 1    0    560
IDE05145-ENG154357-Light configuration-Reserved 10    0    560
IDE05145-ENG154352-Light configuration-Reserved 11    0    560
IDE05145-ENG154182-Light configuration-Reserved 12    0    560
IDE05145-ENG154265-Light configuration-Reserved 13    0    560
IDE05145-ENG154334-Light configuration-Reserved 14    0    560
IDE05145-ENG154340-Light configuration-Reserved 15    0    560
IDE05145-ENG154204-Light configuration-Reserved 16    0    560
IDE05145-ENG154344-Light configuration-Reserved 17    0    560
IDE05145-ENG154195-Light configuration-Reserved 18    0    560
IDE05145-ENG154190-Light configuration-Reserved 19    0    560
IDE05145-ENG99862-Light configuration-Reserved 2    0    560
IDE05145-ENG154300-Light configuration-Reserved 20    0    560
IDE05145-ENG154439-Light configuration-Reserved 21    0    560
IDE05145-ENG154440-Light configuration-Reserved 22    0    560
IDE05145-ENG154441-Light configuration-Reserved 23    0    560
IDE05145-ENG154442-Light configuration-Reserved 24    0    560
IDE05145-ENG154443-Light configuration-Reserved 25    0    560
IDE05145-ENG154444-Light configuration-Reserved 26    0    560
IDE05145-ENG154445-Light configuration-Reserved 27    0    560
IDE05145-ENG154446-Light configuration-Reserved 28    0    560
IDE05145-ENG154447-Light configuration-Reserved 29    0    560
IDE05145-ENG101107-Light configuration-Reserved 3    0    560
IDE05145-ENG154448-Light configuration-Reserved 30    0    560
IDE05145-ENG154449-Light configuration-Reserved 31    0    560
IDE05145-ENG154450-Light configuration-Reserved 32    0    560
IDE05145-ENG154451-Light configuration-Reserved 33    0    560
IDE05145-ENG154452-Light configuration-Reserved 34    0    560
IDE05145-ENG154267-Light configuration-Reserved 4    0    560
IDE05145-ENG154291-Light configuration-Reserved 5    0    560
IDE05145-ENG154239-Light configuration-Reserved 6    0    560
IDE05145-ENG154308-Light configuration-Reserved 7    0    560
IDE05145-ENG154184-Light configuration-Reserved 8    0    560
IDE05145-ENG154255-Light configuration-Reserved 9    0    560
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    0 s    14
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 ∞C    14
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    0.00 ∞C    14
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    0.00 ∞C    14
IDE06096-ENG116596-Interior lights-Innenlicht bei offenem Heckdeckel einschalten    active     6
IDE06096-ENG116597-Interior lights-KL30G ohne PWM    not active     6
IDE06096-ENG116598-Interior lights-KL58 Einschalten mit Rampe    not active     6
IDE06096-ENG116599-Interior lights-KL58 Verriegelungsausschalten    not active     6
IDE06096-ENG116600-Interior lights-Lichtsensor wirkt auf Suchbeleuchtung    active     6
IDE06096-ENG116595-Interior lights-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung    not active     6
IDE06096-ENG115631-Interior lights-Suchbeleuchtung Festwert    100%    6
IDE06425-Dynamometer mode: functional    not active     1
IDE06864-ENG115833-Daytime running lamps-Fahrlicht bei Tag    Daytime running lamps     2
IDE06864-ENG115832-Daytime running lamps-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     2
IDE06864-ENG116592-Daytime running lamps-Standlicht aktiviert zusaetzlich Tagfahrlicht    not active     2
IDE06864-ENG116594-Daytime running lamps-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    active     2
IDE06864-ENG122184-Daytime running lamps-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active     2
IDE06864-ENG115734-Daytime running lamps-Tagfahrlicht nur in Schalterstellung AUTO    not active     2
IDE06864-ENG116593-Daytime running lamps-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    not active     2
IDE06864-ENG115733-Daytime running lamps-Tagfahrlichtkontrollleuchte    not active     2
IDE06864-ENG116591-Daytime running lamps-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     2
IDE07007-ENG148891-Air conditioning/heating function via remote control-Anzahl zulaessiger Remotestarts    2    2
IDE07007-ENG148876-Air conditioning/heating function via remote control-RemoteStart Betrieb Dauer    10 min    2
IDE07356-Position during interval mode    31.494474 ∞    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit     5
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    5
IDE08542-IDE02021-Access control 2-Comfort closing    active     6
IDE08542-IDE02022-Access control 2-Comfort opening    not active     6
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen    active     6
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen    active     6
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit    600 s    6
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus    active     6
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     6
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen    active     6
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen    active     6
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen    not active     6
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus    by convenience operation via remote control key     6
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen    No     6
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen    Yes     6
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung    No     6
IDE08542-ENG115670-Access control 2-Komfortbedienung global    active     6
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer    not active     6
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen    not active     6
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar    adjustable     6
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen    not active     6
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung    active     6
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung    active     6
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf    not active     6
IDE08542-ENG125658-Access control 2-Profilfunktion f¸r Anklappung der Auflenspiegel    active     6
IDE08542-ENG125656-Access control 2-Regenschliessen_art    once     6
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus    not active     6
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock    not_active     6
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen    not active     6
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen    not active     6
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen    not active     6
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen    tilting     6
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen    not active     6
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen    not active     6
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung    active     6
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt    active     6
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron    active     6
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal    not active     6
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar    not active     6
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung    0 ms    4
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     4
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset    not active     4
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert    0 ms    4
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    sensitive     4
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent    not installed     4
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung    present     4
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA    active     4
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben    active     1
IDE08787-ENG148893-Auxiliary functions-Menuesteuerung Garagentoroeffner    not active     1
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15    active     1
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    not active     1
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    not active     1
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken    not active     4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing    not active     4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken    not active     4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung    not active     4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken    not active     4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2    not active     4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing    not active     4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links    not active     4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts    not active     4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken    not active     4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing    not active     4
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken    not active     4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken    not active     4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS    not active     4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN    not active     4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf    not active     4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu    not active     4
IDE09595-ENG115658-Characteristic curve-x0    0 lx    18
IDE09595-ENG101574-Characteristic curve-X1    2000 lx    18
IDE09595-ENG99557-Characteristic curve-X2    4000 lx    18
IDE09595-ENG102140-Characteristic curve-X3    6000 lx    18
IDE09595-ENG102936-Characteristic curve-X4    8000 lx    18
IDE09595-ENG103548-Characteristic curve-X5    10200 lx    18
IDE09595-ENG148955-Characteristic curve-y1_0    0    18
IDE09595-ENG148956-Characteristic curve-y1_1    40    18
IDE09595-ENG148957-Characteristic curve-y1_2    90    18
IDE09595-ENG148958-Characteristic curve-y1_3    140    18
IDE09595-ENG148959-Characteristic curve-y1_4    190    18
IDE09595-ENG148960-Characteristic curve-y1_5    245    18
IDE09595-ENG148961-Characteristic curve-y2_0    0    18
IDE09595-ENG148962-Characteristic curve-y2_1    60    18
IDE09595-ENG148963-Characteristic curve-y2_2    110    18
IDE09595-ENG148964-Characteristic curve-y2_3    160    18
IDE09595-ENG148965-Characteristic curve-y2_4    210    18
IDE09595-ENG148966-Characteristic curve-y2_5    255    18
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.10 s    10
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2    10
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    10
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1    10
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     10
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     10
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    10
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    10
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    10
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     10
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     10
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     10
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     10
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     10
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     10
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    not active     10
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    not active     10
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     10
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    not active     10
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    not active     10
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     10
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     10
IDE09731-ENG148953-Int. light: 2nd generation-Helligkeit T¸rtafelbeleuchtung nicht berechnen    not active     10
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active     10
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     10
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     10
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     10
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     10
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     10
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     10
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    not installed     2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed     2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     2
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    not installed     2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     2
IDE09733-ENG147407-LED bar setting values-Filterzeit Anpassung    3000 ms    10
IDE09733-ENG147406-LED bar setting values-Filterzeit Umgebungshelligkeit    1000 ms    10
IDE09733-ENG147405-LED bar setting values-Lockout time    0 s    10
IDE09733-ENG148967-LED bar setting values-Maximale Dauer fuer konstante Anzeige    0 s    10
IDE09733-ENG148968-LED bar setting values-Maximale Helligkeitsdifferenz    25    10
IDE09733-ENG148971-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor    0 W/m≤    10
IDE09733-ENG148969-LED bar setting values-Schwellwert Plausibilisierung RLS    393210 lx    10
IDE09733-ENG148970-LED bar setting values-Schwellwert Plausibilisierung SLS    393210 lx    10
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    12
IDE10298-Alternating park position 1    7.494498 ∞    2
IDE10299-Alternating park position 2    29.494476 ∞    2
MAS01490-Energy management    active     1
MAS05055-lower turn position    31.494474 ∞    2
MAS05056-upper turn position    170.494336 ∞    2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck    active     3
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb    not active     3
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG    not active     3
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global    active     3
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen    active     3
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schlieflen    active     3
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach    not active     3
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung    active     3
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy    active     3
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder    active     3
MAS05934-ENG116714-Convert. top oper.-Verdeck schlieflen via Funkfernbedienung    active     3
MAS05934-ENG116715-Convert. top oper.-Verdeck schlieflen via Kessy    active     3
MAS05934-ENG116713-Convert. top oper.-Verdeck schlieflen via Schlieflzylinder    active     3
ENG122934-erase_error_table    5570560    3
ENG122933-error_mask    0    2
ENG117283-Frontwaschfunktion    10    2
ENG99457-ENG117394-Head area heater-blower_speed    0    2
ENG99457-ENG98971-Head area heater-Temperature    -3    2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0    0 ms    22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1    200 ms    22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10    2000 ms    22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2    400 ms    22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3    600 ms    22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4    800 ms    22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5    1000 ms    22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6    1200 ms    22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7    1400 ms    22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8    1600 ms    22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9    1800 ms    22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0    100.00%    22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1    72.00%    22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10    0.00%    22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2    48.00%    22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3    33.00%    22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4    18.00%    22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5    12.00%    22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6    8.00%    22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7    6.00%    22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8    4.00%    22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9    2.00%    22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0    0    22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1    50    22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10    0    22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2    100    22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3    200    22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4    253    22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5    0    22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6    0    22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7    0    22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8    0    22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9    0    22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0    0 lx    22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1    50 lx    22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10    0 lx    22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2    100 lx    22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3    200 lx    22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4    500 lx    22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5    0 lx    22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6    0 lx    22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7    0 lx    22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8    0 lx    22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9    0 lx    22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0    0 ms    22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1    200 ms    22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10    2000 ms    22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2    400 ms    22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3    600 ms    22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4    800 ms    22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5    1000 ms    22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6    1200 ms    22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7    1400 ms    22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8    1600 ms    22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9    1800 ms    22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0    0.00%    22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1    1.00%    22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10    100.00%    22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2    3.00%    22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3    5.00%    22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4    11.00%    22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5    22.00%    22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6    40.00%    22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7    80.00%    22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8    95.00%    22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9    100.00%    22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0    0.00%    12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1    6.00%    12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2    16.00%    12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3    30.00%    12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4    60.00%    12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5    100.00%    12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0    10    12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1    10    12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2    100    12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3    150    12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4    220    12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5    253    12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0    0 lx    10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1    8 lx    10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2    200 lx    10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3    300 lx    10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4    500 lx    10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0    16.00%    10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1    16.00%    10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2    100.00%    10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3    100.00%    10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4    100.00%    10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0    0 lx    10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1    8 lx    10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2    220 lx    10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3    300 lx    10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4    500 lx    10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0    6.00%    10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1    6.00%    10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2    100.00%    10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3    100.00%    10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4    100.00%    10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0    0    12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1    10    12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2    50    12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3    100    12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4    220    12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5    253    12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0    2.00%    12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1    2.00%    12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2    6.00%    12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3    10.00%    12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4    80.00%    12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5    100.00%    12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0    0 lx    8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1    8 lx    8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2    50 lx    8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3    500 lx    8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0    100.00%    8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1    100.00%    8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2    100.00%    8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3    100.00%    8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0    0.00%    6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1    50.00%    6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2    100.00%    6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0    0.00%    6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1    50.00%    6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2    100.00%    6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0    0 lx    8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1    8 lx    8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2    50 lx    8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3    500 lx    8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0    100.00%    8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1    100.00%    8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2    100.00%    8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3    100.00%    8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0    0 lx    8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1    8 lx    8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2    50 lx    8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3    500 lx    8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0    6.00%    8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1    6.00%    8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2    100.00%    8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3    100.00%    8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0    0.00%    6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1    50.00%    6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2    100.00%    6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0    0.00%    6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1    50.00%    6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2    100.00%    6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1    100 ms    10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2    160 ms    10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3    200 ms    10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4    260 ms    10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1    5    10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2    15    10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3    10    10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4    100    10
ENG148505-ENG115658-InnenbeleuchtungKL 58xs min-x0    0 lx    8
ENG148505-ENG101574-InnenbeleuchtungKL 58xs min-X1    8 lx    8
ENG148505-ENG99557-InnenbeleuchtungKL 58xs min-X2    50 lx    8
ENG148505-ENG102140-InnenbeleuchtungKL 58xs min-X3    500 lx    8
ENG148505-ENG115659-InnenbeleuchtungKL 58xs min-y0    6.00%    8
ENG148505-ENG99777-InnenbeleuchtungKL 58xs min-Y1    6.00%    8
ENG148505-ENG100480-InnenbeleuchtungKL 58xs min-Y2    100.00%    8
ENG148505-ENG100773-InnenbeleuchtungKL 58xs min-Y3    100.00%    8
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    100    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    12 - Blinkleuchten     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    0    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    0    16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    0    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    not active     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    not active     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    not active     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    0    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    0    16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    0    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    not active     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    not active     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    not active     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    0    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    0    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    0    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    not active     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    not active     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    not active     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    0    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    0    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    0    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    not active     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    not active     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    not active     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15    maximize     16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15    maximize     16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15    maximize     16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15    0    16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15    0    16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15    0    16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15    0    16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15    0    16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15    0    16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15    not active     16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15    Always     16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15    not active     16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15    not active     16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15    not active     16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15    not active     16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15    not active     16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15    not active     16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15    not active     16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    0    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    100    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    12 - Blinkleuchten     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    100    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    12 - Blinkleuchten     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    100    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    12 - Blinkleuchten     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    35    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    39    16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    10    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    13 - Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    35    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3A     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    20    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    13 - Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    Parking light right     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    35    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    100    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    only_if_closed     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Brake lamp     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    35    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    100    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    only_if_closed     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    not active     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Brake lamp     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    100    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2F     16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    1C     16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    only_if_closed     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    0    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    0    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    not active     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    not active     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    100    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    only_if_closed     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    only_if_closed     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    maximize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    0    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    0    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    0    16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    0    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    not active     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    not active     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    not active     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    not active     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    not active     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    0    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    0    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    not active     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    not active     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    maximize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    0    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    0    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    0    16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    0    16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    not active     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    not active     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    not active     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    not active     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    not active     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    minimize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    100    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    0    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    31    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    43    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    48    16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Blinken links aktiv (beide Phasen)     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    not active     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    Standlicht vorn (Positionslicht: Begrenzungslicht)     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    minimize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    100    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    0    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    31    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    44    16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    4C     16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Blinken rechts aktiv (beide Phasen)     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    not active     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    Standlicht vorn (Positionslicht: Begrenzungslicht)     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    Parking light right     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    100    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    11 - Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    not active     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    100    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    11 - Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    not active     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    100    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    1C     16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    37    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    10 - allgemeine Scheinwerfer     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Left high beam     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Lichthupe generell     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    100    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    1D     16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    41    16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    10 - allgemeine Scheinwerfer     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Right high beam     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Lichthupe generell     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14    maximize     16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14    maximize     16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14    maximize     16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14    0    16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14    0    16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14    0    16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14    0    16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14    0    16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14    0    16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14    not active     16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14    Always     16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14    not active     16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14    not active     16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14    not active     16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14    not active     16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14    not active     16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14    not active     16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14    not active     16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14    not active     16
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110.00%    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.50%    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute    40    3
ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute    60    3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30    3
Elapsed Time: 01:39
With the new BCM:
Code:
;SW:5Q0-937-084-CP   HW:5Q0-937-084-CF ---  Cent. Elect. --- SA: 31347
;Component:BCM MQBAB M+  H36 0253     Coding:000000000000000000000000000000000000000000000000000000000000
;EV_BCMMQB    18001    EV_BCMBOSCH_018.rod
;Thursday    17    March    2022    11:48:30:21326
;VCDS Version: Release 22.3.0 (x64)  Data version: 20220225 DS336.1
;VCID: 084991DAF2B60FAB872-805C
IDE00001-ENG99061-Production mode-Access control    not active     3
IDE00001-ENG115730-Production mode-Exterior lighting    not active     3
IDE00001-ENG112304-Production mode-Heckwischer    not active     3
IDE00001-ENG98647-Production mode-Interior lights    not active     3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung    not active     3
IDE00001-ENG115731-Production mode-Virtuel_pedal    not active     3
IDE00002-Transport mode    active     1
IDE00820-Activating and deactivating all development messages    not active     1
IDE01550-Service position    170.494336 ∞    2
IDE02152-Characteristics in production mode    0 ms    4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking    DELAY     10
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln    not active     10
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global    not active     10
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn    active     10
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln    not active     10
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn    short     10
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung    not active     10
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte    not active     10
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen    active     10
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl    not active     10
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl    not active     10
IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit    200 ms    10
IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit    200 ms    10
IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit    200 ms    10
IDE02332-Deactivate production mode    0    3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen    not active     8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen    not active     8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1    8 s    8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2    16 s    8
IDE02711-ENG112304-Rear wiper-Heckwischer    logikgesteuert     8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf    not active     8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck    active     8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1    5 s    8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2    3 s    8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik    7 s    8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall    7 s    8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW    active     8
IDE02711-ENG154784-Rear wiper-Spannungsanforderung_konfig_Wischer    Keine_Spannungsanforderung     8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck    active     8
IDE02711-ENG154831-Rear wiper-Zeit_wasch_min_heck    0 ms    8
IDE03638-IDE04231-Stationary cornering lamp-Steering wheel angle: offset    0.3 ∞    16
IDE03638-ENG116677-Stationary cornering lamp-Abdimmgeschwindigkeit    50.0 %/s    16
IDE03638-ENG116673-Stationary cornering lamp-bei Rueckwaertsfahrt    both sides     16
IDE03638-ENG116675-Stationary cornering lamp-Lower speed threshold    0.0 km/h    16
IDE03638-ENG116682-Stationary cornering lamp-Maximaltemperatur    100.0 ∞C    16
IDE03638-ENG116679-Stationary cornering lamp-obere Grenztemperatur    95.0 ∞C    16
IDE03638-ENG116681-Stationary cornering lamp-Oberer Lenkradwinkel    120 ∞    16
IDE03638-ENG116680-Stationary cornering lamp-untere Grenztemperatur    80.0 ∞C    16
IDE03638-ENG116678-Stationary cornering lamp-Unterer Lenkradwinkel    80 ∞    16
IDE03638-ENG116676-Stationary cornering lamp-Upper speed threshold    40.0 km/h    16
IDE03638-ENG116674-Stationary cornering lamp-Vorschrift    ECE R119     16
IDE03638-ENG115830-Stationary cornering lamp-Zeitwert Einschaltzeit Abbiegelicht    15 min    16
IDE03787-Activate left/right hand drive switch-over    not active     1
IDE04927-IDE01446-Window heater-Running time of heated front window    240 s    11
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung    35.0 ∞C    11
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung    35.0 ∞C    11
IDE04927-ENG142251-Window heater-Frontscheibenheizung _maximale_Dauer    0 s    11
IDE04927-ENG142035-Window heater-Frontscheibenheizung_LED_direkt    not installed     11
IDE04927-ENG142018-Window heater-Frontscheibenheizungsansteuerung direkt von externem Algorithmus    not installed     11
IDE04927-ENG126845-Window heater-FSH Automatik    active     11
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert    600 s    11
IDE04927-ENG141955-Window heater-heizbare Heckscheibe    installed     11
IDE04927-ENG142021-Window heater-Heizbare_Frontscheibe    not installed     11
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH    active     11
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH    not active     11
IDE04927-ENG141962-Window heater-Waschduesenheizung    not installed     11
IDE04927-ENG154810-Window heater-window heating front activation time pause    240 s    11
IDE04928-MAS01577-Anti-theft protection-Parking heater    not installed     8
IDE04928-ENG115867-Anti-theft protection-Akustischer Alarm Signalhorn    not active     8
IDE04928-ENG115864-Anti-theft protection-Alarmsignal    frequency modulated     8
IDE04928-ENG141960-Anti-theft protection-Anti-theft alarm system    not active     8
IDE04928-ENG154588-Anti-theft protection-Deaktivierung DWA-Sensoren via Doppelklick    not_active     8
IDE04928-ENG154589-Anti-theft protection-Deaktivierung_DWA_Sensoren_HMI    activ     8
IDE04928-ENG115865-Anti-theft protection-DWA Alarmverzoegerung    not active     8
IDE04928-ENG115812-Anti-theft protection-DWA Camper Modus    not active     8
IDE04928-ENG142007-Anti-theft protection-DWA_Einfachhorn_oder_Sounder    Sounder_verbaut     8
IDE04928-ENG141961-Anti-theft protection-Heckscheibenbruchsensor    not installed     8
IDE04928-ENG142006-Anti-theft protection-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet    No     8
IDE04928-ENG142249-Anti-theft protection-OBD Alarm    activ     8
IDE04928-ENG154722-Anti-theft protection-RHF_Panikalarm    not_active     8
IDE04928-ENG142009-Anti-theft protection-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv)    No     8
IDE04928-ENG142010-Anti-theft protection-Sensor_fuer_Innenraumueberwachung    Yes     8
IDE04928-ENG115866-Anti-theft protection-Sirenen Alarmzahl    1 Alarm     8
IDE04928-ENG142008-Anti-theft protection-tilt_sensor    Yes     8
IDE04928-ENG126842-Anti-theft protection-Ueberwachung Innenentriegelungshebel    not active     8
IDE04928-ENG115868-Anti-theft protection-Verzoegerung Panikalarm    keine verzoegerung     8
IDE05144-Read parameter address    00 00 00     3
IDE05145-Light configuration    21 34 00 14 02 00 7F 00 00 00 00 00 00 00 00 00 21 3E 00 15 04 00 7F 00 00 00 00 00 00 00 00 00 04 48 00 00 15 00 64 07 00 80 08 09 1A 00 00 00 04 4C 00 4C 15 00 64 07 00 80 08 0A 1A 00 00 00 01 3A 00 49 14 00 7F 08 09 7F 00 00 00 00 00 00 01 44 00 4B 14 00 7F 08 0A 7F 00 00 00 00 00 00 03 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 03 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 24 35 00 26 08 09 7F 00 00 00 00 00 00 00 00 00 24 3F 00 27 08 0A 7F 00 00 00 00 00 00 00 00 00 02 37 00 1E 0D 0F 7F 00 00 00 00 00 00 00 00 00 02 41 00 1F 0E 0F 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00     224
IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN    not_installed     30
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss    0 s    30
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss    0.00 ∞C    30
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle    0.00 ∞C    30
IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI    Keine_Spannungsanforderung     30
IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO    Keine_Spannungsanforderung     30
IDE06089-ENG141977-Seat heater level current consumption allocation-Sitzheizungsfreigabe    not installed     30
IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75    15.0 V    30
IDE06425-Dynamometer mode: functional    not active     1
IDE06507-MAS13125-Button in center console-Function of button 1    Start-stop     8
IDE06507-MAS13129-Button in center console-Function of button 2    not coded/not installed     8
IDE06507-MAS13132-Button in center console-Function of button 3    not coded/not installed     8
IDE06507-MAS13135-Button in center console-Function of button 4    not coded/not installed     8
IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED    LED installed     8
IDE07007-ENG142253-Air conditioning/heating function via remote control-Abbruch_d_Warnblinker_moeglich    active     8
IDE07007-ENG142252-Air conditioning/heating function via remote control-Abbruch_Hupen_RSt    not active     8
IDE07007-ENG142255-Air conditioning/heating function via remote control-Aktivierung_Drehzahlanzeige    active     8
IDE07007-ENG142254-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Akustik    active     8
IDE07007-ENG128461-Air conditioning/heating function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt    active     8
IDE07007-ENG115720-Air conditioning/heating function via remote control-Remote Start    not installed     8
IDE07007-ENG128460-Air conditioning/heating function via remote control-Rueckmeldung_bei_Aktivierung    active     8
IDE07356-Position during interval mode    31.494474 ∞    2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs    abschalten nach der Nachlaufzeit     6
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit    30 min    6
IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein    active     6
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen    active     9
IDE08786-ENG141956-Assistance light functions-Humidity sensor    installed     9
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit    sensitive     9
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe    active     9
IDE08786-ENG142228-Assistance light functions-Maskierung_Regenfunktion    not active     9
IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor    LIN_REGEN_LICHT_SENSOR     9
IDE08786-ENG124476-Assistance light functions-Sunlight photo sensor    not installed     9
IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual    7    19
IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation    not active     19
IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung    not active     19
IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default    active     19
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit    0.10 s    19
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1    2    19
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2    3    19
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3    1    19
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach    80%    19
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe    2    19
IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum    50%    19
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole    80%    19
IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer    50%    19
IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn    50%    19
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen    active     19
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen    active     19
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen    active     19
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen    active     19
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen    not active     19
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen    active     19
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen    active     19
IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen    not active     19
IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten    active     19
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig    not active     19
IDE09731-ENG98648-Int. light: 2nd generation-Interior lighting    Keine_Spannungsanforderung     19
IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM    not active     19
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig    not active     19
IDE09731-ENG142031-Int. light: 2nd generation-LIN-Dachkonsole mit Flaechenlicht    not installed     19
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig    not active     19
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren    not active     19
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig    not active     19
IDE09731-ENG116687-Int. light: 2nd generation-Tuerinnengriff mit Tuertafel    not installed     19
IDE09731-ENG116686-Int. light: 2nd generation-Tuerinnengriffbeleuchtung mit I-Tafel    not installed     19
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig    active     19
IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G    installed     19
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel    not active     19
IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default    0    5
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI    active     5
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel    not installed     5
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel    not installed     5
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher    not installed     5
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen    active     5
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus    active     5
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung    not installed     5
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung    not installed     5
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil    not installed     5
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI    not installed     5
IDE09732-ENG114629-Interior light: light configuration-Footwell lighting    installed     5
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI    not active     5
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar    not active     5
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung    not installed     5
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung    not installed     5
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne    30%    17
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz    25%    17
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne    30%    17
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz    25%    17
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne    58%    17
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz    53%    17
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne    58%    17
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz    53%    17
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne    85%    17
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz    80%    17
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne    85%    17
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz    80%    17
IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung    not installed     17
IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar    not installed     17
IDE09761-ENG142025-Seat fan charac. curve-Sitzpneumatik    not installed     17
IDE10298-Alternating park position 1    7.494498 ∞    2
IDE10299-Alternating park position 2    29.494476 ∞    2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit    1    256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach    1    256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum    0.2    256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel    1    256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher    1    256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko    1    256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd    1    256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer    0.6    256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI    0    256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2    0    256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3    0    256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4    0    256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI    0    256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2    0    256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3    0    256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4    0    256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab    1    256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf    1    256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI    0    256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay    0    256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum    70%    256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren    96%    256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum    70%    256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren    96%    256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum    70%    256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren    96%    256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum    70%    256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren    96%    256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit    100%    256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach    100%    256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum    70%    256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht    100%    256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel    100%    256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher    100%    256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko    100%    256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd    100%    256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren    96%    256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit    100%    256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach    100%    256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum    0%    256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht    100%    256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel    100%    256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher    100%    256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko    100%    256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd    100%    256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren    0%    256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum    70%    256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren    96%    256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit    100%    256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach    100%    256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum    127%    256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel    100%    256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko    100%    256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd    100%    256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren    127%    256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit    126%    256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach    126%    256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum    126%    256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht    0%    256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel    126%    256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher    126%    256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko    126%    256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd    126%    256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren    126%    256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum    127%    256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren    127%    256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit    100%    256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach    100%    256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum    126%    256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht    100%    256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel    100%    256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher    100%    256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko    100%    256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd    100%    256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren    126%    256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit    100%    256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach    100%    256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum    70%    256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht    100%    256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel    100%    256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher    100%    256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko    100%    256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd    100%    256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren    96%    256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit    100%    256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach    100%    256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum    70%    256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel    100%    256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko    100%    256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd    100%    256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren    96%    256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit    100%    256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach    100%    256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum    70%    256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht    100%    256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel    100%    256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher    100%    256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko    100%    256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd    100%    256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren    96%    256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit    100%    256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach    100%    256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum    70%    256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht    100%    256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel    100%    256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher    100%    256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko    100%    256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd    100%    256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren    96%    256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte    200 ms    256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit    0.0 s    256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach    0.0 s    256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum    0.0 s    256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht    0.0 s    256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko    0.0 s    256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren    0.0 s    256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit    0.0 s    256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach    0.0 s    256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum    2.0 s    256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht    0.0 s    256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko    0.0 s    256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren    0.5 s    256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit    0.0 s    256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach    0.0 s    256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum    0.0 s    256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht    0.0 s    256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko    0.0 s    256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren    0.0 s    256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit    0.0 s    256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach    0.0 s    256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum    0.0 s    256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht    0.0 s    256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko    0.0 s    256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren    0.0 s    256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit    0.0 s    256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach    0.0 s    256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum    0.0 s    256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht    0.0 s    256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko    0.0 s    256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren    0.0 s    256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit    0.0 s    256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach    0.0 s    256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum    0.0 s    256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht    0.0 s    256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko    0.0 s    256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren    0.0 s    256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit    0.0 s    256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach    0.0 s    256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum    0.0 s    256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht    0.0 s    256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko    0.0 s    256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren    0.0 s    256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen    0    256
IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1    255    30
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10    0    30
IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2    169    30
IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3    55    30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4    43    30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5    240    30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6    190    30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7    255    30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8    255    30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9    0    30
IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1    255    30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10    255    30
IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2    169    30
IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3    108    30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4    50    30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5    88    30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6    63    30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7    100    30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8    204    30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9    255    30
IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1    255    30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10    255    30
IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2    169    30
IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3    253    30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4    255    30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5    254    30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6    124    30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7    30    30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8    0    30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9    0    30
IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung    not installed     3
IDE11944-ENG141948-Keyless access and start authorization-Kessy    not installed     3
IDE11944-ENG116653-Keyless access and start authorization-Kessy Komfort oeffnen    not active     3
IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen    active     3
IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung    not active     3
IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung    not active     3
IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin    0    30
IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin    0    30
IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin    0    30
IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin    0    30
IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin    0    30
IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin    0    30
IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin    0    30
IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin    0    30
IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin    0    30
IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin    0    30
IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin    0    30
IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin    0    30
IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin    0    30
IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin    0    30
IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin    0    30
IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin    0    30
IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin    0    30
IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin    0    30
IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin    0    30
IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin    0    30
IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin    0    30
IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin    0    30
IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin    0    30
IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin    0    30
IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin    0    30
IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin    0    30
IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin    0    30
IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin    0    30
IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin    0    30
IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin    0    30
MAS01490-ENG142027-Energy management-Energiemanagement Abschaltung    active     5
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation    Energy management active     5
MAS01490-ENG142256-Energy management-Hochvoltfahrzeug    not installed     5
MAS01490-ENG141950-Energy management-Hybrid vehicle    No     5
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement    not active     5
MAS01490-ENG141978-Energy management-Recuperation    active     5
MAS01490-ENG142037-Energy management-Zweitbatterie    not installed     5
MAS05055-lower turn position    31.494474 ∞    2
MAS05056-upper turn position    170.494336 ∞    2
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze    1200 lx    24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze    2200 lx    24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle    0 lx    24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO    600 lx    24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten    1200 lx    24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten    2200 lx    24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red    00 00     24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell    2000 lx    24
MAS08228-ENG142230-Light sensor-HMI_Exterior_light_on_highway    not active     24
MAS08228-ENG142231-Light sensor-HMI_Exterior_light_on_rain    not active     24
MAS08228-ENG142232-Light sensor-HMI_exterior_light_sensitivity    frueh     24
MAS08228-ENG142229-Light sensor-HMI_Wiper_Comfort_Rain_Sensor_OFF    not active     24
MAS08228-ENG126628-Light sensor-LS_Error_Ausgabe    not active     24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung    0 mV    24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung    0 mV    24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke    0 lx    24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung    2    24
ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status    not active     9
ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC    00 00 00     9
ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC    First_dtc     9
ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren    not active     4
ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT    not active     4
ENG141683-ENG141975-Allwetterlicht_Spoiler-tt_spoiler    not installed     4
ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11    0    60
ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12    0    60
ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13    0    60
ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14    0    60
ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15    0    60
ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16    0    60
ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17    0    60
ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18    0    60
ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19    0    60
ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20    0    60
ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21    0    60
ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22    0    60
ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23    0    60
ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24    0    60
ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25    0    60
ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26    0    60
ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27    0    60
ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28    0    60
ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29    0    60
ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30    0    60
ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11    0    60
ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12    0    60
ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13    0    60
ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14    0    60
ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15    0    60
ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16    0    60
ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17    0    60
ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18    0    60
ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19    0    60
ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20    0    60
ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21    0    60
ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22    0    60
ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23    0    60
ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24    0    60
ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25    0    60
ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26    0    60
ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27    0    60
ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28    0    60
ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29    0    60
ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30    0    60
ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11    0    60
ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12    0    60
ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13    0    60
ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14    0    60
ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15    0    60
ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16    0    60
ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17    0    60
ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18    0    60
ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19    0    60
ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20    0    60
ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21    0    60
ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22    0    60
ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23    0    60
ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24    0    60
ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25    0    60
ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26    0    60
ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27    0    60
ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28    0    60
ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29    0    60
ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30    0    60
ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin    0    60
ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin    0    60
ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin    0    60
ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin    0    60
ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin    0    60
ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin    0    60
ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin    0    60
ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin    0    60
ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin    0    60
ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin    0    60
ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin    0    60
ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin    0    60
ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin    0    60
ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin    0    60
ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin    0    60
ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin    0    60
ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin    0    60
ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin    0    60
ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin    0    60
ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin    0    60
ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin    0    60
ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin    0    60
ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin    0    60
ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin    0    60
ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin    0    60
ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin    0    60
ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin    0    60
ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin    0    60
ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin    0    60
ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin    0    60
ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin    0    60
ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin    0    60
ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin    0    60
ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin    0    60
ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin    0    60
ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin    0    60
ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin    0    60
ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin    0    60
ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin    0    60
ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin    0    60
ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin    0    60
ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin    0    60
ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin    0    60
ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin    0    60
ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin    0    60
ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin    0    60
ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin    0    60
ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin    0    60
ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin    0    60
ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin    0    60
ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin    0    60
ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin    0    60
ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin    0    60
ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin    0    60
ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin    0    60
ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin    0    60
ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin    0    60
ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin    0    60
ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin    0    60
ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin    0    60
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1    1    30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10    1    30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11    1    30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12    1    30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13    1    30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14    1    30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15    1    30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2    1    30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3    1    30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4    1    30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5    1    30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6    1    30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7    1    30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8    1    30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9    1    30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1    door     30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10    door     30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11    door     30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12    door     30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13    door     30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14    door     30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15    door     30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2    door     30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3    door     30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4    door     30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5    door     30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6    door     30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7    door     30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8    door     30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9    door     30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1    not installed     30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10    not installed     30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11    not installed     30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12    not installed     30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13    not installed     30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14    not installed     30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15    not installed     30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2    not installed     30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3    not installed     30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4    not installed     30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5    not installed     30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6    not installed     30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7    not installed     30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8    not installed     30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9    not installed     30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12    0    60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1    0    60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10    0    60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11    0    60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13    0    60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14    0    60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15    0    60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16    0    60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17    0    60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18    0    60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19    0    60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2    0    60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20    0    60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3    0    60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4    0    60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5    0    60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6    0    60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7    0    60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8    0    60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9    0    60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1    0    60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10    0    60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11    0    60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12    0    60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13    0    60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14    0    60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15    0    60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16    0    60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17    0    60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18    0    60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19    0    60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2    0    60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20    0    60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3    0    60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4    0    60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5    0    60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6    0    60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7    0    60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9    0    60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8    0    60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1    not installed     60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10    not installed     60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11    not installed     60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12    not installed     60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13    not installed     60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14    not installed     60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15    not installed     60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16    not installed     60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17    not installed     60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18    not installed     60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19    not installed     60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2    not installed     60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20    not installed     60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3    not installed     60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4    not installed     60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5    not installed     60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6    not installed     60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7    not installed     60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9    not installed     60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8    not installed     60
ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente    Keine_Spannungsanforderung     23
ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0    1    23
ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1    1    23
ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10    1    23
ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11    1    23
ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12    1    23
ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13    1    23
ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14    1    23
ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15    1    23
ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2    1    23
ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3    1    23
ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4    1    23
ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5    1    23
ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6    1    23
ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7    1    23
ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8    1    23
ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9    1    23
ENG141649-ENG122212-Auflenlicht_Blinker-ABBA_Blinken    not active     10
ENG141649-ENG133379-Auflenlicht_Blinker-Abbruch Komfortblinken    active     10
ENG141649-ENG116590-Auflenlicht_Blinker-Blinkkontrolleuchte fuer Anhaenger    combined     10
ENG141649-ENG121966-Auflenlicht_Blinker-Crash flashing    not active     10
ENG141649-ENG122207-Auflenlicht_Blinker-DWA_Alarm_Blinken    not active     10
ENG141649-ENG122206-Auflenlicht_Blinker-DWA_Schaerfungsquittung    not active     10
ENG141649-ENG142194-Auflenlicht_Blinker-dynamisch_blinken_10    not active     10
ENG141649-ENG142195-Auflenlicht_Blinker-Dynamische_Blink_Delay    50 ms    10
ENG141649-ENG126819-Auflenlicht_Blinker-Emergency_alert_blinken    not active     10
ENG141649-ENG154601-Auflenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen    Warnblinke_zulaessig     10
ENG141649-ENG115774-Auflenlicht_Blinker-Komfortblinken    active     10
ENG141649-ENG116587-Auflenlicht_Blinker-Komfortblinken Blinkzyklen    3    10
ENG141649-ENG122208-Auflenlicht_Blinker-Multi_kollisions_Blinken    not active     10
ENG141649-ENG122209-Auflenlicht_Blinker-Notwarn_blinken_NBA_Phase_2    not active     10
ENG141649-ENG121967-Auflenlicht_Blinker-Panic flashing    not active     10
ENG141649-ENG154711-Auflenlicht_Blinker-PreCrash_RECAS    PreCrash_passiv     10
ENG141649-ENG122211-Auflenlicht_Blinker-Richtungs_blinken_links    not active     10
ENG141649-ENG122210-Auflenlicht_Blinker-Richtungs_blinken_rechts    not active     10
ENG141649-ENG122201-Auflenlicht_Blinker-Schluessel_Anlern_Blinken    not active     10
ENG141649-ENG121968-Auflenlicht_Blinker-Taxi alarm flashing    not active     10
ENG141649-ENG126629-Auflenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken    not active     10
ENG141649-ENG122202-Auflenlicht_Blinker-UGDO_ Anlern_Blinken    not active     10
ENG141649-ENG142029-Auflenlicht_Blinker-Warnblinken_durch_Fahrerassistenz    not active     10
ENG141649-ENG122214-Auflenlicht_Blinker-Warnblinken_Zuendung_AUS    active     10
ENG141649-ENG122213-Auflenlicht_Blinker-Warnblinken_Zuendung_EIN    active     10
ENG141649-ENG122204-Auflenlicht_Blinker-ZV_Blinken_auf    active     10
ENG141649-ENG122203-Auflenlicht_Blinker-ZV_Blinken_zu    active     10
ENG141647-ENG141986-Auflenlicht_Front-Abblendlicht_Leuchtentyp    H7     9
ENG141647-ENG116705-Auflenlicht_Front-Allwetterlicht Ausschaltgrenze    350 km/h    9
ENG141647-ENG116704-Auflenlicht_Front-Allwetterlicht Einschaltgrenze    350 km/h    9
ENG141647-ENG115833-Auflenlicht_Front-Fahrlicht bei Tag    Daytime running lamps     9
ENG141647-ENG142193-Auflenlicht_Front-Geschwindigkeitsabhaengiges TFL    5 km/h    9
ENG141647-ENG115861-Auflenlicht_Front-Lichthupe bei Zuendung aus moeglich    active     9
ENG141647-ENG115832-Auflenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht    not active     9
ENG141647-ENG142191-Auflenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument    not active     9
ENG141647-ENG142190-Auflenlicht_Front-Signaturlicht_verbaut    not installed     9
ENG141647-ENG116592-Auflenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht    active     9
ENG141647-ENG116594-Auflenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich    not active     9
ENG141647-ENG122184-Auflenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten    not active     9
ENG141647-ENG115734-Auflenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO    not active     9
ENG141647-ENG116593-Auflenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht    active     9
ENG141647-ENG115733-Auflenlicht_Front-Tagfahrlichtkontrollleuchte    not active     9
ENG141647-ENG142192-Auflenlicht_Front-TFL_Abschaltung_ueber_Geschwindigkeit    not active     9
ENG141647-ENG116591-Auflenlicht_Front-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge    active     9
ENG141647-ENG115860-Auflenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren    in Betrieb lassen     9
ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht    No     5
ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit    0 km/h    5
ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA    active     5
ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion    not active     5
ENG141648-ENG142004-Aussenlicht_Heck-Umgreifende_Heckklappe    not installed     5
ENG141656-ENG142020-Auflenlicht_uebergreifend-All-weather light    not installed     18
ENG141656-ENG133381-Auflenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung    abschaltbar ¸ber Energiemanagement     18
ENG141656-ENG133380-Auflenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung    abschaltbar ¸ber Energiemanagement     18
ENG141656-ENG142188-Auflenlicht_uebergreifend-bewusstes Standlicht    Aktive Begrenzung     18
ENG141656-ENG115656-Auflenlicht_uebergreifend-Coming Home Leuchten    Low beam     18
ENG141656-ENG116601-Auflenlicht_uebergreifend-Coming Home Verbaustatus    manual     18
ENG141656-ENG116604-Auflenlicht_uebergreifend-Coming-home Einschaltereignis    Driver door     18
ENG141656-ENG130581-Auflenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach    active     18
ENG141656-ENG126818-Auflenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig    Hinweis_in_LDS-Stellung_Null_und_SL     18
ENG141656-ENG137034-Auflenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer    Faktor fuer x5 Minuten     18
ENG141656-ENG154619-Auflenlicht_uebergreifend-Fernlicht_LH    Sollspannungsanforderung 13.5     18
ENG141656-ENG154177-Auflenlicht_uebergreifend-Fog lamp    Sollspannungsanforderung 13.5     18
ENG141656-ENG116608-Auflenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung    46400 lx    18
ENG141656-ENG116605-Auflenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung    12 lx    18
ENG141656-ENG142189-Auflenlicht_uebergreifend-HVLM_Ladezustandsanzeige    No     18
ENG141656-ENG115858-Auflenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht    integriert in Suchbeleuchtung     18
ENG141656-ENG142185-Auflenlicht_uebergreifend-LCM_blinker    false     18
ENG141656-ENG141992-Auflenlicht_uebergreifend-LDS_mit_AFL    Yes     18
ENG141656-ENG141991-Auflenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht    Yes     18
ENG141656-ENG141990-Auflenlicht_uebergreifend-LDS_mit_Nebellicht    No     18
ENG141656-ENG141993-Auflenlicht_uebergreifend-LDS_mit_Standlichtstellung    Yes     18
ENG141656-ENG115657-Auflenlicht_uebergreifend-Leaving-Home Verbausstatus    Enabled     18
ENG141656-ENG141989-Auflenlicht_uebergreifend-Lichtdrehschalter (LDS)    discrete     18
ENG141656-ENG115862-Auflenlicht_uebergreifend-Lichtwarnungsverhalten    klemmenabhaengig     18
ENG141656-ENG142034-Auflenlicht_uebergreifend-Light_Control_Module    installed     18
ENG141656-ENG98354-Auflenlicht_uebergreifend-Low beam    Sollspannungsanforderung 13.5     18
ENG141656-ENG115863-Auflenlicht_uebergreifend-Menueeinstellung CHO LHO    Menuesteuerung Zeit aktivieren     18
ENG141656-ENG116603-Auflenlicht_uebergreifend-Menueeinstellung Cominghome    10 seconds     18
ENG141656-ENG116607-Auflenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP    10 seconds     18
ENG141656-ENG116602-Auflenlicht_uebergreifend-Menuesteuerung Coming Home Werkseinstellung    active     18
ENG141656-ENG116606-Auflenlicht_uebergreifend-Menuesteuerung Leaving-home Freischaltung per BAP    active     18
ENG141656-ENG115859-Auflenlicht_uebergreifend-Parklicht ueber LSS aktiviert    One-sided     18
ENG141656-ENG126816-Auflenlicht_uebergreifend-Standlicht aus    active     18
ENG141656-ENG115829-Auflenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht    active     18
ENG141656-ENG133383-Auflenlicht_uebergreifend-Standlicht-Verf¸gbarkeit    24 s    18
ENG141656-ENG154174-Auflenlicht_uebergreifend-Turn signal lamp    Sollspannungsanforderung 13.5     18
ENG141656-ENG126817-Auflenlicht_uebergreifend-Umfeldleuchte als Manoevrierleuchte    not active     18
ENG126647-ENG98399-debug_light_function-Activation    0    11
ENG126647-ENG101417-debug_light_function-Adresse    0    11
ENG126647-ENG126820-debug_light_function-Bitmask    0    11
ENG126647-ENG126821-debug_light_function-Divisor    0    11
ENG126647-ENG98827-debug_light_function-Offset    0    11
ENG126647-ENG126822-debug_light_function-Polaritaet    0    11
ENG141675-ENG115658-Dimmunt_KL_58xs_PWM-x0    0.00%    6
ENG141675-ENG101574-Dimmunt_KL_58xs_PWM-X1    50.00%    6
ENG141675-ENG99557-Dimmunt_KL_58xs_PWM-X2    100.00%    6
ENG141675-ENG115659-Dimmunt_KL_58xs_PWM-y0    0.00%    6
ENG141675-ENG99777-Dimmunt_KL_58xs_PWM-Y1    50.00%    6
ENG141675-ENG100480-Dimmunt_KL_58xs_PWM-Y2    100.00%    6
ENG122934-erase_error_table    55 00 00     3
ENG122933-error_mask    0 bit    2
ENG141650-MAS13782-Fernlicht_assistent-Will Beam assistant: responsivity adjustable via BAP    present     6
ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung    NOT-DEFINED     6
ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset    not active     6
ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent    not installed     6
ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung    not installed     6
ENG141685-Front_wash_function    10    2
ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA    not active     6
ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung    800 ms    6
ENG141682-ENG115836-Front_wiper-Frontwischer Notlaufprogramm    active     6
ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf    active     6
ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig    Keine_Spannungsanforderung     6
ENG141682-ENG133394-Front_wiper-Frontwischer_Abtauposition    not active     6
ENG141682-ENG141966-Front_wiper-Frontwischertyp    LIN     6
ENG141682-ENG116617-Front_wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung    active     6
ENG141682-ENG116615-Front_wiper-Menuesteuerung Frontwischer    not active     6
ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer    0 ms    6
ENG141682-ENG115771-Front_wiper-Regensensor aktivieren    Deactivating     6
ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay    300 ms    6
ENG141682-ENG116616-Front_wiper-Tippwischen mit erhoehter Wischfrequenz    active     6
ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status    not active     6
ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung    not active     6
ENG141682-ENG126844-Front_wiper-Washer_Tipwiping_Variant    not active     6
ENG141682-ENG116613-Front_wiper-Wischer abparken bei Oeffnen der Motorhaube    not active     6
ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus    not active     6
ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube    active     6
ENG99457-ENG117394-Head area heater-blower_speed    0    2
ENG99457-ENG98971-Head area heater-Temperature    -3    2
ENG141645-MAS00211-HW_Verbau-Insufficient brake fluid    installed     8
ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid    not installed     8
ENG141645-MAS00213-HW_Verbau-Insufficient coolant    installed     8
ENG141645-MAS00214-HW_Verbau-Brake pad wear    installed     8
ENG141645-ENG142026-HW_Verbau-Druckklappe    not installed     8
ENG141645-ENG141963-HW_Verbau-Elektrische Laderaumabdeckung aktiv    not active     8
ENG141645-ENG142012-HW_Verbau-Elektrische_Laderaumabdeckung    not installed     8
ENG141645-ENG141952-HW_Verbau-Exterior temp. sensor    installed     8
ENG141645-ENG142005-HW_Verbau-Kontaktschalter_fuer_Motorhaube    installed     8
ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung    not installed     8
ENG141645-ENG142036-HW_Verbau-PTC Zuheizer    not installed     8
ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15    active     8
ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung    not active     8
ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0    100.00%    30
ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1    100.00%    30
ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2    100.00%    30
ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3    100.00%    30
ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4    83.00%    30
ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5    67.00%    30
ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6    50.00%    30
ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7    33    30
ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8    17.00%    30
ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9    0.00%    30
ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0    58.50%    30
ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1    58.50%    30
ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2    58.50%    30
ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3    58.50%    30
ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4    54.50%    30
ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5    49.50%    30
ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6    46.50%    30
ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7    35.50%    30
ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8    31.50%    30
ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9    20.00%    30
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0    maximize     16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0    maximize     16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0    maximize     16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0    127    16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0    0    16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0    0    16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0    0    16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0    14    16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0    34    16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0    33 - LED-Modul Blinkleuchten     16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0    Always     16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0    Blinken links Hellphase     16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0    not active     16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0    not active     16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0    not active     16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0    not active     16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0    not active     16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0    not active     16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0    not active     16
ENG141657-ENG116167-Leuchte 35 LED Warnblinktaster C48-Dimming Direction CD 15    maximize     16
ENG141657-ENG116171-Leuchte 35 LED Warnblinktaster C48-Dimming Direction EF 15    maximize     16
ENG141657-ENG116175-Leuchte 35 LED Warnblinktaster C48-Dimming Direction GH 15    maximize     16
ENG141657-ENG116162-Leuchte 35 LED Warnblinktaster C48-Dimmwert AB 15    100    16
ENG141657-ENG116166-Leuchte 35 LED Warnblinktaster C48-Dimmwert CD 15    0    16
ENG141657-ENG116170-Leuchte 35 LED Warnblinktaster C48-Dimmwert EF 15    0    16
ENG141657-ENG116174-Leuchte 35 LED Warnblinktaster C48-Dimmwert GH 15    0    16
ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15    63    16
ENG141657-ENG116566-Leuchte 35 LED Warnblinktaster C48-Lampendefektbitposition 15    0    16
ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15    41 - LED Kleinleistung     16
ENG141657-ENG116163-Leuchte 35 LED Warnblinktaster C48-Lichtansteuerung HD AB 15    Always     16
ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15    Unknown (76)    16
ENG141657-ENG116161-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion B 15    not active     16
ENG141657-ENG116164-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion C 15    not active     16
ENG141657-ENG116165-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion D 15    not active     16
ENG141657-ENG116168-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion E 15    not active     16
ENG141657-ENG116169-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion F 15    not active     16
ENG141657-ENG116172-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion G 15    not active     16
ENG141657-ENG116173-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion H 15    not active     16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10    maximize     16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10    maximize     16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10    maximize     16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10    127    16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10    0    16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10    0    16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10    0    16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10    1E     16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10    37    16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10    2 - Shutter: Diagnosesensierung f¸r 'LED low'     16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10    Always     16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10    Left high beam     16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10    Lichthupe generell     16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10    not active     16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10    not active     16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10    not active     16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10    not active     16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10    not active     16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10    not active     16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11    maximize     16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11    maximize     16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11    maximize     16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11    127    16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11    0    16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11    0    16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11    0    16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11    1F     16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11    41    16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11    2 - Shutter: Diagnosesensierung f¸r 'LED low'     16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11    Always     16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11    Right high beam     16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11    Lichthupe generell     16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11    not active     16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11    not active     16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11    not active     16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11    not active     16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11    not active     16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11    not active     16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12    maximize     16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12    maximize     16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12    maximize     16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12    0    16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12    0    16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12    0    16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12    0    16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12    0    16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12    0    16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12    not active     16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12    Always     16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12    not active     16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12    not active     16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12    not active     16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12    not active     16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12    not active     16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12    not active     16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12    not active     16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12    not active     16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13    maximize     16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13    maximize     16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13    maximize     16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13    0    16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13    0    16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13    0    16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13    0    16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13    0    16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13    0    16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13    not active     16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13    Always     16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13    not active     16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13    not active     16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13    not active     16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13    not active     16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13    not active     16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13    not active     16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13    not active     16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13    not active     16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16    maximize     16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16    maximize     16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16    maximize     16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16    0    16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16    0    16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16    0    16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16    0    16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16    0    16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16    0    16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16    not active     16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16    Always     16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16    not active     16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16    not active     16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16    not active     16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16    not active     16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16    not active     16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16    not active     16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16    not active     16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16    not active     16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17    maximize     16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17    maximize     16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17    maximize     16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17    0    16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17    0    16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17    0    16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17    0    16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17    0    16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17    0    16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17    not active     16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17    Always     16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17    not active     16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17    not active     16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17    not active     16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17    not active     16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17    not active     16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17    not active     16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17    not active     16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17    not active     16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18    maximize     16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18    maximize     16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18    maximize     16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18    100    16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18    0    16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18    0    16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18    0    16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18    16    16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18    8    16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18    12 - Blinkleuchten     16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18    Always     16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18    Blinken links Hellphase     16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18    not active     16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18    not active     16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18    not active     16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18    not active     16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18    not active     16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18    not active     16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18    not active     16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19    maximize     16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19    maximize     16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19    maximize     16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19    100    16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19    0    16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19    0    16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19    0    16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19    18    16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19    18    16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19    12 - Blinkleuchten     16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19    Always     16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19    Blinken rechts Hellphase     16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19    not active     16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19    not active     16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19    not active     16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19    not active     16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19    not active     16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19    not active     16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19    not active     16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1    maximize     16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1    maximize     16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1    maximize     16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1    127    16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1    0    16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1    0    16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1    0    16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1    15    16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1    3E     16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1    33 - LED-Modul Blinkleuchten     16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1    Always     16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1    Blinken rechts Hellphase     16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1    not active     16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1    not active     16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1    not active     16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1    not active     16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1    not active     16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1    not active     16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1    not active     16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20    maximize     16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20    maximize     16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20    maximize     16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20    100    16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20    35    16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20    0    16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20    0    16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20    39    16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20    10    16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20    13 - Bremsleuchten     16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20    Always     16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20    Brake lamp     16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20    not active     16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20    not active     16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20    not active     16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20    not active     16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20    not active     16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21    maximize     16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21    maximize     16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21    maximize     16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21    100    16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21    35    16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21    0    16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21    0    16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21    3A     16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21    20    16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21    13 - Bremsleuchten     16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21    Always     16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21    Brake lamp     16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21    not active     16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21    Parking light right     16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21    not active     16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21    not active     16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21    not active     16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21    not active     16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22    maximize     16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22    maximize     16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22    maximize     16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22    100    16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22    0    16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22    0    16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22    0    16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22    2C     16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22    29    16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22    42 - LED dritte Bremsleuchte     16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22    Always     16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22    Brake lamp     16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22    not active     16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22    not active     16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22    not active     16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22    not active     16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22    not active     16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22    not active     16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22    not active     16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23    maximize     16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23    maximize     16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23    maximize     16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23    35    16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23    100    16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23    0    16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23    0    16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23    29    16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23    0A     16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23    only_if_closed     16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23    not active     16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23    Brake lamp     16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23    not active     16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23    not active     16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23    not active     16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23    not active     16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23    not active     16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24    maximize     16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24    maximize     16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24    maximize     16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24    35    16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24    100    16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24    0    16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24    0    16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24    2A     16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24    1A     16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24    only_if_closed     16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24    not active     16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24    Brake lamp     16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24    not active     16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24    not active     16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24    not active     16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24    not active     16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24    not active     16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25    maximize     16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25    maximize     16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25    maximize     16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25    127    16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25    0    16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25    0    16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25    0    16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25    30    16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25    28    16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25    43 - allgemeine LED     16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25    Always     16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25    not active     16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25    not active     16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25    not active     16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25    not active     16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25    not active     16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25    not active     16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25    not active     16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26    maximize     16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26    maximize     16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26    maximize     16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26    100    16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26    0    16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26    0    16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26    0    16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26    2F     16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26    1C     16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26    only_if_closed     16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26    Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr     16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26    not active     16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26    not active     16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26    not active     16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26    not active     16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26    not active     16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26    not active     16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26    not active     16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27    maximize     16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27    maximize     16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27    maximize     16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27    0    16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27    0    16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27    0    16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27    0    16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27    0    16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27    0    16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27    not active     16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27    Always     16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27    not active     16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27    not active     16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27    not active     16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27    not active     16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27    not active     16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27    not active     16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27    not active     16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27    not active     16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28    maximize     16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28    maximize     16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28    maximize     16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28    100    16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28    0    16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28    0    16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28    0    16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28    31    16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28    0B     16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28    only_if_closed     16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28    Rueckfahrlicht     16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28    not active     16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28    not active     16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28    not active     16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28    not active     16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28    not active     16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28    not active     16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28    not active     16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29    maximize     16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29    maximize     16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29    maximize     16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29    100    16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29    0    16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29    0    16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29    0    16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29    32    16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29    1B     16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29    9 - allgemeine Gl¸hlampe 27W: auch H15     16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29    only_if_closed     16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29    Rueckfahrlicht     16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29    not active     16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29    not active     16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29    not active     16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29    not active     16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29    not active     16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29    not active     16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29    not active     16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2    minimize     16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2    maximize     16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2    maximize     16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2    100    16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2    0    16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2    26    16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2    0    16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2    0    16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2    48    16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2    4 - LED Tagfahrlichtmodul Signal     16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2    Always     16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2    Daytime running lights     16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2    not active     16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2    Blinken rechts aktiv (beide Phasen)     16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2    not active     16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2    not active     16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2    not active     16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30    maximize     16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30    maximize     16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30    maximize     16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30    100    16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30    0    16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30    0    16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30    0    16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30    2    16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30    0    16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30    36 - LED Kleinleistung     16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30    Always     16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30    Footwell lamp     16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30    not active     16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30    not active     16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30    not active     16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30    not active     16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30    not active     16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30    not active     16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30    not active     16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31    maximize     16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31    maximize     16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31    maximize     16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31    0    16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31    0    16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31    0    16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31    0    16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31    0    16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31    0    16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31    not active     16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31    Always     16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31    not active     16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31    not active     16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31    not active     16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31    not active     16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31    not active     16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31    not active     16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31    not active     16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31    not active     16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32    maximize     16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32    maximize     16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32    maximize     16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32    0    16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32    0    16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32    0    16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32    0    16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32    0    16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32    0    16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32    not active     16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32    Always     16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32    not active     16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32    not active     16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32    not active     16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32    not active     16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32    not active     16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32    not active     16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32    not active     16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32    not active     16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33    maximize     16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33    maximize     16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33    maximize     16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33    0    16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33    0    16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33    0    16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33    0    16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33    0    16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33    0    16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33    not active     16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33    Always     16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33    not active     16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33    not active     16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33    not active     16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33    not active     16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33    not active     16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33    not active     16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33    not active     16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33    not active     16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34    maximize     16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34    maximize     16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34    maximize     16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34    0    16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34    0    16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34    0    16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34    0    16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34    0    16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34    0    16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34    not active     16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34    Always     16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34    not active     16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34    not active     16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34    not active     16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34    not active     16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34    not active     16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34    not active     16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34    not active     16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34    not active     16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3    minimize     16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3    maximize     16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3    maximize     16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3    100    16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3    0    16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3    26    16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3    0    16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3    4C     16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3    4C     16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3    4 - LED Tagfahrlichtmodul Signal     16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3    Always     16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3    Daytime running lights     16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3    not active     16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3    Blinken rechts aktiv (beide Phasen)     16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3    not active     16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3    Parking light right     16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3    not active     16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3    not active     16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4    maximize     16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4    maximize     16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4    maximize     16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4    127    16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4    127    16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4    0    16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4    0    16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4    49    16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4    3A     16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4    Always     16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4    Daytime running lamps     16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4    not active     16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4    not active     16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4    not active     16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4    not active     16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4    not active     16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5    maximize     16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5    maximize     16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5    maximize     16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5    127    16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5    127    16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5    0    16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5    0    16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5    4B     16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5    44    16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5    1 - LED Tagfahrlichtmodul Versorgung     16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5    Always     16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5    Daytime running lamps     16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5    not active     16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5    Parking light right     16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5    not active     16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5    not active     16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5    not active     16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5    not active     16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6    maximize     16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6    maximize     16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6    maximize     16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6    127    16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6    0    16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6    0    16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6    0    16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6    1A     16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6    36    16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6    3 - Xenon Abblendlicht     16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6    Always     16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6    Abblendlicht links     16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6    Lichthupe generell     16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6    not active     16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6    not active     16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6    not active     16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6    not active     16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6    not active     16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6    not active     16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7    maximize     16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7    maximize     16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7    maximize     16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7    127    16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7    0    16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7    0    16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7    0    16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7    1B     16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7    40    16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7    3 - Xenon Abblendlicht     16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7    Always     16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7    Abblendlicht rechts     16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7    Lichthupe generell     16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7    not active     16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7    not active     16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7    not active     16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7    not active     16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7    not active     16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7    not active     16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8    maximize     16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8    maximize     16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8    maximize     16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8    127    16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8    0    16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8    0    16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8    0    16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8    26    16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8    35    16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8    36 - LED Kleinleistung     16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8    Always     16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8    Parklicht links (beidseitiges Parklicht aktiviert li & re)     16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8    not active     16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8    not active     16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8    not active     16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8    not active     16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8    not active     16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8    not active     16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9    maximize     16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9    maximize     16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9    maximize     16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9    127    16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9    0    16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9    0    16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9    0    16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9    27    16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9    3F     16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9    36 - LED Kleinleistung     16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9    Always     16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9    Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)     16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9    Parking light right     16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9    not active     16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9    not active     16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9    not active     16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9    not active     16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9    not active     16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9    not active     16
ENG141661-Leuchtenkonfiguration_Aussenlich_Heck    0C 08 00 16 02 00 64 00 00 00 00 00 00 00 00 00 0C 18 00 18 04 00 64 00 00 00 00 00 00 00 00 00 0D 10 00 39 18 00 64 08 09 23 00 00 00 00 00 00 0D 20 00 3A 18 00 64 08 0A 23 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 09 0A 00 29 08 00 A3 18 00 64 00 00 00 00 00 00 09 1A 00 2A 08 00 A3 18 00 64 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 09 1C 00 2F 1C 00 E4 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 09 0B 00 31 19 00 E4 00 00 00 00 00 00 00 00 00 09 1B 00 32 19 00 E4 00 00 00 00 00 00 00 00 00     192
ENG141662-Leuchtenkonfiguration_Sonstiges    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00     128
ENG141658-ENG142197-Leuchtweitenregulierung-1_Sensor_LWR    1-Sensor_LWR     62
ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges    0 mm    62
ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe    not active     62
ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze    90.00%    62
ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze    10.00%    62
ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung    -114.3 ms    62
ENG141658-ENG142209-Leuchtweitenregulierung-diagnose_soll_toleranz    15%    62
ENG141658-ENG142203-Leuchtweitenregulierung-Entprellung_Fehlerlampe    10.0 s    62
ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1    -8.00 mm/%    62
ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2    -8.00 mm/%    62
ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3    -8.00 mm/%    62
ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1    -8.00 mm/%    62
ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2    -8.00 mm/%    62
ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3    -8.00 mm/%    62
ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante    Variante_1     62
ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR    0.00%    62
ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf    0.00 Hz    62
ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung    normal     62
ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal    Negative     62
ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1    0 mm    62
ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2    0 mm    62
ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3    0 mm    62
ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4    0 mm    62
ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand    0 mm    62
ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe    0 mm    62
ENG141658-ENG142226-Leuchtweitenregulierung-lwr_pwm_obere_schwelle    95.00%    62
ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle    2.50%    62
ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr    0 km/h    62
ENG141658-ENG142222-Leuchtweitenregulierung-pa_fDynFiltStatLwr    100 Hz    62
ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung    0.00 Hz    62
ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte    BCM     62
ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed    not installed     62
ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht    not active     62
ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese    20.00%    62
ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart    not active     62
ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad    0.0 %/s    62
ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht    -100.00%    62
ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut    not installed     62
ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR    0.00 s    62
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1    not active     1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2    not active     1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3    not active     1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4    not active     1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5    not active     1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6    not active     1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ    not active     1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0    0.00%    12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1    5.00%    12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2    50.00%    12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3    75.00%    12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4    110    12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5    126.5    12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0    0.00%    12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1    6.00%    12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2    16.00%    12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3    30.00%    12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4    60.00%    12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5    100.00%    12
ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0    -5.00%    20
ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1    -5.00%    20
ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2    -5.00%    20
ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3    -5.00%    20
ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4    -5.00%    20
ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0    -5    20
ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1    -5    20
ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2    -5    20
ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3    -5    20
ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4    -5    20
ENG122979-ENG141954-Networking-A/C electronics    installed     8
ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet    not installed     8
ENG122979-ENG141974-Networking-Bremsen_Steuergeraet    installed     8
ENG122979-ENG141953-Networking-Getriebesteuergeraet    installed     8
ENG122979-ENG99457-Networking-Head area heater    not installed     8
ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG    not installed     8
ENG122979-ENG141969-Networking-UGDO    not installed     8
ENG124714-ENG142044-OCU-DWA_push    not active     8
ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare    active     8
ENG124714-OCU-    not installed     8
ENG124714-ENG142261-OCU-Remote HuF Abbruch    20 km/h    8
ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz    3 Hz    8
ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1    80 s    8
ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3    2000 ms    8
ENG124714-ENG125657-OCU-Remote_Unlock_Lock    not_active     8
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar    active     16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten    4    16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung    not active     16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv    active     16
ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion    profiles_active     16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar    active     16
ENG98831-ENG142030-Personalization-Profil_Variante    Konto (v. 1.x)     16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1    active     16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2    active     16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3    not active     16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4    not active     16
ENG141646-MAS01065-Querschnitts_funktionen-Brand    VW     5
ENG141646-ENG141980-Querschnitts_funktionen-Bedien_und_Anzeigeprotokoll    active     5
ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung    not active     5
ENG141646-ENG141967-Querschnitts_funktionen-Codierungsabsicherung    not active     5
ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21    active     5
ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus    Pin A31     5
ENG141646-ENG154685-Querschnitts_funktionen-Hupe    Sollspannungsanforderung 13.5     5
ENG141646-ENG115810-Querschnitts_funktionen-Klemmenfehler auf CAN ausgeben    active     5
ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme    not_installed     5
ENG141646-ENG141983-Querschnitts_funktionen-Schnittstelle_TrackingSystem    not active     5
ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment    Right     5
ENG141646-ENG141965-Querschnitts_funktionen-Traffic side    Left     5
ENG122927-RLS_close_glazing    2.5 s    1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off    120 s    3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on    10 s    3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off    65 km/h    3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on    140 km/h    3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle    6000 lx    2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high    12    2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low    6    2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht    30 s    2
ENG122929-RLS_LIN_Communication    4 s    1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn    100 lx    1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day    200 lx    1
ENG122930-RLS_tunel_gateway_recognize    5 s    1
ENG122935-RLS_Washer_Front    15 s    1
ENG122926-RLS_wiper_position_parking    15 s    1
ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung    10    10
ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system    not installed     10
ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel    not active     10
ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit    2000 ms    10
ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit    400 ms    10
ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit    0 ms    10
ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit    0 ms    10
ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit    400 ms    10
ENG115729-ENG154424-Scheinwerferreinigung-Waschen    Keine_Spannungsanforderung     10
ENG141684-SFT271873-Slave_systems_identification-Wiper motor control module    Not available     6
ENG141684-SFT271874-Slave_systems_identification-Rain/Light Recognition Sensor    Not available     6
ENG141684-SFT271875-Slave_systems_identification-Light switch    Not available     6
ENG141684-SFT271876-Slave_systems_identification-Garage door opener control module    Not available     6
ENG141684-SFT271877-Slave_systems_identification-Garage door opener control head    Not available     6
ENG141684-SFT271894-Slave_systems_identification-Anti-theft alarm system sensor    Not available     6
ENG141684-SFT271896-Slave_systems_identification-Alarm horn    Not available     6
ENG141684-SFT271904-Slave_systems_identification-Sunroof control module    Not available     6
ENG141684-SFT271910-Slave_systems_identification-Roof electronics control module    Not available     6
ENG141684-SFT271928-Slave_systems_identification-Roof shade control module    Not available     6
ENG141684-SFT271947-Slave_systems_identification-Humidity sensor: interior    Not available     6
ENG141684-SFT271966-Slave_systems_identification-Left head area heater    Not available     6
ENG141684-SFT271967-Slave_systems_identification-Right head area heater    Not available     6
ENG141684-SFT272065-Slave_systems_identification-Blower 1 for left front backrest    Not available     6
ENG141684-SFT272067-Slave_systems_identification-Blower 1 for left front seat cushion    Not available     6
ENG141684-SFT272069-Slave_systems_identification-Blower 1 for right front backrest    Not available     6
ENG141684-SFT272071-Slave_systems_identification-Blower 1 for right front seat cushion    Not available     6
ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker    MFG     4
ENG116588-Sonderfunktionen-    not enabled     4
ENG116588-ENG141979-Sonderfunktionen-Sonderfunktionen 1    not installed     4
ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen    active     5
ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus    by look command via remote control key     5
ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen    active     5
ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung    active     5
ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung    active     5
ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel    active     5
ENG141635-ENG126610-Spiegelverstellung-Signalisierung_Spiegelanklappung    active     5
ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt    active     5
ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung    not active     5
ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron    active     5
ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt    250    10
ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel    10 km/h    10
ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter    CAN     10
ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_f¸r_P_plausibel    10.0 min    10
ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen    40 ms    10
ENG141678-ENG115658-Suchbeleuchtung_58_xs_Bus_Kennlinie-x0    0.0 lx    10
ENG141678-ENG101574-Suchbeleuchtung_58_xs_Bus_Kennlinie-X1    8.0 lx    10
ENG141678-ENG99557-Suchbeleuchtung_58_xs_Bus_Kennlinie-X2    50.0 lx    10
ENG141678-ENG102140-Suchbeleuchtung_58_xs_Bus_Kennlinie-X3    80.0 lx    10
ENG141678-ENG102936-Suchbeleuchtung_58_xs_Bus_Kennlinie-X4    100.0 lx    10
ENG141678-ENG115659-Suchbeleuchtung_58_xs_Bus_Kennlinie-y0    6    10
ENG141678-ENG99777-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y1    6    10
ENG141678-ENG100480-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y2    20    10
ENG141678-ENG100773-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y3    50    10
ENG141678-ENG100631-Suchbeleuchtung_58_xs_Bus_Kennlinie-Y4    100    10
ENG141679-ENG115658-Suchbeleuchtung_58xt_Bus_Kennlinie-x0    0.0 lx    10
ENG141679-ENG101574-Suchbeleuchtung_58xt_Bus_Kennlinie-X1    8.0 lx    10
ENG141679-ENG99557-Suchbeleuchtung_58xt_Bus_Kennlinie-X2    50.0 lx    10
ENG141679-ENG102140-Suchbeleuchtung_58xt_Bus_Kennlinie-X3    80.0 lx    10
ENG141679-ENG102936-Suchbeleuchtung_58xt_Bus_Kennlinie-X4    100.0 lx    10
ENG141679-ENG115659-Suchbeleuchtung_58xt_Bus_Kennlinie-y0    6    10
ENG141679-ENG99777-Suchbeleuchtung_58xt_Bus_Kennlinie-Y1    6    10
ENG141679-ENG100480-Suchbeleuchtung_58xt_Bus_Kennlinie-Y2    20    10
ENG141679-ENG100773-Suchbeleuchtung_58xt_Bus_Kennlinie-Y3    50    10
ENG141679-ENG100631-Suchbeleuchtung_58xt_Bus_Kennlinie-Y4    100    10
ENG141666-ENG115658-Suchbeleuchtung_Abdimmen-x0    0 ms    22
ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1    200 ms    22
ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10    2000 ms    22
ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2    400 ms    22
ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3    600 ms    22
ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4    800 ms    22
ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5    1000 ms    22
ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6    1200 ms    22
ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7    1400 ms    22
ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8    1600 ms    22
ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9    1800 ms    22
ENG141666-ENG115659-Suchbeleuchtung_Abdimmen-y0    100.00%    22
ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1    100.00%    22
ENG141666-ENG115668-Suchbeleuchtung_Abdimmen-y10    0.00%    22
ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2    95.00%    22
ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3    80.00%    22
ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4    40.00%    22
ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5    20.00%    22
ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6    10.00%    22
ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7    5.00%    22
ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8    3.00%    22
ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9    1.00%    22
ENG141663-ENG142240-Suchbeleuchtung_allgemein-Daempfung Abdimmen KL 58xd PWM    0.00 s    21
ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM    0.00 s    21
ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM    0.00 s    21
ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM    0.00 s    21
ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung    HMI     21
ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen    20.0 s    21
ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen    3.0 s    21
ENG141663-ENG116598-Suchbeleuchtung_allgemein-KL58 Einschalten mit Rampe    active     21
ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten    not_active     21
ENG141663-ENG116600-Suchbeleuchtung_allgemein-Lichtsensor wirkt auf Suchbeleuchtung    active     21
ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS    2    21
ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM    0.00 s    21
ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert    100%    21
ENG141663-ENG142234-Suchbeleuchtung_allgemein-Umgebungs_helligkeit_auswahl    Fotosensor_Kombi     21
ENG141663-ENG115819-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Aktivierung    Always active     21
ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor    0.1    21
ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert    6.00%    21
ENG141667-ENG115658-Suchbeleuchtung_Fotosensor-x0    0    22
ENG141667-ENG101574-Suchbeleuchtung_Fotosensor-X1    50    22
ENG141667-ENG115664-Suchbeleuchtung_Fotosensor-x10    0    22
ENG141667-ENG99557-Suchbeleuchtung_Fotosensor-X2    100    22
ENG141667-ENG102140-Suchbeleuchtung_Fotosensor-X3    200    22
ENG141667-ENG102936-Suchbeleuchtung_Fotosensor-X4    253    22
ENG141667-ENG103548-Suchbeleuchtung_Fotosensor-X5    0    22
ENG141667-ENG113992-Suchbeleuchtung_Fotosensor-X6    0    22
ENG141667-ENG115661-Suchbeleuchtung_Fotosensor-x7    0    22
ENG141667-ENG115662-Suchbeleuchtung_Fotosensor-x8    0    22
ENG141667-ENG115663-Suchbeleuchtung_Fotosensor-x9    0    22
ENG141667-ENG115659-Suchbeleuchtung_Fotosensor-y0    0 lx    22
ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1    50 lx    22
ENG141667-ENG115668-Suchbeleuchtung_Fotosensor-y10    0 lx    22
ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2    100 lx    22
ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3    200    22
ENG141667-ENG100631-Suchbeleuchtung_Fotosensor-Y4    500    22
ENG141667-ENG102174-Suchbeleuchtung_Fotosensor-Y5    0    22
ENG141667-ENG113993-Suchbeleuchtung_Fotosensor-Y6    0 lx    22
ENG141667-ENG115665-Suchbeleuchtung_Fotosensor-y7    0 lx    22
ENG141667-ENG115666-Suchbeleuchtung_Fotosensor-y8    0 lx    22
ENG141667-ENG115667-Suchbeleuchtung_Fotosensor-y9    0 lx    22
ENG141665-ENG115658-Suchbeleuchtung_Hochdimmen-x0    0 ms    22
ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1    200 ms    22
ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10    2000 ms    22
ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2    400 ms    22
ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3    600 ms    22
ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4    800 ms    22
ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5    1000 ms    22
ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6    1200 ms    22
ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7    1400 ms    22
ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8    1600 ms    22
ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9    1800 ms    22
ENG141665-ENG115659-Suchbeleuchtung_Hochdimmen-y0    0.00%    22
ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1    1.00%    22
ENG141665-ENG115668-Suchbeleuchtung_Hochdimmen-y10    100.00%    22
ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2    3.00%    22
ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3    5.00%    22
ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4    11.00%    22
ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5    22.00%    22
ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6    40.00%    22
ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7    80.00%    22
ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8    95.00%    22
ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9    100.00%    22
ENG141669-ENG115658-Suchbeleuchtung_KL 58xs max-x0    0 lx    8
ENG141669-ENG101574-Suchbeleuchtung_KL 58xs max-X1    8 lx    8
ENG141669-ENG99557-Suchbeleuchtung_KL 58xs max-X2    50 lx    8
ENG141669-ENG102140-Suchbeleuchtung_KL 58xs max-X3    500 lx    8
ENG141669-ENG115659-Suchbeleuchtung_KL 58xs max-y0    100    8
ENG141669-ENG99777-Suchbeleuchtung_KL 58xs max-Y1    100    8
ENG141669-ENG100480-Suchbeleuchtung_KL 58xs max-Y2    100    8
ENG141669-ENG100773-Suchbeleuchtung_KL 58xs max-Y3    100    8
ENG141668-ENG115658-Suchbeleuchtung_KL 58xs min-x0    0 lx    8
ENG141668-ENG101574-Suchbeleuchtung_KL 58xs min-X1    8 lx    8
ENG141668-ENG99557-Suchbeleuchtung_KL 58xs min-X2    50 lx    8
ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3    510 lx    8
ENG141668-ENG115659-Suchbeleuchtung_KL 58xs min-y0    6    8
ENG141668-ENG99777-Suchbeleuchtung_KL 58xs min-Y1    6    8
ENG141668-ENG100480-Suchbeleuchtung_KL 58xs min-Y2    100    8
ENG141668-ENG100773-Suchbeleuchtung_KL 58xs min-Y3    100    8
ENG141674-ENG115658-Suchbeleuchtung_KL_58xd_log_Bus-x0    0.00%    12
ENG141674-ENG101574-Suchbeleuchtung_KL_58xd_log_Bus-X1    6.00%    12
ENG141674-ENG99557-Suchbeleuchtung_KL_58xd_log_Bus-X2    16.00%    12
ENG141674-ENG102140-Suchbeleuchtung_KL_58xd_log_Bus-X3    30.00%    12
ENG141674-ENG102936-Suchbeleuchtung_KL_58xd_log_Bus-X4    60.00%    12
ENG141674-ENG103548-Suchbeleuchtung_KL_58xd_log_Bus-X5    100.00%    12
ENG141674-ENG115659-Suchbeleuchtung_KL_58xd_log_Bus-y0    10    12
ENG141674-ENG99777-Suchbeleuchtung_KL_58xd_log_Bus-Y1    10    12
ENG141674-ENG100480-Suchbeleuchtung_KL_58xd_log_Bus-Y2    100    12
ENG141674-ENG100773-Suchbeleuchtung_KL_58xd_log_Bus-Y3    150    12
ENG141674-ENG100631-Suchbeleuchtung_KL_58xd_log_Bus-Y4    220    12
ENG141674-ENG102174-Suchbeleuchtung_KL_58xd_log_Bus-Y5    253    12
ENG141673-ENG115658-Suchbeleuchtung_KL_58xd_max-x0    0 lx    10
ENG141673-ENG101574-Suchbeleuchtung_KL_58xd_max-X1    8 lx    10
ENG141673-ENG99557-Suchbeleuchtung_KL_58xd_max-X2    200 lx    10
ENG141673-ENG102140-Suchbeleuchtung_KL_58xd_max-X3    300 lx    10
ENG141673-ENG102936-Suchbeleuchtung_KL_58xd_max-X4    500 lx    10
ENG141673-ENG115659-Suchbeleuchtung_KL_58xd_max-y0    16    10
ENG141673-ENG99777-Suchbeleuchtung_KL_58xd_max-Y1    16    10
ENG141673-ENG100480-Suchbeleuchtung_KL_58xd_max-Y2    100    10
ENG141673-ENG100773-Suchbeleuchtung_KL_58xd_max-Y3    100    10
ENG141673-ENG100631-Suchbeleuchtung_KL_58xd_max-Y4    100    10
ENG141672-ENG115658-Suchbeleuchtung_KL_58xd_min-x0    0 lx    10
ENG141672-ENG101574-Suchbeleuchtung_KL_58xd_min-X1    8 lx    10
ENG141672-ENG99557-Suchbeleuchtung_KL_58xd_min-X2    220 lx    10
ENG141672-ENG102140-Suchbeleuchtung_KL_58xd_min-X3    300 lx    10
ENG141672-ENG102936-Suchbeleuchtung_KL_58xd_min-X4    500 lx    10
ENG141672-ENG115659-Suchbeleuchtung_KL_58xd_min-y0    6    10
ENG141672-ENG99777-Suchbeleuchtung_KL_58xd_min-Y1    6    10
ENG141672-ENG100480-Suchbeleuchtung_KL_58xd_min-Y2    100    10
ENG141672-ENG100773-Suchbeleuchtung_KL_58xd_min-Y3    100    10
ENG141672-ENG100631-Suchbeleuchtung_KL_58xd_min-Y4    100    10
ENG141677-ENG115658-Suchbeleuchtung_KL_58xd_PWM-x0    0    12
ENG141677-ENG101574-Suchbeleuchtung_KL_58xd_PWM-X1    10    12
ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2    50    12
ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3    100    12
ENG141677-ENG102936-Suchbeleuchtung_KL_58xd_PWM-X4    220    12
ENG141677-ENG103548-Suchbeleuchtung_KL_58xd_PWM-X5    253    12
ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0    2.00%    12
ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1    2.00%    12
ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2    6.00%    12
ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3    10.00%    12
ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4    80.00%    12
ENG141677-ENG102174-Suchbeleuchtung_KL_58xd_PWM-Y5    100.00%    12
ENG141670-ENG115658-Suchbeleuchtung_KL_58xt min-x0    0 lx    8
ENG141670-ENG101574-Suchbeleuchtung_KL_58xt min-X1    8 lx    8
ENG141670-ENG99557-Suchbeleuchtung_KL_58xt min-X2    50 lx    8
ENG141670-ENG102140-Suchbeleuchtung_KL_58xt min-X3    500 lx    8
ENG141670-ENG115659-Suchbeleuchtung_KL_58xt min-y0    6    8
ENG141670-ENG99777-Suchbeleuchtung_KL_58xt min-Y1    6    8
ENG141670-ENG100480-Suchbeleuchtung_KL_58xt min-Y2    100    8
ENG141670-ENG100773-Suchbeleuchtung_KL_58xt min-Y3    100    8
ENG141671-ENG115658-Suchbeleuchtung_KL_58xt_max-x0    0 lx    8
ENG141671-ENG101574-Suchbeleuchtung_KL_58xt_max-X1    8 lx    8
ENG141671-ENG99557-Suchbeleuchtung_KL_58xt_max-X2    50 lx    8
ENG141671-ENG102140-Suchbeleuchtung_KL_58xt_max-X3    500 lx    8
ENG141671-ENG115659-Suchbeleuchtung_KL_58xt_max-y0    100    8
ENG141671-ENG99777-Suchbeleuchtung_KL_58xt_max-Y1    100    8
ENG141671-ENG100480-Suchbeleuchtung_KL_58xt_max-Y2    100    8
ENG141671-ENG100773-Suchbeleuchtung_KL_58xt_max-Y3    100    8
ENG141676-ENG115658-Suchbeleuchtung_KL_58xt_PWM-x0    0.00%    6
ENG141676-ENG101574-Suchbeleuchtung_KL_58xt_PWM-X1    50.00%    6
ENG141676-ENG99557-Suchbeleuchtung_KL_58xt_PWM-X2    100.00%    6
ENG141676-ENG115659-Suchbeleuchtung_KL_58xt_PWM-y0    0.00%    6
ENG141676-ENG99777-Suchbeleuchtung_KL_58xt_PWM-Y1    50.00%    6
ENG141676-ENG100480-Suchbeleuchtung_KL_58xt_PWM-Y2    100.00%    6
ENG141680-ENG115658-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-x0    0 lx    12
ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1    10 lx    12
ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2    100 lx    12
ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3    500 lx    12
ENG141680-ENG102936-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X4    800 lx    12
ENG141680-ENG103548-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X5    1020 lx    12
ENG141680-ENG115659-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-y0    0    12
ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1    20    12
ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2    80    12
ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3    180    12
ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4    300    12
ENG141680-ENG102174-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y5    500    12
ENG141664-ENG115633-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x0    0 ms    10
ENG141664-ENG115634-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x1    2000 ms    10
ENG141664-ENG115635-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x2    3000 ms    10
ENG141664-ENG115636-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x3    4000 ms    10
ENG141664-ENG115637-Suchbeleuchtung_Tasterdimmung-Tasterdimmung x4    5100 ms    10
ENG141664-ENG115638-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y0    1.00%    10
ENG141664-ENG115639-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y1    5    10
ENG141664-ENG115640-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y2    15    10
ENG141664-ENG115641-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y3    40    10
ENG141664-ENG115642-Suchbeleuchtung_Tasterdimmung-Tasterdimmung y4    100    10
ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen    not active     4
ENG141632-ENG116646-Sunroof-SAD Komfort schliessen    not active     4
ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen    tilting     4
ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1    not installed     4
ENG141632-ENG141971-Sunroof-Schiebedachmodul_MD_3    not installed     4
ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo    not installed     4
ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule    LIN     4
ENG141634-ENG142013-Verdecksteuergeraet-Cabrio_Verdeck    not_installed     9
ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck    active     9
ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv    not active     9
ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb    not active     9
ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close    not installed     9
ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global    active     9
ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen    active     9
ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schlieflen    active     9
ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf    not active     9
ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen    not active     9
ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung    Always     9
ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden    Always     9
ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit    not installed     9
ENG141634-ENG116717-Verdecksteuergeraet-Verdeck mit Schiebedach    not active     9
ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung    active     9
ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy    active     9
ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder    active     9
ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schlieflen via Funkfernbedienung    active     9
ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schlieflen via Kessy    active     9
ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schlieflen via Schlieflzylinder    active     9
ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal    not active     9
ENG141634-ENG142258-Verdecksteuergeraet-Virtuelles_Pedal_HMI_einstellba    not active     9
ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau    not installed     9
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1    00 00     20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2    00 00     20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3    00 00     20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4    00 00     20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1    00 00     20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2    00 00     20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3    00 00     20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4    00 00     20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5    00 00     20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6    00 00     20
ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute    40    3
ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute    60    3
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute    30    3
ENG141651-ENG116632-ZV allgemein-Bewusstes Safe mit 2. Betaetigung der FFB    not active     7
ENG141651-ENG133387-ZV allgemein-Deaktivierung_Laderaumschliessung_extern    not active     7
ENG141651-ENG125653-ZV allgemein-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster    active     7
ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein    active     7
ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein    not active     7
ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt    not installed     7
ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster    not installed     7
ENG141651-ENG133388-ZV allgemein-LS_Taster_Togglefunktion    not active     7
ENG141651-ENG116633-ZV allgemein-Menuesteuerung Tuerentriegelung    active     7
ENG141651-ENG115755-ZV allgemein-Notschlieflfunktion    active     7
ENG141651-ENG133389-ZV allgemein-Nutzfahrzeug_Schliessung    not active     7
ENG141651-ENG141957-ZV allgemein-Radio freq.    434.42MHz     7
ENG141651-ENG141958-ZV allgemein-Tankschloss    Bidirectional     7
ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum    Freigabe_Softtouch     7
ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung    Globale Entriegelung     7
ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion    installed     7
ENG141654-ENG116628-ZV Autolock-Autolock Autounlock wirkt auf Heck    active     3
ENG141654-ENG116621-ZV Autolock-automatisches Entriegeln    active     3
ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit    not active     3
ENG141654-ENG116706-ZV Autolock-Autounlock NAR    not active     3
ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung    not active     3
ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock    adjustable     3
ENG141655-ENG116627-ZV Crash-Heckdeckel-Bedienstellen nachCrash temporaer sperren    active     4
ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen    not active     4
ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash    not active     4
ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels    active     7
ENG141653-ENG126839-ZV Heck-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang    not active     7
ENG141653-ENG116707-ZV Heck-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster    not active     7
ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster    not installed     7
ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung    not active     7
ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen    not active     7
ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste    Yes     7
ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung    Contact control     7
ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster    0.0 s    7
ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt    not active     7
ENG141653-ENG141982-ZV Heck-Tausch_Tank_Hecktreiberausgang    No     7
ENG141653-ENG115760-ZV Heck-ZV entriegelt auch Heckdeckel    active     7
ENG141653-ENG116629-ZV Heck-ZV Heck nur direkt auswerfen    not active     7
ENG141653-ENG141997-ZV Heck-ZV_Heck_Schlosstyp    1 or 2 notch rear actuator     7
ENG141681-IDE02021-ZV Komfort-Comfort closing    active     8
ENG141681-IDE02022-ZV Komfort-Comfort opening    not active     8
ENG141681-ENG141984-ZV Komfort-elektrischer_Fensterheber_hinten    No     8
ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen    active     8
ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen    active     8
ENG141681-ENG116662-ZV Komfort-FH SAD Kl15Aus Freigabezeit    600 s    8
ENG141681-ENG116648-ZV Komfort-Freigabenachlauf FH bei Kl 15 aus    active     8
ENG141681-ENG122993-ZV Komfort-Freigabenachlauf FH bei Tueroeffnen abbrechen    active     8
ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen    active     8
ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen    active     8
ENG141681-ENG115670-ZV Komfort-Komfortbedienung global    active     8
ENG141681-ENG116642-ZV Komfort-Komfortoeffnen nur FH Fahrertuer    not active     8
ENG141681-ENG122994-ZV Komfort-Menuesteuerung Komfortbedienung einstellbar    adjustable     8
ENG141681-ENG122186-ZV Komfort-Menuesteuerung Regenschliessen    not active     8
ENG141681-ENG125656-ZV Komfort-Regenschliessen_art    once     8
ENG141681-ENG125655-ZV Komfort-Regenschliessen_ein_aus    not active     8
ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen    not active     8
ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen    not active     8
ENG141652-ENG141999-ZV T¸rkonfiguration-Fond_Schloss    2-Motorenschloesser     5
ENG141652-ENG142043-ZV T¸rkonfiguration-HFT_Invertierung_Drehfallensignal    nicht invertiert     5
ENG141652-ENG142039-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Beifahrerseite    not installed     5
ENG141652-ENG142038-ZV T¸rkonfiguration-Schiebetuer_Kontaktmodul_Fahrerseite    not installed     5
ENG141652-ENG142001-ZV T¸rkonfiguration-Schiebetuer_links    No     5
ENG141652-ENG142002-ZV T¸rkonfiguration-Schiebetuer_rechts    No     5
ENG141652-ENG142041-ZV T¸rkonfiguration-Schiebetueren_Crafter    not installed     5
ENG141652-ENG142244-ZV T¸rkonfiguration-Schiebetuerschloss_direkt_BCM    Driver side     5
ENG141652-ENG116631-ZV T¸rkonfiguration-Schliessung der Schiebetuer bei geoeffneter Tankklappe    not active     5
ENG141652-ENG142000-ZV T¸rkonfiguration-Schlosstyp_NAR    No     5
ENG141652-ENG141959-ZV T¸rkonfiguration-Viertuerer    Yes     5
Elapsed Time: 02:08
  • Scan-WVWZZZAUZEP545948-20211210-1434-284578km-176828mi.txt
  • Scan-WVWZZZAUZEP545948-20220430-1220-297793km-185039mi.txt
