not need so much ,this is footwell light also can used in the dashboard and the door ,I mean i saw your product. 57€ is not that much for the "simulator" and 4 footwell lights.
But then again you have to change the whole ambient lighting (If you have one) all the door lights, skylight, dash trim,
For the standard ambient light it wil cost you 250€ for the front door, dashboard, footwell, 100€ for the skylight.
so it would be around 400€ with shipping.
Oh, I get you now.
I bought the OEM light modules sadly the seller do not list the modules. But here is another seller https://a.aliexpress.com/_mqJuwrz
and the optical wire you can use milky or transparent https://a.aliexpress.com/_mt9NepZ
View attachment 224822use this canbus simulator you just need code your unit 30 colors , and plug and play the getway
Yes. That is the oem way with the optical tube.So this module projects the LED and the tube simply distributes it?
This is how it looks
