@golfbuddy3can explain connection to me?
how do you even read those wiring diagrams? can hlep?
If i know the diameter of the led light. from Aliexpress i could try it at home.Well, in that case, I don't think the BCM will support it. However, I don't mind plugging it into existing ambient light. The problem is I don't want to order the LEDs only to find out they don't fit.
Why not ?It doesnt work like that. you can do it with just a regular LED strip but not with the OEM one
There's a typo from VW in the diagram. The BCM connectors on MQB cars areSo, to my understanding:
Pin 1 -> Pin 4 of B552 (roof wiring harness)
Pin 2 -> Pin 29 of T73B (Socket B of BCM0
Pin 4 -> Ground?
Correct me if I am wrong...There's a typo from VW in the diagram. The BCM connectors on MQB cars are
A: T73a = 73 pins
B: T46b = 46 pins
C: T73c = 73 pins.
Basically you have to look for Pin 29 on T73C. I have checked google for a pic of my BCM 5Q0937087AA 028 0163. I can find a "BCM 5Q0937087AA 028 0162"-pic and it isn't equipped with Pin 29 on connector C.
Why not ?
I think you can tap it on the existing ambient light if you want only the white light. i think they are the same LEDs.
This diagram is for a 2018 tiguan, maybe its the newer module or maybe ZERO is right and its a typo.Correct me if I am wrong...
But Golf is on the 1gen MQB platform
and The Mk2 Tiguan is on the MQB A2 platform.
So i think they have different BCM.
But i think the TOURAN had the ambient pano lights aswell.
And if my memory is correct, then the Touran Golf share the same MQB platform
So if my statement is correct we should look at the Tourans BCM
A: T73a = 73 pins
B: T46b = 46 pins
C: T73c = 73 pins.
I pulled an adpmap from a NA 2019er Tiguan once. It had 5Q0937087BB as BCM # and it appears to have the same 73/46/73 connectors. On the NA Arteon documentation there are similar typos...This diagram is for a 2018 tiguan, maybe its the newer module or maybe ZERO is right and its a typo.
