Remote Start MK7 GTI, OBD Eleven folks chime in
The Dude
PNW
So there's nothing I'm aware of on the market that allows you to maintain the oem security system, you have to bypass KESSY, one way or another. There's a menu option I found within the central electrics section while I was fooling around with OBD Eleven, and before I click it active I figured I'd ask if anyone else had tried it. Are there any VW vehicles that have a factory remote start? If so, what hardware bits do they have that we don't?
Sc629
IN
Yes, a few MQBs do come from factory with remote start. Namely the tiguan, Jetta, and atlas at least. I have considered whether this was possible to retrofit before. VW sells factory retrofit kits for the Tiguan models that didn’t come with it. They cost somewhere from $200-400 (don’t have a link, just check VW parts website). It would seem obvious to me that it could retrofitted to our cars with the correct parts, coding, and activation. No one has tried it yet as far as I know and I don’t have the funds to go down a possible rabbit hole but should theoretically be possible given the modular structure of MQB
The Dude
PNW
I have homework to do then ?
WhyNotZoidberg?
Chi-Town
Ride
2017 GTI, 2015 TDI
Is remote start an option on any MQBs w/ 3pedals from the factory? AFAIK any attempts at a clutch switch bypass mod have been futile.
The Dude
PNW
I've got a dsg, we can burn that bridge when we get to it ? there isn't a way to code a bypass for the clutch switch? Why not wire a ground to the e brake handle, so when you park the car, e bdake up, it'd show the clutch being in? Is that a monumentally stupid idea? I'd imagine there's a reason no one's done it.
WhyNotZoidberg?
Chi-Town
Ride
2017 GTI, 2015 TDI
Unfortunately it's not just a wire to short 2 pins, VW made it as complicated as humanly possible..
Here's a post about it, you can read more in the same thread:
