What are you charging for the one side?Sounds like you just need a seat airbag canceller. If you have the yellow connector style I can make up a set for you.
$25 a side or two for 40 currently for the airbag resistors.What are you charging for the one side?
If you have the yellow resistor for the seat airbag canceller, then you need a driver's rail position sensor. You can either remove this from your harness and tuck it away, or buy the rail sensor only unit that matches your part number. You can then pin that in and tuck it away leaving the seats whole for resale.Navi, would you mind terribly posting a parts list ? I thought I had everything but I guess not.
I would check with a dealer. The parts listed earlier in the thread weren't completely correct for my car.Anyone know the difference between these and the GTI versions? It doesn’t appear to matter for cloth vs pleather since it’s the same part number for both. I’m guessing I should go this route since I have a golf Sportwagen?
If you can wait, I wouldn't worry about repair wires and just order the connector from Ali. They come pre terminated most times with either stranded copper, or stranded tinned copper wire. They're a bit cheaper than just buying the connecter from the dealer, the trade is you have to wait about a month for them to show up.Found my box of seat stuff. I have:
2 of: 5GM-963-557-C (seat back)
a left over yellow repair wire. I used the other one to make the 2 needed cancellers, however those are missing.
So I need the 2 bottom heater pads that have the occupancy sensor, and 2 rail sensors?
thanks, will pmIf you can wait, I wouldn't worry about repair wires and just order the connector from Ali. They come pre terminated most times with either stranded copper, or stranded tinned copper wire. They're a bit cheaper than just buying the connecter from the dealer, the trade is you have to wait about a month for them to show up.
Occupancy sensor is just for the passenger side. Drivers side would just be the heating pad if you wanted to install it for your own comfort. Then yes, you'll need two rail sensors, one for each seat.
I'll probably be signing up for a partslink24 account to run the vins on a few of the cars i'm assisting with building kits for, shoot me yours and I'll grab your rail sensor and occupancy sensor part numbers for you.
