Recaro Sporster CS install mk7 gti
burgerkong
Ontario, Canadeh
So I'm putting these in driver side only, I'll transfer over the rail position sensor as well as do the 3.3ohm resistor? Anything else? Will be using a Sparco/Planted base and Recaro sidemount/sliders. Seat belt receptacle I'm reusing from my stock seat (low budget), I hope they fit.
mr wrong
Franklin TN
I thought only the passenger side had the sensor..??...
EpicTech
Houston
MK7 GTI 6sp w/PP
I just picked up a cloth Sportster. How did ya'll take off the fabric? I want to lay down heaters for it. Thanks in advance. Especially to all the folks who've went ahead and did this install.
You lucky.... I had to settle for Corbeau's
mmdb
California
I wouldn't say that so much. I'm not wow'd by the quality of this seat's fabric. The bolsters are a bit more functional than stock as far as holding the driver into the seat vs the slippery stock leather. I've yet to settle on the purchase, but initially I was contemplating about selling it. I'll give it a honest try first however. The Corbeau's look nice. You're not missing out IMO.
Did you get a deal on the cloth Sportster GT? If so where from?
Nope no deal. I paid 400$ less vs the leather one. I was told the leather version crack over time. I figure I'll just get cloth and call it a day. I paid retail.
https://www.urotuning.com/products/recaro-sportster-cs-driver-seat?variant=37794214576321
vstypicals
N/A
N/A
Seat rail position sensor off the top of my head
Is this the connector for the front crash sensor? I'm getting the following error below, and I'm trying to diagnose what the issue is. I've swapped passenger/driver crash sensors (the ones by the IC/radiator), and the error persisted to be on the passenger side. It is likely a wiring issue. I did do a lot of engine work including depinning an MPI, but I don't know if that's related. I plugged the connector above and the error didn't change. When I disconnected the yellow connector in the middle, I got 2x "airbag resistance" errors.
Any ideas?
vw671
San Diego
Any ideas?
None of those connectors are for the front crash sensor. I believe that one is for the seatbelt buckle.
fzi124
Ontario
2018 VW Golf R
Hi guys, I've been wanting to do this for a while now. Got myself a Recaro Profi XL seat and have OEM heated pads set up and working. I am ran into a problem with the airbag connector housing. I checked the airbag connector housing under my OEM seat (2018 Golf R) and it looks like the one in Image 1 (with the watermark). I ordered the 4h0972773 part from VW and got the connector in Image 2 (added wires and 3.3 ohm 1/4W 5% resistor). I am running into the issue where the connector will not fit and lock properly onto the male end. My thoughts are because the black push/pull to release tabs have a different locking pattern?
Has anyone ran into this issue?
Other than that, seat is ready to get installed.
HelloNewman
SoCal
Mk7
Has anyone tried replicating the OEM sportster CS by swapping over the cloth material from the oem seats into the inserts? Is that even a possibility or would you have to source new cloth? Not even sure where to find that tbh.
