Recaro Sporster CS install mk7 gti
Vinsanyon
OR
So the seats doesn’t come with air bag?
From some of the info I read, if the partial of the air bag is out, the whole system won’t work.
Or when you trick the system so there is no air bag light will also accomplish that the whole system will work properly even one is out?
El_bigote_AJ
Las Vegas
2019 GTI bunny
Correct, the whole system will still work you just won’t have one go off in the seat. A pillar and b pillar bags will still deploy.
avgmk7
Gapplebees
Slow Volkswagen
is there a way to get around the passenger occupancy sensor and the seat heaters if they are not wanted?
EpicTech
Houston
If you are ok with the airbag light being on.
Cuzoe
You can code out seat heaters. Although even with them disconnected and not coded out I think you'll only have soft faults in the BCM that show up in a scan. You could "go all the way" and replace your HVAC controls with a set that does not have the buttons for heated seats as well.
El_bigote_AJ
Las Vegas
2019 GTI bunny
Do you never have a passenger in the seat? You need the sensor working so the bag will deploy in case of an accident
avgmk7
Gapplebees
Slow Volkswagen
Well I want the sensor to work but I am attempting to install kirkey 55's and not too sure where to put the seat heaters or the sensor but I planned on wiring the airbag resistor so is that enough without the others plugged in or?
vw671
San Diego
You need the occupancy sensor, seat rail sensors, and resistors for seat air bags connected for all faults to be removed. There is a different fault for each.
El_bigote_AJ
Las Vegas
2019 GTI bunny
To be noted the occupancy sensor is only needed in the pass seat, you’re not installing the metal Bucket in the pass side are you?
avgmk7
Gapplebees
Slow Volkswagen
Planned on doing a set but if I cant I suppose I wont I only have one on order atm was going to try to figure it out when I got it.
