Cliff p.
- El Paso, TX
- '17 Golf R DSG
Now after looking at the above photo, I realize that the instructions they provided weren't the case after all. I had questioned it, but decided to go with the provided instructions. Now after looking at the AOS cutaway, I need to have the crankcase blowby into the top and not the side port. Good thing I've got plenty of extra hose to make this change.
I was going to say something..LOL..but I thought maybe the picture was of a slightly different model..haha
JE recommended I go for basically OE size hole with their perfect skirt coated pistons. I talked to one of their tech guys just yesterday about it. The reason I called was because I have a spare long block I am building and had intended on this time going with Mahle 82.5's vs 83 so I had the block checked for taper, roundness, etc. and torque plate honed to 3.2480 which is exactly what Mahle told me to do. I then decided to go with the JE's, same size but I knew they were 2618 alloy and needed more room to grow so I called to find out what I would need to get the block re-honed to and was told its perfect where I was at = 3.2480 (82.5mm) with their new perfect skirt coated pistons.So why does JE recommend a bigger piston to wall clearance? I'm still debating which pistons to go with, JE or Mahle, just not sure yet.
What plugs were you running when you had the failure?JE recommended I go for basically OE size hole with their perfect skirt coated pistons. I talked to one of their tech guys just yesterday about it. The reason I called was because I have a spare long block I am building and had intended on this time going with Mahle 82.5's vs 83 so I had the block checked for taper, roundness, etc. and torque plate honed to 3.2480 which is exactly what Mahle told me to do. I then decided to go with the JE's, same size but I knew they were 2618 alloy and needed more room to grow so I called to find out what I would need to get the block re-honed to and was told its perfect where I was at = 3.2480 (82.5mm) with their new perfect skirt coated pistons.
As far as catch can goes for me, even after I built my first motor with the 83mm Mahle slugs I never had more than a few drops in my APR can running 35psi, stock oil separator, after beating on it for almost 25k miles and a recent plug failure its just now starting to burn oil abnormally, hence the recent work on a spare block. And like others, the motor sounds like crap cold on the Mahle's.
Wait...you honed the block without the machine shop having the pistons in hand to measure? Huge risk and I'd never recommend that, and am very surprised Mahle instructed that.
As for the piston slap, it sucks. I wouldn't buy Mahle pistons again just because of it. Even with very tight tolerances the engine sounds like a 300k mile chevy truck for the first 5 min...yet pistons with double the clearance are quiet. IMO that's a design flaw.
JE told me the same thing, I literally called them today and asked about that because my pistons arrived today and I had some questions about the ring gap factor. Seems the machining is now so precise on the manufacturing of the pistons they feel confident in telling you that. I do however have a torque plate, decent bore gauge and micrometer set to check myself but I imagine a far cry from professional grade.
