krs
- Las Vegas, NV
- MKVIIS R
I'm getting into some territory of topics that I lack the knowledge on.
I'm running the Bilstein B16 Damptronic coil overs on my R, (among other things). These last to autox events I noticed I'm getting some tire rub on the fender lip of the rear wheel wells. For this season I'm on 18x9 ET42 wheels, with 255/35 RT660's. Last year I didn't have the issue with the 18x8.5's. The rear camber is right at -1.9° on both sides.
I'm looking for the best bang for the buck fix on this. I'm really not ready to pull the B16's out, and go down the path of a better coilover/rates setup for autox. I will at the end of their life cycle, but that's not now.
Any thoughts?
- For those that know, is there a general rear camber setting that is best not to go past? I thought I had read about -2.0° is it. If I bought camber arms and went to -2.5° is this territory that I should stay away from? I'm not savvy on the the rear suspension dynamics to truly know how this is affected.
- I know the B16 DCC spring rates are on the softer side. Is it possible to find a better rate to help mitigate this?
| metric (imperial) | Front | Rear |
| Spring Rate | 6.6 kg/mm (371 lb/in) | 5.4 kg/mm (303 lb/in) |
| Top ID | 88-90 mm (3.46 - 3.54 in) | 61-61.7 mm (2.40 - 2.43 in) |
| Bottom ID | 71-71.6 mm (2.8 - 2.82 in) | 55-56.1 mm (2.17 - 2.21 in) |
| Middle OD | 145 mm (5.71 in) | 121 mm (4.76 in) |
| Wire Diameter | 13.25 mm (0.52 in) | 13 mm (0.51 in) |
| Overall Length | 215 mm (8.46 in) | 215 mm (8.45 in) |
- Size down on tires? These tires are pretty new, with only maybe 20 runs on them. I hate to ditch them so early in their cycle.
- Raise the car up? I'm not sure at what height I'd need to go to prevent the rubbing under compression.
Any thoughts?
