Rear Sway Bar + Endlinks Inquiry
geokilla
Toronto, Ontario, Canada
Ride
2018 VW GTI DSG
I'm considering upgrading my rear sway bar and looking for something to reduce the understeer without making it too tail happy in the snow and uncomfortable as a daily driver. My family needs to drive the vehicle too so their safety is just as important as my fun at the track, if not more important. Of course the ride quality is important too since I daily the vehicle. I find the car a bit stiff over bumps and last thing I want is it for it to get bumpier. I see a lot of recommendations on rear sway bars so I'm researching the following:
SuperPro 24mm Rear Sway Bar
Adjustable and seem to be very popular on the MK7. Not that much thicker compared to stock MK7.5 GTI rear sway bar so theoretically it should be the safest of the 3. I wouldn't adjust it after its installed so its adjustability isn't much of a selling point to me. It's also fairly cheap compared to the other options.
Eibach 25mm Rear Sway Bar
Second cheapest and Eibach always makes good suspension products. They're 25mm and tubular, which I assume means it's hollow? I read there was some discussion between the hollow vs solid, but I don't think there was much of a consensus on what is better. It's a bit thicker than SuperPro so it should reduce the understeer even more than the SuperPro. Very reasonably priced and I get their million mile warranty, however that works.
H&R 24mm & 26mm Rear Sway Bar
Probably the most aggressive out of all of them? We know it's a solid bar so it's probably stiffer than a hollow bar. Extremely expensive but you pay for what you get.
ST Rear Sway Bar
Seems to be recommended on Reddit and very popular but haven't found much info on the forums here.
It seems Eurocode and SuperPro endlinks are the best ones to get too. So what should I go for if I'm looking for a mild upgrade?
Visceral
Northbrook, IL
I recently installed the H&R 24mm RSB and while I was at it replaced the OE endlinks with Moog endlinks. My car is a daily driver with suspension mods beyond the RSB. One of the big selling points for me were the teflon bushings which make for squeak-free motoring. I have read too many horror stories of people chasing suspension noises to ever want to mess with that. Do not spend more money on the endlinks beyond what you would for Moog. I do not see the point. I will say that the Moog endlinks come un-finished so they got a coat of Krylon paint before being installed. As for the driving impressions, I'm a fan. The car is more eager to rotate through a turn but I wouldn't call it oversteer either. More neutral and easier to adjust mid-corner for sure. You will be happy with the results. As for ride, dunno... I think it makes it stiffer and thus there is some more movement of the rear which translates to the seat of your pants IMO. There is certainly more side-to-side movement but nothing I would say is distracting from the driving experience. Its just what you would expect from a tighter suspension setup. I track my car at Road America and after making the suspension upgrades minus the RSB I was hanging with a new Cayman all afternoon. I couldn't stop grinning. Now, with the RSB I cannot wait to get out there next Spring. Its that much of an improvement.
Hope this helps in your decision making and good luck.
blaqsheep
Canada
Ride
IS38 GTI PP 6MT
25mm ST bar here with Moog endlinks. It was the cheapest non-adjustable option. Does what it needs to do, no complaints.
MK7 AP2
Tucson, AZ
I have the same setup. Handling is more neutral and I haven't had any issues with noise or clunks. I believe it is very similar to Eibach.
3rdOne
NC
Thanks for posting. I am looking for a RSB as well. I hav read many posts and threads on this as well but haven't found many actual driving impressions. I know its hard to compare as most just buy one bar. But my situation is a little different, I want more of a track/autoX set up.
I have been considering the H&R 26mm. Anybody have one of those that would share handling changes?
GTI-CAL
Bay Area
i have eibach 25mm rsb with oem endlinks. Fantastic upgrade. Does not completely remove body roll but significantly reduced. This sway bar does not make the car stiffer...definitely not noticeable.
Visceral
Northbrook, IL
Dangerous? You bet! Just kidding... really, if you are interested in something like this then understand you are sharpening the reflexes of your ride. It will bite back if you mis-handle it. But its a FWD platform and so, understeer is the default for this platform. You can dial out some of it, like with a RSB, but it will always have a relatively safe trait of understeering at the limit.
Bay Area Smoke Hell
Ride
2017 GTI Sport DSG
Same. Been running it for about 3 years. I do get clunking/creaking from back there though. Not sure what the deal is with that. I've got the harmonic balancer from GolfDave's thread on order so we'll see how that does.
GTI-CAL
Bay Area
I would reinstall the bar to fix the clunking noise. Make sure the car is on the ground when it's done. Recheck the torque after you drive it some miles.
Wrap the area of the bar with teflon tape where the bushing goes and you will not have any creaking/squeaking noise.
geokilla
Ride
2018 VW GTI DSG
I just don't want it too neutral and oversteer in the wet and snow when my mom and sister drives it. But I guess that's where ESC would come in and save the day.
Cowzill00
Florida
Very happy with my H&R 24mm. Have about a year on it now. This mod literally made me laugh it’s so good. Can’t speak to snow handling as I don’t deal with that 4 letter word here. ;)
Roadhog
Ride
19' R
I would think you would need some traction to get the sway bar to flex. I can't see it making much of a difference on low traction surfaces like snow and ice.
Ride
If it's just wet it will handle the same as dry conditions. If it's snow or ice all bets are off as speed will determine where it slides. I wouldn't count on ESC saving the day on ice or snow.
Visceral
Northbrook, IL
Honestly, I have a lowered suspension and I have to try to get the rear to swing around! Lots of fun on icy parking lots (empty). So, in real world terms, the RSB shouldn't make any difference to the handling characteristics in snow or rain or low traction environments. I really do appreciate your concern for your family driving the car but I would think they wouldn't know its there unless they drive it like they stole it.
napadirt
United States
You’re asking all the right questions here regarding adding a rear sway bar. I’ve been driving with the 27mm “Race” Nuespeed bar for over 60k miles and overall have been happy with this setup. Read my review here:
I have never found the handling balance to be dangerous. Ride quality has suffered though, the rear end is just stiffer, especially driving in a straight line when the sway bar isn’t loaded. That’s in part the reason why I just purchased EQT coilovers a few days ago with the goal of obtaining a similar handling balance but with improved ride quality. Also what pushed me into making this purchase after contemplating coilovers for years is my front suspension is noticeably worn out. I also like that this kit allows you to run stock ride height.
My advice is that a stiffer rear sway bar and grippier tires are probably the least expensive way to improve the driving experience of your car.
00Zero
Pittsburgh, Pa
FYI, the eibach usa bar is 25mm OD and 6.4mm thick (info from eibach usa). This would be a equivalent to about a 24.6mm solid bar.
Too many people only compare OD and not hollow tube thickness mistakenly ranking stiffness incorrectly.
I have been running eibach 25mm with moog end-links for over a year. My only issue is some squeaking when cold but that is me being too lazy to re-grease the brushing.
Rain and snow stability are fine and i have a softer golf front sway bar stock with my GSW.
Upgraded end-links are unnecessary/expensive unless you are racing allot and/or corner-weighting. The only reason i run moog is they are cheaper than OE (i didn't want to wrestle the rusted factory ones off) being metal is a nice piece of mind but overkill.
-Jonathan
sloopercat
Knoxville
I just bought the Eibach rear and the Moog endlinks. The bar was about $160shipped, endlinks about $45. I can’t imagine spending 50% more for just the bar is going to improve things that much.
