Rear subframe swap
ncsteinb
Saginaw, MI
So, I got this crazy idea in my head to swap a Golf R rear subframe assembly into a Golf TDI. Is this feasible? Has this swap been done?
Thanks.
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
If you have a hatch the spare wheel well is deeper on the 2wd compared to the AWD (R)......& if you have the torsion beam rear axle the top mounts for the springs are in a slightly different place compared to the multilink suspension. I know this as another person on here contacted me as they had huge problems trying to convert torsion beam to multilink..& it wasn't until I went through all the rear body panels & their PR codes that I found the exact differences in panels!....
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
sounds crazy
Not really......in fact the easiest to convert is the estate from 2wd multilink to full blown AWD (R).......as the bodyshell is exactly the same!.....& I was planning on doing it & found a nice donor manual R....(estate is DSG only in R)....anyway didn't have the time for it, but there is a person on here who did do it...
kelsheikh
Egypt
Octavia 3
Hello golfdave,
can you illustrate more
is it impossible to do the swap?
or can it be done?
what will I need to change?
thank you
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Hello golfdave,
or can it be done?
thank you
What are you wanting to swap???? 2wd to 4wd???
or just torsion beam to multilink?
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
To swap from 2WD torsion beam to 2WD multilink
you need to remove this from your car:-
& fit this:-
You also need to alter the mounting on the body for the top of the springs as its in a slightly different place, unless you buy expensive coil-over rear dampers/springs..
golfdave
Scotland (U.K.)
Mk7 Golf GT Estate
Just torsion beam to multilink on my golf 7
was planning a awd swap on my skoda octavia mk3 2015 as well
What is your Octavia?..torsion or multilink??
The MKIII Octavia has more torsion beam version cars than AWD
Parts drawing for the rear bodywork for the 2WD PR code = 1X0
floor plates; spars; wheel housing inner part - Octavia(OCT) [EUROPA 2015 year] (7zap.com)
Parts drawing for the rear bodywork for the AWD PR code = 1X1
bottom plate; spars; wheel housing inner part - Octavia(OCT) [EUROPA 2015 year] (7zap.com)
Although the AWD has a two part boot floor & in theory the spare wheel well should be far enough away from the rear axle (like the Mk7 Golf estate) the AWD should fit (besides the top perch for the springs). However there may be differences so I'm not 100% certain..
2WD multilink MK7 Golf estate to AWD is very easy, all the bodywork is the same...I looked at doing it in 2014 & others have done it since then..
