2.0Low
- NB, Canada
Anyone know how to code the rear fog without the reverse wire hack?
I have a 2015 GTI and retrofitted mk7.5 tails and front fog lights awhile back. The tail harness I have isn't easily modded to have the fog work (JBale ver.1), so I chose to run a wire from the BCM, direct to my rear tail.
So far, I've run a wire from pin 72 on connector "A" from my BCM to pin 7 on my inner tail. I was advised by JBale that pin 7 was the correct one for this harness. I've also checked off "light switch with rear fog" in central electrics via VCDS.
From my understanding, I now need to activate pin 72 in VCDS but that parts in German. Any help activating this would be appreciated!
Attached is a photo I found on the forums (can't remember what one), that was made/posted by user DV52.
