golfdave
- Scotland (U.K.)
- Mk7 Golf GT Estate
Having had VAG cars for 26yrs one of the common causes for rear callipers sticking beside the cable problems is that the internal return spring inside the caliper can fail, & usually they use the same spring for both sides, instead of making them "handed". So you din that one side will fail sooner then the other side. You can in some cases retro-fit external helper springs on the lever arms, usually T-4 van or Passat springs etc...
One other problem is that the fixed & moving parts of the calliper/pads stick together & require a good grease..I now use Loctite "heavy duty" which is a grey high temp grease suitable for stainless steel, & wash out proof etc..
