PowerDemon
- Richmond, VA
- Golf GTI, Camaro ZL1
You’ve got a built motor though right? Should be fine to like 8k?
New factory motor.You’ve got a built motor though right? Should be fine to like 8k?
I'd be very cautious going that high in the rpms with a stock engine. If you go too high multiple times, could end up getting valve float.New factory motor.
So what is it? Wastegate not open enough?I highlighted the parameter in the log...
That still don’t change our confusion for the cat clock meaningI highlighted the parameter in the log...
I see that now on my PC. I usually browse on my phone and datazap loads but is impossible to actually use.I highlighted the parameter in the log...
CTS 3.5" and factory catback. Can't imagine it's worse than my old 3" ebay special.That wastegate percent at 27psi on a vortex seem typical to me considering he’s using a choked up downpipe (lol )
Good question. Power definitely falls off. This was in drive not sport but using the paddle to upshift. Got a new file today. I’ll flash it and see how it is.Why does it drop boost at the shift?
