Quebster's Neverending Story - 2015 GTI S 6MT - The Good, the Bad, the End... and the Resurrection!
Gvazquez
North Carolina
I also think that this is the main contribution to turbo failures on this platform because a pressurized crankcase also means that your turbo drain line isnt actually draining properly because it's a gravity drain line that goes to the block. If theres pressure there, then you wont have sufficient drainage for the turbo. Just speculation of course but tell me what you guys think.
Gvazquez
North Carolina
I would imagine random seals will start leaking some oil.
Gvazquez
North Carolina
What do you mean by weep?
Gvazquez
North Carolina
Lol. I mean that is common and even after rebuild on mine with all new gaskets, I suspect this is an actual problem versus a normalized thing for these engines.
The Dude
PNW
MK7 GTI S
a properly plumbed PCV system should pull a slight vacuum on the crank case, shouldn't it? I'm gonna have to read more about how the system is supposed to work, because my understanding from school is that you keep a slight vacuum on the crank case so that you don't pressurize it and blow gaskets and seals out.
Gvazquez
North Carolina
It should at idle and then go closer to 0 with vacuum not applied, i.e under load/acceleration.
Quebster
Dallas, Tx
I think that blowby does and at the same time doesn't make sense. lol. I think if it's blowby, I wouldn't call it excessive, but would call the ventilation inadequate. Why some have the issue and some don't, hard to say. We all know how finicky these motors seem to be. Maybe it's something with my early '14 build. But I don't think <10% leakdown @ 100psi warrants "excessive" blowby in any scenario.
Regardless... nail in the coffin here. I was out doing some logs yesterday and had a turbine blade just break right off. No idea why. I'll scope my cylinders and see if I have pieces of my pistons missing or anything, but one blade breaking and the rest being fine doesn't seem like FOD to me.
I was struggling to convince myself to give up on the GTI but this seals the deal for me. I've been telling myself if I had to pull the turbo back off, the stock IS20 is going on and I'm not taking it off. So here we are! GG gents
Quebster
Dallas, Tx
One other item. A compression test is done at TDC, yes? The assumption is that the bore is consistent all the way down in that case, no? What if it isn't? Could that not be the cause of the blowby? Just spitballing here.
Not sure.
Also, sorry to keep posting but did that wheel need that much grinding to balance? It's out of focus but damn it's missing a healthy chunk at the bottom...
You're talking about the "nut" in the center? That's just how it is, it isn't ground I don't believe. Or is it? I guess I really don't know. I just assumed that was the shape of the nut. lol
Here was my V2 when it was new:
