proper oil level - on dipstick
chillax
Wi
18 GTI SE plaid
After my last oil change at the dealership I checked the dipstick and the oil level showed up just over the minimum mark. Is this okay or considered low? In the past they've always filled to show a much higher reading. I'm wondering if I should top it off.
I would top it off. When I get my oil changed I bring 6 quarts and it always brings it up to a hair below the top mark. The manual says 6 quarts. Including the filter.
chillax
Wi
18 GTI SE plaid
I've been driving with it at that level for a couple months (about 1.2K miles). I'm not sure the exact oil they use but I think it's VW branded Mobil 1.
Strange Mud
Small Town CT
Assorted
I would add oil to it. Technically it's fine but easy-peasy to make it more fine
OldVWFan
NW Arkansas
17 GTI Sport
When you checked the oil level had the car been driven where the normal oil temperature was achieved? If you did and this was the level on the dip stick then I would add enough to bring it up to mid-way on the dip stick. My 17 GTI takes 5.7 liters and t dip stick shows at mid-way when cold thus allowing for oil expansion when hot.
