Diggs24
- de plains! de plains!
- 2015 GTI
hmm, guess I'll have to drill through the existing inserts to make a hole. nbd. I'll post pics.
Thought they were always 925, it was CTS that uses 980.Why did PR reduce the size of their injectors from 980cc, like what I have, to now 925cc?
No hose clamps. Also, the instructions state to "use the provided hose". There are no fuel lines in the kit so I think they need an update.
PR does need to update their install PDF. Their wiring harness now includes 3 wires for the flex fuel sensor which is not mentioned on the install PDF. This will throw people off at install time.
Lol, that line is still on the kit contents section too.
So I guess that means they want you to use the stock fuel line instead. Either way, I'd clamp the connections to rail and hpfp. My inserts never backed out but had that AN6 line pop off the barbed fitting and the hpfp. A section of the stock line might work better in that spot since it's more flexible.
That's exactly what happened to me! Haha. Took me a long time to figure it out even with Railroader's help. Discussed in post #88.
I do have a question about the lines. It looks like the stock line has a fitting there that it could be taken apart at there on the left side of the manifold. Do you guys just separate it there and jam it into the barbed part of the mpi rail and clamp it down or do you just cut out a section of the OEM line on both sides? Obviously the OEM line is too long and needs cut down a bit mpi rail to hpfp.
I haven't installed my kit, but did have conversations with them back in December when I received the goods since based on the install doc, it seemed I had missing parts.
In short, they said something along the lines of the stock hose, fitting better in typical installs than the hose they were previously including. There was mention of a fitting too. I can't recall if there was an extra one included or if one was taken out from the parts vs parts on doc.
I got an email today from PR saying they are working on a new install doc and if ready, I might even get a copy of it by email. Will advise if so.
I am being told the fuel rail hasn't changed. Only the install hardware.
