PowerDemon
- Richmond, VA
- Golf R, GLI, ZL1
Hello all,
I never thought I would dive down this rabbit hole enough to warrant a build thread, but I think it is time to make one.
Interior:
Raceseng Topology
OEM Monster mats
Helix Subwoofer Upgrade
Exterior:
BMS billet exhaust tips
Rennwagen V1 Spoiler Extension
Llumar Ceramic tint 50/35%
Engine:
DBV2 V1 Journal Bearing Hybrid IS38
DBV2 Large Bore TMD
Equilibrium Tuning Protune
Southbend Stage 2 Daily
Baun Performance FMIC
aFe Magnum Force Pro Dry S Intake
MST Performance TIP
Brisk Racing ER10S
Bosch 4-BAR PUT Sensor
Fueling:
Autotech HPFP Internals
Pagparts 450 LPFP
Pagparts 8mm Fuel Lines
Exhaust:
CTS Turbo 3.5” Catted Downpipe
Custom 3” Midpipe
Vibrant 17950
Suspension:
BFI Stage 2 Engine and Trans Mounts
Powerflex Black Series Poly Dogbone Mount Insert
10/15mm APR Spacers
19” VW Pretoria (Hyper Black) with Firestone Firehawk Indy 500s
18” Audi A3 S-Line wheels (Porsche Silver) with Michelin Pilot Sport All Season 4s (winter)
Braking:
(Front)
Stoptech ST-40 Calipers
Stoptech 355mm Slotted 2-Piece Rotors
Hawk Performance HPS pads
Stoptech Stainless brake lines
(Rear)
Stoptech 272mm Slotted Rotors
Hawk Performance HPS 5.0 pads
Fluids:
Motul Gear 300 75W-90 (Transmission oil)
Liquimoly 5W-40 Leichtlauf High Tech (Engine oil)
Misc:
BMS Clutch stop
BMS Billet washer fluid cap
Clutch delay valve delete
Bosch Aerotwin wipers
Braille G20S
MeLe Series 600 battery mount
Performance (Dragy) (93)
1/4 Mile - 13.13s @ 116.5mph
60-130 - 9.63s
60-100 - 4.26s
0-60 - 5.54s
I got the car in July of 2018. I searched for at least 2 months to find the one I wanted. I wanted CSG, manual transmission, S trim, and the lighting package. I finally found the one I wanted in Pennsylvania and I bought it CPO with 36,xxx miles on it. Unfortunately a few thousand miles into my ownership I took it to my local dealer to get a weird clunking sound looked into. It turned out to be a failed transmission, which was fortunately replaced under warranty. While they had the engine out I took the opportunity to have them install a Southbend Stage 2 clutch. I finally got the car back and it turns out that it was still making the same clunking noise. Imagine that. I took it back and it turned out to be a failed lower control arm and bushing. I replaced both and it seemed to fix the issue.
Heres the car after I picked her up from Pennsylvania.
Around 42,xxx miles I took the car to my first stage of power modifications with an aFe dry filter and a JB4. I ran the JB4 on a custom map 6 set up by George who was very helpful throughout the process. I also got a Llumar window tint installed 50/35%. The car was a blast in this configuration and I planned to keep it this way for a long time. I kept it in that state for maybe 20,000 miles.
Here she is all cleaned up after the tint job.
Late in 2019 I decided to take it to the next level. I installed a CTS Turbo downpipe, Brisk spark plugs, and a Stratified Stage 2 tune. The car was a blast and had a ton more power. I ran it like this until early 2020 when I bought a whole new round of modifications to take my car to Stage 3.
Early 2020 I bought a DBV2 V1 Journal bearing turbo, EQT protune, Stoptech brakes, and a Baun Performance FMIC. Today I got the FMIC and Stoptech brakes put on. I am still waiting on the turbo, and it should be in early April. I got the Stoptech ST40 355mm kit and it was a crazy easy install. If I had to do it again I could probably do it in an hour and a half. The brakes feel great as well. I haven't gotten a chance to test out the FMIC yet because it isn’t quite warm enough yet to notice but the install was relatively easy. I also might get the rear calipers painted silver to match the fronts. I bought a set of used black 19” Pretoria wheels. I got them stripped, the curb rash fixed, re-powdercoated hyper black, and had a set of Firestone Firehawk Indy 500s mounted. I am very pleased with the wheel and tire setup. The only con to the Pretoria wheel is that I have to run 10mm spacers to fit the Stoptech brakes, but I think they look good enough to justify it.
Some install pics. Intercooler going in...
Here she is after the intercooler install.
Vibrant 17950 along with custom 3” midpipe. Shoutout to Lou’s Custom Exhaust
Here she is after I installed the Stoptech ST-40 kit with the 19” Pretoria wheels.
And here she is in her current state after a fresh wash.
Winter Mode
Interior:
Raceseng Topology
OEM Monster mats
Exterior:
Engine:
DBV2 Large Bore TMD
MST Performance TIP
Brisk Racing ER10S
Fueling:
Pagparts 450 LPFP
Exhaust:
Custom 3” Midpipe
Vibrant 17950
Suspension:
10/15mm APR Spacers
Braking:
(Front)
(Rear)
Fluids:
Misc:
BMS Clutch stop
Braille G20S
60-130 - 9.63s
60-100 - 4.26s
0-60 - 5.54s
Winter Mode
