silverfish
- USA
- MK7 Jetta GLI 35th
2019 gli, hpa hpfp, arm fmic, big bore turbo inlet, cai,
running full e85, im running into a power cut and i cant chase down what is causing it.
https://datazap.me/u/jjttls/log-1716267106?log=1&data=1-3-12 4th gear with traction ( no, traction control isnt the issue )
You can see the limiter kick in at the end and then i let of throttle a bit after.
Any ideas will help
This is a 3rd with no traction. Same issue except this one cut timing with no knock. https://datazap.me/u/jjttls/log-1716260080?log=0&data=1-3-6-12
Low timing, high timing, low boost, high boost, it keeps happening. Happened prior to the hpfp install, and the intercooler install. Seems to be much more apparent now
Any ideas will help
