Setam
- Bucharest, Romania
Hello everybody,
First of all I want to say that this is my first post on GolfMK7 so please go easy on me.
[Intro]
As most of you guys know, retrofitting an MIB2 unit on a MIB1 mk7 was always a problem because of CP and Fec's (especially if you are on a budget). As of now, there are a few people on the internet that can remotely remove CP and enable all Fec's for a substantial sum of money (aprox. 250-300 euros) either by ODIS online or by hacking the unit. The later one caught my attention so I did some research on my own. Recently some Porsche owners have been upset that PCM4 (equivalent to MIB2) units only support CarPlay and no AndroidAuto so they did their own research and managed to enable this function on their units using some programming and reverse engineering skills. This opens a lot of possibilities for MIB users too. They managed to do this by dumping the PCM's firmware on a SD card, modifying it and then flashing back the firmware into the unit. Unfortunately this involves some advanced programming skills. Luckily for us, one Porsche owner has managed to do a step by step guide on how to do this, except for one step. This is where we need to work together in order to make this work.
Since my programming skills are limited (next to nothing), I ask you, my fellow MK7 owners, for help.
I will attach the instructions that explain this process step by step and the links to the topics where this has been discussed. I highly recommend taking the time to read these.
Together we might be able to do this retrofit without ever stepping into a VW dealership.
Enjoy
[Instructions]
Enabling Android Auto on PCM4
Step 1. Required Components
What if I flash a bad ifs image to my head unit?
⁃ If this happens, MIBRoot will fail to start and you will not be able to interface with PCM4. it will appear to boot from the LCD panel, but touch and audio will not work. However, it will still boot into QNX for recovery since we are only flashing the stage2 image.
⁃ To recover, log into QNX with root / oaIQOqkW
⁃ Copy your original IFS root file (ifsroot_stage2_orig.ifs) to your SD card and install to left slot of PCM4.
⁃ Issue commands:
⁃ flashunlock
⁃ flash.it -v -x -d -a0x00BA0000 -f/net/mmx/fs/sda0/ifsroot_stage2_orig.ifs
⁃ flashlock
⁃ Note: If stage2 ifs flashing fails, flash.it, flashlock and flashunlock may no longer be present on your system. Copy them to your SD card from your extracted ifs directory and run them from the SD card, for example /net/mmx/fs/sda0/flashunlock.
What if my firmware flash works but I still don't have Android Auto?
⁃ Your VIN, VCRN, or FECs may need to be corrected, review step 7. Cars without CarPlay may need to add FECs 00030000, or 00060700 and 00060800
⁃ If your FECs are being removed from FecContainer.fec and being placed into IllegalFecContainer.fec, then your FECs are failing the signature check. Your patch is wrong and you need to review step 5 again.
⁃ If you did not have CarPlay or Android Auto previously, you may also need to code USB media player functionality within PIWIS II.
What if I want to return to stock?
⁃ Connect to PCM4 via UART
⁃ Log into QNX with root / oaIQOqkW
⁃ Issue commands:
⁃ flashunlock
⁃ flashlock
⁃ mount -uw /mnt/efs-persist
⁃ rm /mnt/efs-persist/FEC/FecContainer.fec
⁃ mv /mnt/efs-persist/FEC/FecContainer.fec.orig /mnt/efs-persist/FEC/FecContainer.fec
⁃ Done. Reboot by holding power button for 30s
[Links]
https://rennlist.com/forums/991/1142493-retrofitting-pcm4-in-a-991-1-a-3.html
https://rennlist.com/forums/991/1049794-porsche-pcm-upgrade-hack-for-android-auto-is-this-real.html
https://github.com/herrfrei/PorschePCMStuff
[Intro]
Enjoy
[Instructions]
- ⁃ UART -> USB Adapter (Setam's eddit: From what I understood, this might be done using a d-link dub-e100)
- ⁃ PuTTY or similar terminal app
- ⁃ IDA Pro ($$$$$), Ghidra (free), or similar ARM V7-A compatible disassembler
- ⁃ SD Card
- ⁃ Linux computer to unpack + repack filesystem
- ⁃ dumpifs and mkxfs from QNX SDP / OpenQNX. Build these from source on your linux machine to ensure proper compatibility. (available at https://github.com/ibreakifix/PorschePCMStuff pre-built for Ubuntu 19.04 x64)
- ⁃ mkxfs attributes file from https://github.com/ibreakifix/PorschePCMStuff
- ⁃ Connect GND to GND (PCM4 chassis works), RX on adapter to J5_TX on PCM4, TX to J5_RX on PCM4; pins B3 and B9.
- ⁃ To connect, you can remove the connector block from the quad-lock, then route your TX/RX/GND pigtails through the opening.
- ⁃ Open PuTTY, launch a serial connection to your COM port (see devmgmt.msc) - 115200, 8, N, 1
- ⁃ Login with root / oaIQOqkW
- ⁃ Issue the "stfu" command to stop verbose logging to the terminal.
- ⁃ Insert SD card into PCM4, left slot
- ⁃ Issue the following command to download your filesystem: "dd if=/dev/fs0 of=/net/mmx/fs/sda0/PCM4_NOR.bin".
- ⁃ Issue the following command to copy your existing FEC file: "cp /mnt/efs-persist/FecContainer.fec /net/mmx/fs/sda0/orig_FecContainer.fec"
- ⁃ Remove SD card and insert into your PC.
- ⁃ You can also pull this image from an update SD card at ./RCC/ifs-root/*/default/ifs-root.ifs **Note: The desired image is the second ifs contained within this update file, use ctrl+f and find the second instance of file magic "EB 7E FF", your IFS image begins at this location and ends at the end of the file. If you do this, you can skip steps 4.1 to 4.3**
- ⁃ Open downloaded RCC NOR image (PCM4_NOR.bin) in your favorite hex editor
- ⁃ Jump to offset 0xBA0000, ensure IFS magic of "EB 7E FF" is present. If not, issue "flashlock" on PCM4 shell to obtain correct offset, target IFS is ~15.6mb. See screenshot.
- ⁃ Select from 0xBA0000 to the end of the IFS, which is indicated by a block of padding "FF FF FF FF FF". In my case, this data was 15,639,040 bytes. See screenshot.
- ⁃ Cut and paste this block of data into a new file, name it ifsroot_stage2_orig.ifs
- ⁃ Move to a linux computer with dumpifs binary (available from QNX SDP)
- ⁃ Copy ifsroot_stage2_orig.ifs to some folder, open your terminal and CD to that folder.
- ⁃ Copy dumpifs_helper.sh to this same folder. Chmod it to 755
- ⁃ Issue "./dumpifs_helper.sh ifsroot_stage2_orig.ifs" to extract the IFS, your files will be in ./ifs_extracted. Ensure files are present as shown in the terminal output
- ⁃ Place a copy of /usr/apps/MIBRoot so it can be patched with IDA, Ghidra or similar
- ⁃ Place your patched MIBRoot into your extracted IFS location, overwriting the old MIBRoot. It should be located at ./ifs_extracted/apps/bin/
- ⁃ Open terminal. Issue command: EXPORT QNX_TARGET="/"
- - cd to whatever the parent directory is to the ifs_extracted folder we made earlier
- ⁃ Download mkifs_attributes.txt from github repo. Place it in your current working directory
- ⁃ Build the new IFS with mkxfs, issue command "mkxfs -t ifs -nn -o ./ -r / ./mkifs_attributes.txt ./ifs_extracted ./patched_ifs.ifs"
- ⁃ Place patched_ifs.ifs back onto your SD card
- ⁃ Open the FEC container (orig_FecContainer.fec) from earlier in your favorite hex editor
- ⁃ Copy VIN from file. This should match your car's VIN, unless component protection is enabled, then it would be the VIN from the donor car
- ⁃ Copy down VCRN (hex values of bytes 16-20 in file). Write it down as shown in the blue highlighted text in the screenshot. The VCRN may be obtained through measurement channels on PIWIS if you only have a 4 byte empty FEC file.
- ⁃ Make a comma separated list of your existing FECs, from offset 0x43 until the checksum begins. Use hex values, add commas at every 4 bytes (8 digits), for example, from screenshot it would be 00030000,00030001,(...),06310099
- ⁃ Add one last FEC to the end of that list, which will enable Android Auto: 00060900
- ⁃ You can also add other FECs to your PCM4 at this time, see below. Additional coding / adaptations may be required.
- ⁃ Download MIB2_FEC_Generator.sh from Github, chmod it to 755
- ⁃ Issue command to generate FEC Container "MIB2_FEC_Generator.sh -f {YOUR_FEC_LIST_CSV} -n {YOUR_VCRN} -v {YOUR_VIN} -d {Output_Directory}"
- ⁃ Output file is FecContainer.fec, copy this new file to your SD card
- ⁃ Remount efs-persist as r/w with command "mount -uw /mnt/efs-persist/"
- ⁃ Copy your new FECs with command "mv /mnt/efs-persist/FEC/FecContainer.fec /mnt/efs-persist/FEC/FecContainer.fec.orig; cp /net/mmx/fs/sda0/FecContainer.fec /mnt/efs-persist/FEC/FecContainer.fec"
- ⁃ Issue commands to flash your stage2 ifs-root... THIS CAN BRICK YOUR HEAD UNIT, SO BE CAREFUL! Important note: "flash.it" is actually one word, but RL censors it, so remove the period otherwise the command won't work.
- ⁃ flashunlock
- ⁃ /usr/bin/flash.it -v -x -d -a0x00BA0000 -f/net/mmx/fs/sda0/patched_ifs.ifs
- ⁃ flashlock
- ⁃ Reboot unit by holding down power button for 30s.
- ⁃ Cross fingers and hope your patch worked
- With PIWIS II / PIWIS III, or VCDS
- ⁃ If using PIWIS II, place it into engineering mode via Settings -> Diagnostics Configuration -> 911, 918s, etc... -> Mode -> Select "E". Save + Exit
- ⁃ In PIWIS, Open Diagnostics -> 911 -> 991, scan car (F12) to obtain installed modules, select head unit (Named MIB2...). In VCDS open module 5F
- ⁃ Select "Manuelle Codierung ohne MCR-Regeln" -> Vehicle_configuration
- ⁃ Set Bitfield (3) Google_GAL -> "on"
- ⁃ Save coding, wait for system to reboot
- Alternate method coding through PCM4 shell:
- export LD_LIBRARY_PATH=/mnt/app/root/lib-target:/eso/lib:/mnt/app/usr/lib:/mnt/app/armle/lib:/mnt/app/armle/lib/dll:/mnt/app/armle/usr/lib
- export IPL_CONFIG_DIR=/etc/eso/production
- on -f mmx /eso/bin/apps/pc b:0:3221356628:7.7 1
- ⁃ Plug in your phone. You should now have Android Auto
⁃ Issue commands:
⁃ flashunlock
⁃ flashlock
⁃ Issue commands:
⁃ flashunlock
⁃ flashlock
[Links]
