So about a year ago I had a basic service done on my 2016 GTI. Oil change, piugs tire rotation (non-dealer outfit). Well after picking up the car and doing the usual 100+ test drive I felt some serious vibration and loud noise coming from the left front wheel area. At first it would happen only over 60 mph and I would get serious steering wheel vibration and hear a strange loud vibrating noise coming from the front. I would pull over after every occurrence and finally check the wheel bolts and discovered they had not been tightened but slightly threaded but into the wheel so someone forgot the tighten them.
So after fixing the problem and thinking all would be fine, Ive now noticed a very loud squeaking screeching noise coming from the left front of the car (same wheel) and only happens between 1-5 mph. sounds like metal on metal. So im asking here to hopefully someone who might be a mechanic what they think might be causing that screeching currently and if having fucking loose wheel bolts and doing 100 with a non tightened wheel may cause damage to something ie rotors etc. Thanks much in advance... wouldn't know what to do with these forums.
