swifthide
- Riverside, CA
Thank you! But do you think I’d need any spacer at all for 18x8.5 et43?99% sure it will. Fit with 18x7.5 et51 with 10mm spacers and with room to spare
No it shouldn’tThank you! But do you think I’d need any spacer at all for 18x8.5 et43?
Sorry to bump an old thread, but I'm seriously considering going this route on my Alltrack and just wondering how this has worked for everyone in the long term.
these are great brakes. If you want then, get them lol
I'm certainly leaning toward it. Just wanted to get some long term feedback.
Are the Boxster calipers much larger than the stock Alltrack calipers?
Stock Alltrack is 312mm disc with a 57mm diameter single piston sliding fist caliper....basically standard GTI..
Are the Boxster calipers themselves larger than the Alltrack calipers?
2+ years and they are great. Super easy to service. But I also put on residual pressure valves as mentioned elsewhere, 10psi. definitely needed them
Don’t know if it’s been mentioned yet but source pads from FCP Euro and you can get replacements for free (just cost of return shipping the old ones) whenever or as frequently as you want
Which OBD11 adaption changes bias?TLDR: I noticed my rear brakes were not being used (unusual increase in front-biased braking) after installing these brakes (possibly due to piston size difference?) and i corrected it through OBDeleven.
to anybody else that has done this, I had noticed something interesting on my base golf. The rear rotor always had a strange, worn-looking pattern on it. I had come to realize recently it was because my rear brake was not engaging as much as it should (thus the 986 brakes doing most of the work). I was able to correct this with Obdeleven/vcds coding. Under brake adaptions is "hydraulic brake boost" which was set to an offset of 8 stock. I had first tried setting it to 7 and had already noticed more balanced braking. my rear rotor also started to look more normal (the normal silver instead of a rusty and coated look). I tried 6 and this time with some hard stops on an empty road (to test safety under hard braking). 6 seems to favor the rear just slightly but overall i think its where im currently satisfied and the rear rotor looks exactly as i would expect it should.
To add a disclaimer, I can't 100% guarantee that what i noticed is true and adding too much rear bias could pose a lot of safety issues ( too much rear bias is much more difficult to recover from under hard braking and stock cars usually have some front bias).
