*EDIT* All the part numbers you need below.
Well, here it is, NQSBBK fitted on MK7 GTI, highly recommended for anyone who's on a tighter budget and doesn't want to dish out 2K+$ for upgraded brakes.
Below is the parts list you need for this kit :
Porsche boxster calipers, you can find these used from a local scrapyard or on the forums. If not, here is a link to buy them new for about double the price of used.
Left : 986-351-421-03
Right : 986-351-422-03
http://www.apikol.com/index.php/products/braking/brake-components/porsche-boxster-caliper-set.html
Caliper mounting brackets, mounting screws and banjo bolts (to reuse stock brake lines) :
http://www.apikol.com/index.php/pro...10/a3-vw-mkv-mkvi-boxster-brake-brackets.html
Caliper dust boots and piston seals, if you wish to rebuild your used ones :
http://store.zeckhausen.com/catalog/product_info.php?cPath=88_3944_6261_6262&products_id=5789
Rotors :
Stock GTi rotors, 312x25mm
Pads :
Any pads you like for Boxster 2001-2004
Brake pad "anti-squeal" dampers, will greatly help in reducing potential brake squeal :
Part Number: 987-351-088-01-M100
http://www.pelicanparts.com/catalog/SuperCat/986M/POR_986M_BRKPAD_pg3.htm
Spacers :
Haven't tried with stock MK7 wheels (18x7.5 et49) but with the Serrons on my MK6 (18x7.5 et51), I needed 3 mm spacers for a decent clearance. (I have good clearance on 18x8 et50 with no spacers)
You should be good to go!
Rotors :
Pads :
Spacers :
