Hi, I’m hoping for some help regarding quite a few fault codes. ACC, stop start is unavailable and also a flashing orange glow plug light on the dashboard although the car doesn’t seem to be in limp mode.
Please see the list of codes below and hopefully some of you can shed some light on it all.
Any input is appreciated thanks.
Car Scanner ELM OBD2
Version: 1.99.8/1.99.8/iOS
DTC report
Connection profile: Volkswagen OBD-II / EOBD Diesel 1.6 TDI CAYC, CAYA engineDate: 9/14/2023 5:12:59 PM
VIN: WVWZZZAUZGP012820
OBD-II
No DTC found.
19. CAN Gateway19. CAN Gateway
DTCs: 3
131604 [0x020214] Archive (inactive)
U015500: Lost Communication With, Instrument Panel Cluster (IPC) Control Module
Timeout_Node_0x14_DiagAdress_17_KOMBI
Status bits: 1
Priority: 2
Frequency: 7
Unlearning index: 83
Odometer: 73397 km
Date, time: 2023.09.13 17:58:03
Status: Confirmed
131671 [0x020257] Archive (inactive)
U023500: Lost Communication With, Cruise Control Front Distance Range Sensor
Timeout_Node_0x57_DiagAdress_13_ACC
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 73390 km
Date, time: 2023.09.13 15:25:14
Status: Confirmed
15360512 [0xEA6200]
U110100: Component protection active
Komponentenschutz aktiv
Status bits: 1
Priority: 4
Frequency: 2
Unlearning index: 43
Odometer: 73396 km
Date, time: 2023.09.13 00:01:43
Status: Test failed, Confirmed
09. Onboard supply control unit09. Onboard supply control unit
DTCs: 5
263442 [0x040512] Archive (inactive)
B131DF7: Sirens / alarm horn for anti-theft warning system, No release by immobilizer
Kommunikationsüberwachung Kombiinstrument zum BCM (Fehler DWA)
Status: Confirmed
539925 [0x083D15] Archive (inactive)
U112100: Databus missing message
Kombi_02 Datenbus fehlende Botschaft
Status: Confirmed
552213 [0x086D15] Archive (inactive)
VIN_01 Datenbus fehlende Botschaft
Status: Confirmed
558869 [0x088715] Archive (inactive)
Kombi_01 Datenbus fehlende Botschaft
Status: Confirmed
559637 [0x088A15] Archive (inactive)
WFS_01 Datenbus fehlende Botschaft
Status: Confirmed
03. ABS control unit
No DTC found.
01. Engine control unit01. Engine control unit
DTCs: 4
25577 [0x0063E9] Archive (inactive)
P157000: Engine Control Module (ECM) disabled
Status: Test failed since last DTC clear
25810 [0x0064D2] Archive (inactive)
25812 [0x0064D4] Archive (inactive)
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 73390 km
Date, time: 2023.09.13 15:24:47
Engine RPM: 0 rpm
Calculated engine load value: 0.00 %
Vehicle speed: 0 mph
Engine coolant temperature: 46 ℃
Engine oil temperature: 26 ℃
Barometric pressure: 14.5037738007 psi
Klemme 30 voltage: 13
Paramteric values: 20 96 28 44 D0 00 00 20 3C 00 07 21 0F 00 08
25130 [0x00622A]
P164700: Checking coding/versions of, control modules in drivetrain
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear, Warning indicator requested
04. Power steering04. Power steering
DTCs: 2
22016 [0x005600] Archive (inactive)
KFC_KOMBI_01 Botschaft - CAN-Timeout
Status: Confirmed
24064 [0x005E00] Archive (inactive)
VIN_01 Botschaft - CAN-Timeout
Status: Confirmed
08. Heater and climate08. Heater and climate
DTCs: 1
459011 [0x070103] Archive (inactive)
Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation
Status: Confirmed
10. Parking Assistant 210. Parking Assistant 2
DTCs: 3
13637426 [0xD01732] Archive (inactive)
U112300: Databus error value received
ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen
Status: Confirmed
12670240 [0xC15520] Archive (inactive)
Steuergerät für Schalttafeleinsatz-J285 - Gateway_72.WFS_01_alt - kein Signal/keine Kommunikation
Status: Confirmed
12670210 [0xC15502] Archive (inactive)
Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation
Status: Confirmed
13. Active cruise control13. Active cruise control
DTCs: 10
15360768 [0xEA6300]
FAULT_ATP_IKA_FAST_FAILED
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 73396 km
Date, time: 2023.09.13 00:00:39
Paramteric values: 02 8D 00 12 02 85 76 10 16 00 00 10 0F 00 00
01058 [0x000422] Archive (inactive)
FAULT_TIMEOUT_ESP_05
FAULT_CIS_ECD_NOTAVAILABLE
Status: Confirmed
01059 [0x000423] Archive (inactive)
FAULT_CIS_ESP_FAIL
Status: Confirmed
01093 [0x000445] Archive (inactive)
U112200: Databus implausible message
FAULT_CHK_ESP_24
FAULT_CIS_MILEAGE_INIT
Status: Confirmed
00284 [0x00011C]
FAULT_CIM_TIMEOUT_Getriebe_11
01027 [0x000403]
FAULT_CIS_TIMEOUT_Getriebe_13_alt
01028 [0x000404]
FAULT_TIMEOUT_APS_01
FAULT_CIS_TIMEOUT_Getriebe_14_alt
00274 [0x000112] Archive (inactive)
FAULT_CIM_TIMEOUT_Kombi_01
Status: Confirmed
01043 [0x000413]
B10E7F0: Cruise Control Front Distance Range Sensor, separated
FAULT_CIS_TSK_IRREV_FAIL
01034 [0x00040A] Archive (inactive)
FAULT_CIS_TIMEOUT_Uhrzeit_01_alt
Status: Confirmed
15. SRS15. SRS
DTCs: 3
1054976 [0x101900] Archive (inactive)
NWD: 0x6B7 Kombi_02 Timeout
Status: Confirmed
1051904 [0x100D00] Archive (inactive)
NWD: 0x30B Kombi_01Timeout
Status: Confirmed
1051136 [0x100A00] Archive (inactive)
NWD: 0x6B4 VIN_01 Timeout
Status: Confirmed
16. Steering column
No DTC found.
17. Dashboard17. Dashboard
DTCs: 3
16777028 [0xFFFF44] Archive (inactive)
U111000: Function restriction due to communication interruption
BAP_AWV_0x1B keine Kommunikation
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Status: Confirmed
16776960 [0xFFFF00] Archive (inactive)
ACC_02 keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 73390 km
Date, time: 2023.09.13 15:25:11
Status: Confirmed
16776961 [0xFFFF01] Archive (inactive)
ACC_04 keine Kommunikation
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 73390 km
Status: Confirmed
42. Driver door electronic equipment42. Driver door electronic equipment
DTCs: 1
458794 [0x07002A] Archive (inactive)
Status: Confirmed
44. Power steering44. Power steering
DTCs: 2
Status: Confirmed
Status: Confirmed
52. Front passenger door electronics52. Front passenger door electronics
DTCs: 1
Status: Confirmed
5F. Electronic Information System 15F. Electronic Information System 1
DTCs: 9
01555 [0x000613]
B201A00: Checking software version management
Softwareversionsmanagement prüfen
Check software version management
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 41
Odometer: 73390 km
Date, time: 2023.09.13 15:25:21
Paramteric values: 02 86 7D 10 02 00
06706 [0x001A32] Archive (inactive)
Kombi_01 keine Kommunikation
Instrument cluster, no communication
Status: Confirmed
06714 [0x001A3A] Archive (inactive)
VIN_01 keine Kommunikation
VIN, no communication
Status: Confirmed
07173 [0x001C05] Archive (inactive)
U111100: Function limitation due to missing message
ACC (0x05) - function restriction due to communication error - BapErr_retry not successful
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Date, time: 2023.09.13 15:25:25
Paramteric values: 02 86 7C 18 44 02
Status: Confirmed
07183 [0x001C0F] Archive (inactive)
Bordcomputer-Setup (0x0F) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful
Trip computer setup (0x0F) - function restriction due to communication error - BapErr_retry not successful
Status: Confirmed
07185 [0x001C11] Archive (inactive)
Uhrzeit/Datum (0x11) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful
Time/date (0x11) - function restriction due to communication error - BapErr_retry not successful
Status: Confirmed
07186 [0x001C12] Archive (inactive)
Service-Intervallanzeige Ölstandsanzeige (0x12) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful
Service interval display oil level display (0x12) - function restriction due to communication error - BapErr_retry not successful
Status: Confirmed
07187 [0x001C13] Archive (inactive)
Zentraler Einheitenmaster (0x13) - Funktionseinschränkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful
Central unit master (0x13) - function restriction due to communication error - BapErr_retry not successful
Status: Confirmed
07195 [0x001C1B] Archive (inactive)
Brake assist system (0x1B) - function restriction due to communication error - BapErr_retry not successful
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Status: Confirmed
76. Parking assistant76. Parking assistant
DTCs: 3
Status: Confirmed
Status: Confirmed
Status: Confirmed
DTC report
OBD-II
No DTC found.
DTCs: 3
Status bits: 1
Priority: 2
Frequency: 7
Odometer: 73397 km
Status: Confirmed
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 73390 km
Status: Confirmed
15360512 [0xEA6200]
Status bits: 1
Priority: 4
Frequency: 2
Odometer: 73396 km
DTCs: 5
Status: Confirmed
Status: Confirmed
Status: Confirmed
Status: Confirmed
Status: Confirmed
No DTC found.
DTCs: 4
Status bits: 1
Priority: 2
Frequency: 1
Odometer: 73390 km
Engine RPM: 0 rpm
25130 [0x00622A]
DTCs: 2
Status: Confirmed
Status: Confirmed
DTCs: 1
Status: Confirmed
DTCs: 3
Status: Confirmed
Status: Confirmed
Status: Confirmed
DTCs: 10
15360768 [0xEA6300]
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 73396 km
Status: Confirmed
FAULT_CIS_ESP_FAIL
Status: Confirmed
FAULT_CHK_ESP_24
Status: Confirmed
00284 [0x00011C]
01027 [0x000403]
01028 [0x000404]
Status: Confirmed
01043 [0x000413]
Status: Confirmed
15. SRS15. SRS
DTCs: 3
Status: Confirmed
Status: Confirmed
Status: Confirmed
16. Steering column
No DTC found.
DTCs: 3
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Status: Confirmed
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 73390 km
Status: Confirmed
Status bits: 1
Priority: 2
Frequency: 3
Odometer: 73390 km
Status: Confirmed
DTCs: 1
Status: Confirmed
DTCs: 2
Status: Confirmed
Status: Confirmed
DTCs: 1
Status: Confirmed
DTCs: 9
01555 [0x000613]
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Status: Confirmed
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Status: Confirmed
Status: Confirmed
Status: Confirmed
Status: Confirmed
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 73390 km
Status: Confirmed
DTCs: 3
Status: Confirmed
Status: Confirmed
Status: Confirmed
