shovelhd
- Western MA
The VW order guides have a lot of this information. Here's a 2017 version.
2017 VW Golf GTI order guide
I'd guess like 1k. I'm getting mine installed just because my trans is already coming out.P.S. What are people paying these days to buy a proper LSD and have it installed into non-PP models? (DSG). Looks like the unit is ~$1000-1300. What's install typically run?
Sorry to burst your bubble but you don't have a "LSD" with the performance pack......you get a Haldex unit bolted to the passenger side (NAR) driveshaft after the gearbox...
The term LSD refers to a limited slip differential...which is something the PP doesn't have as it still has a basic "open" differential in the gearbox case...
I did a write up here....
https://www.golfmk7.com/forums/index.php?threads/how-the-vw-golf-gti-performance-pack-pp-“front-differential-lock”-vaq-works.351185/
Its advertised as an LSDSorry to burst your bubble but you don't have a "LSD" with the performance pack......you get a Haldex unit bolted to the passenger side (NAR) driveshaft after the gearbox...
I don’t think you’re bursting anyone’s bubble by calling it something else. The practical effect is very similar.
“The amount of pressure on the clutch pack affects the transfer of torque from the spinning inner wheel to the driven outer wheel. Thus, torque acting on the spinning inner wheel is reduced & applied to the driven outer wheel, thus reducing or eliminating understeer & providing better cornering & control.”
No bubble has been burst. I know its not an actual LSD but the end result when driving feels just as good to me, so as I said it was well worth it. Whatever magic they are doing down there is doing its job.Sorry to burst your bubble but you don't have a "LSD" with the performance pack......you get a Haldex unit bolted to the passenger side (NAR) driveshaft after the gearbox...
Sounds like somebody didn’t get the PPSorry to burst your bubble but you don't have a "LSD" with the performance pack......you get a Haldex unit bolted to the passenger side (NAR) driveshaft after the gearbox...
I read what you wrote. I even quoted your write-up in my reply....The mechanical term "LSD" has been around for decades & refers only (in mechanics) to a Limited Slip Differential...this item fits inside the gearbox case, & is purely mechanical..
The VAQ unit is outside the gearbox case on the passenger side driveshaft & is electrical..pull the fuse & it won't work.....The VAQ units job is to cause the existing "open" type diff in the gearbox case to lock up by locking the driveshafts....& it relies on the ABS systems & uses the brakes to get around the "preload" situation & requires additional special oils at service time........go read the how it works guide that I wrote...
An LSD is 100% mechanical, fits inside the gearbox case as it replaces the basic "open" type diff.....& doesn't rely on the ABS or the brakes & has no electrics....also it runs only on the gearbox oil...do additional "special oils" come service time
Wouldn't want it anyway...Sounds like somebody didn’t get the PP
