Did they ever release an update to enable this?
Nope. I checked with my Dealer last week and VW hasn't issued anything yet.
Total speculation on my part, but I have a suspicion that there's something missing in the MIB3 head unit that prevents this functionality. If it were a simple software problem why would VW not have a TSB for a re-flash by now?
If I'm right and it would require a tech to open the dash, the cost to do this in the field would be much higher. Ford Pinto disease is still real.
It'll be interesting to see if the North American 2022 MK-8s have it. I'm assuming that that they have MIB3s. If so, the delay in updating our 2021s will make no sense at all.
Anybody have any updates on performance monitor release for MIB3?
also in speculation mode: I would guess their engineers are working on getting glitches out of the MK8 and other modelsTotal speculation on my part, but I have a suspicion that there's something missing in the MIB3 head unit that prevents this functionality. If it were a simple software problem why would VW not have a TSB for a re-flash by now?
The stock coolant temperature is not accurate. It stays on 194* unless you are about to overheat. The oil temp is accurate.So you guys can't check oil or coolant temp? I know the stock monitor isn't the most accurate thing, but it's still nice to have.
Yeah, the oil temp is more important. I realize an AP gives more accurate readings, but it's still silly that they haven't given this to the 2021 crowd.The stock coolant temperature is not accurate. It stays on 194* unless you are about to overheat. The oil temp is accurate.
Sure is.Yeah, the oil temp is more important. I realize an AP gives more accurate readings, but it's still silly that they haven't given this to the 2021 crowd.
Oil temp is pretty much the only thing I have displayed in the cluster.So you guys can't check oil or coolant temp? I know the stock monitor isn't the most accurate thing, but it's still nice to have.
