So if you install one and set it "100% linear", does the engine bog down when you give it to much fuel?
Yes. So if you input too much throttle, the ECU overrides it to deliver the maximum possible without bogging? Is there that much of an improvement in throttle response?
Nice thing about the BMS unit is you can have a daily setting and a showing off setting as well.
No it will not add any power, but my R is a tenth quicker in the 1/4 mile with it installed and turned all the way up.
You mean you can program a quick select for different settings?
There’s different stages (that corresponds to a light colour)
white= stock
green = stage1
orange = stage2
red = stage3
In those settings you can fine tweak with + or -
I recommend the BMS unit. Makes a considerable difference.
white= stock
green = stage1
orange = stage2
red = stage3
Settings can be changed on the fly.
I have mine set for street and strip with one push of the button.
