anotero
- Hither and thither
- Mk7 GTI
Does anyone know the latest/best revision of the PCV system for the GTI? I'm getting conflicting info by searching online.
2017 GTI
2017 GTI
Are the GTI and R PCVs different? I see they have differing two letter suffixes at the end of the PNs.06K103495AP I think is the one for the MK7(15-18) GTI's, but could be wrong.
06K103495BM? I show fitment on that for R's and the Audi MQBs.Are the GTI and R PCVs different? I see they have differing two letter suffixes at the end of the PNs.
Yeah, I saw that. I assume PCVs are not interchangeable between the GTI, R, A3, etc?Or 06K103495BL? That one I also Show Audi (A3-4, 4 Quattro), but also Golf 1.8T along with the GSW/Alltrack.
Edit: Parts.Vw shows BL also fitting '19 R's
Not sure, I tend to go with what parts.vw.com calls out (when it can be found) for my car as it'll generally be the latest revision. You can also call your local dealer and give them your VIN and ask, most will check even if you don't order from them. Looking at FCPEuro though, the underside looks different between BL and BM/AP:Yeah, I saw that. I assume PCVs are not interchangeable between the GTI, R, A3, etc?
Very different indeed. I'll check. Thanks for the input.Not sure, I tend to go with what parts.vw.com calls out (when it can be found) for my car as it'll generally be the latest revision. You can also call your local dealer and give them your VIN and ask, most will check even if you don't order from them. Looking at FCPEuro though, the underside looks different between BL and BM/AP:
06K103495BL:
BM:
AP:
Looks like BM and AP might be interchangeable, but BL is missing the Fin looking guy at the top. Double checked with an ECS picture to make sure it wasn't the FCP angle:
BL again:View attachment 212884
