Passenger Door and Controls Stopped Working
BBSkarting
Indianapolis
I've had this issue for quite some time, but honestly I didn't care enough to investigate and see what was wrong.
What DOESN'T work:
Passenger side view mirror controls
Indicator on mirror housing
Locking mechanism
Lock/Unlock button on door
What DOES work:
Window and window control
Accent lighting on trim
So I originally thought that I had a fuse go bad causing the door not to get power, but everything is in order there from what I can find as far as a wiring diagram to figure out what is what. If anyone else has seen this issue or can point me in the right direction for where to look it would be greatly appreciated.
