DocNotDoctor
- Eastern NC
I've been a long time lurker on the forum and wanted to throw out my current situation for all of you to chew on.
For about 2 months had an intermittent P0141 code that would clear on its own but became almost daily a couple of weeks ago. At the same time, noticed a metallic ticking (tappet) sound that was apparent in before and after warm up. No other codes popped. Within a day or two, threw a P039B code with EPC during a 3rd gear pull at around 3700RPM. After turning car off and on, code cleared. The car runs fine at idle and during acceleration up to WOT/4k RPM then EPC with and without P039B. No smoke, no misfire, etc. Ran a few different tanks of 93, no change. Replaced RS7 plugs and coils, no change.
Contacted a local APR dealer and VW repair shop to perform diagnostics. They have performed most of the work on the car in regards to clutch, oil changes, etc. Confirmed codes and they believe tapping noise was a bad hydraulic lifter. Reflashed tune and spoke with APR, not tune related...per APR. They believe tapping noise is coming from cylinder 3 and 4, confirmed with stethoscope. Shop found the knock sensor to be defective (high voltage? I believe) and contributed the P039B (high pressure in cylinder 1) to the fault. They pulled off intake manifold to replace sensor. While there, they found minimal carbon buildup and cleaned as needed. Good news on that part. Knock sensor was replaced but code was still present during test drive and WOT.
Next step is to get to the top of the motor and explore the tapping/knock. Any thoughts? Fuel injectors? I'm replacing the 02 sensor tomorrow, hope to get rid of the P0141. I've searched the forum for the P039B code and didn't find anyone that addressed it. Google search produces little. Any clue why it would pop or if it's correlated with the ticking noise? Thanks all, sorry for the lengthy post. I hope to share my experience and findings.
Current Mods: 2015 MT, APR Stg 2 for 30k miles 93/HO (current 58k), CTS intake, CTS inlet, CTS intercooler, stock DV, APR DP, RSR clutch, RS7 plugs, BFI mounts, stock IS20 and exhaust. Haven't had any issues with the car thus far, regular ~8k oil change (5W-40 Motul). RS7 Plugs and coil packs have 200 miles on them.
