Andrewbens
- Modesto
- 2019 GTi S 6 Speed
Today my friend brought over his 2017 Dsg Gti with a stage 2 tune from sneeky and the car runs great we installed new motor mounts from bfi and it’s super smooth, but I wanna get to a point the car has never ran strong with his is38 stage 2 setup the car was apr stage 2+ is38 when he bought the car and the tune was weak he went sneeky and it was still weak but much better. I found out the wastegate was only 3.1 volts and had it adjusted and adapted to 3.65 now and the car still doesn’t make the correct amount of boost it’s about 5 psi down.
Here’s my suspect for the code
* Bad DV? Does the latest DV revisions go bad on the mk7?
*faulty map sensor on boost pipe. maybe?
*boost leaks? I’ve checked everything I cannot find any leaks and the car is quiet when mashing the pedal at 100% no weird noises.
*bad turbo? But i would hear a dentist drill noise or something funky and the turbo sounds fine at start up or when you at 100% throttle.
Here’s my link to 2 logs on 2 different maps Datazap
Hopefully this log helps
https://datazap.me/u/andrew149/5150-and-sneeky-log?log=0&data=8-15
Engine Performance mods
-is38
-3” Dp
-ecs fmic
-ie intake with ie inlet
-cts exhaust
-tmd
And here’s a pic of the motor while we were putting in the bfi motor mounts
-is38
-3” Dp
-ecs fmic
-cts exhaust
-tmd
