VW_8v
- North east ohio
Had the same issue, and code. Tried soaking with pb blaster over the course of a few days. No luck. Got the car back to stock and dealer replaced turbo under warranty
So you would be fairly certain it's just the actuator, and I can probably just drive it to another shop and have them replace the actuator itself?They won’t mess with replacing the actuator even though the rest of the turbo is fine. Find an independent garage to replace it
yes. but first try lubing the flaper arm
I suggest you read through this entire thread in detail. I've described my findings in fine detail a few pages back and in addition a few things you can try on your own to see what the issue is (seized linkage joint or broken actuator). Try this first when you get your car back. If the actuator arm is hard to move back and forth by hand then give it some penetrating oil over a few nights to get rid of the corrosion. Then I'd do the nickel antiseize paste as per Diggs suggestion.So you would be fairly certain it's just the actuator, and I can probably just drive it to another shop and have them replace the actuator itself?
yes. but first try lubing the flapper arm
Nickel based hot bolt paste. work it in real good right at the joint
Just better power delivery for the smaller upgrades vs Is38? Is that why you would suggest that instead? Trying to do something with what shops around me are offering since I won't be doing it on my own. Seems most offer Unitronic but I can look around more and see if others offer what you mean. I know I can get TPC easily here, but would a place that set me up with that and Access Port setup instead which seems less common here. The tune wouldn't work properly without IC? I had one person tell me that where I am it isn't totally necessary since it is cold here a lot of the year and if I'm not really running it hard all the time. It is still a DD for me, if that makes any difference.Might as well get a vortex or garret or tpc other small sized upgrade vs is38. unitronic is very meh. get a cobb ap and get a custom tune for it. dp and ic are necessary
