Over boost after gear shift spike to 2.6Bar...
kakluote
beijing
Audi TT K04
Over boost after gear shift spike to 2.6Bar, shift at 6800 RPM ,and fall back to 5000RPM after shift
Gear 3rd to 4th spike to 2.5Bar
Gear 4th to 5th spike to 2.6bar
No overboost on single gear pull, such as gear 4 2000 to 7000RPM
any advice will be much appreciated.....
aaronc7
17 S3
I assume diverter valve issue would still rear its head when you let off during a single gear pull scenario. Crazy high boost and/or compressor surge.
Got a datalog? Both shifting thru the gears vs single gear scenario.
Wrath And Tears
Azusa, CA
17 Sport, 99 E36
DV doesnt open on gear shift. Turbine wastegate does.
What tune do you have?
DV definitely opens on gear shift, well when you let off the accelerator anyway. VW uses the DV for boost control quite often with the electronic DV's. I guess with a no lift shift tune it could be controlled strictly with the wastegate if that is how a tuner chooses to do it. I know my DSG will open the DV between shifts when floored occasionally.
kakluote
beijing
Audi TT K04
revo stage 3 is38 etr
通过我的 CLT-TL00 上的 Tapatalk发言
kakluote
beijing
Audi TT K04
i use turbosmart DV....
littco
London
On a manual it will open . On Dsg the timing just get pulled, throttle stays open and wastegate opens as well.
Almost guarantee this is a mapping issue. Torque maps not correct
kakluote
beijing
Audi TT K04
if I try to make fall back to 5500+RPM, it spikes to 2.2bar then drop back to 1.9 to 2.0bar at 6000.
otherwise if RPM fall back to 5000RPM after gear switch ,I will see 2.5 to 2.6bar spike depending on gears...
how can I get it resolve?
Mk7Will
Temecula
So is this off a stand alone boost gauge or data log? Hopefully you're not reading the boost pressure from the infotainment
kakluote
beijing
Audi TT K04
from boost gauge
In data log it showing reach the map sensor limit 3001mbar
Mk7Will
Temecula
Are you reading ambient pressure as well as your positive boost pressure? If you are reading data from say VCDS or equivalent from the ECM your true boost pressure is your ambient minus your actual boost pressure. So if you are hitting 2.6 bar, you may only be hitting 1.6 bar depending on your conditions. If you a have a photo of your log, it might help to determine what your issue is
kakluote
beijing
Audi TT K04
here is the logs, 2.999bar is the reading limit of OEM 3bar MAP sensor
actually it is 2.6bar reading from the gauge (3.6bar include ambient )
strange that i didn't see WG was opening after shifting
