averyislost
- Charlotte, NC
- 2020 GTI S
Got the osrams installed Saturday morning, took about 3 hours working by myself. I swear I spend 30-45 minutes just figuring out how to remove the grill. Still working on getting the aiming dialed in just right.
I do have a question. When installing, did any of you mess with this large height adjustment bolt? My OEM one was in a similar position. My new ones, however, were much more unscrewed than that. The threaded part was flush with the bottom of the plastic tab, not protruding at all. To get the correct height between the bumper support and the bottom of the housing, I had to screw in that bolt around 2.5 turns. I'm wondering if I didn't turn it enough because I had to make a huge adjustment to the aiming screw to get them close to factory. I probably made 6 full turns of the vertical screw. I was worried I was going to reach a stop somewhere, or the gear was going to pop off inside.
I didn't touch that height adjustment bolt. If it is mainly used for fitment of the lights with the bumper, mine actually had better fitment than stock. I don't remember having to make too many adjustments to the height, but I did have to raise both light patterns up a bit. I also had to do a little tweaking of the side/side pattern. If I remember, I brought both sides inwards a bit as well
