osram headlights delaminating?
LVE2DRV
NYC
Do any of you guys run osrams on LP cars? if so, has anyone been able to figure out how to disable AFS on dash? I have the LP version of osrams and annoyed with the dash error
ZERO815
Köln Germany
2017 GTI SE DSG
I run Osrams on my NA LP GTI since 2019 w/o a faulty AFS.
The Xenon-Osram- variant is made for the low VW Xenon headlight variant, while NA cars got the mid VW Xenon headlight variant. Mid variants control the auto leveling and corner swiveling via CANbus, while low variants control auto leveling via 4 wires between AFS control module and each headlight.
After downgrading to the low AFS module, adding of some extra wiring between each headlight and the AFS module, minor coding changes, my headlights show no faults. Auto leveling works fine too.
LVE2DRV
NYC
how is your auto leveling working? Osrams do no have auto leveling in their lighting housing? Are you running the Osrams with 10 or 14 pin connectors?
I actually came across some European company that supposedly claims they have an adapter that goes in between the OEM wires and the Osrams and supposedly eliminates AFS. Only issue is I am not familiar now that you mention which specific variant of AFS the module tricks. The are from Germany so not sure if they may have a language barrier of understanding what I asked them specifically.
If you are there and speak German and know what it is ANY chance I can bribe you to speak with them?
ZERO815
Köln Germany
2017 GTI SE DSG
The 14-pin Osram Xenon variant does have auto leveling, but no cornering lights. So the headlight range is adjusted automatically depending on load or throttle. Here is how wired it:
According to the website of the German adapter company it works for mid and high OEM Xenon headlight cars.
  • "Plug & Play solution for your Golf 7 pre-facelift with factory fitted AFS (cornering lights) LED daytime running lights for conversion to OSRAM LEDriving Xenon headlights
  • also for DLA headlights (masked high beam)"
LVE2DRV
NYC
You are familiar with the company I was talking about?
here is their info
https://electronicworks.de/en/produkt/mk7-headlight-controlling-adapter-golf-7/
Do you think that it would work on US based cars?
I saw the above write up before I got my osrams, however only thing that's preventing me going that route is the added cost and also if I ever want to return things back to stock, it'll be a hassle to undo everything and redo wiring. Hence I have been looking for an alternative.
ZERO815
Köln Germany
2017 GTI SE DSG
I don’t know the company. In one German forum one guy reported about his successful retrofit w/ the adapter. However it sounded like he was paid for it. Guess what, he received quite a bit BS responses and was never seen again. I can’t speak for the product.
In 2019 I had to provide a VIN number of a car that came w/ low Xenons from the factory to be able to order a set of Osrams! Came up w/ the downgrade idea. Actually added a self made adapter at the headlights, the additional 8 wires go through a grommet at the fire wall. The low AFS module is „velcroed“ to the factory AFS module. If I ever feel like I have to remove the Osrams all it takes is cut the added wires at the fire wall, pull both ends out, remove the AFS module.
LVE2DRV
NYC
damn. I was hoping this would have been the trick. Tempted to get it but with shipping and tax would be a costly mistake especially if it a total failure.
May have to go through your route to get it to work correctly. Just was hoping not to run the extra wires. Are those modules expensive? Any chance I can PM you for additional support?
ZERO815
Köln Germany
2017 GTI SE DSG
I got the AFS module used from ebay.de for cheap. You can send me a PM if you like.
Have you tried to just unplug the AFS module under the dash? If you don't need (I needed it for TÜV inspection in Germany) auto leveling it might be the cheapest solution.
Pineapple
Boston, MA
2017 Golf GTI S
Just got mine installed. I'm going to be out of warranty after the ~2 yrs it seems to take for these to start peeling. Would some sort of coating be able to ward off this fate?
RIP TDI
Santa Barbara, CA
'15 Golf TDI SW 6M
I put 14 mil PPF on mine when new 4 1/2 years ago. Zero lens delamination since, but the car spends very little time in the sun...
woodardhsd
NC
2019 GTI Rabbit CFB
Well I’ll be damned osram came through and delivered a new set of headlights to me under warranty … received today. It’s been a journey. Just wanted to give credit where it’s due. Specifically their instagram team which reached out to their email department for me to get the ball rolling, even after emailing the address someone posted above. Great company.
Glad to hear things worked out. Both of my 23-month old Osrams are doing the same thing yours were. On the driver's headlight, the peeling is actually on the lens rather than just the top.
Did you message them in instagram, or comment on a post of theirs?
Cuzoe
Both of mine are preling a little bit at the top. Car spends at least 5 days a week out in the sun at the airport for 10 hours a day. And I did nothing to protect them, lol.
Also well over 2 years old at this point feeling gets bad enough there's a non-zero chance I buy another set and although I would protect them this time. Or I use it as an excuse to go DLA headlights. Probably determined by whether enough time has passed for DLA parts to come down in price before going way back up in price because parts are hard to get.
aegis
Ontario
MK7 GTI
Thanks for confirming, good to know for those who may run into this in the future.
krvnked
NJ, USA
MK8 GTI
I emailed first, didn't really get an acknowledgment except an automated response, then I contacted them directly on instagram who then contacted someone in the correct department for me.
