In for a discord invite and the fb group too. Just made the jump from eurodyne with Railroader tuning for me. Can't wait for next spring!
Thanks
Do you currently use discord? What's your username?
Thanks
TherealvrtDo you currently use discord? What's your username?
There should be 4 digits after your name, those are needed to add someone on discord. For example my discord username is "Bad Hombre#4813"Therealvrt
Android device with 9.0 or higher as your interface
SimosTools app off the google play store (for flashing and logging)
dongle (plugs into obd2, interfaces with app for flashing and logging and realtime gauges)
tunerpro for tuning
You can flash with vw_flash as well but SimosTools is a much slicker experience. Realtime gauges, DTC checking/clearing, log viewing, etc... none of which vw flash has. I think you can even set your wastegate actuator now as well.
https://www.golfmk7.com/forums/inde...e-tuning-solution.380998/page-18#post-7885021
Switchleg makes and sells dongles.
Flashing over GIAC is probably doable??? Not sure anyone has done that yet. Not all companies use the same process.
You would then have to completely redo your tune from scratch and enable/tune for flex.
Unless you have a dongle or flashing device from GIAC you would have to wipe and start over, no way to legitimately store off another tune. That being said I am sure the community can help you out. I was hesitant to go from UM on my wagon at the time but made the switch, and then I got help in flashing back to stock when I sold the wagon and got an S3, and then help with the tune on the S3.
ok so i should plan to do a full retune myself then?Can't backup existing tunes.
Enabling flex isn't difficult. Actually tuning for it takes effort.
perfect thanks
