Diggs24
- de plains! de plains!
- 2015 GTI
I need to find this SIMOS guy. Sounds like a real baller.
I used Crossover windows emulator in my M2. It worked… fine. Not perfect and had weird issues when resizing windows, but got the job done. A true Windows experience like Parallels would probably work better.Anyone running tunerpro in a VM on a M-series Macbook? or should I buy a cheap windows 7 laptop..
eBay has lots of barely-OOW Dell Latitudes for cheap, most of which can easily be coaxed into running Windows 11. OR, you can use ECUleg and tune from an Android device, which would enable you to use the same device for flashing that you're already using for tuning. With that said, I've gotta shill MegaLogViewer for viewing lots of data at once, Datazap is great for sharing but MLV makes it easier to view large swaths of things at the same time.Anyone running tunerpro in a VM on a M-series Macbook? or should I buy a cheap windows 7 laptop..
ECUleg is a great option because you need and Android device to flash and log via Simos Tools anyways. Get an Android tablet and let that be your dedicated tuning thingy.eBay has lots of barely-OOW Dell Latitudes for cheap, most of which can easily be coaxed into running Windows 11. OR, you can use ECUleg and tune from an Android device, which would enable you to use the same device for flashing that you're already using for tuning. With that said, I've gotta shill MegaLogViewer for viewing lots of data at once, Datazap is great for sharing but MLV makes it easier to view large swaths of things at the same time.
also beneficial because it's much easier to migrate Android devices IMO than it is to get new Windows devices, particularly tablets that don't suck. I've seen a large number of USB-C ports wear out on laptops where they're used for docking stations/charging, and it's a bummer because generally speaking that means replacing the motherboard. On an Android phone you're able to do just about everything wirelessly, so it's a much more stout device, and if using OneDrive/Google Drive/Dropbox/etc to back up files and a Google account to back up your local phone settings/profile stuff, it's not hard to migrate hardware without too much issue.ECUleg is a great option because you need and Android device to flash and log via Simos Tools anyways. Get an Android tablet and let that be your dedicated tuning thingy.
I joined this forum for this thread. Firstly, thank you to everyone who has contributed to making this what it is! I decided I would read all (at the time of this writing) 36 pages before posting or asking anything. I found this thread after I decided that I was fed up with my current tune and setup. I started hunting for the ability to self-tune ( I have no tuning experience). I found a YouTube video of Joe doing a flash with the VW_Flash. That led me on a larger hunt, and this thread kept coming up. I've already applied and was accepted today to the FB group (haven't posted there yet). I plan to learn from there before asking about the Discord group.Don't just ask for invites. A better idea would be to tell me/us:
1. What your current setup is (hardware, tune, etc)
2. What your prior tuning experience is
3. What your technical background is
4. What your goals are
This really is a red pill or blue pill situation. You take the red pill, you'll lose your current tune if you have one and you'll retune your car from scratch. You'll need to learn a lot of new stuff. You may never live in peace again because you'll always have the ability to tweak. You'll see the world of tuning differently and you won't sleep as easy at night. The red pill isn't for everyone.
I'm still learning is that off of simostools or that's a patch to the ECUYou can do different tunes with mapswitching.
That is thanks to Switchleg's work building the patch 'SwitchPatch', which enables a much better traction control system, launch control, map switching, and some other stuff I don't fully understand. But for what you're after, yes on-the-fly map switching is easily available, meaning you can drive down the road on a more economical tune and then see something fun, hop over to your aggressive map, and then go dominate the skreetz. All without ever having to stop driving.I'm still learning is that off of simostools or that's a patch to the ECU
