PhlRmrz
- Fort Worth, TX
So this is appears to most likely be an oil pan leak? It looks like it's kind of creeping up where the RMS is? Also I see posts about plastic vs metal pans and sealant vs gaskets, I was seeing that there is a plastic pan on Amazon with a gasket if anyone had any experience with it. I just recently replaced the upper timing cover because it was leaking and when I went under the car to clean up the oil I found this mess, I pump my oil from the top hence why the leak went unnoticed for so long. Thanks
