- Phoenix
- 2018 SE DSG
I thought you said CC with stock pcv don't catch anything? So if there nothing to catch until you remove the stock pcv, then you're the one creating the problem than you spunken cc solves.
AGAIN, unless you track, you don't need a CC.
Read the link . If you get a catch can that doesn't REPLACE the OEM PCV valve the OEM PCV valve will continue to function as it does with nothing being diverted to the catch can. The Spulen OCC sends the liquid to the can and the vapor back through the intake.
