Jose_Gti
- Philadelphia
I had that problem with my 2015 GTI I replaced the O-ring, latest cap, eventually I could see the leaking happening again so I let it be.
Just FYI, I had to use 2 o-rings to get it to stop leakingSo i replaced the cap with the new yellow one. That didn't help. Still got leakage and quite a bit. So just put on the O ring. Seems tighter, so hopefully that'll do it.
Good to know. Luckily i ordered 2. If it doesn't work, I'll add the 2nd one.Just FYI, I had to use 2 o-rings to get it to stop leaking
I bought an extra gasket with this in mind, glad to know there might be a valid reason to me potentially wasting $5, lolJust FYI, I had to use 2 o-rings to get it to stop leaking
this is why I always wear 2 condomsJust FYI, I had to use 2 o-rings to get it to stop leaking
Or is it that our are you trying to make up for lack in girth?this is why I always wear 2 condoms
Everything counts.Or is it that our are you trying to make up for lack in girth?
I'll let you know on the next oil change, haha.Great find! How does rubber handle?
Did an oil change and no leaks so far!Great find! How does rubber handle?
