Official Reflex Silver Metallic GTI / Golf Thread
uberdot
2017 S 6MT
I really like em! I think the smoked isn’t too popular but they’re all plug and play. The harness allows the blinker to be animated instead of binary. They’re obviously not OEM build quality but they seem sturdy so far. If they leak in my climate or let creepy crawlies in that’s the test.
tpa_mk7
Tampa, FL
Hi there
What spoiler do you have?
uberdot
2017 S 6MT
I’ve read those are a bitch to get on and usually destroy some plastic in the process
Chet Ubetcha
SoCal
2016 GTI
Personally I don't like the idea of using a heat gun to "unglue" the black trim on the sides of the rear glass in order to get the extension installed. Seems overkill.
I'm actually planning on fabricating my own soon. If it turns out well maybe I'll sell em on ebay or something lol.
uberdot
2017 S 6MT
I’ll buy one. If you get yours painted reflex silver I’ll pay for the cost while yours gets done. 😁
Chet Ubetcha
SoCal
2016 GTI
Hmm might be worth finding out if others are interested as well! We'll see how mine turns out. I was between using a gloss black plastic similar to Aerofabb or aluminum ready for paint match or maybe powder coat black.
uberdot
2017 S 6MT
I hated the aerofabb diy vids I’ve seen.
It's Sam
New York (The cool part)
2017 GTI SE
Honestly it looks much more intimidating than it actually is. As long as you're gentle you won't have an issue installing it. The instructions they provide are pretty idiot-proof.
I was also a little hesitant about the glue on the fins, but that's not bad either with the right tools and patience. I've used heat to release glue in other applications before this and like anything else it just needs patience. Once you get it soft enough it's butter. VW is a bit overkill on the glue too so when you put the trunk spoiler back on you can sort of re-stick them. Gaps on mine after install were no bigger than before I installed it.
+1 to see your custom one though. Paint matched could be interesting.
Chet Ubetcha
SoCal
2016 GTI
@uberdot @It's Sam
Here are some pics of what I've got so far. These are bare finish aluminum, plan to either paint match or powder coat. Luckily with the color of the car it almost looks paint matched already so it's easy to get the idea.
I have holes in the outside corners for bolting up to the stock wing. However the stock wing will not need to be removed in order to bolt it up. I plan on using rubber rivet nuts that install from the outside and squeeze on the inside when a bolt is threaded into it. This will both cushion the stock wing from the extension, and provide solid mounting.
Let me know what you think!
Both styles, nicknamed V1 and V2
V1 mounted pics
V2 mounted pics
It's Sam
2017 GTI SE
Man, the amount of envy I have for you guys with fabrication setups 😄
V2 looks awesome, and I like how you left the V1 with less of a rounded look, so it sort of matches the roofline more. I love my aerofabb but the one tiny thing that wakes up my anal retentiveness is the way it curves at the sides. The more square look makes it look larger and more like an actual ducktail. And it's aluminum so no more scratches!
I'm curious to see how the powder-coating goes. Paint matched would look cool but something looks off to me about the silver on the rear side against the trunk (though that's personal preference).
Kudos to you, both look sweet!
Chet Ubetcha
SoCal
2016 GTI
Thanks a ton! I should probably move to posting in the cosmetic mod section. If I can gather enough interest for a short run of parts I can probably see about sending some finished parts out for some R&D 🤔
EpicTech
Houston
I'd probably buy one of those.
