Stage2Sasquatch
- Walled Lake Michigan
Hey guys,
I've been pretty hesitate to post this, but like with the MK6 guys, people will find out sooner or later. This will be a thread dedicated to the part list for the DIY TTRS Clutch Kit. For those of you who don't know (and I'll use the word "similar" loosely) the kits from RSR and Haus of Dub are very very "similar" to this one. They are all based of TTRS pressure plate. So again I don't want to spell it out, but I'll just say this kit will be very "similar" to the RSR + Haus of Dub kits.
Here's the part list of what you will need:
1. Part #1878005146 or #03G141031T (1) $99
http://www.eeuroparts.com/Parts/73466/Clutch-Disc-240mm-1878005146/
2. Part #07K141015BX (1) $355.35
https://deutscheautoparts.com/audi-ttrs-clutch-pressure-plate-07k141015bx.html
3. Part #N90847002 (3) 3x.99= $2.98
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/hex-bolt-priced-each/n90847002/
4. Part #N90320701 (6) 6x.74= $2.22
http://www.eeuroparts.com/Parts/56339/Clutch-Pressure-Plate-Bolt-N90320701/
5. (Optional Throw-out Bearing) Part #0A5141671 (1) $75.99
https://www.fcpeuro.com/products/vw-audi-clutch-release-bearing-0a5141671
Total Without TOB: 459.55
Total With TOB: $535.54
Now keep in mind a couple things:
-You will need to enlarge a hole to fit the metal aligning dowels. You can do this many ways, and it's not a huge deal to be perfectly precise.
-These were reported by a MK7 Golf R user and but it has been confirmed to work on a GTI. That being said it's the same transmission, and the same engine etc so there's no reason it shouldn't work.
-There is still value to getting the real RSR and Haus of Dub kit. If something goes wrong generally you will have the full company support, which can be worth it to some.
-This is the same as the DIY RSR kit on the MK6 except I put in the MK7 hardware.
-The hardware parts were reported by a user on the MK7 Facebook group but I have looked it over and things check out.
*EDIT* I've gotten a lot of question as to why there's two clutch disks. This is because the one that comes with the pressure plate has the wrong spline count. Therefore you cannot use it. Unfortunately, they only sell the pressure plate along with that flywheel, hence why you have to buy another clutch disk that fits.
Here is a full DIY of this kit, isntalled: Courtesy of DAP
https://shopdap.com/blog/post/how-to-install-a-ttrs-clutch-on-a-mk7.html
Enjoy!
Enjoy!
