Kushdaiin
- Connecticut
- MK7 R, MK7 GSW SEL
I got one too. If it works I’ll need to get another one.
Had this same thought as well; center of the device would be where you’d see the most benefit. Maybe it helps if it keeps air moving around/within the cubby ambiently as well? As others have pointed out, could also function in reverse to draw warm air out of the cubby.I wonder what the efficacy of that vent would be given its positioning if it is indeed for cooling the device – is there much cooling if the vent is not under the centre of the device with the coils?
Its probably taking air from the cubby and exhausting it out, The area under the cubby is pretty warm most of the time so that seems like a bad place to draw air from.Had this same thought as well; center of the device would be where you’d see the most benefit. Maybe it helps if it keeps air moving around/within the cubby ambiently as well? As others have pointed out, could also function in reverse to draw warm air out of the cubby.
Also a valid line of thinking. Efficacy still remains a question for me... is the issue that the ambient temperature around the device is too hot or that the device itself is getting hot and retaining the heat?Its probably taking air from the cubby and exhausting it out, The area under the cubby is pretty warm most of the time so that seems like a bad place to draw air from.
I think our only problem is how to customize the rubber mat so it works well with the cooling system.Also a valid line of thinking. Efficacy still remains a question for me... is the issue that the ambient temperature around the device is too hot or that the device itself is getting hot and retaining the heat?
I guess there's no point continuing to speculate since so many are going to try it and find out soon enough . Fingers crossed that whatever the fan and vent are doing makes a difference.
Same thing, canceled the order.
Was going to message these guys today; looks like they’re the only ones with it still listed for sale: https://www.aliexpress.com/item/1005005846979885.htmlAnyone ask one of the other sellers if they have stock? I suppose the one seller said that there is no stock in China but curious if that is true.
I also found this seller: YZ autoWas going to message these guys today; looks like they’re the only ones with it still listed for sale: https://www.aliexpress.com/item/1005005846979885.html
Uh oh, haven't got a message from them for my order (yet). Hopefully they don't waste their money sending me the old version .Bad news gents :/
