@Kushdaiin, Nice to see you experimenting ?. When keeping problems, consider to increase the thickness of your inlay even more. You might consider my last design also in post #256. There the air actually flows against the back of the phone.
Yesterday I tried the original 5NA charger for comparison. Just because I would like to retrofit the external antenna. And at first I was actually pretty optimistic, because my phone charged 2 percent in about 15 minutes, with AA etc. I could actually live with this number, as long as it could keep up, and not draining the battery. Yes, it doesn't charge as fast as the 5CG, but at this point I couldn't say that the 5CG is 3 times faster also.
But in the evening I drove a little further, after about an hour, I took the phone out of the cubby, and it was insanely hot. You could actually see that the phone was throttling because probably the phone clocked down CPU speed etc. Also I noticed sometimes during the trip that the QI logo was greyed out, but the phone wasn't fully charged at all. Probably also the phone interrupted charging because overheating. This caused that the phone barely could keep up charging (+2%) after a one hour drive, I can imagine that longer drives possible drain the battery, because of overheating. Also, it can't be good for your phone when it is hot like that.
So today I'm going to reinstall my 5CG and keep it that way. For the moment for me it's the best solution. For my opinion it is even more reliable than the 5NA, where I sometimes just slightly needed to reposition the phone before it started charging, where I don't have that at all with the 5CG.
